Vad säger ni om denna basen då den kanske funkar???
Car power by Monacor SONIC-15
A clear reproduction, very low fundamental resonance, very, very high volume, and stable even at the highest levels: that is how a state-of-the-art car audio bass speaker should perform even in smaller cabinets. The new SONIC bass speakers perfectly meet those requirements and are available at such a favourable price which for these high-tech woofers can only be realised by CARPOWER.
Top-class car HiFi subwoofer, 2 x 800WMAX, 2 x 400WRMS, 2 x 2Ω
Bass speaker of highest power capability with a diameter of 38cm (15"), dual voice coil, stable diecast basket, the carbon fibre cone features an exclusive rubber surround of long excursion and is driven by a really convincing motor system. The 75mm voice coil allows a sensationally wide linear excursion (+/- 25mm) at full drive and the sound pressure which results in the bass range is more than impressive. The most suitable cabinets for this large bass speaker range from closed cabinets with an extra small size of 40 litres to bass-reflex cabinets of 80-100 litres for maximum power.
Car&HiFi 02/2006: rating: top class
Price/performance: very good
"Not only loud, but of extra high volume; this speaker is absolutely nothing for weaklings! When it starts to work, no eye remains dry."
Klang+Ton 06/2006
"The SONIC-15 is one of a very few speakers which features efficient quality for closed subwoofers. In addition, it meets every requirement made on power capability, stability, and technology. This is not only a bonus, but makes this speaker an ideal component."
Technical Facts Speakers
Impedance (Z) 2 x 2Ω
Resonant frequency (fs) 25Hz
Max. frequency range f3-300Hz
Music power 2 x 800WMAX
Power rating (P) 2 x 400WRMS
SPL (1W/1m) 88dB
Suspension compl. (Cms) 0.13mm/N
Moving mass (Mms) 310g
Mech. Q factor (Qms) 10.86
Electr. Q factor (Qes) 0.52
Total Q factor (Qts) 0.50
Equivalent volume (Vas) 126 l
DC resistance (Re) 2 x 1.9Ω/1 x 3.8Ω
Force factor (BxL) 19Tm
Voice coil induct. (Le) 2 x 0.7mH/1 x 2.8mH
Voice coil diameter Ø 75mm
Voice coil former Kapton
Linear excursion (XMAX) ±25mm
Eff. cone area (Sd) 830cm2
Magnet weight 180oz.
Weight 15.6kg
