* Officiell Tråd - Squeezebox™ Duet *
1152 svar till detta ämne
Postad 06 januari 2008 - 16:14
  • 19 788 inlägg
Dags för en ny tråd som behandlar Slimdevices senaste koncept Duet!
Här handlar det om tvåvägskommunikation med wifi-fjärren och det sprillans nya Squeezecenter 7.0
Fyller på med info allteftersom vi får veta mer och prova själva!
Bifogad fil  1.jpg   25,55K   23 Antal nerladdningar
Squeezebox™ Duet
Listen to the music you love in any room in your home. Browse and play songs from your personal collection, online music services, and Internet radio. Enjoy crystal clear, CD-quality audio in your home theater, the stereo in your bedroom, the mini system in the kitchen — anywhere you have audio gear.
Squeezebox Duet Network Music Player
Squeezebox Duet consists of a multi-room Squeezebox Controller & charging stand, and a Squeezebox Receiver.
Play all of your music from the palm of your hand
The multi-room controller with 2.4-inch color display makes it easy to browse playlists, albums, artists, and more. Even search by name. Convenient scroll wheel, simple menus, and intuitive buttons make navigation a breeze.
Experience incredible sound quality
Expert engineering and sophisticated audio rendering technology provide sound clarity to please even the most demanding audiophile.
Enjoy a hassle-free, wireless setup
Advanced 802.11g wireless technology eliminates the need to string wires everywhere just to listen to the music from your computer. And setting up an additional room is simple as pushing a button — even on secure networks.
Listen even when your computer is off
Access millions of songs, thousands of Internet radio stations, and music service providers such as Pandora, Rhapsody and Slacker, without ever turning on your computer using SqueezeNetwork™, our unique Internet service. Even your personal music collection can be stored online in an MP3tunes music locker and played through your Squeezebox.
Music everywhere
Connect the Squeezebox Receiver to your stereo or powered speakers and create a musical oasis. Add additional Squeezebox Receivers and listen to a different song in each room, or synchronize them and hear the same music everywhere.
Detailed Specifications:
Audio outputs (general)
* Digital and analog outputs
* All RCA connectors are gold-plated
* Volume control is provided for all outputs
* Multiple outputs may be used at the same time
Analog RCA outputs
* High fidelity Wolfson® 24-bit DAC
* Two dedicated linear power regulators for DAC and line-out stages
* Full 6.0Vpp line-level signals
* Signal-to-noise ratio: over 90dB
* Total harmonic distortion: less than -88dB (0.002%)
Digital S/PDIF outputs
* Optical and coax digital connections
* Dedicated high-precision crystal oscillators (no PLL, no resampling)
* Standard IEC-958 (S/PDIF) encoding
* Optical connector: TOSLINK 660nm
* Coax connector: RCA, 500mVpp into 75 ohms
* Sample rates: 44.1Khz, 48Khz
* Audio format: linear PCM, 16 or 24 bits per sample
* Intrinsic jitter: less than 50ps (standard deviation)
Audio formats
* Lossless Formats (Apple Lossless, FLAC, WMA Lossless)
o "Bit-perfect" CD audio streaming, with reduced storage and bandwidth usage
o Approximately 2:1 compression ratio
* Uncompressed formats (AIFF, WAV, PCM)
o Supports raw pass-through of uncompressed PCM audio formats
o Digital passthrough to S/PDIF for DTS
* Compressed formats (MP3, AAC, Ogg Vorbis, MP2, MusePack, WMA)
o MPEG decoding uses MAD software, widely regarded as the most accurate, most compatible MP3 decoder
o High accuracy 24-bit synthesis
o Supports all MP3 data rates and sample rates, including VBR
o May be streamed in PCM (raw), MP3 (transcoded), or FLAC (transcoded) formats
o Sound Check and Replay Gain support for automatic volume control
o Some formats may require additional software installation (e.g. QuickTime), depending on platform
Internet Radio
* "Always-on" Internet Radio, powered by SqueezeNetwork, lets you tune in to Internet Radio streams even when the home PC is switched off
* Quick selection from hundreds of Internet Radio streams offered by Logitech's partners
* Internet Radio favorites can be saved in a playlist for easy access
* Displays song title information during playback
* Support for MP3, Ogg Vorbis, and WMA formatted Internet Radio streams
Squeezebox Controller Architecture
* Samsung 200 MHz ARM processor
* 64 MB NAND programmable flash
* 64 MB high-speed RAM
* 3-axis accelerometer tilt sensor
* Removable 1250 mAh Li-ion rechargeable battery
Firmware (both)
* Flash upgradeable firmware
* Network settings are stored in non-volatile memory
* Easy setup for wireless networks
Squeezebox Receiver Architecture
* 250 MHz 8-way multithreaded RISC processor
* "Pure software" SlimDSP™ architecture
* Field-upgradeable Xilinx CPLD
* 64Mb high-speed RAM
* 16Mb NAND programmable flash
* Low-power design, all solid-state, fanless
Network
Wireless Interface
(Squeezebox Receiver and Controller)
* True 802.11g wireless networking
* Bridging capability allows Ethernet devices to connect to the network through Squeezebox Receiver's wireless connection
* Throughput up to 54Mbps, high speed PCI interface to radio module
* Dual antennas for improved range and throughput (Squeezebox Receiver)
* Supports all 802.11b and 802.11g access points
* Automatically detects available networks for quick setup
* Supports both WPA Personal, WPA2-AES and 64/128-bit WEP encryption
Ethernet Interface
* True 100Mbps throughput
* Shielded CAT5 RJ-45 connector
* Connects to any 100Mbps or 10Mbps network
* Auto-detects full duplex and half duplex modes
* Automatic receive polarity correction
* Maximum cable length: 100 meters (328 feet)
Squeezebox Receiver Power input
* 9.0V DC, regulated
* Center positive, sleeve ground
* Connector: 1.05mm ID, 3.5mm OD, 7mm long
* Min supply rating: 550mA
Power supplies
* Universal switching power supplies included
* Power supplies are small, efficient, and do not get hot
* One of four adapter plate styles is included depending on country
What's included:
* Squeezebox Controller
* Squeezebox Receiver
* Charging Cradle with power supply
* Power supply for the receiver
* Stereo audio cable
* Installation guide
* Rechargeable Li-ion battery pack
System requirements:
* SqueezeCenter™ 7.0
* All systems: 256MB RAM and 80MB hard disk space
* Macintosh: Mac OS X 10.3.5 or later
* Windows: 733Mhz Pentium running Window 2000/XP/Vista
* Linux/BSD/Solaris/Other (Perl 5.8.3 or later)
* Ethernet and/or 802.11b/g wireless home network
* Broadband Internet connection required for Internet radio and music services
Squeezebox Receiver
* Dimensions: L: 156mm x W: 106mm (w/o connectors); 112.5mm (w/connectors) x H: 29.25mm
* Finish: high gloss black
* Dimensions: L: 156.2mm x W: 50.8mm x H: 18.8mm
* 2.4-inch color LCD TFT display
o 240 x 320 pixels
o 256K colors
o LED backlit
Bifogad fil  2.jpg   23,54K   22 Antal nerladdningar
Bifogad fil  3.jpg   34,15K   14 Antal nerladdningar
Bifogad fil  4.jpg   19,68K   11 Antal nerladdningar
Bifogad fil  5.jpg   15,99K   9 Antal nerladdningar
Redigerat av Martin, 06 januari 2008 - 16:15.
Postad 06 januari 2008 - 16:19
  • 19 788 inlägg
Amerikanska priserna just nu:
399$ för båda produkterna
299$ för fjärren
149$ för mottagaren
Postad 06 januari 2008 - 16:35
TCM
  • TCM
  • 777 inlägg
Spännande! Jag har en amerikansk kompis som kommer i början av april - jag kanske ska lägga in en order (det blir väl lite billigare att köpa i USA?)... :)
Jag såg i specen för Receivern att man är tvungen att ha den nya fjärren för att göra en "network setup".
Squeezbox Controller required for network setup
Det måste väl innebära att man inte kan köpa Receivern separat (utan att äga en fjärr först)?
Postad 06 januari 2008 - 16:39
TCM
  • TCM
  • 777 inlägg
#erlandi
Du skrev i det här inlägget att hörlursutgången inte är aktiverad än. Krävs det en uppdatering av firmware för att det ska funka? Personligen var det en detalj jag såg fram emot väldigt mycket.
Postad 06 januari 2008 - 16:55
  • 19 788 inlägg
Köpa den kan du säkerligen, men kanske inte använda den :)
Men som du säger, det första man gör lär ju vara att skaffa sig ett helt "kit". Sen bygger man ut med valfritt antal mottagare.
Postad 06 januari 2008 - 17:49
TCM
  • TCM
  • 777 inlägg
Tack för det svaret Martin :)
Det verkar som att priset i Sverige för Duetten (känns som man pratar om en gammal Volvo B)) kommer att bli 3999:-
Länk
Postad 06 januari 2008 - 18:28
erlandi
  • erlandi
  • 345 inlägg
#erlandi
Jo det är en firmware uppgradering som behövs, men i dagsläget är det väldigt enkelt att uppgradera firmware, du bara väljer "Upgrade firmare" i menyn på fjärren sen laddar den ned det senaste från SqueezeCenter/SlimServer.
Det jag tror saknas är mjukvaran i Controller för att ta emot musik stream'ad från SqueezeCenter och skicka den vidare till hörlursutgången. Det lär sannolikt komma eftersom det annars hade varit helt meningslöst att inkludera samma DAC i Controller som i Receiver. Min gissning är att de bara in hann med att göra det till release datumet.
Postad 06 januari 2008 - 19:17
  • 19 788 inlägg
Hittade en markant skillnad här som inte verkar så bra för dom som tänkt använda den analoga delen.
Det är det väl iofs inte så många som tänkt, men det kan vara bra att veta, och istället investera i en Squeezebox V3
Squeezebox™ Duet
Analog RCA outputs
Squeezebox™ V3
Analog RCA outputs
* High fidelity Burr-Brown™ 24-bit DAC
* Signal-to-noise ratio: over 100dB
* Total harmonic distortion: less than -93.5dB (0.002%)
Digitaldelen verkar vara densamma :)
Postad 06 januari 2008 - 19:38
erlandi
  • erlandi
  • 345 inlägg
Har du koll på hur DAC'en i en normal förstärkare står sig i jämförelse med DAC'en i SqueezeBox 3 ?
Jag har fått för mig att DAC'arna i CD-spelare (och även i SqueezeBox 3) som regel är bättre än DAC'arna i förstärkare i <10 tusen kronors klassen, har jag missuppfattat det ?
Jag kör idag min SqueezeBox 3 analogt till min Sherwood RVD-9090RDS förstärkare.
Jag kan spontant känna att det är lite synd om de lyckats ta bort SqueezeBox 3 två största styrkor (analoga ljudkvaliteten + displayen) i den nya produkten. Men jag tror vi kanske bör avvakta lite riktiga tester innan vi avgör om den analoga ljudkvaliteten faktiskt är sämre än tidigare även om det nu ser ut så på specen.
Postad 06 januari 2008 - 19:59
  • 19 788 inlägg
Har bara högst ovetenskapliga inlägg angående DACen. Har testat analogt och digitalt till min Denon 3806, hörde väl inga större skillnader, men valde då att köra digitalt.
Känns bättre att hålla signalen digital så länge som möjligt tycker jag.
Sen måste man ju ändå ha digitalkabeln ikopplad när man kör 5.1 musik i DTS och Dolby Digital.
Har även testat Squeezeboxen (analogt) mot en Audionet VIP (35.000:-) cd-spelare i ett halvblint test.. inga speciella nivåmatchningar och sånt, men ingen kunde i alla fall med någon som helst statistisk relevans placera vilken apparat som spelare eller om någon var bättre eller sämre än den andra :) Ett betyg gott som något enligt mig.
Jag härjar även på ett annat forum som heter Sweetspot, där har många bytt svindyra cd-spelare mot Squeezeboxar som transport. Squeezens era är här på riktigt, när gamla härdade audiofiler vräker ut sina cd-spelare är det nya tider på G B)
Men om jag förstått allt rätt så kommer ju Duet och V3 säljas parallelt ... så man kan ju köpa bara fjärren om man vill och sen vanliga boxar.
Själv ser jag ett trevligt användningsområde att skaffa helt dolda musikanläggningar, det kan ju vara trevligt ibland :P
Redigerat av Martin, 06 januari 2008 - 20:02.
Postad 06 januari 2008 - 20:13
  • 19 788 inlägg
Bifogad fil  best_of_2008.gif   3,72K   1 Antal nerladdningar
Seven Logitech Products Win CES Innovations Awards
LAS VEGAS — CES — Jan. 5, 2008 — Seven Logitech (SWX: LOGN) (NASDAQ: LOGI) products were named 2008 CES Innovations award winners for excellence in design and engineering, including the Logitech® Harmony® One advanced universal remote, which won the prestigious Best of Innovations award in the Home-Entertainment Accessories category. All of the award-winning Logitech products will be on display at the 2008 International CES tradeshow in the Logitech booth (No. 35512, South Hall, Las Vegas Convention Center).
“It is truly an honor for Logitech to be recognized alongside so many other great products,” said Jerry Quindlen, chief executive officer of Logitech. “These awards validate our deep commitment to world-class design and acknowledge our design and engineering organizations for their persistent devotion to delivering products that delight our customers.”
The award-winning products include:
Best of Innovations: The Logitech Harmony One Advanced Universal Remote
Winner of the CES 2008 Design and Engineering Award: Best of Innovations in Home-Entertainment Accessories, the Harmony® One advanced universal remote control marks a significant leap in the evolution of the best-selling line of Harmony remotes. Offering the same one-touch, activity-based control as other Harmony remotes, the Harmony One makes controlling home entertainment even easier with a full-color touch screen, an intuitive button layout and an exceptionally comfortable user-friendly design.
To better address ergonomics, the Harmony One remote features a curved, exceptionally comfortable shape that is easy for anyone in the family to hold, regardless of hand size. Presenting an elegant piano-black top and a silver base, and black buttons with white backlighting, Harmony One is the perfect complement for any living room. And the rechargeable remote’s recharging station has a sleek profile with an adjustable light that makes it easy to find, even in the dark.
Honoree: Logitech diNovo Mini Palm-Sized Keyboard with Media Remote and ClickPad
For people who have connected their PC to their TV, the Logitech® diNovo Mini™ keyboard with media remote and ClickPad makes it easy to control PC entertainment from the sofa. For easy navigation, the diNovo Mini palm-sized keyboard features backlighting and an innovative ClickPad, which can be used as a touch pad to point, scroll and click – or as a directional pad to navigate menus and make selections. For unfettered use from anywhere in the living room, the mini-keyboard uses Bluetooth® 2.0 wireless technology.
Honoree: Logitech Squeezebox Duet Network Music System
The Logitech® Squeezebox™ Duet network music system extends the promise of the award-winning Squeezebox products, which allow people to access and listen to the music they love in any room of their home. The Squeezebox Duet offers an innovative controller, which includes a full-color LCD screen, and a compact receiver – enabling people to wirelessly browse, select and play their digital music on their existing stereo speakers anywhere in the home.
To help people navigate their digital music collections, the new Squeezebox Controller features a 2.4-inch full-color LCD screen. The multi-room controller uses a convenient scroll wheel, familiar menus and intuitive buttons, making it easy for people to browse, select and play their personal music collection, Internet radio and online subscription services.
Honoree: Logitech G9 Laser Mouse
The Logitech® G9 Laser Mouse takes customization to the extreme, giving PC gamers the ability to modify nearly every part of the G9 mouse for the best personal fit, feel and performance. With the G9 mouse, gamers can enjoy interchangeable grips, on-the-fly dpi switching ranging from 200 dpi to 3200 dpi, full-speed USB laser tracking, an onboard-memory profiling system, weight tuning, a custom-color LED and the hyper-fast MicroGear™ Precision Scroll Wheel.
Honoree: Logitech Pure-Fi Dream Premium Bedroom Music System for iPod
The Logitech® Pure-Fi Dream™ Premium Bedroom Music System for iPod® establishes a new category of iPod speakers for the bedroom. The Pure-Fi Dream speakers feature an innovative application of motion- and light-sensing technology, premium audio, a built-in radio and alarm clock functions all in a stylish, compact speaker system perfect for any night stand. A premium accompaniment to any iPod, the Pure-Fi Dream speakers offer one-button access to iPod playlists and radio stations.
Honoree: Logitech MX Air Rechargeable Cordless Air Mouse
The Logitech® MX Air™ Rechargeable Cordless Air Mouse works on the desk and in the air. Similar to the way people use a remote to control a television, when holding the MX Air mouse, people can now lean back and relax while navigating the computer and enjoying media content. To enable effortless in-air navigation, the new mouse combines three important technologies – Freespace™ motion-control, gesture command and wireless – so people can point, select and play media files with just a flick of the wrist.
Honoree: Logitech VX Nano Cordless Laser Mouse
The Logitech® VX Nano Cordless Laser Mouse for Notebooks offers the tiny, plug-and-forget Nano-receiver. The mouse’s Nano-receiver provides highly mobile notebook PC and MacBook® users with a mouse that simplifies life on the road. Because the USB receiver is so small, people no longer need to constantly plug and unplug it when moving from place to place.
Redigerat av Martin, 06 januari 2008 - 20:17.
Postad 06 januari 2008 - 20:25
erlandi
  • erlandi
  • 345 inlägg
Jag har inte kört något regelrätt blind test, men vi var några stycken som jämförde min gamla Arcam Alpha 7SE CD-spelare med SqueezeBox3 (analogt), och vi var rätt överens om att Arcam spelaren som då gick på ca 5000kr hade mer dynamik i ljudet. Man fick en bredare ljudbild och det gick att positionera instrumenten i ljudbilden mer exakt än vad som gick med SqueezeBox'en. Jag valde dock ändå att lägga Arcam spelaren på hyllan p.g.a. SqueezeBox'en gav så många andra fördelar, exempelvis att man hade tillgång till hela musikbiblioteket utan att behöva springa och byta CD-skivor stup i kvarten.
Postad 06 januari 2008 - 22:51
durand
  • durand
  • 272 inlägg
Ser fruktansvärt intressant ut! Tycker inte att displayen på squeezen spelar någon större roll med tanke på vad fjärren innehåller. Blir ett givet köp när den kommer.
Kan någon förklara de analoga ändringarna för mig? Hur stor effekt kommer/kan det ge?
Redigerat av durand, 06 januari 2008 - 22:54.
Postad 06 januari 2008 - 23:17
Micke65
  • Micke65
  • 27 inlägg
Se länk där Sean Adams kommenterar DACen (7e posten i länken)
DAC-duet
/Micke
Postad 07 januari 2008 - 00:13
Alezman
  • Alezman
  • 438 inlägg
när tror ni man kan förvänta sig att kunna köpa den här? i vår?
Postad 07 januari 2008 - 00:15
  • 19 788 inlägg
Säljstart ska vara nu i januari månad!
Postad 07 januari 2008 - 00:49
TCM
  • TCM
  • 777 inlägg
Nu har jag läst igenom båda trådarna i SlimDevices forum (10 + 19 sidor puh B) ) och precis som under en period förra året så blev det mycket prissnack. Framför allt att Controllern kostar nästan $300 om man köper den separat, men även den gamla diskussionen om priserna i Europa vs USA. I Logitechs värld är EUR 1 = $ 1 [jag vet, det finns andra saker som påverkar också :)]. Sammanfattningsvis går väl diskussionen som: Duet-paketet är prisvärt, Controllern är dyr separat. Sen diskuteras det en del att man är tvungen att ha en Controller för att kunna använda den nya Receivern. Det går inte (för tillfället) att köra Duettens setup utan Controller.
En sak som jag tyckte var intressant: om du inte har trådlöst nätverk hemma (utan som jag har dragit kabel) kan ändå använda Controllern. Controllern går bara via WiFi, men om Receivern är inkopladd med kabel i nätverket så kan man skapa en Ad-Hoc anslutning mellan den och Controllern. Det jag (som en nybörjare på WiFi) skulle vilja veta är: hur funkar det? Stabilitet? Räckvidd? etc :P
Postad 07 januari 2008 - 19:02
erlandi
  • erlandi
  • 345 inlägg
Controllern går bara via WiFi, men om Receivern är inkopladd med kabel i nätverket så kan man skapa en Ad-Hoc anslutning mellan den och Controllern. Det jag (som en nybörjare på WiFi) skulle vilja veta är: hur funkar det? Stabilitet? Räckvidd? etc :)
Det fungerar säkert bra.
Jag vet inte exakt hur det fungerar men när jag sökte lite på nätet läste jag att man vid ad-hoc uppkoppling är begränsad till 11Mbps även om trådlösa kretsarna man har fixar 54Mbps. Detta skulle möjligtvis kunna innebära en lite sämre prestanda i Album menyn där skivomslag presenteras. Jag tror dock ändå inte att det har någon påverkan, för det är förmodligen själva hanteringen i SqueezeCenter som tar tid inte själva nätverkskommunikationen. Jag kör min Jive prototyp över 11Mbps och den fungerar bra (räckvidden var inte tillräcklig för att den skulle nå 54Mbps accesspunkten som står i ett annat rum).
Personligen så kan jag dock känna att det är rätt enklelt att köpa en trådlös accesspunkt för 400kr och sätta in den i nätverket och då även få möjlighet att koppla upp andra trådlösa enheter som en laptop eller varför inte en iPod Touch/Nokia800. Jag skulle gissa att säkerheten på en Ad-hoc uppkoppling är lite svårare att konfigurera, så är man orolig att grannarna skall kunna få möjlighet att välja vilken musik man skall spela så känns en trådlös accesspunkt tryggare.
Postad 07 januari 2008 - 22:04
TCM
  • TCM
  • 777 inlägg
Jag försökte hjälpa morsan och farsan med ett trådlöst nätverk för att tag sedan - det slutade med nätverk via elen istället... :) Tack för svaret.
Postad 08 januari 2008 - 10:58
Stormen
  • Stormen
  • 351 inlägg
Riktigt tjusigt om det går att köra den nya fjärren på en V3. Samt att den går att köpa separat. Då får man en snygg display i hyllan som alltid visar vad som spelas. Samt i reserv en gammal hederlig strömsnål fjärrkontroll. Det här är bra. I rätt riktning. En mobiltelefon med Opensource kanske skulle kunna minimera antalet fjärrkontroller/manicker hemma.?
Om 5 år kommer vi att ha riktigt häftiga grejer på marknaden.
Postad 08 januari 2008 - 11:28
PsychoCheF
  • PsychoCheF
  • 1 341 inlägg
Hmmm... detta kanske kan vara ett bra alternativ till Sonos mediaspelare?? Ska bli spännande att titta på detta :)
Redigerat av PsychoCheF, 08 januari 2008 - 11:29.
Postad 08 januari 2008 - 13:21
Avregistrerad523
  • Avregistrerad523
  • 5 967 inlägg
DAC-duet
/Micke
Som jag misstänkte
Specs for the Receiver's DAC are good but not quite as good as SB3's
Med andra ord är det ingen uppgradering och inte en SB4
Maveric :)
Postad 08 januari 2008 - 13:26
  • 19 788 inlägg
Dock kan man ju få en Squeeze för 149$ när man väl köpt en fjärr :)
Riktigt trevligt må jag säga. Det öppnar ju upp prismässigt att verkligen slänga in en låda i varje rum i huset.
Postad 08 januari 2008 - 13:47
Avregistrerad523
  • Avregistrerad523
  • 5 967 inlägg
Ja ... jag har ingen på dass .. så det var en god idé :D
Maveric :rolleyes:
Postad 08 januari 2008 - 14:36
thejejk
  • thejejk
  • 59 inlägg
Som jag misstänkte
Maveric :)
Precis. Blev lite upphetsad först när jag såg duetten, men att lansera en ny produkt med sämre specs (på pappret) än den gamla känns ju lite beigt, hur superduperflashig än fjärrkontrollen är. Men visst, SB3an är fortfarande kvar i sortimentet, och verkar även stanna där ett tag till, så en kombo med fjärren och SB3an funkar ju. Och ett squeezecenter till den 2a-anläggningen skadar ju inte.
Något jag väntar på är att de ska få till nextgen trådlöst (11.n) i squeezeboxen, så att den inte drar ner hastigheten på övriga trådlösa nätverket om man inte kör med nätverkskabel. (rätta mig gärna om så inte är fallet)
Postad 08 januari 2008 - 14:48
Wide
  • Wide
  • 212 inlägg
Fan va grym den blev! :rolleyes: . Kul att kunna sitta och glo på fjärren och leta skivor( vi som är så vana att glo på mobilen hela dagarna.....hehehe...). Ska bli spännade och se den live, se hur displayen är..:). Nästa inköp! :D .
När kommer det upp tester på denna tror ni?..
Postad 08 januari 2008 - 17:01
  • 19 788 inlägg
Ingen aning om när det kommer upp tester från staterna och diverse tidningar och sajter. Men jag kommer personligen att göra ett ordentligt test i slutet av januari om allt vill sig väl :)
Redigerat av Martin, 08 januari 2008 - 17:02.
Postad 08 januari 2008 - 23:01
erlandi
  • erlandi
  • 345 inlägg
DAC-duet
/Micke
Som jag misstänkte
Tänk bara på att det är mer än DAC'en som påverkar ljudkvaliteten. Om jag har förstått det rätt så var väl poweradaptern i SqueezeBox3 en "stor" begränsning för analoga ljudkvaliteten. Har jag förstått det rätt så har de en annan nätenhet i SqueezeBox Receiver, så helst plötsligt så kompenserar det att DAC'en är något sämre.
Jag avvaktar tills någon faktiskt testar dem mot varanda innan jag bestämmer sig om det är en förbättring, försämring av ljudkvaliteten.
Jag kan dock hålla med om att jag personligen hellre sett att den hade en DAC som var mer åt Transporter hållet, men förmodligen är det viktigare att kunna sänka priset för att nå ut till fler kunder.
Postad 09 januari 2008 - 01:28
Falloutboy
  • Falloutboy
  • 444 inlägg
Från vad jag har läst har de snålat in ordentligt på nätdelen i SB Receiver eftersom den inte ska driva någon display.
Jag läste också på ett annat forum att det är den helt nya top-of-the-line DACen WM8741 från Wolfson som sitter i SB Receiver och om det stämmer måste de misslyckats rejält med implementeringen eftersom den är högre specad än DACen i SB3 (TI PCM1748).
Läs mer om Wolfson WM8741 här: http://www.audiodesi...ducts/202201531
Precis. De preliminära siffrorna säger ju inte mycket (S/N över 90dB säger ju inte hur mycket över ;)).
DACen i Transporter (AK4396. Läs mer om den här: http://www.electroni...km/akm100.html) är mycket billigare än Wolfson DACen (om det är den de använt).
Bra DACar och andra komponenter kostar nästan ingenting idag (Jag såg ett amerikanskt budgetljudkort med 4 st AK4396 DACar (Transporter har en) för $79 (ca. 500kr)), men hur de används är givetvis minst lika viktigt.
Postad 09 januari 2008 - 14:52
Morfendite
  • Morfendite
  • 26 inlägg
Hej! Jag tror denna produkt kan vara något för mig.
Men jag skulle vilja ha råd av er som kanske har lite mer erfarenhet av "mångzonsljud" och hur man kan använda sig av Squeezebox i dessa sammanhangen.
I mitt hem har jag ett loft med kombinerat sovrum med ordentlig hemmabio med HTPC som även får agera stereo till verkstan vid sidan av/under. Rakt under har jag kontor/kök med mera stora högtalare och slutsteg, dock bara stereo. Jag skulle vilja kunna styra ljudet från båda högtalar/slutstegsseten från antingen laptopen på kontoret (via remote desktop) eller från en så'n här Squeezebox Duet vilket verkar var ett enklare alternativ.
Förmodligen krävs det då att jag kopplar in ett mångkanalsförsteg mellan HTPC:n och slutstegen för att kunna alternera mellan HTPC och Squeezebox. Eller?
Den HTPC jag har nu kommer troligen att snart bli ersatt av en hfx-burk då dess fläktar stör för mycket och kan då användas som medieserver och nedladdningsdator. (Och då givetvis enbart för legalt anförskaffad media.);
Ett par saker är viktiga, nämligen att ljudet kommer samtidigt från alla högtalare, oavsett hur många kit jag kopplar in (ett i badrummet skulle i så fall vara nästa) och att alla går att styra enkelt.
Tacksam för spån och ideér över detta och hur man kan använda sig av olika apparater och då speciellt av nå'n "mediaexpander" typ nå'n Squeezebox och dess tillbehör.
Givetvis är det även viktigt att ljudkvaliteten är den bästa.
/M
Redigerat av Morfendite, 09 januari 2008 - 15:03.
Postad 09 januari 2008 - 15:41
TCM
  • TCM
  • 777 inlägg
Fan va grym den blev! :D . Kul att kunna sitta och glo på fjärren och leta skivor( vi som är så vana att glo på mobilen hela dagarna.....hehehe...). Ska bli spännade och se den live, se hur displayen är..;). Nästa inköp! B) .
Här brukar dom länka till en del tester - du får hålla utkik
http://www.slimdevic...om/au_news.html
Postad 09 januari 2008 - 16:58
  • 19 788 inlägg
Nu är sakerna prissatta i Sverige också! Mycket billigare än jag kunde tänka mig ;) B)
Snacka om billigt att bygga en helgrym multi-roomanläggning nu.
Postad 09 januari 2008 - 18:54
TCM
  • TCM
  • 777 inlägg
Duet är prissatt till SEK3999 på Logitechs hemsida - hoppas att priserna står sig till produkterna blev tillgängliga. Nu är gapet mellan USA och Sverige inte så stort: $300 = SEK1955 (Controller).
Redigerat av TCM, 09 januari 2008 - 18:55.
Postad 09 januari 2008 - 20:49
Grodman
  • Grodman
  • 55 inlägg
Nu är sakerna prissatta i Sverige också! Mycket billigare än jag kunde tänka mig ;) :wub:
Dom priserna tar jag med en nypa salt tills duet finns i lager.
Håller dom fast vid priset även i slutet av januari så har dom en beställning.
Postad 10 januari 2008 - 07:29
erlandi
  • erlandi
  • 345 inlägg
/M
Jag vet inte om jag har koll på exakt hur du kopplat ihop din utrustning, men principen kring SqueezeBox är att för att få ljud i ytterligare ett rum så behöver du:
SqueezeBox i det aktuella rummet -> Förstärkare i det aktuella rummet -> Högtalare i det aktuella rummet.
Du kan sedan ha en sådan uppsättning i varje rum i ett hus. Den enda kopplingen som behövs mellan de olika rummet är att alla SqueezeBox'ar måste ha nätverkskontakt till den dator som SlimServer exekverar på. Genom detta så kommer ljudet från alla rum att synkroniseras så att det kommer ut samtidigt. Du kan också välja att de olika rummen skall ha separat ljud och kan då spela olika saker i olika rum. Har du trådlöst nätverk i huset så behöver du inte dra några nätverkskablar till respektive rum, har du inte ett trådlöst nätverk antingen skaffar du ett eller också drar du nätverkskablar från respektive rum till en central router/switch/hub någonstans i huset som även datorn du kör SlimServer på är kopplad till.
Kopplingen mellan SqueezeBox och en förstärkare kan göras enligt:
- Analoga kablar: Du använder då DAC'en i SqueezeBox'en och förstärkaren förstärker den analoga signalen och skickar den till högtalarna
- Digital kabel: SqueezeBox'en skicka en digital signal till förstärkaren som med DAC'en i förstärkaren konverterar den till en analog signal som förstärks och skickas till högtalarna.
Detta gör givetvis också att du måste ha en egen ingång i förstärkaren för SqueezeBox'en, så om du idag bara har ett slutsteg med en ingång så måste du ha något framför så du kan koppla in exempelvis både HTPC'n och SqueezeBox'en till den och ha möjlighet att switcha mellan dem.
Man kan säga att den produkt du behöver i respektive rum är någon av:
- SqueezeBox Receiver ($149)
- SqueezeBox 3 ($299)
- Transporter ($1999)
Väljer du en SqueezeBox Receiver behöver du dessutom minst en SqueezeBox Controller ($299), det är då fördelaktigast att köpa dem i ett paket i form av en SqueezeBox Duet ($399).
Skillnaden mellan dessa olika produkter är att SqueezeBox 3 och Transporter har en display på själva enheten medan SqueezeBox Receiver saknar display men istället har display på fjärren (SqueezeBox Controller). Transporter är audiophile versionen, medan de övriga är tänkt för vanliga konsumenter som vill ha bra ljud men inte är perfektionister.
Om du väljer att enbart köpa SqueezeBox 3/Transporter är det bra att vara medveten om att du måste då ha ögonkontakt med en av SqueezeBox'arna för att kunna byta låt genom att fjärren till dessa använder IR. Det går dock utmärkt att köpa till en SqueezeBox Controller fjärr om du vill kunna styra dem utan ögonkontakt.
Postad 10 januari 2008 - 07:35
erlandi
  • erlandi
  • 345 inlägg
En gissning är att dessa priser inte kommer att stå sig, tittar man generellt så brukar en $300 produkt hamna på mellan 2500 och 3000 när den kommer till Sverige. Det skall läggas på Svensk moms och den svenska återförsäljaren och butiken skall ha en del av kakan.
Min personliga gissning är att vi lär hamna på något liknande:
- SqueezeBox Controller: ca 2700
- SqueezeBox Receiver: ca 1300
- SqueezeBox Duet: ca 3600
Men detta är enbart gissningar, priserna på logitech.se hamnar förmodligen på ungefär 10x dollarkursen.
Postad 10 januari 2008 - 11:27
TCM
  • TCM
  • 777 inlägg
Håller med. Än så länge finns bara Duet i Logitech:s webbutik, ska bli intressant och se om dom "får" sälja separata Controllers och Receivers. Enligt uppgift kommer ju bara SlimDevices själva och ett antal utvalda nätbutiker få sälja de separata enheterna. Undrar om det blir någon/några svensk butik/butiker (som det är nu får ju inte europeer handla i SlimDevices butik)?
Postad 10 januari 2008 - 20:19
Wolfram Tungsten
  • Wolfram Tungsten
  • 13 inlägg
Låter faktiskt intressant.....det enda som saknas är en USB 2.0 anslutning på receivern då skulle man ju kunna koppla in en protabel hårddisk.
Postad 10 januari 2008 - 20:44
TCM
  • TCM
  • 777 inlägg
Du måste fortfarande köra SlimServer/SqueezeCenter på en dator eller en NAS, det skulle inte bara gå att koppla på en hårddisk. Vill du koppla in ytterligare en hårddisk är det ju bättre att få bort den från platsen där du lyssnar på musik med tanke på störande fläktar etc. Alltså köra din slimserver i ett annat rum.
Postad 11 januari 2008 - 10:25
TCM
  • TCM
  • 777 inlägg
Nu har Duet och Controller försvunnit från "billiga" affären som Martin nämnde. Frågan är väl hur seriösa dom var? Jag nämnde prisjakt i en tråd hos SlimDevices [länk], frågan är om det har påverkat beslutet att ta bort produkterna. Vad var det företaget hette? Något med 123 har jag för mig. Nu är det bara Reference Audio som listar Duet och pratar om leverens i början på februari.
Postad 11 januari 2008 - 10:27
Wolfram Tungsten
  • Wolfram Tungsten
  • 13 inlägg
Tack för svaret. Jag förstår det tekniska problemet. Det jag tänkte på är att det finns ju många AV-receiver som inte har någon USB anslutning. Mitt problem är att jag har en MP3 (iRiver H300 med 40 GB HD) som jag gärna hade kopplat direkt till receivern. Tyvärr är det så att den analoga kopplingen inte fungera särkilt bra, då uteffekten från MP3n är för dåligt. Förvisso kan man väl koppla in en amp. men jag inbillar mig att USB kopplingen hade fungerat bättre. Går nämligen i tankar att köpa antingen en NAD T785 eller en Onkyo 905, den senare har ju funktionen men inte Naden...
Postad 11 januari 2008 - 10:35
  • 19 788 inlägg
http://128bit.se/
Jag förstår inte riktigt vad du menar här, var kommer Squeezeboxen in i ekvationen om du vill koppla in en mp3-spelare? :) .. och usb?
Postad 11 januari 2008 - 12:54
Morfendite
  • Morfendite
  • 26 inlägg
Kan man styra controllern via en PC?
Vore trevligt att från controllern kunna spela upp ljud från datorn från andra program tex Winamp, Zoomplayer och Internet Explorer med Last.fm mm...
Postad 11 januari 2008 - 13:03
Wolfram Tungsten
  • Wolfram Tungsten
  • 13 inlägg
http://128bit.se/
Som jag skrev så hade det varit trevigt med ett USB uttag på den delen av av Squeezeboxen som är kopplat till receivern så att man kan ansluta en MP3 spelare via USB uttag istället för den vanliga analoga. Då skulle man
slippa använda den ofta ganska svaga utgångsignalen i "line out" som finns på MP3 spelare och använda MP3 spelare
som en portable HD. Men jag har nu förstått att detta inte går att genomföra, i alla fall inte i dagsläge.
Postad 11 januari 2008 - 13:29
kzall
  • kzall
kan man köra Controllern (fjärren) mot en SqueezeBox v3 ?
har läst igenom tråden men inte fått ett riktigt klart svar. Jag anar mig till att det skall vara möjligt - stämmer det ?
Postad 11 januari 2008 - 15:51
TCM
  • TCM
  • 777 inlägg
Du kan styra en SB 3 med Controller. Den jobbar mot slimserver via wifi så den är inte beroenda av version på SB:n, du ska även kunna styra orginal SB:n
http://www.slimdevic...controller.html
Postad 11 januari 2008 - 23:45
TCM
  • TCM
  • 777 inlägg
Från SlimDevices forum i kväll:
The Duet was approved for production on Monday.
Hopefully you guys will see them on your shelves by the beginning/middle of next month.
Mike
_________________
Michael Valera
Online Communities Manager
Logitech Streaming Media Systems
slimdevices.com
länk
Postad 12 januari 2008 - 13:20
Thomas_1974
  • Thomas_1974
  • 22 inlägg
Detta verkar vara en fantastisk produkt. Precis vad jag velat ha!! ;)
Jag är tyvärr inte så insatt i hur det funkar med inkoppling av en sån här produkt. Skulle någon kunna beskriva hur en installation skulle kunna göras?
Jag har ju en dator där mp3:orna ligger och en stereo (hemmabio) där jag vill trycka ut ljudet. Datorn har endast ett nätverkskort för nätverkskabel där bredbandet går in.
Vad behöver jag ha mer för att få igång min squeezebox med controller? Trådlöst nätverkskort? Router?
Funkar WiFi genom väggar (gjorda av gips och spånplatta)?
Mvh Thomas
Postad 12 januari 2008 - 13:29
capture
  • capture
  • 371 inlägg
När jag skaffar min kommer jag koppla det såhär: datorn-->router<---squeeze. Detta sättet fungerar både med trådlöst och med kabel. Du kan även koppla squeezen direkt till datorn med trådlöst nätverk eller kabel.
Ladda hem squeezebox 3s manual och läs den. Lär fungera på samma sätt.
Redigerat av capture, 12 januari 2008 - 13:44.
Postad 12 januari 2008 - 13:51
Thomas_1974
  • Thomas_1974
  • 22 inlägg
En fråga till:
Går det att få Controllern att kommunicera till förstärkaren, tex för volym?
  • Kappa 8.
    Dalpinne
    2016-09-26 06:55:20
  • Bion
    JoJoJohan
    2016-09-25 21:24:43
  • CINEMA EMPIRE - Ny film från CDON
    tony97
    2016-09-25 08:07:53
  • CINEMA EMPIRE - Kvällens film Kizz I Las Vegas 2016-09-24
    tony97
    2016-09-24 23:06:44
  • Akustiktavla
    Jacke89
    2016-09-24 09:34:14
Prisjakt © 2000 - 2016 Prisjakt   Denna sajt använder cookies.   Våra regler.
