SVS PB2-Plus (Subwoofers) | 1 | (7) | Inga priser | |
SVS PB10-ISD (Subwoofers) | 1 | (12) | Inga priser | |
SVS 16-46 PC-Plus (Subwoofers) | 0 | (4) | Inga priser | |
SVS PC-Ultra (Subwoofers) | 1 | (4) | Inga priser | |
SVS 16-46 CS (Subwoofers) | 1 | (0) | Inga priser | |
SVS 20-39 PC-Plus (Subwoofers) | 1 | (11) | Inga priser | |
SVS SB12-Plus (Subwoofers) | 1 | (6) | Inga priser | |
SVS PB12-NSD (Subwoofers) | 3 | (7) | Inga priser | |
SVS PB13-Ultra (Subwoofers) | 4 | (13) | Inga priser | |
SVS PC12-Plus (Subwoofers) | 1 | (5) | Inga priser | |
SVS PC12-NSD (Subwoofers) | 3 | (12) | Inga priser | |
SVS PC13-Ultra (Subwoofers) | 6 | (6) | Inga priser | |
SVS SB12-NSD (Subwoofers) | 4 | (9) | Inga priser | |
SVS PB12-Plus (Subwoofers) | 6 | (12) | Inga priser | |
SVS SB13-Ultra (Subwoofers) | 6 | (7) | Inga priser | |
SVS PB-1000 (Subwoofers) | 1 | (6) | Inga priser | |
SVS SB-1000 (Subwoofers) | 7 | (6) | Inga priser | |
SVS PB13-Ultra DSP (Subwoofers) | 6 | (5) | Inga priser |
Postad 01 oktober 2012 - 17:52
Ingen som har hört något om sb ultran?? Kommer den till Sverige?
Jag undrar detsamma, skulle gärna vilja se lite tester osv oxå.
Postad 01 oktober 2012 - 18:22
Postad 02 oktober 2012 - 06:54
Stod själv ivalet och kvalet mellan SB13 eller en PC13, men med tanke på hur mitt huse kommer se ut så fick det bli en PC13 efter inrådan av L-sound.
Väntar spänt att få prova den i timmerstugan tillsvidare
Han kommenterade jämföreslsen så här.
I suggest the SB13-Ultra if you want as much compact subwoofer you can get, but still have the power and qualities. Since size does matter the PC12-Plus and PC13-Ultra will have far more output below 30Hz which will make a difference on movies, but they are also much much larger. If you want a powerful compact subwoofer, go for the SB13-Ultra - if you want the extreme deep bass (but still SB13-Ultra is very strong down to 20Hz!) for your favorite movies, then you can look at the PC12-Plus and PC13-Ultra.
Size wise the PC13-Ultra is only larger than the PC12-Plus as they have the same diameter. You can see the dimensions under "Additional information" on the product page and you can add these to the comparison. PC12-Plus shares alot with the PC13-Ultra in terms of sound quality but since the PC13-Ultra have a larger driver, more amp power and larger enclosure the PC13-Ultra has about 60-70% more output. So it comes down to how much you want to invest in a subwoofer, how big it can be and how loud you can play. You can obviously play very loud with the PC12-Plus as well!
When you have a subwoofer like the PC13-Ultra for example, which is of a very good quality, I would prefer a large vented subwoofer than a small compact and sealed in a large room. This is because the room does not affect the frequency response that much like you get in a small room where you may get too much deep bass due to room gain below 30Hz.
If you want the deep and powerful bass from SVS, and since you have an open solution which results in big volumes to fill, I would suggest the PC13-Ultra. Can you go for the size, go for it!
Postad 02 oktober 2012 - 12:00
Tanken är ju att komplettera med en ytterligare och det var helt omöjligt att få i plats med 2xPB13 tyvärr, Bagarns element ger ännu mer ha begär ~som man som 18 åring för första gågen såg JBl GTI element , tråkigt att den sämre ½ inte förstår värdet av en stor fin basslåda(lr 2 tom)
Kommer nog komplettera mina Canton Ergo RC-A med lite mer punch i botten, dom har för klent steg för att spraka igång nån jätte orkan även om de går ner till 18Hz.
Redigerat av STI-RA, 02 oktober 2012 - 16:32.
Postad 02 oktober 2012 - 19:46
Enligt mig är fyra SB13U snyggare och mer estetiskt tilltalande än en PB13U
Postad 02 oktober 2012 - 20:24
... behövs bara fler. fleeer!!
Postad 02 oktober 2012 - 20:53
När strandskyddsdispansen gått igenom får man väl fila på en bio bakom garaget
Gillar ju att leka me bilar ännu...men ljud är f-n billigt i jämförelse.
Tog en stund bara att inse att en sub för 15k är små pengar, i jämförelse vad jag handlat till subban i garaget
Ville ju ha dedikerat hembio rum nu när man bygger nytt, men fick ju kompromissa tyvärr
F-n nu är det bara att vänta några veckor...innan den dyker up gissar jag på..Schenker suger när det gäller frakt..
Postad 02 oktober 2012 - 22:02
Tänk på att LFE ligger 10dB högre redan vid kalibrering..
Det kan behövas 110-115dB bas redan vid referensnivå helt kalibrerat..
Det är ganska mycket bas...
Man kan ALDRIG få för mycket bas.
Postad 02 oktober 2012 - 22:08
Folk förstår inte hur mycket bas som behövs för att matcha ett normalt 5 eller 7-kanalssystem vid referensnivå med lite headroom...
Näe, folk förstår nog inte som du säger
En sak i ett vardagsrum och lyssna på 70dB...
Satte min PB13-Ultra på 16Hz tune idag och mätte lite och kalibrerade in den fint. Bottnade hyffsat snabbt i Kung Fu Panda i slutscenen när han knäpper med fingret. I Project X så tog jag mig till referensvolym innan den sa ifrån igen.
Då mäter den dock spikrakt ned till ~11Hz innan den faller FORT.
Så för min del så blir det 20Hz tune för att jag inte ska bottna den, får mycket mer headroom då och det ska mycket mer till för att den ska bottna. Då mäter den rakt ned till ~14Hz innan den faller spikrakt ned.
Skulle gärna haft minst en till framöver.
Redigerat av Jonas__W, 02 oktober 2012 - 22:08.
Postad 04 oktober 2012 - 21:21
Tack!
Postad 06 oktober 2012 - 15:30
Postad 06 oktober 2012 - 15:42
Kostar den 13tkr så kan det mycket väl bli 2-4st för min del
Redigerat av Anton, 06 oktober 2012 - 15:44.
Postad 06 oktober 2012 - 16:33
SB12:an kan du ju gå på annars... liten, snygg, och frambringar riktigt bra bas, speciellt i ett litet rum på 22kvm.
Jo, suttit och läst om den ett par timmar. Sitter nu och är på väg att beställa en från Lsound, det tar 6000 inkl frakt.
Redigerat av Zerox_no1, 06 oktober 2012 - 17:14.
Postad 06 oktober 2012 - 17:42
"Later we will have some completely new subwoofers from SVS at a never before seen price range from this brand. But this is for another News Bulletin."
http://www.lsound.eu/news/relaunch/
Postad 06 mars 2013 - 08:07
Har själv en SVS PC12-Plus.
Har en fråga angående y-split av subkabeln.
I manualen står det att basen (SVS-subbar) skall ha en enkel kabel. Dock hade jag själv tidigare y-linkkabel. Enligt vad man hört tidigare är det ju bara positivt att köra med det för att öka ingångssignalen till en aktiv subwoofer.
Vad har ni andra?
Single eller Y-link?
tacksam för snabba svar, funderar på att byta kabeln som jag köpte igår.... det var endast en single supra...
109350.jpg 3,09K 2 Antal nerladdningar
Postad 06 mars 2013 - 08:16
Du ökar ju bara insignalen som du säger.
Postad 06 mars 2013 - 10:07
Känns ändå som att det skulle bli något bättre med Y-link men då litar jag på ditt ord.
Postad 06 mars 2013 - 19:33
lite sugen på denna som är prisvärd och går djupt med tanke på priset och storleken på elementet.
Redigerat av jonas_79, 06 mars 2013 - 19:34.
Postad 09 mars 2013 - 22:52
Funderar då främst om ni hört några rykten då någon direkt info säkert inte är offentliggjord.
Postad 11 mars 2013 - 11:38
Någon som använt Parametric Equalizer (PEQ) på sin PC12-Plus? Jag har mätt upp rummet, som några av er sett i denna och någon annan tråd. har några mindre noder som jag skulle vilja justera.
När man använder PEQ skall man ju kunna välja följande enligt bruksanvisningen:
The PEQ has three controls: Frequency, Bandwidth, and Level.
jag kan välja bandwithh och Level. Men när man kommer till Freqvensy och klickar "händer inget". Jag kan alltså inte välja vid vilka Hz som det skall förstärlas sller försvagas. Mycket frustrerande.
Någon som vet om det är min bas det är fel på? den köptes som ett demoex från Hembiobutiken.
Postad 11 mars 2013 - 21:41
Återkommer med reflektioner om det finns intresse av dessa lite mindre svskuber...
Postad 11 mars 2013 - 23:03
Pb1000 på onsdag förhoppningsvis.. Får tyvärr inte in större sub i vårt vardagsrum:(
Varit sugen på denna ett tag så vill gärna höra hur du uppfattar denna.
Postad 12 mars 2013 - 07:24
Frugan?
Postad 12 mars 2013 - 10:35
Jag är också intresserad, har med den vita modellen, som kommer om 4-5 veckor, på min "kandidatlista".Pb1000 på onsdag förhoppningsvis.. Får tyvärr inte in större sub i vårt vardagsrum:(
Postad 12 mars 2013 - 16:46
Vad ligger frakten på denna hem och ungefär totalkostnad ??
Postad 12 mars 2013 - 16:59
Kan det vara ett vettigt val?
Hade en rel t3 som lät kanon men som var för klen.
Säljs sb-modellerna i Sverige?
Postad 12 mars 2013 - 23:28
Ca 5000 kr levererad till dörren. Mitt rum ca 25 kvm halvöppen planlösning...inte det optimala men men... Har haft xtz både 10.16 o 12.16, sunfire hrs 8, subben som medföljer hkts 60.. Så det är dessa subbar i min miljö jag kan jämföra med...kanske ändå ett o annat värt tips men som sagt återkommer, synd jag inte visste att den kom i vitt lr det kanske bara var sb1000?
Postad 12 mars 2013 - 23:42
Ja, fel av mig där. Det är bara SB-1000 som kommer i vitt. Så du kan vara nöjd ändåFrun...absolut, kanske tur det;)
Postad 14 mars 2013 - 13:37
Postad 14 mars 2013 - 14:06
Jag kan rekommendera denna scenen, jag får i alla fall riktigt bra tryck där!Har nu testat lite film bland annat transformers 3 samt spelat lite infamous 2;)...första intrycket är att den flyttar mer luft alltså mer ljudtryck än mina tidigare subbar i mitt rum. Jag har inte vågat köra fullt ut men hyggligt högt utan att den tappar orken det minsta. Har inte hunnit testa hur den agerar vid musik men återkommer. Kör som sagt hkts 60 sateliter med en h/k 365.
http://www.youtube.c...h?v=ZA8ws3sZarI
Postad 14 mars 2013 - 14:13
http://www.avsforum....requency-charts
längtar tills man kan ha en dedikerad bio o köpa ngn större svs sub!...mersmak...
Postad 14 mars 2013 - 17:29
Den sidan är sedan länge bokmärkthaha där rör det på sig;) får bli hem o testa..Här hade de ganska bra tips också!
Min favoritbasfilm (som för övrigt är en riktig skitfilm, enligt mig) är Immortals. Det är bas ungefär hela tiden
Postad 20 mars 2013 - 06:58
Postad 20 mars 2013 - 07:59
Du får svar på någon minut...
Postad 21 maj 2013 - 08:24
Kom från en DD10 som är en väldigt fin liten sub men SB13-Ultra (som såg gigantisk ut bredvid minimala DD10:an) har betydligt större dynamik resurser och jag skulle dessutom säga att den är väldigt tight och musikalisk.....är väldigt nöjd faktiskt ;-)
Postad 24 maj 2013 - 11:24
Välkommen till klubben iaf, vi är några stycken som har köpt svs 13-tummare och alla är nog rätt nöjda
Postad 06 juni 2013 - 00:03
Kan förstå om vissa saknar en mer peak:ig respons för att få mer av en kick när det smäller och den är lite knepig att placera rätt i ett rum, särskilt om rummet är relativt litet och inrett med sittmöbler, andra högtalare och filmhyllor. Det kanske inte är världens största sub, men tar helt klart betydande plats. Och för att inte få för mycket rums-gain går hörnen ju också bort.
Funkar utmärkt i filmer och pallar gott vad t.ex. Starwars Ep I-III och Sagan Om Ringen trilogin kräver. Fixar även den mesta musiken jag lyssnar till, men t.ex. DVD-A-skivan 'Rivers' med Patrick Leonard är den övermäktig (alternativ jazz på Steinway-flygel och ståbas). Detta nog för att definitionen är otillräcklig och att basen kan bli lite dominant. Men inget verktyg kan göra allt, och en sluten sub (som jag ursprungligen tänka köpa) hade nog gjort detta bättre. Eller två slutna.
Redigerat av Unregistered39377, 06 juni 2013 - 00:10.
Postad 07 juni 2013 - 00:30
Postad 09 juni 2013 - 00:31
Vilken ska jag välja?
Postad 10 juni 2013 - 11:31
Jag tror att det är en smaksak och beror lite på hur rummet ser ut. PC:n spelar ju neråt, så man behöver ett stadigt golv. Den tar samtidigt inte upp lika mycket plats på golvet. Skulle påstå att denna är den som är mer allround av de två.Har en begagnat affär på gång men jag måste välja mellan en pc-12 plus och en pb13-ultra. Pc12 kostar 5000 pb13 kostar 11000 båda med bash förstärkare.
PB:n flyttar ju mer luft, är starkare, har mer brutalt tryck. Vissa anser den okänsligt brutal, dvs. inget du lyssnar på klassisk eller annan mer finstämd musik med då den kommer dominera ljudbilden hur du än gör. Lättare att ställa in ljudet på betr. roll-off dock.
Hade det varit jag hade jag gått på PC:n, eftersom den är ett bra mellanting som gör det mesta bra utan att kanske vara bäst på något. Men vill man ha något snabbt och brutalt för typ dub-step eller mest ser actionfilmer och vill ha max impact så hade jag gått på PB:n. PB:n klarar ju högre volym och större rum också, även om jag tror båda räcker gott och väl till i de flesta sammanhang.
Postad 15 augusti 2013 - 13:36
Postad 26 augusti 2013 - 16:00
