The information below pertains to the product upgrade for the Harman Kardon® AVR 247.
Harman Kardon AVR 247 SOFTWARE UPGRADE INSTRUCTIONS
Thanks to innovative design technologies, the software that powers your AVR 247 can be upgraded with new features and performance improvements. This is just one reason why Harman Kardon products have earned the Designed to Entertain designation: They're kept up to date even after you've brought them home!
Please note that depending on when your AVR was manufactured, it may have already had the latest software installed at the factory. To see if its software requires an upgrade, please follow these steps:
With the AVR turned on, press the 1, 2, 3 and 4 buttons on the remote in that order; then press the SET button.
After a short pause, the software version number will appear on the AVR's front-panel display.
If the top line reads "02-02-2008 02" you have the current software and no further action is required.
If the version number is lower than the number listed above, click on the button below to download the most current software version.
This software update addresses the following issues:
LFE output levels willnow equal regardless of the input digital source or signal type.
When the input source connection is HDMI, the surround mode selection will now react to the first button press on the remote.
In addition, this update package contains allthe benefits of previous upgrades. In the event that you have not installed the previous software upgrade for your AVR, the following benefits are also installed:
The ability to process 7.1 PCM digital audio streams sent to your AVR over an HDMI connection. This makes your AVR compatible with the latest high-resolution disc players.
The switching of 1080/24p signals directly from a source to the video display connected to your AVR.
The display of closed-caption information from analog sources via the S-video outputs.
Improved HDMI connectivity.
Följ denna länk nedan:
http://www.harmankar.....DEBFK YyXw==#Länk till harman/kardon
OBS! Läs igenom all information noga
Denna tråd gäller endast AVR-247. Jag kommer inte ha möjlighet och besvara frågor kring denna. Se det som information, och som sagt läs igenom all information innan uppgradering.
The information below pertains to the product upgrade for the Harman Kardon® AVR 347.
Harman Kardon AVR 347 SOFTWARE UPGRADE INSTRUCTIONS
Thanks to innovative design technologies, the software that powers your AVR 347 can be upgraded with new features and performance improvements. This is just one reason why Harman Kardon products have earned the Designed to Entertain designation: They're kept up to date even after you've brought them home!
LFE output levels will now equal regardless of the input digital source or signal type.
When using the Zone II remote with an A-BUS module, main room operation is no longer interrupted when selecting "Tuner" as the source with the "AM/FM" button.
In addition, this update package contains all the benefits of previous upgrades. In the event that you have not installed the previous software upgrade for your AVR, the following benefits are also installed:
Följ länken nedan:
http://www.harmankar.....mDEBFK YyXw==Länk till harman/kardon
Jag kommer inte ha möjlighet och besvara frågor kring denna tråd. Se det som information, och som sagt läs igenom all information innan uppgradering.
Hälsningar
Joakim
Harman Consumer
Följ länken nedan:
Hälsningar
Joakim
Harman Consumer
Redigerat av Unregistered43749, 23 June 2008 - 11:52.
