Pioneer BDC-202
43 svar till detta ämne
Pioneer BDC-202 / BDC-S02 (Optiska enheter för datorer) 1 8.090908 (10) Inga priser
Postad 28 July 2007 - 00:51
Unregisteredd5dddbb3
  • Unregisteredd5dddbb3
  • 64 inlägg
Ser mycket intressant ut för det priset tycker jag...
http://www.cdrinfo.c...20773&PageId=33
http://www.dvdmarkna...talog/2195.html
Redigerat av Unregisteredd5dddbb3, 31 July 2007 - 16:44.
Postad 28 July 2007 - 02:18
Addex
  • Addex
  • 1902 inlägg
Moving on to Blu-Ray support, we welcome the drive's ability to play back Blu-Ray movies as well as read BD-R /RE media, including dual-layer BD-Rs (50GB). With the appropriate PC configuration, the Pioneer BD-202 will transform your computer into a Blu-ray entertainment home PC.
With the majority of the Blu-Ray burners currently available for around $500, and the boom in the high-definition movie production, especially in the U.S., Pioneer seems to have wisely decided to focus on Blu-Ray playback support for the PC with the specific model. Priced at around $300, the BDC-202 (BDC-S02 retail) could still be considered as expensive for the masses, but it could definitely replace your current DVD burner in your high-end PC. The drive will be introduced in Europe and the U.S. markets around the end of June.
The generally high performance of the Pioneer drive, especially considering that we tested a Pre-production sample, leaves us with no option but to give it our Editor's Choice Award.
Very nice! Perfekt för de med HTPC.
Redigerat av Addex, 28 July 2007 - 02:18.
Postad 31 July 2007 - 13:31
  • 64 inlägg
Från http://www.avforums....ad.php?t=546186
Re: Pioneer BDC-202
I can concur that using 'AnyDVD-HD' does remove region locking on the Blu-Ray drive.
I have discs from both regions and they play just fine.
Re: Pioneer BDC-202
As for the drive what can I say, works fine using PowerDVD + AnyDVDHD to remove HDCP.
Redigerat av Unregisteredd5dddbb3, 31 July 2007 - 13:31.
Postad 31 July 2007 - 17:10
necrio
  • necrio
  • 646 inlägg
woohoo, remove region + hdcp.. nice find :-)
graffekort med hdmi ut är allt som fattas.
Postad 01 August 2007 - 00:02
Scrapanatchi
  • Scrapanatchi
  • 1061 inlägg
blir nog ett köp ! underbart
Postad 03 August 2007 - 13:21
ferna
  • ferna
  • 179 inlägg
Aj aj aj, vad sugen jag blev.
Denna tillsammans med ett HD2400 eller 2600 så har man äntligen en komplett HTPC.
Konstigt att den bara finns hos en butik, och en tämligen okänd (för mig) oxo
Postad 03 August 2007 - 13:43
didjital
  • didjital
  • 305 inlägg
Det är väl en ny produkt. Kolla eu-priserna, där ligger den en femhundring lägre. Finns dessutom i en bundle-variant som heter S02, har för mig att där ingår även programvara samt en bd-film, men i övrigt är specarna exakt lika.
Postad 04 August 2007 - 23:25
isolde
  • isolde
  • 70 inlägg
Hejsan !
Skall köpa denna drive endast orolig för det här S-ata interface, är inte så kunnig på pc så jag undrar om det är något problem ?
Isolde
Postad 10 August 2007 - 07:42
nombz
  • nombz
  • 480 inlägg
Jag har köpt en BDC-202 nu och den sitter tryggt i HTPC:n.
Såg min första blu-ray film igår kväll :huh:
AnyDVD HD för att bli av med kryptering etc, PowerDVD 7.3 för uppspelning. Funkar finfint.
Nu skall jag bara koppla in HD-DVD driven också.... Och så klart skaffa MATERIAL att titta på också :)
Postad 10 August 2007 - 08:40
didjital
  • didjital
  • 305 inlägg
Härligt!
Hur är ljudnivån från den?
Postad 10 August 2007 - 10:36
nombz
  • nombz
  • 480 inlägg
Den är inte tyst(vid läsande av DVD, blu-ray vet jag inte, då hade jag anläggningen igång...). Men jag antar att man kan dra ner max speed på den för att tysta den.
Postad 15 August 2007 - 20:58
Prism
  • Prism
  • 856 inlägg
Såg min första blu-ray film igår kväll :)
Nu skall jag bara koppla in HD-DVD driven också.... Och så klart skaffa MATERIAL att titta på också :D
Berätta gärna hur det gick att kör med både HDDVD & Bluray spelare i PowerDVD, skriva också hur du upplevde ljudnivån när du körde Bluray filmer.
Redigerat av Prism, 15 August 2007 - 20:59.
Postad 16 August 2007 - 10:00
Addex
  • Addex
  • 1902 inlägg
Såg min första blu-ray film igår kväll :blink:
Nu skall jag bara koppla in HD-DVD driven också.... Och så klart skaffa MATERIAL att titta på också :P
Pioneer BDC-202 läser bara BD/DVD/CD inte HD DVD.
The BDC-202 reads both single and dual-layer Blu-ray disc formats and provides high-speed read and write compatibility for a wide range of DVD and CD discs.
Postad 16 August 2007 - 20:23
Prism
  • Prism
  • 856 inlägg
Addex, om du kollar igen vad nombz skrev så hade han även en HDDVD spelare, och min fråga var hur PowerDVD klara att att hantera båda formaten samtidigt i samma dator.
Postad 22 August 2007 - 14:49
urbfre
  • urbfre
nombz, du som har installerat.
Är det S-ATA eller IDE? Dustin skriver IDE men på andra ställen står det S-ATA. Om det är S-ATA, vilket jag förutsätter hur ansluter man till MB? På en S-ATA plats där "normalt" en HDD sitter? Vet du om det finns alternativ lösning, utifall HDD fyller alla S-ATA och man vill slippa trassla?
Postad 12 September 2007 - 08:00
dabman
  • dabman
  • 325 inlägg
Dustin skriver IDE, men det är SATA. Kollega som har en sådan, beställd från Dustin och det är en SATA.
Postad 12 September 2007 - 08:12
urbfre
  • urbfre
OK!
Någon som vet om det finns alternativ för att skapa en S-ATA utifall alla S-ATA på MB är fyllda med HDD?
USB och FW kan man ju tillskapa i en PCI-plats, t.ex.
Postad 12 September 2007 - 20:16
Grower
  • Grower
  • 208 inlägg
Alltså, denna spelare är knappast en kombo-drive för HD-formaten, enbart Blu-ray.
Skulle varit perfekt om den hade klarat HD-DVD också.
Redigerat av Grower, 12 September 2007 - 20:26.
Postad 04 October 2007 - 09:19
Andi_One
  • Andi_One
  • 3008 inlägg
Vem har sagt att det är en kombo-drive då?
Ja är grymt sugen på att köpa mig en faktiskt.
Har Toshibas HD-DVD spelare i min burk nu.
Blir perfekt för mig med en BD spelare oxå så att man
är klädd :)
Postad 07 October 2007 - 10:42
TheSwede86
  • TheSwede86
  • 443 inlägg
OK!
Finns ju SATA kontrollerkort precis som du snackade om USB/FW så är det bara ett PCI-kort som installeras och ger mer SATA-platser.
Kontrollera dock att det är PCI då vissa är PCI-E.
Ex: Promise SATA300 2-portar 3g - Retail
Postad 14 November 2007 - 01:04
Liemannen
  • Liemannen
  • 12 inlägg
Hm.. Jag som köpt en 'riktig' blu ray-spelare blev ju sugen på en i datorn istället. Sparar ju lite pengar på det sättet :blink:
Är det bara jag som är för optimistisk? Jag ser inte direkt några nackdelar med att ha en i datorn istället för i bokhyllan.. Samma kvalitét, likadant ljud, etc etc.. Om man såklart kör med HDMI och kanske en optisk ljudutgång.
Speciellt för de som snart skall uppgradera datorn i alla fall :lol:
Är det någon som har lite synpunkter på det?
Postad 14 November 2007 - 07:39
dhanjel
  • dhanjel
  • 2495 inlägg
Har med denna spelaren och den fungerar kanon. AnyDVD kan dessutom ställa ner hastigheten på spelaren.
Postad 15 November 2007 - 21:02
bracken2
  • bracken2
När jag försöker köra min första blu-ray film (the fifth element, nya utgåvan) så kommer det upp detta meddelande.
A critical component of the player requires periodic updates. New movies could fail to play if the critical component is not updated promptly. Would you like to update now? Jag svarar OK och då kommer detta meddelande upp : Player applikation update, Update progress finished OK. Sen händer inget mer och när jag försöker starta filmen igen så blir det samma sak. Jag använder Any DVD HD 6.1.9.7 & Power DVD 7.3 Ultra. Nån som vet vad som felar? :)
Postad 17 November 2007 - 17:37
kotten33
  • kotten33
  • 1039 inlägg
Denna skall väl finnas i både beige och svart, men de flesta butikerna verkar endast ha den i svart. Finns den inte i beige längre?
Hade tänkt att ha den i ett AntecFusion (silver) chassie och då är det väl bättre med en beige, men förresten, det kanske finns någon lucka på chassiet som döljer värgen på spelaren.
En viktig sak är ju ljudnivån när man spelar upp en BD film, så inte spelaren går upp i var och för en massa oväsen.
Postad 05 December 2007 - 20:26
elarn
  • elarn
  • 22 inlägg
Tjena!
Jag har en rabattkod om det är någon som vill sänka priset på det ni handlar med 10 % på www.dvdmarknaden.com
Koden är: ciuoiosu
Ha det bra!
Postad 12 December 2007 - 02:10
Unregistered035dce0b
  • Unregistered035dce0b
  • 549 inlägg
Ja Tänker Köpa Den...Precis Köpt Hddvd spelaren till 360n så denna kommer nog bli bra i nya htpc bygget.
Postad 23 December 2007 - 22:22
Tompa123
  • Tompa123
  • 524 inlägg
Har precis köpt den som julklapp åt mig själv. Tyckte att jag behövde den. Jorå, lugna nu - har köpt en massa andra julklappar åt de nära och kära också. :)
Funkar kanonbra. Hittills har den inte stört mig iaf.
Kör också en PowerDVD Ultra 7.3...
Redigerat av Tompa123, 23 December 2007 - 22:22.
Postad 24 December 2007 - 20:40
bjornf
  • bjornf
  • 223 inlägg
Går det att få ut 1080i på blu-rayfilm på något enkelt sätt? I htpc alltså, Min Z-3 klarar inte 1080p.
Postad 05 January 2008 - 20:27
Frixos
  • Frixos
  • 73 inlägg
Till er som har den här:
Hur mycket låter den när man typ stoppar i en skiva? Dvd, cd, bd?
Bränner den dvd, cd bra? Hur snabbt går det, låter det mkt?
Postad 07 January 2008 - 14:45
Unregistered590e4d07
  • Unregistered590e4d07
  • 25 inlägg
Projektorn skalar automatiskt ner från 1080p till 1080i, den låter typ inget..
Postad 07 January 2008 - 23:03
Tompa123
  • Tompa123
  • 524 inlägg
Jag måste säga så här:
Film = låter inget.
Musik = alldeles för mycket.
Gudskelov har jag nu också en HD-DVD (Toshiba's läsare). Den låter inget vid musikuppspelning heller.
Redigerat av Tompa123, 08 January 2008 - 21:11.
Postad 28 January 2008 - 17:25
Tottesloda
  • Tottesloda
  • 27 inlägg
Jag tycker den surrar för mycket :rolleyes: och får inte tyst på den med any dvd...
någon som har något tips?
Postad 09 February 2008 - 23:18
Tompa123
  • Tompa123
  • 524 inlägg
Jag tycker den surrar för mycket :lol: och får inte tyst på den med any dvd...
Har percis köpt en HDDVD-spelare Toshiba HD-EP30. Kommer vid nästa löning köpa, förmodligen Samsung BD-P1400. Står inte ut med surret när man gör annat än kollar på Blu-Ray med den här spelaren. Dessutom är skillnaden så stor bildmässigt mellan min Toshiba interna HDDVD med standalone-spelaren att jag bara måste ha en standalone Blu-Ray också. Sen blir det tebax med min gamla inte alls bullriga Samsung SATA-DVD-bränare i datorn...
Redigerat av Tompa123, 09 February 2008 - 23:23.
Postad 15 February 2008 - 12:19
menhallå
  • menhallå
  • 1014 inlägg
Någon som testat denna spelare tillsammans med :
DVDFab HD Decrypter 4.0.6.2: från http://www.dvdfab.com/free.htm ?
Det skall klara både BluRay och HDDVD och är gratis.
Jag tänkte använda min TVIX för att spela upp film på TV & projektor.
Mvh/menhallå
Postad 24 February 2008 - 14:36
PerssonsPack
  • PerssonsPack
  • 925 inlägg
Jag tycker den surrar för mycket :D och får inte tyst på den med any dvd...
Intressant, använder du PowerDVD som spelare datorn? Vad använder du för grafikkort?
Står ockås i valet och kvalet om jag ska bry mig om BD i HTPC'n nämligen, eller köpa en standalonelirare.
Postad 24 February 2008 - 17:06
ursidae
  • ursidae
  • 26 inlägg
Vad tycker ni om ljudet från spelaren i samband med DVD-uppspelning?
Jag hör ett "tuggande" ljud från spelaren vid DVD-uppspelning, mycket störande. :)
Vid BD-uppspelning hörs inget särskilt.
Postad 25 February 2008 - 18:59
Unregisteredc0be16a0
  • Unregisteredc0be16a0
  • 120 inlägg
Jag kör med BDC-202 samt 360'ns HD-DVD i min HTPC och BDC-202 är mycket tystare än 360'ns HD-DVD, man hör den inte i princip.
Nu har jag inte hunnit testa BDC-202 med vanliga DVD, men jag har å andra sidan en annan DVD-ROM för det som är regfri.
Jag kör inte med Any Dvd, Mediaspelare för HD är PowerDVD Ultra v7.3.3319a.
Stod i valet och kvalet mellan en stationär spelare (Samsung 1400) men valde BDC-202.
Postad 25 February 2008 - 21:13
ursidae
  • ursidae
  • 26 inlägg
Jag skulle vara tacksam om du kunde prova att spela standard-DVD i Pioneern, så jag får veta om det endast är mitt ex som beter sig så.
Jag håller med om att läsning av BD verkar hålla en låg ljudnivå. (Jag har inte lyssnat specifikt efter ljud från spelaren, men systemet i övrigt är ganska tyst så skulle den ha gjort något väsen av sig borde jag hört det.)
Postad 26 February 2008 - 18:51
  • 120 inlägg
Jag testade Casino Royale (DVD) och den lät lite mer i menyn, men när filmen började så var den nästen lika tyst, den lät lite mer.
Postad 04 April 2008 - 19:03
ursidae
  • ursidae
  • 26 inlägg
Jag kan tillägga att jag skickade tillbaka min spelare, och fick ett nytt ex.
Den låter dock likadant som den förra jag hade. :)
Fick följande svar från Pioneer när jag mailade till [email protected]:
Hei Björn,
Dette har ikke vært et problem som vi kjenner til. Hvis du har byttet driven hos din ÅF kan det være at du har fått 2 enheter fra samme bacth som utviser et slikt problem.
Venligts prøv Nero Drive Speed og lås lesehastigheten for DVD på lav hastighet for å se om dette hjelper. Nero Drive Speed kan lastes ned her: http://www.cdspeed2000.com/
Med vennlig hilsen / kind regards
Servicon AS
Tom-Erik
Provade det som föreslogs, men det programmet verkar inte funka alls. Hursomhelst tror jag inte problemet har med läshastigheten att göra. Det är ju inget vanligt CD/DVD-"surrande" som jag vill bli av med.
Jag har dock en fundering om det kan ha att göra med det DVD-uppspelningsprogram jag använder (PowerDVD Ultra), det kanske läser skivan på något olämpligt sätt? Vad använder du för program, trance4m?
Postad 08 July 2008 - 09:20
sjogren5
  • sjogren5
  • 52 inlägg
Bumpar lite ... Någon som vet om det följde med en molex-sata adapter med spelaren ? Eller blir det till att försöka få tag på en vid sidan av .
Postad 02 August 2008 - 14:23
kalle_22
  • kalle_22
  • 276 inlägg
jag har hentat hem powerdvd men när jag ska spela upp en blu-ray film så kommer det, A disc with an unsupported format in drive D:
Postad 06 August 2008 - 17:10
ursidae
  • ursidae
  • 26 inlägg
kalle_22:
Det är PowerDVD Ultra du behöver för att spela upp BD, vanliga PowerDVD duger inte.
sjogren5:
Jag fick inte med någon adapter vad jag minns. (Vad exakt menar du för adapter? Strömkontakten?)
Köpte iofs produkten som "bulk" (som man väl oftast gör), köper man den som "retail" är det kanske annorlunda.
Problemet med tuggande ljud vid DVD-uppspelning som jag skrev om för tidigare visade sig bero på en bugg i PowerDVD. Det verkar ha blivit rättat i en av patcharna (använder dock MediaPortal för DVD-uppspelning nu).
Redigerat av ursidae, 06 August 2008 - 17:13.
Postad 15 March 2009 - 12:21
pgg
  • pgg
  • 284 inlägg
Köpte den här spelare för några veckor sedan och har funkat bra. Dock så stör jag mig nått otroligt på att den söker skivan, eller nått, var 5:e sekund om jag har en bluray skiva i.
Är det någon som har samma problem? Och kanske har löst det?
Lite irriterande att man måste ta ut skivan för att få tyst på ****t.
