Sony Xperia™ Z5 Compact
21 svar till detta ämne
Sony Xperia Z5 Compact E5823 2GB RAM 32GB (Mobiltelefoner) 9 5,91 (73) 1 783:-
Postad 10 september 2015 - 19:53
Avicii
  • Avicii
  • 1 167 inlägg
Bifogad fil  Z5 Compact black.jpg   15,79K   0 Antal nerladdningar Bifogad fil  Z5 Compact white.jpg   13,69K   0 Antal nerladdningar
Bifogad fil  Z5 Compact red.jpg   16,62K   0 Antal nerladdningar Bifogad fil  Z5 Compact yellow.jpg   15,36K   0 Antal nerladdningar
Bifogad fil  Z5 Compact back.jpg   20,67K   0 Antal nerladdningar
Sony Xperia Z5 Compact Key Features:
- 3G Network: HSDPA 850 / 900 / 1900 / 2100
- 4G Network: LTE 700 / 800 / 850 / 900 / 1900 / 2100 / 2600
- Nano-SIM
- Connectivity: Wi-Fi 802.11 a/b/g/n/ac, Dual Band, DLNA, Wi - Fi Direct/HotSpot, Bluetooth v4.1 With A2DP/APT-X, MicroUSB v2.0 (MHL 3.0 TV-Out) , USB Host And NFC
- GPS With A-GPS Support And GLONASS
- Dimensions: 127 x 65 x 8.9 mm
- Weight: 138 Grams.
- Display 4,6" TFT LCD HD (~319 Ppi Pixel Density) With Chemical Tempered Glass And Anti-Fingerprint Coating
- 32 GigaBytes Memory Internal
- Expansive Memory Up To 200 Gigabytes
- 2 GigaBytes Ram LPDDR4
- CPU Qualcomm MSM8994 Snapdragon 810 Quad - Core 2.0 GHz Cortex A57 And Quad - Core 1.5 GHz Cortex A53
(SemiConductor Technology 20 nm HPM HK-MG)
- GPU Adreno 430 (Quad - Core Graphics @650 MHz)
- Android 5.1.1 (Lollipop) With Sony UI
- Office Document Viewer (Word, Excel, PowerPoint And Reader PDF)
- Camera 23 MP With Wide Angle Sony G Lens (24mm) And Pulse Led Flash
- CamCorder UltraHD 2160p @30 FPS
- 5 MP Front Facing Camera Wide Angle Lens (25mm) With Led Flash, SteadyShot And CamCorder (FullHD 1080p)
- Hi-Res Audio With Digital Noise Cancelling
- Stereo FM Radio With RDS
- Standard Battery Li-Ion 2700 mAh (Non-Removable) With Fast Battery Charging: 60% In 30 Min (Quick Charge 2.0)
- Fingerprint Sensor (Fast And Secure Unlock)
- Waterproof And Dust Tight (IP65 And IP68)
- Available Graphite Black, White, Yellow And Coral Colors
Xperia™ Z5 Compact
White Paper
Postad 12 september 2015 - 12:39
DevilGod
  • DevilGod
  • 1 517 inlägg
Om de sänker priserna a'la Storbritannien så kanske det blir ett köp.
Postad 22 september 2015 - 07:21
Unregistereddc471864
  • Unregistereddc471864
  • 24 891 inlägg
Hade lätt köpt denna om jag hade varit ute efter en android-telefon. Perfekt storlek.
Postad 30 november 2015 - 16:24
Allendorr
  • Allendorr
  • 97 inlägg
Fick min Z5 Compact för en 4 dagar sedan. Displayen var trasig direkt. Pixelfel längst ner på skärmen. Annars är telefonen kanon. Älskar ljudet från hörlursutgången jämfört med min Iphone 5c. Synd bara att jag inte längre kan streama spotify till mina Audio pro produkter :/
Postad 30 november 2015 - 18:29
Unregistered43b822d3
  • Unregistered43b822d3
  • 3 782 inlägg
Vad är problemet med Audio Pro i detta fall?
Postad 01 december 2015 - 13:11
Allendorr
  • Allendorr
  • 97 inlägg
Problemet är att audio pro streamar via Airplay och telefonen inte stödjer det. Kan spela upp låtar via DLNA men det går inte med spotify såklart. :/ :( Nästan så jag byter tillbaka till Iphone för att kunna spela musik i vanlig ordning.
Postad 01 december 2015 - 13:40
K1M
  • K1M
  • 298 inlägg
Roota och installera AirStream eller ngn liknande app.
Postad 01 december 2015 - 13:43
Allendorr
  • Allendorr
  • 97 inlägg
Roota? Du tror att detta kommer lösa mitt problem? Fick för mig att Airplay inte funkar på Android? Att det inte skulle vara kompatibelt?
Postad 01 december 2015 - 13:48
nisseläsk
  • nisseläsk
  • 742 inlägg
Ett annat alternativ är att köpa en Chromecast Audio o koppla till dina högtalare och köra Spotify Connect.
Postad 02 december 2015 - 13:14
(SiC)
  • (SiC)
  • 1 025 inlägg
Min Z1C's batteri har börjat strula, dyker från ca 30-40% till ingenting och stänger av sig..  Har fått garantiärende via inköpsställe (Cyberphoto), men vägrar vara utan lur i minst 2-4 veckor (juletider).
Funderar på att slå till på Z5C när det ändå är bra pris idag, hur är det med värmeutveckling och kameraproblemen - har det blivit bättre med nyare mjukvara?
/Z!
Postad 03 december 2015 - 11:48
jay-jay
  • jay-jay
  • 158 inlägg
Ja det är verkligen trist när produkter bara stödjer låsta format. Det jag hatar mest med Apple. De gör så att standardprotokoll hamnar i skymundan och vissa saker låses till Apple utan att de skulle behöva det.
Själv skulle jag aldrig köpa en sådan produkt fast jag skulle aldrig köpa en Appleprodukt privat heller. I jobbet måste jag tyvärr använda skiten. Tyvärr struntar många konsumenter i sånt och då blir läget så här :-(
Postad 03 december 2015 - 15:07
Allendorr
  • Allendorr
  • 97 inlägg
Var på närmsta Tre butik idag och lämna in telefonen, fick med mig en ny direkt! Kanon support! Nu är skärmen som den skall! Älskar min Z5c!
Postad 04 december 2015 - 13:13
(SiC)
  • (SiC)
  • 1 025 inlägg
Grattis  :-)
Köpte mig förresten en häromdagen...
Postad 01 februari 2016 - 11:58
ilovematcha
  • ilovematcha
Är det någon som upplever dålig GPS mottagning med sin Z5:a? Telefonen ser kanske upp till 20 satelliter men tar lång tid till att få fix (över flera minuter) eller inte alls. Jag har testat med appar som GPS Status och GPS test. Lekt också med inställningarna under "Location". Även med färsk AGPS data är det dålig mottagning. Har jämfört med min Moto G och då denna  får fix under 10s får Z5:an fix kanske efter 1 minut, då håller jag båda telefoner i varsin hand! När den väl har fix så är noggranheten sämre än Moto G (Moto G <5m, Z5<15m). Har googlat en hel del och det verkar som om det det var/är en hel del GPS problem med Z3:an, men har inte hittat mycket när det gäller Z5:an.
Här är någon som upplever något liknande https://talk.sonymob...ow/td-p/1058026
Postad 03 februari 2016 - 21:23
The_Dude
  • The_Dude
  • 60 inlägg
Har en Z5C och har inga problem med GPS mottagningen. Fix under 10 sek. Noggrannheten har jag dock inte kollat så noga. Använder den ibland när jag springer och cyklar och har inte gjort några djupare analyser men distans, km tider och tempo brukar stämma ganska bra jämfört med andra alternativ jag använt och uppmätt sträcka i spåret.
Postad 09 februari 2016 - 09:59
ilovematcha
  • ilovematcha
Det visade sig vara ett fel på mitt ex. Jämförde med någon annan som hade samma modell... fix inom 5 sekunder på dennes, min fick ingen fix ens inom 1 minut. Skickade tillbaka den.
Redigerat av ilovematcha, 09 februari 2016 - 09:59.
Postad 11 februari 2016 - 16:49
DevilGod
  • DevilGod
  • 1 517 inlägg
Körde in uppdateringen som kom igår och efter det har den spontant startat om sig fyra gånger (som jag vet om iaf). Fler som detta har hänt för? Den kunde starta om sig en gång i veckan innan på sin höjd. Har den svarta modellen.
Postad 12 februari 2016 - 08:10
Allendorr
  • Allendorr
  • 97 inlägg
Jag har oxå svarta modellen men den startar aldrig om sig.
Postad 28 februari 2016 - 18:52
DevilGod
  • DevilGod
  • 1 517 inlägg
Då verkar vi lida av samma fenomen.
Postad 28 mars 2016 - 12:04
Unregistereda021f600
  • Unregistereda021f600
  • 587 inlägg
Någon som uppdaterat till 6.0? För / nackdelar?
Postad 28 mars 2016 - 17:26
Allendorr
  • Allendorr
  • 97 inlägg
Min är up to date men har inte märkt något större.. Lite små fix bara.
Postad 23 april 2016 - 18:15
Unregistered8244c3d5
  • Unregistered8244c3d5
  • 587 inlägg
Hejsan..
jag har en sony xperia C6603
har haft den i några år men tycker att den är för stor nu....
funderar på att på Z5:an nu när den är så billig...hur är Z5 compakt mot min xperia c6603?
är kameran bättre..hur är musikspelaren ..är det bra ljud?
vilken har bäst skärm?
min xperia har 1920x1920
Z5 har 1280 x 720...gör det någon skillnad?
mvh roland
