* Officiell tråd - Cambridge Azur BD650
211 svar till detta ämne
Cambridge Audio Azur 640BD (Blu-ray & DVD-spelare) 0 (0) Inga priser
Cambridge Audio Azur 650BD (Blu-ray & DVD-spelare) 2 9 (10) Inga priser
2 relaterade trådar
#201
Postad 02 March 2011 - 20:45
Tompa123
  • Tompa123
  • 524 inlägg
Ny firmware för 650BD på G! Fick detta svar 110228 på min fråga till supporten vilken FW som var den senaste:
Thank you for your email.
The most up-to-date firmware version is 650BD-06-1104. However, in the next few weeks we will be releasing a new update to version 650BD-10-1112. This improves BD playback with various new discs.
Kind regards,
Har installerat DEM(2 st) idag.
#202
Postad 18 March 2011 - 16:52
Tille
  • Tille
  • 156 inlägg
Updaten inkluderar subtitle shift !!!! Tack tack tack, Cambridge!
Dear XX,
650BD firmware update
Cambridge Audio is pleased to announce a new firmware update for the 650BD.
The update includes the following;
Improved Blu-ray disc compatibility, including many new BD discs with new BD authoring techniques
Minor setup menu restructuring - see 650BD user manual addendum sheet
Subtitle Shift feature added – allows the user to adjust the vertical position of subtitles to better fit various aspect ratios
Improved AVCHD playback
Fixes a bug where the dim display setting is not remembered after power down when Ethernet is connected
The easiest way to update your player is to connect it to the internet, via the player’s Ethernet connection. The next time the unit powers up, the player will see that an update is available and will automatically prompt you to update the firmware for your 650BD (so long as firmware notification is ON in the Device Setup Menu). Alternatively, select Upgrade Firmware – Via Network, also within the Device Setup menu.
If it is not possible to connect your 650BD to the internet to update it, then you can also carry out the update via USB by following the instructions found here on our customer support website.
Regards,
Cambridge Audio
#203
Postad 20 April 2011 - 18:54
  • 3166 inlägg
Varning för den nya uppdateringen!!!
Du kan inte kör Reg1 dvd efter uppdateringen, nån annan som råkat ut för det?
#204
Postad 20 April 2011 - 21:38
bahama
  • bahama
  • 977 inlägg
Chippad eller ochippad?
Har aldrig spelat dvd i min då jag har dvdspelare men kan vara intresant o veta ändå. För kan de ta bort chippad dvdregfrihet med mjukvara kan de säkert snart sänka bd regfriheten med.
#205
Postad 20 April 2011 - 22:18
  • 3166 inlägg
Den är ochippad, säljaren på HK sa att den är regionsfri för dvd men inte för BD.
Har kunnat spelat Reg1 utan problem men idag så gjorde jag uppdateringen och skulle kolla nu på kvällen på en Reg1a och fick meddelandet "Fel region".
#206
Postad 25 October 2011 - 20:23
  • 3166 inlägg
Har beställt Hardware-kit för att göra den regfri både BD och DVD.
http://www.ebay.com/...#ht_2283wt_1392
#207
Postad 25 October 2011 - 22:14
tomano58
  • tomano58
  • 3281 inlägg
Här har du ursprunget. http://www.bluraychi...p?id_product=13
#208
Postad 14 June 2012 - 10:06
bahama
  • bahama
  • 977 inlägg
Ny firmware igen.
Verkar framför allt fixa vissa kompabilitetsproblem med vissa skivor.
#209
Postad 23 February 2015 - 01:38
Tille
  • Tille
  • 156 inlägg
Ny firmware släppt! Fixar uppspelningsproblem med nyare discar, bl a senaste X-men. Underbart att de vårdar spelaren fortfarande.. 😉
#210
Postad 23 February 2015 - 08:40
  • 3166 inlägg
Ja jag blev förvånad när den ville patcha, var länge sen sist. Jag googla lite på vad patchen gjorde men jag hitta ingen info.
Tack för infon.
Jag har förövrigt inte haft problem med min och vill inte byta ut den, färgen är lite unik samt att den är reg-fri, bra skit.
#211
Postad 14 August 2018 - 21:04
  • 3166 inlägg
Nån som fortfarande kör med denna spelare, min börjar närma sig 10 snart och funkar klockrent förutom en sak som börjat bråka den sista tiden, den har svårt att ladda skivor.
Jag måste ibland öppna och stänga släden flera gånger innan spelaren fattar vad det är för skiva som är i, är det nån annan som har det problemet?
#212
Postad 18 September 2018 - 15:39
Tille
  • Tille
  • 156 inlägg
Har en tryckt originalmanual som jag hittade först efter jag sålde min maskin, nån som är intresserad? Skickas mot porto.
