Jag har gjort bort mig.....
6 svar till detta ämne
Postad 25 March 2007 - 11:00
olakrafft
  • olakrafft
Skulle kolla lite av ren nyfikenhet i service menyn på min samsung lcd. Blädrade runt på alla menyer för att kolla vad som fanns. När jag var inne på ett meny alternativ som hette calibration så lyckades jag trycka på fel knapp och den startade med någon form av kalibrering.(AV calibrate)
Föjden av detta är att efter alternativtet AV calibrate så står det nu mera failure :)
Vad göra för att komma till rätta med detta........
Redigerat av olakrafft, 25 March 2007 - 11:12.
Postad 25 March 2007 - 12:37
ingo76
  • ingo76
  • 13 inlägg
inte roligt testa det här på egen risk
you have, by accident, messed up the calibration, ie. calibration indicates Failure, you can re-calibrate the inputs.
This procedure for HDMI calibration is from nicolail at http://www.avforums....&postcount=3162
- DISCLAIMER -
Before you proceed with the recalibration (or thinking about recalibrating your perfectly working F71) record ALL - i repeat ALL - your setting is the service menu - It is VITAL you do so in case something bad happens and you need to go back, the settings are made in the factory and is unique to your tv, once you loose them there is no way to get them back.
SO DON'T BLAME ME IF IT GOES WRONG.
- DISCLAIMER -
A while ago while fiddling with the service menu i unfortunately activated the recalibration of the HDMI 1 port, it did not totally mess up my F71 but it bugged me a lot as it reported a Failure.
Here is what i did to remedy the failure:
1 : set your resolution to 1080p (60 or 30hz)
2 : download this checkerboard image
http://www.avforums....34&d=1172541175
it is 1920x1080 monochrome (black and white), its zipped so unzip it.
it consists of 8x8 fields starting in the top left corner with a white square
3 : view the image
DON'T use Microsoft's image viewer , it sux ; download Irfanview and view the picture FULL SCREEN !!!!!! Get it here : http://www.irfanview.com/
4 : turn the tv off
5 : press info,menu,mute,power
6 : be absolutely sure you are in the port you need to calibrate
7 : go into the calibration menu, select HDMI and press right on the remote.
8 : wait (mine took about 10 seconds)
9 : now it should say success !!!!
10 : go back into the main service menu
11 : select reset...
and you're done, remember to take a note of the new settings
Redigerat av ingo76, 25 March 2007 - 12:49.
Postad 25 March 2007 - 12:57
ilstallione
  • ilstallione
  • 111 inlägg
Använder du den porten? Om inte skit i vilket, bättre det än att skruva till det mer :)
Postad 25 March 2007 - 19:41
olakrafft
  • olakrafft
En fråga ???
Jag har ju ingen tv dator(HTPC) att visa bilden ifrån utan den ingången som är problemet är min comhem dekoder ansluten till.
Hur skall jag fixa en calibrerings bild :)
Postad 25 March 2007 - 19:50
Unregistered4dac292f
  • Unregistered4dac292f
  • 158 inlägg
i värsta fall kan du väl höra av dig till Samsung?
Om dom säger att de kommer att bli dyrt så kan du väl använda dig av drulleförsäkringen (om du har nån?)
Känns som detta passar in rätt bra just på den försäkringen.
Postad 25 March 2007 - 19:59
olakrafft
  • olakrafft
Det borde inte vara någon dyr sak att åtgärda, med tanke på att det går alldeles utmärkt att titta på tv. Men bara tanken att det står failure i en calibrerings meny, kan väll få vilken hemmabio fantast(nerd) att rysa.
Kan man inte få någon fin kalibrerings bild från DVD´n för den sitter ju på AV den med??
Postad 15 March 2008 - 17:41
PhotoJoe
  • PhotoJoe
Detta har hänt mig också, fast på HDMI. Lite jobbigt!
Men jag lyckades få till detta genom att följa instruktionerna.
Jag kunde kopiera över bilden till min PS3:a och öppna den där. Gick kanon!
Det enda jag inte gjorde var att köra en "Reset", då får man installera om tv:n samt sortera alla kanaler igen och det kändes onödigt.
