Octagon SF918 HD
72 svar till detta ämne
Postad 19 June 2008 - 20:24
Unregistered30519
Unregistered30519
20 inlägg
Denna kommer inom en snar framtid finnas i mitt hem..
Var först inne på DM800 men efter att ha läst vad denna boxen klarar av så är jag helt såld!!
CoZ
An elegant HDTV digital satellite receiver
With LG tuner, 32-bit 1000 MHz processor and 400 MB of memory provides
OCTAGON the HD SF 918 for a strong and first-class reception.
Enjoy the HD quality with less than 1 sec switching time of the programmes.
With the Ethernet LAN connectivity, USB, eSATA and HDMI, they have the choice of agony
Over the remote controlled tuner gain (AGC value) also enables the weak channels without interference to receive this receiver was unique.
Individual color settings (brightness, contrast, color saturation) to its Sendungsart (film, news, sports, users) allow them the best image quality.
Only Arte features:
1000 MHz - 32-bit processor
400 MB RAM
10 000 places (TV & Radio)
Ethernet LAN - 10/100 Mbps
E-SATA port
USB 2.0
HDMI connector
VFD display (Dot Matrix Vacuum Fluorescent Display)
2 x CI slots for modules
Smart Card reader for encryption CONAX
Features:
Digital Satellite Receivers MPEG 4/H.264 & DVB-S2 (DVB) compatible
Format Resolution: 576p/720p/1080i
3D user-friendly OSD menu
Clear and simple on-screen interface
Color Adjustment: color, brightness, contrast and color saturation
Bedienfreundlicher EPG (electronic program guide) for the display of program information and program preview
254 satellite programmable
Level control DiSEqC 1.0, 1.1, 1.2 and 1.3 (USALS)
LNB voltage 13/18V & 14/19V adjustable in long lines
Video format in 4:3, 16:9 and letterbox
Zoom & pause function
Recall function: storing the last 20 selected stations
Find function: stations can be found alphabetically
Program timer function
Sleep timer function
8 favourite lists for the organization of TV programmes (film, news, sports, music, children, drama, family, Misc.)
8 favourite lists for the organization of radio stations (film, news, sports, music, children, drama, family, Misc.)
Parental Controls for menu and programs
Several clear channel sorting functions such as delete, rename, move and block
Backup & restore the setting (Backup / Restore)
8 buttons on the front panel
Front buttons on / off switch
Support for Teletext and subtitle
Software - Updates on USB/RS-232 (PC-STB / STB STB)
Data transfer: receiver to receiver
Menu in 24 languages
Games menu: Sokoban, Snake, Tetris, Mines, Slot Machine, Othello
Calendar and calculator function
Automatic NTSC / PAL detection
Very fast channel search
Multi-Search: several satellites can be marked and searched
Manual input PID (audio, video and PCR)
Volume difference for each channel individually adjustable
Main background and radio background image changed
Boat image on / off
Div. Selectable menu animations: Stripe, spray, Slide, Fade
Power switch on / off
HF Modualtor
Dolby Digital 5.1 SPDIF output (optical)
2 x Scart (TV / CVR)
2 x RCA audio output (R / L)
1 x RCA video output
Following component (YUV - YPbPr)
Dimensions: 340 x 60 x 268 mm
Weight: about 2.5 kg
Postad 19 June 2008 - 22:37
humlan57
humlan57
1434 inlägg
Först ska Ni veta att jag pratar i egen sak, å att jag är involverad i försäljningen av den här boxen, vilket säkert diskvalificerar mig från att ha några giltiga åsikter..., antar jag. Å andra sidan är jag mer hobbyist än försäljare, å har haft det här som intresse/hobby under lång tid.
Till boxen då.. Den här Octagon HD SF-918 är väl vad de flesta letar efter, åtminstone om man har sat-Tv som hobby, å nöjer sig med en en-tuners mottagare. Som jag ser det, så saknas inte nåt, Conax integrerat, SATA, USB, masvis med minne (jmf med andra boxar) RF-modulator, loop through, undertexter, motorstyrning..., har jag missat nåt!? Mjukvaran då..? Det finns många saker att förbättra, men den är inte sämre än att den bör klara WAF utan att tömma hela pungen.., d.v.s såpor å annat fungerar..., vad jag vet.
Postad 20 June 2008 - 09:50
Mich
Mich
610 inlägg
men Hallå... den klarar ju inte SD formatet som används här (europa), 576i.
Hoppas det är en felskrivning.
PS. Då det bara var en tuner så är det inget för mig.
Postad 20 June 2008 - 10:39
bpl
bpl
858 inlägg
men Hallå... den klarar ju inte SD formatet som används här (europa), 576i. Hoppas det är en felskrivning.
Jorå den klarar 576i, boxen skalar om 576i till 576p...
Redigerat av bpl, 20 June 2008 - 10:40.
Postad 20 June 2008 - 10:42
putta
putta
226 inlägg
Var hittar men den här och pris?
//P
Postad 20 June 2008 - 18:19
bpl
bpl
858 inlägg
Postad 20 June 2008 - 22:15
Mich
Mich
610 inlägg
Det klassar inte jag som att den klarar. Okey det kommer ut en signal, så svensson nöjer sig nog. Dock är det inget för den som vill ha något som fungerar.
Postad 21 June 2008 - 00:44
Jet100
Jet100
34 inlägg
Octagon SF 918 är mycket bra S mottagare.
Postad 21 June 2008 - 09:09
bpl
bpl
858 inlägg
576i är ju alltid bäst på SD om man har en TV som är bättre på att skala bilden... 576i fixas säkert med en mjukvaruuppdatering, det fixades på DM800...
Postad 21 June 2008 - 13:12
Johan_J
Johan_J
11 inlägg
Enligt vad jag har läst så fungerar även CS på boxen
Postad 22 June 2008 - 09:00
humlan57
humlan57
1434 inlägg
Vi har ju direktkontakt med utvecklarna av av mjukvaran, så ev problem eller önskemål kommer Vi såklart att låta dom få reda på. Boxar kan beställas från vårat forum, då en av våra medlemmar fått försäljingsrätten för Skandinavien, å priset är som i Tyskland 2795 sek...
humlan.
Postad 22 June 2008 - 11:00
Unregistereda8f82565
660 inlägg
Postad 22 June 2008 - 11:35
humlan57
humlan57
1434 inlägg
Va e de för forum då?
HS
digitalsat.nu eller ufs910.se Å admin, jag lovar minhembio.com ska få en länk på första sidan hos oss humlan.
Postad 22 June 2008 - 11:46
humlan57
humlan57
1434 inlägg
Med er hjälp så kan Vi göra nåt riktigt bra av det här, men det förutsätter förstås att "feedbacken" fungerar. Så Ni som köper en box, låt oss få reda på problem, direkt Ni hittar nåt. Å när Vi nu ser ut att få ordning på Kathrein UFS-910 boxen, efter div strul med utvecklare av mjukvara, å nu hörsammats på våra krav. Så nog sjutton ska Vi duga till å få ordning på den här åxå
humlan.
Postad 22 June 2008 - 15:20
Unregistered8af05ad5
40 inlägg
Hur i hela tiden räknades klockfrekvensen som står i databladet ut? Det sitter en ARM 920-processor på 295 MIPS i den här boxen, den borde ligga runt 300-350 MHz. Detta måste vara tidernas överdrift när det kommer till försäljningsargument.
Postad 22 June 2008 - 15:38
humlan57
humlan57
1434 inlägg
Ja jag har åxå funderat på det där, å att boxen har ungefär samma prestanda som flertalet andra boxar. Förutom att den här har betydligt mer internminne.. Jag har ju iofs påtalat det här tidigare, men fick inte mycket till gensvar då.., dessutom är jag inte helt säker på hur jmf ska göras.. Men det kan kanske nån annan göra..., alltså vad man vinner resp förlorar med resp processor.. humlan.
Postad 22 June 2008 - 16:10
40 inlägg
humlan.
Ja, visserligen så finns det troligtvis även någon co-processor för AVC/H.264, men det verkar vara en godtycklig översättning mellan olika räknesätt. Här är broschyren för processorn: http://www.conexant....S...681&revid=2
Postad 22 June 2008 - 17:05
humlan57
humlan57
1434 inlägg
Ja då kan Vi vara överens om att det inte är nån större skillnad.., bättre eller sämre blir mest nåt subjektivt omdömme. Förutom minnesstorleken då, å den oförutsägbara utrvecklingen av mjukvara..
Fast jag kan inte låta bli att ha en viss ryggmärgskänsla över den här boxen.. Precis på samma sätt som jag haft av Dreambox å Kathrein.., 20 års erfarenhet kansker mer, ger en viss känsla för vad som är rätt.. Både Dreambox å Kathrein har jag blivit utskrattad om..., nån som vill påstå att jag haft fel nu
humlan.
Postad 22 June 2008 - 21:43
Jet100
Jet100
34 inlägg
humlan.
Tack,Jag ska beställa en Octagon SF918 Hd,varför finns inte Octagon sektion i forumet Digisat??
Redigerat av Jet100, 22 June 2008 - 22:55.
Postad 23 June 2008 - 12:34
Johan_J
Johan_J
11 inlägg
Det finns det men du kanske måste vara inloggad för att se det.
Postad 24 June 2008 - 21:19
Unregistered30519
Unregistered30519
20 inlägg
Helt rätt att man måste vara inloggad.
För övrigt anländer min box i slutet på veckan....
CoZ
Postad 24 June 2008 - 21:52
Han Solo
Han Solo
83 inlägg
Jag har nu också beställt en från "faktor" på digisat forumet! De var skickade från distributören i Tyskland igår så slutet av veckan låter troligt, sweet!
Postad 25 June 2008 - 04:22
Jet100
Jet100
34 inlägg
Tack,man måste vara inloggad.
Postad 27 June 2008 - 15:32
Unregistered30519
Unregistered30519
20 inlägg
Har nu efter lite strul fått boxen att fungera lysande... Har visserligen inget annat att jämföra med men jag är helnöjd än sålänge... Nästa projekt efter sommaren blir att slänga ut fet-tv'n och investera i något roligare.
Postad 27 June 2008 - 17:56
humlan57
humlan57
1434 inlägg
Jämföra med..., tja.., boxen är ovanligt fullsmetad med funktioner, för att tillhöra dom nyföddas skara..., nästan för mycket för att passa mig  Det ska ju ta ett tag att få allt på plats å fungera bra, men här det mest att fortsätta att utveckla, det som redan finns + alla plugins som förstås går att hitta på i all oändlighet.. Men för den som är nybörjare med att ha sat-Tv som hobby, är den här boxen perfekt..., inte helt enkel, men absolut inte för svår, för den som har baskunskaperna att hantera en PC. humlan.
Postad 28 June 2008 - 09:31
humlan57
humlan57
1434 inlägg
Eftersom Vi har direkt-kontakt med utvecklarna av mjukvaran till den här boxen, så har Vi nu lagt till en avdelning där Ni kan rapportera om hittade buggar i den. Ni kan även komma med egna önskemål om innehåll, förbättringar m.m avseende mjukvaran, som Vi då kommer att framföra till utvecklarna. Vår förhoppning är att det här ska leda till en mjukvara, som i slutänden tillfredställer allas behov å krav på, den "perfekta dekodern".
humlan.
Postad 29 June 2008 - 14:30
humlan57
humlan57
1434 inlägg
Nu har utvecklarna av mjukvaran reggat sig på vårat forum, så det går bra att direkt framföra ev problem å önskemål i en egen avdelning, men det måste göras på engelska. Kan Ni inte det, så använd istället den svenska delen, å be samtidigt om hjälp med översättningen. Ni bör då hålla koll på vad som händer, å vara beredda att svar på frågor angående problemet eller vad det nu kan vara.... humlan.
Redigerat av humlan57, 29 June 2008 - 14:40.
Postad 14 August 2008 - 07:23
erito
erito
636 inlägg
Sådär då var den beställd, det är ditt 'fel' humlan  Kommer förhoppningsvis så man kan installera och se lite HD kanaler till helgen. HW spec på Octagon verkar ju bättre än det mesta på marknaden och man får väl försöka hjälpa till att utveckla för boxen. Fler som kör Octagon HD box? Kollar man på displayen så verkar det finnas 1080p stöd planerat, eller så används bara någon standarddisplay som råkar ha 1080p med i texten...
Redigerat av erito, 14 August 2008 - 08:05.
Postad 14 August 2008 - 20:46
magnuse
magnuse
30 inlägg
Finns det planer för DVB-T och eller DVB-C varianter av boxen? Helst vill man ju ha pl-in tuners så att man kan byta själv.
/Magnus
Postad 15 August 2008 - 09:54
humlan57
humlan57
1434 inlägg
/Magnus
Det tror jag inte, då det är en väldigt marginell marknad, i världen. Den delen/marknaden tar ofta kanldistrubitörerna själva hand om, så utbutet av C å T dekodrar kommer aldrig att bli speciellt stort... humlan.
Postad 15 August 2008 - 12:02
erito
erito
636 inlägg
Hårdvaran verkar väldigt bra, men klarar bild-chippet av 1080p? Jag hittar inget om detta.
Anledningen är ju att det skulle vara fint om Octagon kunde spela upp inspelat/lagrat 1080p material från hårddisk. Då skulle min Popcorn Hour bli överflödig
Postad 15 August 2008 - 13:17
humlan57
humlan57
1434 inlägg
Maila Octagon i Tyskland..., tyvärr tror jag dom går på semester nu, så Du får antagligen vänta på ett svar. http://www.octagon-germany.de/humlan.
Postad 15 August 2008 - 15:09
Leatherface
Leatherface
Mega-Guru
7299 inlägg
nu vet jag inte riktigt vad det sitter för chip i Octagon men dom flesta billiga boxar kör med ST 7100 chip och den klarar inte 1080p
Postad 15 August 2008 - 18:19
humlan57
humlan57
1434 inlägg
Det är mycket troligt att det är nån typ av ST 71XX chip, då nästan alla tillverkare använder sig av någon variant av ST 71XX. Men jag hittar inte vad det är just nu, så därför är det säkrast att kontakta generalagenten för att få ett riktigt svar... humlan.
Postad 16 August 2008 - 16:48
Unregistered7a069c9a
59 inlägg
Hittade detta på det tyska forumet. Finns äve bild där. CPU: ARM926 CPU with Linux-compatible MMU, conexant MPEG II HL Decorder CX24170 Edit: Hittade detta i chipets datablad som finns här http://pdf1.alldatas...NT/CX24170.htmlPrimary display supports HD 1080i and 720p picture output with six-plane compositing
Redigerat av Unregistered7a069c9a, 16 August 2008 - 17:18.
Postad 16 August 2008 - 16:53
Leatherface
Leatherface
Mega-Guru
7299 inlägg
mpeg ii? om det stämde så skulle den inte få in många hd kanaler då dom flesta är i mpeg4
Postad 16 August 2008 - 17:53
humlan57
humlan57
1434 inlägg
Klart den klarar MPEG 2, likväl som 1 å 4. Om det nu är en conexant 24170x så är det här specen.
humlan.
Postad 16 August 2008 - 18:14
Leatherface
Leatherface
Mega-Guru
7299 inlägg
självklart klarar den mpeg2 men det såg lite konstigt ut som han skrev det bara...
men då var det som jag trodde den klarar inte 1080p
Redigerat av Leatherface, 16 August 2008 - 18:15.
Postad 16 August 2008 - 19:52
humlan57
humlan57
1434 inlägg
självklart klarar den mpeg2 men det såg lite konstigt ut som han skrev det bara... men då var det som jag trodde den klarar inte 1080p
Jag tror inte många tillverkare kommer att bry sig i 1080p öht, utan det kommer säkert att bli betydligt högre upplösningar istället. 1080p kommer ju aldrig att, så vitt jag vet, bli nån sändningsstandard, så varför lägga nån möda på en parantes.. Skillnaden i bildkvalite är ju så liten, att den är försumbar på de flesta skärmar som används, så jag tvivlar på att nån ser skillnadenmellan 1080i å 1080p på en 50" skärm.., å de flesta har idag inte ens den storleken på sin Tv/skärm. humlan.
Redigerat av humlan57, 16 August 2008 - 19:53.
Postad 16 August 2008 - 19:55
Leatherface
Leatherface
Mega-Guru
7299 inlägg
även om de inte blir 1080p på TV sändningar så finns det HD material från bluray osv som är 1080p...
broadcom chipet i dm800/dm8000 t.ex klarar 1080p men tror inte dom lagt in stöd för det än i mjukvaran men det kommer väl...
och nog ser man skillnad på 1080i och 1080p då 1080i blir 540 linjer på rörliga bilder alltså mindre linjer än vanlig SD sändning.... därför 720p rekomenderas för sport och annat med mycke rörelse... pga den skickar interlaced blir ju bilden filmrigare och ryckigare också då....
Redigerat av Leatherface, 16 August 2008 - 20:12.
Postad 16 August 2008 - 20:56
Huddingebo
Huddingebo
2526 inlägg
Har den HDMI och kan spela in på en extern HD är det ett kap med den prislappen. Kan den spel in material på en extern HD via en Media Extenders, eller kan man enbart spela upp via Octagon?
Postad 16 August 2008 - 21:17
Unregistered10ecfd50
357 inlägg
Ni som har denna kan ni vara vänlig att medela fördelar och nackdelar med denna ?
Funderar på denna eller en vantage 8000.
Vill kunna köra i sovrummet via cs.Men är osäker på om det fungerar på 8000.
Hoppas på kloka svar / tipps
Mvh:ML
Postad 16 August 2008 - 22:20
humlan57
humlan57
1434 inlägg
även om de inte blir 1080p på TV sändningar så finns det HD material från bluray osv som är 1080p... broadcom chipet i dm800/dm8000 t.ex klarar 1080p men tror inte dom lagt in stöd för det än i mjukvaran men det kommer väl... och nog ser man skillnad på 1080i och 1080p då 1080i blir 540 linjer på rörliga bilder alltså mindre linjer än vanlig SD sändning.... därför 720p rekomenderas för sport och annat med mycke rörelse... pga den skickar interlaced blir ju bilden filmrigare och ryckigare också då....
Det har gjorts så många blindtester, å de flesta har svårt att se skillnader när materialet är riktigt bra. Å vid vanligt Tv-tittande spelar så mycket annat in än just upplösning å svepfrekvenser. Generellt så duger nästan vad som helst för format på en skärm upp till 40", om info i signalen är perfekt.. Så vad jag kan förstå, kommer det att bli ett betydlgt bättre format än 1080 som kommer att lanseras i nästa generation mottagare. Å detta just för att 1080p inte kommer att bli nån Tv-standard. Behovet å efterfrågan är alldeles för litet helt enkelt. Dessutom lär teknikförbättringar när det gäller att hantera 1080i, komma i både mottagare å skärmar, nåt som gör 1080p, mer eller mindre överflödigt. humlan.
Postad 16 August 2008 - 22:24
humlan57
humlan57
1434 inlägg
Den har all hårdvara som krävs, men boxen är bara ett par månader gammal, så allt är ännu inte implementerat i mjukvaran.., men det kommer såklart. Boxen har ju 3 syskon/kloner/andra märken, så risken att mjukvaran inte kommer att bli bra, är väldigt liten... humlan.
Postad 16 August 2008 - 22:26
Leatherface
Leatherface
Mega-Guru
7299 inlägg
spelar ingen roll om det är 32",40" eller 50" snabba rörelser i bilden gör bilden ryckig och flimrig för det.... då är 720p bättre att köra än 1080i i dom fallen.... du pratar om skillnaden mellan 720 och 1080 där många inte har sett skillnaden på mindre TV's och i dom fallen har du rätt men nu pratar vi om skillnaden mellan interlace och proggesivt och det är nåt annat...
Redigerat av Leatherface, 16 August 2008 - 22:27.
Postad 16 August 2008 - 22:27
humlan57
humlan57
1434 inlägg
Ni som har denna kan ni vara vänlig att medela fördelar och nackdelar med denna ? Funderar på denna eller en vantage 8000. Vill kunna köra i sovrummet via cs.Men är osäker på om det fungerar på 8000. Hoppas på kloka svar / tipps Mvh:ML
Fördelen ska väl vara att Vantage 800 har funnits längre på markanden, men jag kan inget om den boxen. Vet att det finns kloner av den, så möjligen går det att hitta en mjukvara som är riktigt bra..., men jag vet inte. Kortdelningen på Vantage kan knappast vara bättre än på Octagon, den kör ju med Gbox så nåt slår knappast den. humlan.
Postad 17 August 2008 - 10:25
erito
erito
636 inlägg
humlan.
Jo, men nu har ju jag 104" och där ser man definitivt skillnad. Jag ville bara kunna ta bort en pryl (popcorn hour) ur maskinrummet och visa 1080p med Octagon, men då verkar det som att man får strunta i det. 720p ger en stabilare bild enligt mig. Har provat det mesta och 1080p är ju såklart bäst, men jag sätter faktiskt också 720p över 1080i åtta dagar i veckan... Fördelen ska väl vara att Vantage 800 har funnits längre på markanden, men jag kan inget om den boxen. Vet att det finns kloner av den, så möjligen går det att hitta en mjukvara som är riktigt bra..., men jag vet inte. Kortdelningen på Vantage kan knappast vara bättre än på Octagon, den kör ju med Gbox så nåt slår knappast den.
humlan.
Och inspelning finns redan till Octagon till extern eSATA disk, men det är ännu en test image. Lär väl komma både för eSATA och USB inom kort. Hoppas även på ethernet så man kan spela in till en NAS  Tänkte försöka hacka lite med Octagon nästa vecka om jag får tid
Postad 17 August 2008 - 11:50
humlan57
humlan57
1434 inlägg
Med min erfarenhet så vill jag faktiskt varna för att stirra er blinda på specarnas uppgifter. Helt enkelt för att olika boxar presterar så olika i bildkvalitet. Så det gäller det att ha lite tur när man väljer en box, inte alls bra att det är så, men tyvärr ett faktum.
humlan.
Postad 17 August 2008 - 14:32
erito
erito
636 inlägg
humlan, hur bra tycker du bildkvaliteten på Octagon är jämfört med de andra boxar du testat? Främst HD kanalerna då.
Postad 17 August 2008 - 15:14
humlan57
humlan57
1434 inlägg
Octagon har jag bara en hög med utlåtanden, från div testare jag har kontakt med, å alla dom är positiva. Å jag litar på att dom delger mig någorlunda objektiva åsikter, å det brukar stämma mot det jag själv tycker, så det gör det säkert nu åxå. Dessutom är jag säker på att bildkvaliten kommer att höjas några snäpp, när väl mjukvaran tagit sig igenom den första utvecklingsfasen.., det brukar vara så. Men jag gillar eg aldrig att säga nåt om återgivningen, annat än som referens på min egen skärm. Alltså om nåt är bättre eller sämre hemma hos mig. Du vet säkert att det som fungerar perfekt med dom prylar Du har, kan bli nåt helt annat om man byter ut en del i kedjan. En Octagon ska jag testa senare, men måste först ta mig igenom en del annat, så det dröjer till vintern innan en box hamnar hos mig. Men jag tror stenhårt på den här boxen, liksom de andra boxar jag valt ut, bland "alla" dom som finns på markanden. Kvar återstår att hitta en box med dubbla tuners, som klarar HD å som inte är så dyr, men ändå innehåller bra hårdvara... humlan.
TV-apparater
Digital-TV
