Benq W9000 rs232 styrning?
1 svar till detta ämne
Postad 27 November 2007 - 08:06
Unregisteredeee306cc
  • Unregisteredeee306cc
  • 449 inlägg
Någon som vet var jag får tag på protokollet för att styra Benq w9000 via serieporten?
Postad 28 November 2007 - 18:33
stcrambo
  • stcrambo
  • 9 inlägg
Varsågod ;)
BenQ Projector RS232 code for OPLUS Version
Code Function Comment
X001X Power on/off System operation
X003X Menu OSD operation
X004X Enter OSD operation
X005X Exit OSD operation
X006X Up OSD operation
X007X Down OSD operation
X008X Left OSD operation
X009X Right OSD operation
X041X Load preset 'cinema' mode Load settings
X042X Load preset 'home theater' mode Load settings
X043X Load preset 'family room' mode Load settings
X044X Load preset 'photo' mode Load settings
X045X Load preset 'gaming' mode Load settings
X046X Load from user's memory 1 Load settings
X047X Load from user's memory 2 Load settings
X048X Load from user's memory 3 Load settings
X049X Load default of all user OSD Load settings
X091X Lamp ECO Mode (200W)
X092X Lamp Normal Mode (250W)
X093X Disable Auto Source Searching
X112X Color Temp: LampNative
X113X Color Temp: Warm
X114X Color Temp: Normal
X115X Color Temp: Cool
X116X Color Temp: User1
X117X Color Temp: User2
X118X Color Temp: User3
X131X CVBS Input source select
X132X S-Video Input source select
X133X RGB-HD Input source select
X134X HDMI Input source select
X135X YPbPr 1 Input source select
X136X YPbPr 2 Input source select
X137X YCbCr 1 Input source select
X138X YCbCr 2 Input source select
