Crysis
239 svar till detta ämne
Postad 21 January 2006 - 22:55
  • 38133 inlägg
http://www.gamershel...creenshots.html
Tja vad ska man säga? Ser hyfsat ut :) . Typ allt ska gå att förstöra och är dynamiskt.
Spelet ska komma i slutet av 2006 och är 60 % klart.
Motorn stödjer dualcoreproccesorer så det är en fördel att ha det i sin PC. Spel med samma motor finns under utveckling till 360 och PS3 som borde klara av den bra med tanke på sin multicoredesign.
Redigerat av Zoiler, 04 August 2006 - 10:39.
Postad 22 January 2006 - 17:08
Unregisteredc5472c21
  • Unregisteredc5472c21
  • 338 inlägg
ser väldigt intresant ut.
En lite film: http://www.gamershel...oad_12286.shtml
BSR Slack-Jaw posted found this translation
Start saving for a new rig now folks!!!!!!!!!!!!!!!!!!!!!!!!
Found translations of pages,
Page 29
The Story
An unknown object (not an asteriod because it didn´t cause enough damage) hits an island in the Pacific, and the North Koreans send their army to investiage the issue, and so does China and the US sends two carrier there as well. The tensions between the NK and US are close to a war, so the US starts a CovertOp and sends in Jake Dunn (our character) and a small team to infiltrate and investigate the situation on the island. He and his team make a HALO jump at night and unlike in "NOLF", this isn´t a special level but we actually fall several miles thru air and the beautiful volumetric clouds and can steer our ´chute onto the island beneath us. There are no annoying level loadings and every object casts his own shadows which move accordingly as the times passes by just like in real life.
At first Dunn and his men are sneaking thru the jungle, listening to what the NK soldiers are saying, and investigating artifacts in a similar way like you can do in "Condemned" with a scanner and after sending it to your carrier you´ll receive ammo drops or weapon modifications.
Page 30 (Picture description: Notice how the dynamic sun movement changes the "mood" of the exact location. In the evening the jungle casts long shadows and a moody scary scene while middays the jungle has bright vibrant colors. All pictures are not pre-rendered but actual ingame pictures.)
Although the first actions of you and your team are covert and sneaking, soon you will take good use of your arms (pistols, MPs, assault rifles, sniper). All weapons are 3D objects and can collide with trees or other solid objects, so if you want to actual hit your targets, better make sure your rifle is lined up properly. (the way it is explained, it seems that the game helps you to line it up automatically as well. thats my guess though)
More details on the physics
The physical realism in Crysis is very amazing and doesn´t end at at the guns, but every object that looks like it can be moved, can actually. The times when a single leaf/branch stops the player are definitly over. Actually almost every object is destructable. We are droping trees and crush fences, detonate houses and even "damage" grass and leave trail behind us as we go thru the jungle. As we crouch into the grass, we actually feel safe because unlike in Far Cry, the AI does not see thru the grass but it does notice unnatural movement of the grass, and starts to investage the area.
The weapons
Almost every weapon in Crysis can be customized. You can either mount silencers, scopes, lasers. Jake itself is a mod-able weapon, he wears a Nano Muscle Suit. This suit does not only give him some armour and enhances his strenght and speed but the player can actually move the suits energy to either increase the armour/shield, speed, strenght. You can assign hotkeys to this energy management system and quickly change the settings of the suit. For a retreat you´d for instance try to maximize running speed etc. The suit can also heal you but of course all actions with the suit cost energy, but after a while it re-charges itself.
Page 31 (the KI Koreans are smart, they re-group and attack the people in the "building" simultaneously)
The suit can also help Jake to sneak around (costs energy as well) as it can reduce his noises, but if you forget to turn it off and fire a loud weapon, you can see how you waste your suits energy.
Holiday on ice
An AC might be a standard item in almost every car, but even Jakes suit has one as well and it will soon save his life. Because the unknown piece from outer space is not an asteriod but actually an alien ship who want to terraform the earth into an ice world. In a scene all out of sudden the aliens fire their ships ice cannon and parts of the jungle are now iced. This happens realtime ingame, the level doesn´t reload or anything like that. We can see how the area/island gets iced further and further as the time passes by. Game designer Bern Diemer told us "there won´t be any pre-rendered video clips that pull the player out of tense and nervwracking scenes". (similar like COD I guess)
The enemies become allies
After the surprise attack by aliens, the US and North Koreans now are allies and try to fight off the threat to all humans together. You might be now wondering if NKs have no bad feelings about Jake all out of sudden? They do. In Crysis the former enemies don´t forget what you have done. A Korean general knows exaclty what you have done with his soldiers. Have you killed many of them, especially out of situations where you suprised them, he won´t co-operate with you completely and might keep imporant information for himself or even "hiddes" equipment or ammo. All major NPCs have this kind of "memory" in Crysis and with the right actions Jake can even end up in a romantic relathionship with a hot female soldier. The main plot isn´t affected by this but the various side plots increase the replay value of Crysis tremendously.
Page 32 (picture: for the night we have mounted a silencer on our rifle. Our compass seems to be broken because the sun goes down in the north)
"Farewell brothers"
Crysis even remembers our most spectacular attacks. When we fraged several aliens at the same with a well placed ´nate, a young soldier told us his amazement shortly after. Thanks to this we feel like a part of this world, that we can affect it and get to know the characters and therefore its even a little painful if our fellow mates get killed. The KI teammates however act independently and the player can´t give them any orders or commands. The devs told us they wanted the gameplay to be concentrated on Jake Dunn and our fellow soldiers don´t affect the main plot anyway. If they get killed they are simply not available in the next misson/chapter. So when things get really bad and your whole team is dead, you´ll end up celebrating your victory alone at the end of the game. BTW, we found our young soldier later on half way iced inside a huge ice block.
Cold War
The aliens have 2 primary weapons, the "Molecular Accelerator" shoots ice nails and doesn´t need ammo but far more spectaculor is the "Molecular Arrester". With that one we can freeze our enemy and split him into little ice cubes .... in realtime. If we get iced ourself, the Nano suit can safe our life if it has enough energy and the action can continue. Our suit has another advantage in the war against the aliens. He can drop our body temperature so deep that the alliens won´t see us anymore (they only see thermal vision). This obviously works only a short time, uses a lot of energy and can cause damage to Jack. The suit has also an emergency function where it sends out a shockwave and all enemies in area (maybe 50m around us) can´t fight us for a little while. The suit can also malfunction and take a little longer than usual to recharge after using the emergency function.
Freeroaming
In Crysis there will be huge partly metallic enemies who Jake has to climb on (with magnetic shoes lol). Jake won´t be walking the whole time on ceilings and walls unlike the hero in "Prey" but later on he will be "floating" inside the alien ship because it won´t have any gravity.
Page 33 (Detail in Crysis is not a rare thing, notice the labels on the missiles, the starting officers vest and btw, Jake can pilot these VTOLs himelf. Other picture: Not only the sun is casting dynamic shadows, but so do explosions and fires)
The battles in air will be similar amazing. Yes Jake won´t only to use jeeps, or small vehicles, but also helicopters and high-tec jets. There won´t be any noticeable dead ends of the levels, but just like in FarCry when you leave beyond the limit you will either be stopped by the own troups, the aliens or a tropical storm.
A short vacation
As intense the Crysis adventure feels, its also short like it. The game is about 10 hours long, and frustating scenes like in FarCry won´t exists, in Crysis we are allowed to save our game at any time. Crytek wants to improve the multiplayer as well, and will include DM, TDM, CTF, and a more tactical mode similar to BF2 but unlike holding positions, it will actually be special artifacts that give the team special abilities, like weapons, upgrades, vehicles. The opposing team can steal these artifacts and vice versa. There won´t be any aliens in MP and a coop mode for SP won´t most likely be added either.
Destination unknown
While the guys from Crytek are still far from an official release date, CEO Cevat Yerli was optimistic: "The work on Crysis advances nicely and we are aiming at an release in Q4 2006." The red box also said that the game is finished around 60%.
Crytech utveckling: http://www.monsterso.../comparison.jpg
Postad 22 January 2006 - 17:35
Unregistered5697a427
  • Unregistered5697a427
  • 166 inlägg
Man blir ju lite våt i byxan när man ser filmen alltså... Men frågan är ju vilken superdatorn man lär behöva för det.... har man tur kommer väl spel med denna motorn till 360 med.... :)
Postad 22 January 2006 - 17:58
En konfig med Dual AMD och SLI GF7900 Ultra senare så är det ju bara att köra... :)
Fast ja, det var väl hyffsat.
Postad 22 January 2006 - 18:32
  • 338 inlägg
[quote name='pacman' date='Jan 22 2006, 17:58 ']
En konfig med Dual AMD och SLI GF7900 Ultra senare så är det ju bara att köra... :P
frågan är ju om ett 7900 skulle funka då det kräver dx10 grafikkort! :)
Postad 22 January 2006 - 18:57
rayko
  • rayko
  • 3653 inlägg
Då är frågan, kommer PS3an och 360 klara denna grafik? eller måste vi vänta till PS4an och 720n?
Postad 22 January 2006 - 19:50
  • 166 inlägg
Haha, ja en 720:a kommer nog krävas :)
Postad 22 January 2006 - 21:51
  • 38133 inlägg
Som jag skrev så är spel som bygger på samma motor under utveckling till PS3 och xbox 360 as we speak, så det ska inte vara några problem att köra. PS3 versionen var "custom-made" för PS3 iofs.
Ska bli spännande att se vilka andra motorer som utvecklas till nextgen. Alltid lika roligt :P . UE3 börjar kännas gammal trots att inga spel kommit ut med den :D .
Tack för infon Ragganof. Verkar häftigt :) . Värt att notera att filmen du lade upp är nåt år (?) gammal, så det finns utrymme för förbättring ;) .
Postad 22 January 2006 - 22:15
Unregistered8147b14e
  • Unregistered8147b14e
  • 2473 inlägg
Detta har jag hört sägas om en hel del spel... inget har dock levt upp till det påståendet :)
Postad 22 January 2006 - 22:35
  • 338 inlägg
farcry hade ju ganska fin fysik sånt så tror faktist att dom kommer att gå steget längre nu! :P
det jag vill göra är att få en minigun i spelet och återskapa predator scenen! ;)
hoppas även att fienderna blir så att dom kanske spränger en vägg på en föråd om man gömemr sig i det för att tydeligen så kommer det att vara så att saker som rammlar gör realistiska skador.
så att förådet abra kolapsar över en själv.
Men är grafik chippen i 360 och ps3 komplatibla med directx 10?
Postad 23 January 2006 - 00:50
  • 38133 inlägg
Det går inte att jämföra på det sättet tydligen:
While most modern GPUs share many architectural similarities, Bob Feldstein and Chris Evenden of ATI went out of their way to explain to me, no matter how hard I tried to convince them otherwise, that the Xbox 360 GPU is very much an original creation. While some will try to tell you that is it simply a modified DirectX 9 GPU, you might be interested to learn that the only API spec that the Xbox 360 hardware meets is its own API. That is correct, the Xbox 360 GPU only meets it own Xbox 360 API specifications. While of course some lessons learned in DX9 and upcoming DX10 were applied, the GPU of the Xbox 360 is very much its own and comparing it directly to anything in the PC world is simply “not right” according to Mr. Feldstein.
http://www.hardocp.c...ml?art=NzcxLDE=
Mer:
Well neither is RSX since it'll be using OpenGL and Cg. :) I think all he's saying there is that DX is the layer, not the hardware itself. Since ATI's chip is in the closed platform of a console their own API applies and they can get past restrictions of DX (as well as add something like MEMEXPORT), just like Nvidia has their own API (Cg). In that sense any G70 derivative in the PS3 is also a bit beyond Shader Mark 3.0. But both chips are still mostly analogous to DX9/SM 3.0 hardware when its all said and done. Fully SM 4.0 featured chips havent even taped out yet.
Angående Shader 4.0:
found some interesting facts on the Xbox 360 GPU handling this. we know this game will support Shader Technology 4.0 which will come besides DX10. interesting thing is that PS3 is shader 3.0 while here is xbox 360's custom shader (no its not shader 3.0)
Shader 3.0 instruction slots: more than 512, Xenos : 4000
Shader 3.0 max instructions executed: 65535, Xenos: 500,000
Shader 3.0 temp registers : 32, Xenos: 64
Shader 3.0 texture samplers: 20, Xenos: 48
and so on, here: http://www.beyond3d..../index.php?p=09
so Xbox 360 seems to be more closer to Shader 4.0 than Shader 3.0 is
Postad 23 January 2006 - 14:57
  • 338 inlägg
Låter ju sketa bra det där,då behöver man inte oroa sig att dom skulle måste fula ner saker för konsollerna.
Samt att man heldre köper en konsoll änn byter till "windows vista" på datorn.
Postad 23 March 2006 - 15:00
  • 38133 inlägg
Här är den senaste filmen från GDC:
http://zdmedia.vo.ll...wmv_640x360.zip
Ser...nästan verkligt ut. Imponerande.
Postad 29 March 2006 - 15:41
  • 38133 inlägg
Bifogad fil  4738220060328_235052_0_big.jpg   376.98K   301 Antal nerladdningarBifogad fil  4738220060328_235053_1_big.jpg   191.52K   255 Antal nerladdningarBifogad fil  4738220060328_235054_4_big.jpg   216.03K   203 Antal nerladdningarchment]Bifogad fil  image_o_matic.jpg   205.9K   257 Antal nerladdningarBifogad fil  screen1_large.jpg   98.51K   155 Antal nerladdningar[attachment=1999
7:attachment]Bifogad fil  screen3_large.jpg   245.19K   241 Antal nerladdningarBifogad fil  screen4_large.jpg   169.84K   293 Antal nerladdningar
Postad 30 March 2006 - 14:47
:huh:
Postad 30 March 2006 - 14:54
Unregistered36883
  • Unregistered36883
  • 3680 inlägg
Jahapp... då verkar det som om man kommer bli tvungen att släppa ut spel-djävulen snart igen då...? Som om inte tjejen tycker att man spenderar för mycket tid som det är framför burken... :huh:
För det här ser ju riktigt snyggt och intressant ut....
//Hylle
Postad 07 June 2006 - 13:00
  • 38133 inlägg
Ta en titt på de här Crysis vs verkligheten bilderna i spoilern:
Rekommenderar att ni tittar på den här filmen också, ca 14 minuter lång. Visar när de skjuter ned träd och spränger bilar mm. Mycket realistiskt.
http://video.uol.com.../wmv/crytek.wmv
Kopiera in länken i webläsaren.
Postad 07 June 2006 - 20:46
Unregisteredf1616e6c
  • Unregisteredf1616e6c
  • 786 inlägg
länken funkar inte så bra du...
Postad 08 June 2006 - 00:22
  • 38133 inlägg
Den funkar för mig, jag har IE. Kopiera in länknamnet i webläsaren och tryck enter så ska du få en fil att spara.
Edit: Nej, nu har de tagit ner den. Synd...där missade ni nåt =P.
Redigerat av Zoiler, 08 June 2006 - 00:28.
Postad 13 June 2006 - 13:48
Photek
  • Photek
  • Anime Junkie
  • 486 inlägg
Hittade en annan länk, antar att det är den som Zoiler menade.
Crysis video
Postad 13 June 2006 - 16:00
  • 38133 inlägg
Ja, den är lika stor så det måste vara den, skynda att titta allesammans :ph34r:
Postad 13 June 2006 - 16:28
Guwwic
  • Guwwic
  • 700 inlägg
Crysis video
Inte en chans att min dator kommer palla det där spelet :ph34r:
Blev mäkta imponerad över grafiken på båten, holy shiet!
Postad 13 June 2006 - 18:12
:huh: :o :D :o :P
Så jäkla mkt next-gen att det är löjligt. :ph34r:
Postad 13 June 2006 - 20:57
  • 2473 inlägg
Ujuj, dags att lägga undan pengar för en ny dator MAo. =) Jag spelar helst FPS på dator då jag inte kommer överrens med handkontroller i FPSers
Postad 04 August 2006 - 10:37
  • 38133 inlägg
Systemspecifikationerna för Crysis:
Minimum Requirements
CPU: Athlon 64 3000+/Intel 2.8ghz
Graphics: Nvidia 6600/X800GTO (SM 2.0)
RAM: 768Mb/1Gb on Windows Vista
HDD: 6GB
Internet: 256k+
Optical Drive: DVD
Software: DX9.0c with Windows XP
Recommended Requirements
CPU: Dual-core CPU (Athlon X2/Pentium D)
Graphics: Nvidia 7800GTX/ATI X1800XT (SM 3.0) or DX10 equivalent
RAM: 1.5Gb
HDD: 6GB
Internet: 512k+ (128k+ upstream)
Optical Drive: DVD
Software: DX10 with Windows Vista
Postad 04 August 2006 - 11:02
Fredrik HL
  • Fredrik HL
  • 980 inlägg
Och som alla vet så är de rekomenderas specifikationerna bara till för att man ska få spelet att flyta på bra med medium inställningnar, om man ska komma upp i 30-60fps med 1600x1280 upplösning måste man säkert ha två st Dual 7900GT på SLI för att det ska klara av, 4st kort räcker nog. Ne, tack jag väntar nog tills det kommer till next-gen konsol istället för att köpa en dator för 30000kr
Postad 04 August 2006 - 11:35
DrJP
  • DrJP
  • 103 inlägg
Gott. Klarar precis av minimum-kraven... undrar vad det blir 10 fps i 640x480? hehe
Postad 05 August 2006 - 01:29
Shunon
  • Shunon
  • 255 inlägg
jag läste nånstanns att crysis kommer till 360 stämmer det?
Postad 05 August 2006 - 01:47
Unregisteredf64a5233
  • Unregisteredf64a5233
  • 14825 inlägg
Crytek jobbar med att porta motorn till "next gen", men om det blir Crysis eller något annat spel återstår att se.
Postad 06 August 2006 - 15:28
Dolph_Lundgren
  • Dolph_Lundgren
  • 1170 inlägg
Det finns ingen som gått ut och sagt att spelet ska komma till någon konsol.
Men crytek söker tydligen multiplatforms programmerare för ps3,
Postad 08 November 2006 - 22:23
  • 14825 inlägg
Ser ju helt OK ut.
Postad 28 January 2007 - 02:01
Unregisteredc17c0c25
  • Unregisteredc17c0c25
  • 1199 inlägg
så bra som far cry är så kan ju detta bara bli helt underbart!
nån som vet när de släpps?
Redigerat av Unregisteredc17c0c25, 28 January 2007 - 02:01.
Postad 28 January 2007 - 03:35
Unregistereddc471864
  • Unregistereddc471864
  • 24891 inlägg
Mycket möjligt men det kommer inte se ut som på PC isf. Det finns det ingen konsoll som pallar med.
Postad 30 January 2007 - 15:52
casshern
  • casshern
  • 183 inlägg
Crysis DX10 benchmarks makes GeForce 8800 GTX SLI walk on all four
http://www.nordichar.../news,5560.html
Dags att uppgradera.
Postad 30 January 2007 - 18:42
derpious
  • derpious
  • 4346 inlägg
You should remember though that neither Crysis nor NVIDIA's ForceWare drivers for Vista are completed so the figures may very well improve.
Tror det där kan göra ganska mycket.
Postad 30 January 2007 - 21:02
swebarb
  • swebarb
  • 585 inlägg
Jag hoppas verkligen det inte bara blir snygg grafik och effekter för hela slanten..man tröttnade ju på farcry halv vägs när monsterna kom in i bilden. Vill se nåt intelligent fps spel som i Fear typ där AI verkligen är smart å klok.
Postad 02 February 2007 - 16:24
jonsod76
  • jonsod76
  • 1105 inlägg
Hoppas verkligen att de lyckas att förbättra drivrutinerna till windows vista vad gäller detta spel.
Har precis lagt ut 25 papp på ny dator, verkar ju knappt räcka till ändå!!??
Innefattar bl.a.
Gainward Geforce 8800GTX
Pentium Dual core QX 6700
Corsair 4 GB RAM DDR2 800Hz
Enligt testet ovan så körs Crysis med DUBBLA 8800 GTX-kort i SLI-mode, och ändå så fick systemet kämpa svinhårt med Crysis i hyffsad upplösning. ;) :lol: :lol:
Jonsod
Redigerat av jonsod76, 02 February 2007 - 16:36.
Postad 02 February 2007 - 18:03
auToeXeC
  • auToeXeC
  • 323 inlägg
att crysis kommer bli jobbigt för en PC förstod man sn det kom med första glimten. Men hoppas dom kommer med ågot liknande till kryssboxen med. Vore inte helt fel
Postad 02 February 2007 - 18:06
  • 38133 inlägg
Det gör de väl? Sa de inte att de hade ett Crysis på G till 360, fast inte samma Crysis? Alltså i samma "universum".
Postad 02 February 2007 - 20:46
  • 14825 inlägg
Innefattar bl.a.
Enligt testet ovan så körs Crysis med DUBBLA 8800 GTX-kort i SLI-mode, och ändå så fick systemet kämpa svinhårt med Crysis i hyffsad upplösning. :lol:  :lol:  :lol:
Jonsod
Det är av den här anledningen jag verkligen hatar PC-spel. ;)
Spelar ingen roll hur modern dator man tycker man har så bör man uppgradera för att kunna spela "nästa" spel.
Postad 02 February 2007 - 21:25
  • 12482 inlägg
Med den grafiken blir det garanterat diabilder på Xbox 360.
Men, det blir väl som med andra spel sämre grafik men flyter på någorlunda bra. Men det går ju
att sänka grafiken på PC med, även om det inte är kul ;)
Postad 03 February 2007 - 11:06
Johan78
  • Johan78
  • 1419 inlägg
Den testen är fejk.
Postad 04 February 2007 - 10:34
jonsod76
  • jonsod76
  • 1105 inlägg
Den testen är fejk.
Jaha, hur vet du det? Källa?
Nordic Hardware är ju inte oseriösa vad jag vet.
Jonsod
Postad 04 February 2007 - 10:43
Fak3r
  • Fak3r
Den testen är fejk.
Jonsod
http://www.sweclocke.../nyhet/?id=5464
"Ännu en indikation på att prestandatesterna var bluff är att ett BFG Ageia Physx-kort användes. Detta är mycket underligt eftersom Crysis inte stödjer detta hårdvarufysikkort."
Postad 04 February 2007 - 15:29
jonsod76
  • jonsod76
  • 1105 inlägg
Den testen är fejk.
Jonsod
Puuhh, tack för infon! ;)
Ja då kan man slappna av igen...
Jonsod
Postad 04 February 2007 - 15:47
Johan78
  • Johan78
  • 1419 inlägg
Den testen är fejk.
Jonsod
Det var ju inte Nordic Hardware som genomförde testet utan de bara hänvisade till artikeln. Det finns tyvärr folk som ser en njutning i att släppa fejkad info om en väldigt högt efterfrågad produkt.
Postad 04 February 2007 - 17:51
Unregisteredbb649a5e
  • Unregisteredbb649a5e
  • 4239 inlägg
kollade på en av filmerna, och tycker att man har hört allt dom säger tidigare.
förstör omgivningen
aldrig spela samma igen
bla bla bla..
nu ser juh dock detta ut att kunna infria dessa "löften" lite bättre än tidigare spel, men ändå.
ser juh iallafall fruktansvärt bra ut. synd bara att granaterna inte verkar göra hål i marken. saknar det i spelen.
nu kvarstår dock frågan. ska jag sälja mig själv för att få råd till en fetepc, eller ska man vänta och införskaffa 360 och om nåt kommer dit?
Postad 04 February 2007 - 17:54
  • 38133 inlägg
Det hela står väl inte och faller med ett spel ;) ?
Postad 04 February 2007 - 18:04
  • 4239 inlägg
nah, självklart inte. 360 är jag intresserad av och kommer troligen införskaffas endera dagen..
en bättre pc är juh samtidigt aldrig fel, men när tusan ska man ha råd med ett vidunder till dator egentligen =/. billigaste och enklaste är nästan att satsa helt på 360, för då vet man att det är optimalt, och behöver inte oroa sig för att ens grafikkort inte fungerar =)
Postad 04 February 2007 - 22:35
auToeXeC
  • auToeXeC
  • 323 inlägg
Jag ska inte säga att jag hatar gaming på PC för jag köpte mig en laptop för 33 laxar för att kunna spela krävande spel. Men det gick någon månad sen kötpe jag 360 och insåg hur dum jag har varit som inte letade mig till konsolträsket tidigare.
Men sen att crysis motorn inte kommer vara lika snygg på 360 som på pc ä väl inte så farligt. har vi klagar på grafiken hittils på våra lilla konsol? Tror inte vi kommer bli missnöjda här heller, släpper dom ett spel som är så genomtänk som farcry (med tanke på tiden att göra) så tror jag inte dom ser till att grafiken kommer på en oacceptabel nivå till oss
