Musical Fidelity A1008 Amp
5 svar till detta ämne
Musical Fidelity A1008 Integrated Amplifier (Förstärkare) 2 8.75 (3) Inga priser
Postad 29 May 2007 - 13:48
cyanide
  • cyanide
  • 264 inlägg
Output:
Voltage, RMS 45 Volts 20Hz to 20kHz
Voltage, Peak-to-peak 127.3 Volts
Power 250 Watts per channel into 8 Ohms (24dBW)
400 Watts per channel into 4 Ohms
Current Peak-to-peak 75 Amps
Damping factor 140
Output devices per channel 4
Pre-out impedance 50 Ohms
Line inputs:
THD + N, 20Hz to 20kHz < 0.01%, typical
Signal / noise ratio >100dB 'A'-weighted
Input sensitivity for 250W 330mV
Input impedance 220k Ohms
Overload margin 26dB
Channel separation > 70dB typical
Frequency response 20Hz to 20kHz, +0, -0.2dB
DAC:
DAC circuit 24 bit Delta-Sgma (Bit stream) dual differential 8X over sampling
Total correlated jitter < 135pS
Linearity <0.1dB down to -96dB
Output digital 0dB level 2.18 VRMS at 1kHz nominal
Frequency response 10Hz to 20kHz nominal
Channel separation > 105dB 20Hz to 20kHz
Signal/noise ratio >17dB 'A'-weighted
Total Harmonic distortion <0.003% 10Hz to 20kHz
Phono input response: RIAA/IEC combined, see graph
Signal/noise ratio >96dB 'A'-weighted
Input sensitivity 2.5mV (MM)
01.5mV (MC)
I1input impedance 47K Ohms (MM and MC)
1Overload margin 24dB (MM and MC)
Connections:
Line level inputs: 4 pairs ine level RCA connectors,
1 pair phono (MM/MC) RCA connectors
Line level outputs: 1 pair RCA [preamp] controlled by the volume
1 pair RCA [tape record] fixed line level
Digital inputs: 1 USB 1.1 [32, 44, 1, 48 kHz sample rates] connector for computer only
2 S/PDIF (RCA connector)
1 optical (TOSLINK)
Digital outputs: 1 S/PDIF (RCA connector)
1 optical (TOSLINK)
Speaker outputs: 1 pair 4mm banana plug/binding posts per channel
Power requirement:
100 / 115 / 230 Volts AC
50 / 60Hz (factory pre-set) 700 Watts maximum into 8 Ohms, 120 Watts idle
Standard accessories:
Power Supply Unit A1008 Power Supply Unit 1 off
Power supply lead, Control 1.0m 39 1/4 inches 1 off
Power supply leads,
Left & Right Supplies 1.0m 39 1/4 inches 2 off
Mains lead 10 Amp IEC type 1 off
Remote control A1008, universal 1 off
Batteries Size LR03 or AAA, manganese alkaline type 2 off
Dimesions:
Main unit 440mm, 17 1/3 inches wide
125mm, 5 inches high inc. feet
400mm, 15 3/4 inches deep inc. terminals
Power supply 254mm, 10 inches wide
380mm, 15 inches deep inc. terminals
Weight:
Main unit 13kg, 30 1/3 lbs unboxed
32kg, 70 1/2 lbs boxed unit including power supply and all accessories
Power supply 9.7kg, 21 1/3 lbs unboxed
eftersom jag har mycket mp3 musik på ps3an tänkte jag att de skulle va najs med att ansluta ps3an till uppsamplings dacen och in i förstärkaren.
vad tror ni om det :blink:
edit. jag äger alltså inte förstärkaren men är rätt sugen på köpa den ;)
Redigerat av cyanide, 29 May 2007 - 14:07.
Postad 29 May 2007 - 15:38
Unregistered1064
  • Unregistered1064
  • 756 inlägg
Ah, den där såg inte dum ut. Den måste vara purfärsk,
då jag inte hittade mkt om den på nätet. Förutom ett förväntat
pris på ca 3000 Pund.
Och visst, att använda D/A omvandlaren i den till det du beskriver är
väl inte fel tänkt!
Redigerat av Unregistered1064, 29 May 2007 - 15:38.
Postad 14 June 2007 - 10:48
Audionaut
  • Audionaut
Audiofile Blasphemy? :wub: MP3 på Musical Fidelity til ca 30000 +-kr?
Dette skal være en "state of the art" forsterker - altså MEGET god!!!
Den aksepterer ikke å spille noe annet enn CDer dessverre... ;)
Postad 27 September 2007 - 19:19
cyanide
  • cyanide
  • 264 inlägg
Nu har jag haft den hemma här ett bra tag och kan bara säga att den e riktigt grym :) . Men måste erkänna att det känns lite "overkill" att ha den endast som ljud åt PS3 hehe.
Jag har hört den tillsammans med a1008cd. Fantastisk kombo! kanske blir till att spara pengar till en riktig cdspelare men först så ska jag prova med att "streama" med en soundbridge eller liknande.
Postad 27 September 2007 - 20:00
mr-välljud
  • mr-välljud
  • 3700 inlägg
Musical fidelity är ett märke som är högt på min lista av goda produkter. De släpper ingenting som inte är PERFEKT. :) Köp! :)
Postad 28 September 2007 - 20:30
cyanide
  • cyanide
  • 264 inlägg
Om det är någonsom vill provlyssna a1008 cd och amp så rekommenderar jag OJCO INTERNATIONAL i helsingborg. De kör mf med focal 1027be :) . Första gången jag hört de högtalarna spela så bra faktiskt.
