Battlefield Bad Company
438 svar till detta ämne
Postad 20 June 2007 - 18:34
Transform
38133 inlägg
IGN har fått spela en preview på spelet och det låter och ser hur bra ut som helst. Äntligen total förstörelse <a href="http://xbox360.ign.com/articles/794/794427p2.html" target="_blank">http://xbox360.ign.com/articles/794/794427p2.html</a> Patrick Söderlund, VP and General Manager for DICE, told the crowd that the company aimed from the start to create a game that could not be done on PS2 or Xbox. Gears of War, he noted, could have been made on a last generation console, even if it would have been severely toned down in the graphics department. The Frostbite engine isn't just a new way to create pretty graphics. It was designed to create a new gameplay feature that couldn't be done before. In this case, that feature is totally destructible environments.
Destructible environments have been done before. Company of Heroes on PC had physics based destruction, but it was an RTS. Red Faction had a good amount of the environment that could be blown to bits, but some surfaces were indestructible. Other first person shooters had similar features, but many of the explosions were pre-determined animations. For Bad Company, we didn't find a single thing we couldn't blow up.
Grenades tossed into a grassy field wipe out the underbrush, blacken the earth, and leave a small pocket in the ground where the blast went off. Buildings, walls, fences, statues, huts, vehicles, trees, and everything else we came across could be taken down with the right amount of firepower. Hitting a building with a rocket will send out a shockwave that shatters all of the windows as a hole gets blown out of the area where you hit it. Snipers can't hide in windows and pick you off from cover because the walls in front of them can be destroyed with a blast from a tank or a well placed explosive. Mortar strikes will level whatever they hit.
From the top of the hill, we were able to pick off most of the remaining ground resistance. The helicopter was still a source of annoyance though. You can snipe out the pilot if you want or a perfectly timed mortar strike will do the trick on flying vehicles. But we had our heart set on the anti aircraft gun that sat within the walls of the encampment. Once inside gun, we started laying down a steady stream of bullets at the helicopter which took cover behind a group of trees on a nearby hill. Unfortunately for the pilot, anti aircraft fire also takes down trees. With the trees mowed down, the helicopter didn't last.
The demo finished when a heavy tank began rolling in. Grenades and other light explosives won't put a dent in a vehicle of this size. It was time to call in a guided missile. Our first attempt at controlling the missile didn't go so well and we ended up missing the tank. We did, however, hit the bridge it was trying to cross. The tank ended up falling through the hole we made in the bridge, disabling it long enough that we had no problem finishing it off.
Bilder. Notera hur bitar av hus och träd flyger överallt. Ser väldigt bra ut.                  Ytterligare ett spel att längta efter
Redigerat av Zoiler, 03 November 2007 - 13:09.
Postad 20 June 2007 - 20:40
Dolph_Lundgren
Dolph_Lundgren
1170 inlägg
Har löjligt höga förväntningar på detta spel.. kan bli det bästa spelet från Sverige hittills !!
Postad 21 June 2007 - 08:17
Viz
Viz
484 inlägg
Ser riktigt skojj ut, trailern var riktigt rolig den med!
Synd att det inte kommer till PC
Postad 24 June 2007 - 12:41
Unregisteredcadb2904
907 inlägg
när ska detta spel släppas?
Postad 24 June 2007 - 13:42
Transform
38133 inlägg
Någon gång 2008. Så det är ett rätt bra tag kvar.
Postad 24 June 2007 - 13:43
907 inlägg
så länge till, shit också
Postad 06 September 2007 - 15:06
Unregisteredf64a5233
Über-Guru
14825 inlägg
Gameplay-video på Battlefield: Bad Company.Holy shit, det ser ut som shit! Nej, men det ser inget vidare ut just nu, otroligt dålig framerate och drawdistance. Inget annat ser nå vidare ut heller (förutom att det går att skjuta sönder byggnader). Förhoppningsvis är detta bara en väldigt tidig version.. När skulle det släppas?
Redigerat av Unregisteredf64a5233, 06 September 2007 - 15:06.
Postad 06 September 2007 - 16:09
Unregistereddc471864
Über-Guru
24891 inlägg
Postad 06 September 2007 - 16:27
Transform
38133 inlägg
De senaste bilderna ser iallafall grymt snygga ut. http://www.gamersyde...ws_4946_en.html
Postad 06 September 2007 - 17:41
derpious
derpious
4346 inlägg
*shrug*
Trailern var riktigt dålig iaf, såg inte speciellt bra ut och det såg ut som spelet fryste precis innan stora explosioner.
Postad 06 September 2007 - 17:53
hedda
hedda
275 inlägg
Jag har blivit så skeptisk mot screenshots efter den senaste tidens artiklar om allt Photoshop-jobb som görs på dom.
Tyckte videon som morlock länkade till var klart imponerande om det bara inte vore så att spelet skulle släppas i år! Känns som om det skulle behövas lite mer tid till polish (kikaren igenom väggen, framerate m.m)
Men jag tror hursomhelst att det här kommer bli ett toppenspel! Gillar bara inte när det släpps screenshots som ser fantastiska ut osså möter inte spelet mina förväntningar grafiskt sedan. Påminner mig alltför mycket om C64-tiden när spelkartongerna hade omärkta screenshots från arkad-versionen på baksidan!
Snacka om blåsning
Postad 06 September 2007 - 18:29
Transform
38133 inlägg
Tja, filmen är ju från en alphaversion (står t o m i beskrivningen) så polish är inget jag oroar mig för. De försenar dessutom hellre ett spel än att släppa det med så uppenbara framerateproblem. Speciellt om det är ett stort spel som Battlefield. Det är trots allt DICE vi snackar om och inga amatörer. Förhoppningsvis är detta bara en väldigt tidig version
Alpha. Snoopers (från Xboxyde) Ok, I got to say that I saw the game running during Leipzig, and if the graphics aren't that clean - YET, the game looked incredible nevertheless. It runned fine (for an alpha build, that is), the graphics were beautiful, and most importantly, the engine seemed very dynamic. Best destructions in a game I have ever seen - I'm not even exaggerating - and totally relevant gameplay-wise. One of my favourite surprises of the Game Convention.
Postad 06 September 2007 - 18:42
Über-Guru
14825 inlägg
Ja det låtet bra iaf, DICE ska leverera och brukar göra det.
Postad 08 September 2007 - 14:05
SPL
SPL
34 inlägg
Ett spel som jag kommer hålla minst ett öga på. Vem säger att man måste använda en motorsåg för att röja lite skog?
Postad 03 November 2007 - 13:10
Transform
38133 inlägg
Ny preview från IGN. Det här verkar spännande, HDR Sound The newest Battlefield is doing more than just throwing destructibility into the gameplay mix, it's also changing the way war games are portrayed through the use of aural stimulation; the team at DICE calls it HDR sound. Just as light doesn't look the same when you're indoors as when you're outside using HDR lighting, HDR sound changes the way gunshots, explosions, and even speech sounds when in different surroundings. In other words, the feeling of rattling off a few clips indoors will leave your ears ringing just as it should. http://xbox360.ign.c...2/832229p2.htmlBattlefield: Bad Company is a serious step forward for the series. One that EA hopes will endear the Battlefield name to more console gamers than Modern Combat managed. From what we were shown of the game, which was actually quite a bit, things are progressing very nicely for the planned early 2008 launch. Destructibility, a fully developed solo story, an aural department that would blow the doors off of a rock concert, and the always tantalizing multiplayer will hopefully come together to deliver the Battlefield experience that console gamers have been drooling after for years.
Postad 12 February 2008 - 14:41
lifter
lifter
1542 inlägg
Är det någon som vet någonting om något releasedatum?
På gamereactor står det mars, men de brukar ju inte ens veta vilken veckodag det är så det kan man väl ta med en container salt...
Postad 12 February 2008 - 15:06
Über-Guru
24891 inlägg
Kan inte stämma isf hade det "gått guld" vid det här laget och isf hade det varit nyheter överallt.
Postad 12 February 2008 - 15:21
Unregistered56e968a9
1431 inlägg
Det blev väl uppskjutet...
Postad 12 February 2008 - 15:38
Über-Guru
24891 inlägg
Hahaha
Postad 12 February 2008 - 20:48
Unregistered01e78752
307 inlägg
Kanske sköt de upp det, för att de kom på att de måste fixa till den klumpiga noll-respons-styrningen som alla andra "battlefield" lider av.
Hursom... Verkar intressant med ett riktigt single player läge denna gången iaf (om de nu har kvar det och jobbat med den ideen, evigheter sedan orkade läsa några "news" om det spelet).
Postad 12 February 2008 - 20:54
1431 inlägg
Well, I kind of thought... you know... that it was embedded.
Postad 12 February 2008 - 22:03
Unregistered6fb5a100
2517 inlägg
Har de sagt något om PS3vs360 versionerna? Bygger de från grunden och upp till båda eller? Vorre drygt om PS3 fick en kass port. Det har ju hänt förr nämligen.
Postad 12 February 2008 - 22:11
Transform
38133 inlägg
Deras Frostbitemotor är byggd för både och: Built from the ground up for Xbox 360, PlayStation 3 and Multi-core PCs with DirectX 9 Shader Model 3 & Direct3D 10 and designed to be used in future DICE games.
Postad 28 February 2008 - 16:14
asbra
asbra
680 inlägg
Lite nya läckra gameplay-clip släppta idag. Spana på gametrailers.com
Postad 28 February 2008 - 17:33
lifter
lifter
1542 inlägg
Postad 28 February 2008 - 18:37
bananplanta
bananplanta
2143 inlägg
Mnja, ska det vara nåt det här?
Postad 28 February 2008 - 22:06
Rasken
Rasken
192 inlägg
Ser ju kanonbra ut. Det påminde ju inte så lite om COD4 grafikmässigt och det är ju inte direkt negativt. Sen att man kan spränga väggar och annat skräp gör det bara ännu mer lockande. Undrar vad guldtackorna ska vara bra för, är det något pengasamlande? Jaja, blir väl ett köp, fast det beror lite på vilket av detta och Mercenaries 2 som kommer först.
Postad 28 February 2008 - 22:52
Unregistered6116c5cb
531 inlägg
Haha, undrar vad alla som ogillar noobtuben i CoD4 kommer att tycka om detta.
Postad 28 February 2008 - 23:19
lifter
lifter
1542 inlägg
 Bananplanta, du och jag i BFBC?
Postad 28 February 2008 - 23:54
bananplanta
bananplanta
2143 inlägg
Mjaaaa, vet inte det jag, då får du nog sweettalka lite värre än så
Tycker vapnen ser väldigt rekylfria ut i en del videos, hoppas verkligen att de inte blir det. COD4 tycker jag är ett utomordentligt bra exempel på både lagom rekyl och riktigt bra användning av vibfunktionen i handkontrollen.
Angående guldtackorna så nämnde han väl i ena videon att det var nåt som SP gick ut på, dessutom skulle det vara en ny spelform i MP.
Postad 29 February 2008 - 10:02
Unregistered801fc485
510 inlägg
Battlefieldserien har ju aldrig varit något bra på vapenbiten, tyvärr. Förhoppningsvis har det ändrats.
Postad 29 February 2008 - 10:04
Xunder
Xunder
137 inlägg
Hoppas på det samma. Ett av de största problemen med Battlefield 2 till pc var att vapnen hade ingen rekyl alls och allt kändes ungefär "plastigt". Kändes och såg ut och framför allt lät som om man höll och sköt med en soft air gun, inte kul alls. Men hoppas det är fixat det i BC. Men ska jag vara ärlig har jag inga höga förväntningar på detta spel. Men forstbite är intressant / Alex
Postad 29 February 2008 - 10:28
Evil Nicke
Evil Nicke
138 inlägg
Läste lite i aftonbladets spelblog o där hade han varit på nån visning av Bad company och de sa att hade sneglat lite på black angående vapnen så jag antar att det kommer bli riktigt bra med rekyl o volym.
Postad 29 February 2008 - 12:40
Unregistered24c8cfe3
468 inlägg
Kong har provspelat Bad Company, och de verkar ganska positiva. Kong testar Bad Company.
Postad 29 February 2008 - 12:56
Über-Guru
24891 inlägg
Release i sommar ngngång. Finns inget exakt datum.
Postad 29 February 2008 - 13:00
510 inlägg
/ Alex
Det har varit så enda sedan BF1942s tider, redan då fanns det ingen känsla i vapnena. Detta vägdes ju visserligen upp av det annars så galet grymma spelet  Kommer ihåg när man lirade banan "Berlin" över LAN när man låg och sniperade (nytt ord?) sina polare uppe i dom sönderbombade husen. De var tider de  Jag kan ju tycka att DICE borde ha fattat galoppen vid det här laget.
Postad 29 February 2008 - 13:23
PsychoCheF
PsychoCheF
1353 inlägg
meeeen.... tänker de inte släppa detta till pc alls?
Postad 29 February 2008 - 13:50
Xunder
Xunder
137 inlägg
Nej endast till Xbox360 och Playstation 3, om jag har fattat rätt. frosse: Jo håller med. Både BF1942 och BF2 var roliga spel, men jag tappade lusten att spelet spelen ganska fort pga den dåliga känslan. Hoppas så jäkla mycket att dem har fixat det till BC / Alex
Postad 29 February 2008 - 14:12
Über-Guru
24891 inlägg
Det är ett EA spel. Det kommer nog till PC så småningom. Hänger nog på hur det säljer till PS3 och 360.
Postad 04 March 2008 - 14:37
510 inlägg
Har vi fått något datum än? Vissa sidor säger runt 26 mars, andra så långt bort som juni?
Postad 04 March 2008 - 16:09
Coistrel
Coistrel
804 inlägg
Tror inte det är den 26 mars.
Postad 04 March 2008 - 17:14
Unregisteredf664f8f0
171 inlägg
ska lätt köpas då BF2 är det grymmaste online spelet någonsin!
Postad 04 March 2008 - 17:41
Unregistered2b236a0e
697 inlägg
BF 1942 är ett av de roligate onlineliren jag spelat. Framförallt när man körde capture the flag på de större banorna med flygplan och man landade inne i fiendens bas hoppa ur och tog flaggan och sedan flög iväg, ibland slutade det dock att man flög iväg i ett brinnande plan  då fick man ta fallskärmen och landade oftast mitt ute i ingemansland med vetskapen att man var jagad av både pansarvagnar och stridsflygplan. På nåt sätt var det skoj med alla buggarna som fanns också, tex att man kunde köra på någon med flygplanet så hoppade denna in om denne tryckte (use) och det fanns ledig plats i planet.
Redigerat av Unregistered2b236a0e, 04 March 2008 - 17:44.
Postad 04 March 2008 - 20:25
510 inlägg
Gud va skönt lir  ska leta fram skivorna och installera det igen!
Postad 16 March 2008 - 22:59
Shawty
Shawty
51 inlägg
Okej jag har aldrig lirat konsol utan tyckt att spel ska spelas på dator .. tycker till viss mån det fortfarande, men eftersom jag ska köpa en fet TV så vet jag redan nu att jag kommer sitta där och lira Bad Company i sommar  Frågan är , eftersom PS3 är så mycket dyrare, blir det exakt samma grafik och flow på en 360 eller är det att jämföras med en starkare respektive svagare speldator som inte kan lira på samma grafik och FPS ? Jag vet jag e n00b
Postad 16 March 2008 - 23:27
Transform
38133 inlägg
Japp. Eller kanske marginellt bättre på 360, brukar vara så.
Redigerat av Zoiler, 16 March 2008 - 23:27.
Postad 17 March 2008 - 12:46
eKeD
eKeD
1 inlägg
kommer få detta spel den 27 mars tror jag  ska bli kul på xbox 360
Postad 17 March 2008 - 16:04
Transform
38133 inlägg
Eh, hur då? REDWOOD CITY, Calif.– March 13, 2008– DICE, a studio of Electronic Arts Inc. (NASDAQ: ERTS) today announced the multiplayer beta test for Battlefield: Bad Company on the Xbox 360™ video game system from Microsoft®. IGN Founders’ Club and IGN Insider will offer keys to members and the public in North America and Europe to participate in the multiplayer beta test starting March 17 provided by IGN’s popular game download site FilePlanet ( http://www.fileplanet.com). In addition, keys will also be available through IGN Entertainment’s gaming Web sites including IGN.com, GameSpy, TeamXbox, Planet Battlefield and Voodoo Extreme. Battlefield: Bad Company will launch on the PLAYSTATION®3 computer entertainment system and Xbox 360 in June 2008.
Postad 17 March 2008 - 17:10
asbra
asbra
680 inlägg
Ge mig ett Beta-pass  Den våta drömmen. Borde vara som Call of duty 4-betan. Alla får vara med
Postad 17 March 2008 - 19:51
Unregistered274dc322
167 inlägg
Det skulle släppas nu i Mars. Men som sagt, releasen är framflyttad till 2008-06-19. Tyvärr
Media & Mediauppspelning
Spelkonsoler & PC-spel
Xbox
