Vilka filmer/tv-serier vill DU ska släppas på Blu-Ray?
236 svar till detta ämne
#201
Postad 20 juli 2013 - 07:04
3 166 inlägg
Då saknades det nog cirka en timma eller så. Tror inte den släppts oklippt i Sverige någon gång.
Var det våld som klipptes bort eller mest random crap för att korta ner? Farsan har serien på VHS fortfarande men det är nog 30 år sen jag såg den.
#202
Postad 21 juli 2013 - 18:29
Unregisteredb2422138
222 inlägg
Det var bara för att korta ner. Finns endast släppt (i ganska risigt skick) oklippt på DVD i Tyskland.
#203
Postad 31 juli 2013 - 14:58
Dr. Zaius
Dr. Zaius
3 568 inlägg
Pat garrett & Billy the Kid hoppas jag släpps på Blu-ray snart.
#204
Postad 01 augusti 2013 - 11:44
Transform
37 986 inlägg
TV-serien Buffy: The Vampire Slayer på Blu-ray, har jag väntat på "ett tag"...
#205
Postad 01 augusti 2013 - 15:53
sinnes
sinnes
2 237 inlägg
X-Files kommer på bluray \0/ A number of our industry sources are now telling us that Twentieth Century Fox Home Entertainment is planning (and in fact may already be gearing up to) release their classic TV series The X-Files on Blu-ray. As fans will already be aware, the first four seasons of the show were produced in 4x3 format, like many TV programs of its era. The series then went to a 16x9 widescreen format for the remainder of its run, as anamorphic widescreen displays were starting to become common. The entire show was still broadcast in standard definition – not actual high-definition – and the visual effects and post-production were finished in SD. (Note that the first actual HD broadcast on Fox was for the 2004 NFL season, while X-Files ended its run in 2002.) Our sources say Fox has likely decided to “rebuild” the seasons in high-definition, in much the same way that CBS has done with Star Trek: The Original Series and Star Trek: The Next Generation. Provided all the original camera negative has been properly stored and archived, it’ll presumably be an easier task as the show featured fewer and less elaborate visual effects.
This wouldn’t be the first time Fox has upgraded a show to Blu-ray: They did something roughly similar with Firefly on Blu-ray back in 2008, although to be fair all of the show’s visual effects were upconverted to HD rather than re-rendered in actual high-definition to save costs.
If all goes well, we’re told the first seasons of The X-Files could appear on BD sometime in late 2013. We’ll post additional updates as they come in. Stay tuned…
Källa: http://thedigitalbit...-to-blu-in-2013
Redigerat av sinnes, 01 augusti 2013 - 15:53.
#206
Postad 01 augusti 2013 - 19:54
Über-Guru
16 356 inlägg
"Our sources say Fox has likely decided to “rebuild” the seasons in high-definition" Blir ett köp.....NOT!
#207
Postad 01 augusti 2013 - 20:02
Mega-Guru
7 289 inlägg
Möjligen för £25 på Zavvi, finns ju på Netflix
#208
Postad 17 december 2013 - 17:17
Avicii
Avicii
1 167 inlägg
Fy fan, vad dåliga nyheter. Ingen samlarbox med alla säsonger på BD, med svensk text då...
Jo då. Samlarboxen kommer preliminärt 9 april 2014. Släpps av Discshop i en limiterade upplaga på 50 ex och med svensk textning på hela kompletta serien. Givet köp.
Breaking.jpg 166,01K
0 Antal nerladdningar
Redigerat av Core2, 22 december 2013 - 12:17.
#209
Postad 22 december 2013 - 11:55
Spaken_
Spaken_
157 inlägg
Vore Nice om OZ blev släppt på BD.
Känns inte så troligt dessvärre.
#210
Postad 03 januari 2014 - 20:57
3 166 inlägg
Blev sugen på att se Liftaren 1986 igen och kom då på att jag saknar den på BD Sjukt bra film, kunde varit lite mer blodig bara.
Redigerat av Lactoferrin, 03 januari 2014 - 20:58.
#211
Postad 03 januari 2014 - 21:07
3 990 inlägg
Ja, Liftaren originalet från 86 står högt på min lista också, dvd-utgåvan ser tyvärr inget vidare ut.
#212
Postad 06 januari 2014 - 00:06
Unregisteredddb310e6
2 625 inlägg
Absolut ett givet köp...om jag inte hade köpt samma utgåva från England redan. Trodde aldrig att vi skulle få den till Sverige. Synd på den svenska texten, men texten spelar inte så stor roll att jag köper den svenska bara för det :/ EDIT: Fler och fler serier kommer i bluray nu. Deadwood har ju kommit på BD också, så nu väntar jag "bara" på Vita Huset och The Wire
Redigerat av Unregisteredddb310e6, 06 januari 2014 - 00:09.
#213
Postad 12 januari 2014 - 22:24
Glidtassen
Glidtassen
4 423 inlägg
Verkar som om "Fried Green Tomatoes" kan vara på gång Filmen
#214
Postad 12 januari 2014 - 22:41
Glidtassen
Glidtassen
4 423 inlägg
Men också "Någonstans i tiden" med Christopher Reeve
#215
Postad 14 januari 2014 - 00:25
Man of Steel
Man of Steel
117 inlägg
På tal om Breaking Bad på BD med svensk text. Man behöver inte köpa den limiterade utgåvan på BD från Discshop eller CDON för att få svensk text. Det är inte bara dom 50 ex. som blev fullbokad på Discshop men nu har dom tydligen fått in fler ex. för bokning då dom har lagt upp den igen. Breaking Bad släpps på BD med svensk text som man kan boka från CDON 899:- och Dischop 995:- http://cdon.se/film/...ray%29-26395045http://www.discshop....blu_ray/P121040Så slipper ni köpa specialutgåvan för 1000kr dyrare bara för att få svensk text. Tar upp betydligt mindre plats på filmhyllan som redan börjar bli full och så slipper ni allt lull lull.
#216
Postad 10 februari 2014 - 12:17
sinnes
sinnes
2 237 inlägg
Rederiet, komplett samlingsbox på bluray.
#217
Postad 10 februari 2014 - 12:32
Jimpstyle
Jimpstyle
198 inlägg
Enemy at the gates. Den vill jag gärna ha i bluray. har sett den på vissa utlänska sidor men jag vill ha en svensk version med svensk text, vilket inte verkar finnas
http://www.imdb.com/...0/?ref_=nv_sr_1
Redigerat av Jimpstyle, 10 februari 2014 - 12:33.
#218
Postad 03 december 2014 - 14:18
Avicii
Avicii
1 167 inlägg
The Wire...skulle jag vilja ha som svenska samlingsboxar på BD.
Ibland går önskningar i uppfyllelse... The Wire: Complete Box - Säsong 1-5 (Blu-ray)Inget datum ännu, men har sett på andra forum sommaren 2015.
#219
Postad 03 december 2014 - 14:50
FEA
FEA
4 196 inlägg
Helt underbart, tack HBO! Se till att släppa Six Feet Under nu också :-)
#220
Postad 03 december 2014 - 19:30
Unregistered577c6879
2 986 inlägg
Se tråden i tv-delen. HBO hade fuckat upp denna utan Simons inblandning.
#221
Postad 21 oktober 2015 - 21:13
Unregistered2294
Unregistered2294
2 941 inlägg
Dansar med vargar. Långa versionen på Blu-ray. Sätt lite fart nu och gör denna eminenta film till verklighet även för oss som gillar kvalitét på bilden
#222
Postad 21 oktober 2015 - 21:29
2 878 inlägg
Som sagt så är det den amerikanska reg A som gäller då! Jag har även andra guldkorn typ the shining och natural born killers som finns i längre versioner på bd i USA som inte är släppta här!
#223
Postad 21 oktober 2015 - 21:35
hellfog
hellfog
393 inlägg
Ja du får skippa svensk text och köpa Amerikanska.
#224
Postad 22 oktober 2015 - 18:43
tuna74
tuna74
568 inlägg
Vad spelades Rederiet in på för medie? Video, 16 mm eller 35 mm?
#225
Postad 24 oktober 2015 - 08:00
sinners_bleed
sinners_bleed
177 inlägg
THE SHIELD CONVERTED TO 4K FOR NEW DIGITAL AND BLU-RAY RELEASES
http://screencrush.c...ray-conversion/
#226
Postad 09 november 2015 - 10:25
222 inlägg
JAAAAA!!!!!! Fy fan va härligt!
#227
Postad 12 november 2015 - 23:14
3 990 inlägg
THE SHIELD CONVERTED TO 4K FOR NEW DIGITAL AND BLU-RAY RELEASES http://screencrush.c...ray-conversion/
Härligt! Det här ser jag fram emot.
#228
Postad 13 november 2015 - 09:15
Nomad
Nomad
"Justice is coming"
6 401 inlägg
Detta är ju en anledning till att starta en övertalningskampanj hemma att vi ska byta ut TV. Igen.. Men till 4K
#229
Postad 01 december 2015 - 22:33
3 990 inlägg
Har nämnts tidigare men tål att nämnas igen, The Hitcher originalet!
Kollade på DVDn nyligen och jösses vad den ser risig ut, är det nån som vet ifall det finns en HD master till denna film?
Kan ju hoppas på att Shout Factory plockar upp den och släpper nåt kul.
#230
Postad 02 december 2015 - 10:29
budwhite
budwhite
1 918 inlägg
16mm kan se riktigt bra ut på BD så varför inte. Kul!
#231
Postad 06 december 2015 - 13:12
Unregistered28641812
2 286 inlägg
Äntligen släpps en av mina favoritserier på Blu-ray.
#232
Postad 06 december 2015 - 14:17
FEA
FEA
4 196 inlägg
Alla Ridley Scotts filmer finns på blu-ray.
Alla utom en.
Så jag vill se Someone To Watch Over Me på blu-ray, tack
#233
Postad 28 augusti 2016 - 13:15
Avicii
Avicii
1 167 inlägg
Ser ut att bli försenad till sent 2017.
https://twitter.com/...150834912153600
Men väntar man på något gott, så väntar man aldrig för länge...
#234
Postad 30 augusti 2016 - 07:01
moparman
moparman
Über-Guru
11 727 inlägg
OZ
p7891901_b_v8_aa.jpg 140,63K
#235
Postad 16 mars 2017 - 14:52
Unregisteredc49a1f15
3 205 inlägg
Oerhörd bump men men...
Någon som vet om Fucking Åmål kommer att komma på bluray? det är något jag verkligen vill ha.
Igår nämnde SFI:s restaueringschef på nypremiären av Fucking Åmål på Cinemateket att det kommer att filmen kommer att få ett bredare släpp med den nya mastern inom kort. Och med inom kort menades den kommande hösten, preliminärt. Dels kommer den att släppas för streamingtjänster och dylikt men en Blu-Rayutgåva är också på tapeten.
Den nya mastern såg f.ö. riktigt bra ut med tanke på utgångsmaterialet (filmen är skjuten på positiv 16mm, varav kamerapositivet användes som källa). DVD:n är rentav patetisk i jämförelse.
Redigerat av Unregisteredc49a1f15, 16 mars 2017 - 14:53.
#236
Postad 19 september 2017 - 11:08
2 986 inlägg
Flipper (1964) säsong 1-2 finns nu tillgänglig via Olive Films. S03 ska komma om en månad. För att vara så blandade inspelningsmiljöer är det en riktigt bra transfer.
#237
Postad 20 mars 2018 - 00:30
Voldo
Voldo
846 inlägg
När ska väntan på The Abyss egentligen vara över??
Media & Mediauppspelning
Film
UPDATE 2024
UPDATE 2024
UPDATE 2024
UPDATE 2024!
2024-04-15 16:28:12
6mån senare så är foam monterat
Anton
2024-04-11 18:04:03
