Officiell tråd - D-link Boxee
8094 svar till detta ämne
#3501
Postad 13 October 2011 - 00:23
Unregistered277056c3
  • Unregistered277056c3
  • 4773 inlägg
Tjosan!
Burken uppdaterade sig nyss automatiskt till ver 1.2.1.20451 (oct 11).
Ingen aning vad de fixat nu, och uppdateringen var inte frivillig...
#3502
Postad 13 October 2011 - 07:38
lostsoul
  • lostsoul
  • 415 inlägg
Boxee New firmware 1.2.1.20451 is now available
New firmware is available or you can manually update it from here http://support.boxee.tv/entries/3288...boxee-software
We’ve really focused on issues that we’ve been hearing from the community on this one so we’ve invested a lot in SMB sharing issues, syncing, and streaming issues. We know there’s still issues to conquer, but we feel this release is a huge step in the right direction.
Bug fixes
Networking & File Playback
  • Inconsistency when trying to access a password protected share of Windows7 via SMB
  • SMB mount fails with Invalid argument error
  • SMB fails to mount with error “Key has expired”
  • Fail to access or create SMB password protected shares when the password contains special characters
  • Mounting SMB CIFS password protected share is missing the domain parameter
  • SMB shares are only mounted to hosts which are found by boxee network discovery
  • SMB browsing into WORKGROUP fails
  • When adding an SMB password protected file source manually, boxee writes the password and user name in the log
  • SMB shares cannot be accessed on a Synology NAS when disabling the guest account
  • Using wrong credentials to access a SMB password protected share will fail and prompt user and pass dialog until reboot
  • Browsing into password protected SMB directory fails with error Operation not supported
  • Users is prompted for pre-defined password when accessing protected SMB sources
  • Subtitles show up as "unknown" instead of the proper language with embedded subs in MKVs
  • MKV playback over UPnP drops out after ~ 48 minutes
  • Cannot seek in MKV videos on UPnP
  • 2 channel FLAC always converted to 48 Khz PCM on HDMI interface if EDID is disabled
  • Boxee will only output 96Khz and 88.2 Khz PCM over HDMI if EDID is enabled in the Boxee settings
  • 88Khz FLAC and WAV files result in silent playback
  • Subtitles timing problem causes overlay
  • Song title in upper OSD disappear only every second select click
  • AC-3 Audio volume is lower than previous version
  • MPEG4 with packed bitstreams didn't work
  • WMV streaming out of sync
  • Small ISO files would not fast forward / rewind
  • WMV/MMS streaming issues
  • Dropouts on AC-3 audio
Apps
  • UStream Lounge search/browse features stopped working
  • The Gymbox application not loading workouts
  • Accuweather App - hourly forecast is showing daily forecast data
  • HDHomeRun .strm files no longer work
  • Speed TV: Labels in List Container are scrolling
Interface
  • Boxee crash when trying to move up from the most upper line in the Share Dialog edit box
Libraries
  • After removing a channel via the channel filter it remains available in the channels list, but it's TV episodes are no longer available
  • Marking a TV show as watched doesn't work
Browser
  • Remove redundant video controls from Bloomberg video
  • Audio stopped working after Youtube (appeared for other flash websites as well)
Localization
  • Localization sync for Accuweather
  • Norwegian translation errors
  • Italian translation errors
Misc.
  • Logitech keyboard controller K700 support
  • AirPlay support for iOS 5 devices
__________________
Team Boxee
Redigerat av lostsoul, 13 October 2011 - 07:43.
#3503
Postad 13 October 2011 - 08:17
PalmiNio
  • PalmiNio
  • 8074 inlägg
Har hört det snart ska komma en trevlig app, fredag eller nästa vecka....
#3504
Postad 13 October 2011 - 08:27
LimpFish
  • LimpFish
  • 55 inlägg
Jag ska hämta min BB på Posten idag, så utveckla gärna! :wub:
#3505
Postad 13 October 2011 - 09:46
  • 4773 inlägg
...Bug fixes
Networking & File Playback...
Tack för listan! Hittade den inte i natt, var förmodligen för trött.
Efter uppdateringen har boxen tappat bort en del subtitles, men det kan man väl stå ut med...
Eeh, varför så hemlighetsfull? :)
Redigerat av Unregistered277056c3, 13 October 2011 - 09:47.
#3506
Postad 13 October 2011 - 09:59
Garrett
  • Garrett
  • 7007 inlägg
Gillar inte att det hackar på vissa scener i Planet Earth, i tex Fresh Water del 3, strax efter den maffiga scenen efter vattenfallet... ändå i bara 720p... konstigt, för den klara ju "Fågelscenen" i 1080p... :unsure:
Nu har jag ju detta på BD med såklart... men det är rätt smidigt när man bara vill se vissa scener, eller avsnitt snabbt, på dom som ligger på datorn... vad beror detta på tro..?
Gäller det srt filerna med, eller bara såna man sökt genom opensutitles genom Boxeen?
#3507
Postad 13 October 2011 - 10:01
_Lucifer_
  • _Lucifer_
  • 857 inlägg
Mitt problem med lagg och hackande filmer är nu löst. Problemet var min D-Link router som måste startas om med jämna mellanrum.
Alltså inget problem med Boxeen.
#3508
Postad 13 October 2011 - 10:40
  • 4773 inlägg
Gillar inte att det hackar... ... vad beror detta på tro..?
Tryck på "i" och kolla cpu load. Ligger den på 90-100% är det förmodligen segt i nätverket.
Fick bläddra för att få igång ett par srt. Vet inte med opensubs...
#3509
Postad 13 October 2011 - 10:43
Garrett
  • Garrett
  • 7007 inlägg
Om det är CPUn som är överbelastad, har det väl inte med nätverket att göra? :) Kör med Gigabyte switch...
Edit: kollade scenen igen, låg på 55-73% i CPU usage... så överbelastad kan den inte vara... kan va att jag inte startat om den efter uppdateringen kanske..?
Redigerat av Garrett, 13 October 2011 - 11:02.
#3510
Postad 13 October 2011 - 11:13
  • 4773 inlägg
Håller med om att det kan verka en smula ologiskt, men här går cpu load upp dramatiskt när det är hög belastning i nätet.
Kört samma 1080p-fil och sett konstant ca 18% (wlan 54Mbps) med "tyst" i nätet, och uppåt 80% när det körs onlinespel samtidigt.
Boxen har väl bara 100Mbps, så max bandbredd blir ca 70-80 i praktiken med kabel.
#3511
Postad 13 October 2011 - 13:29
Unregistered5716f3e8
  • Unregistered5716f3e8
  • 29 inlägg
Vad störigt att de har översatt "Rating" gällande åldersgräns osv till "Betyg" :huh: (när man ser informationen för ett Arrested Development-avsnitt)
En annan skön översättning är när man ska kolla på ett tv-serie avsnitt, för att starta uppspelningen står det "lägg till stöd" vilket jag tyckte var lite skumt, sen kom jag på att i den engelska versionen stod det "ad supported", alltså reklamfinansierat...
Det i sig blir ju också lite komiskt, då man tittar på svt-play, vilket inte alls är reklamfinansierat. Det bästa hade kanske varit om det bara stod play/spela avsnitt.
Såg i listan över ändringar i nya uppdateringen att de fixat språkfel i finska och italienska versionen, nån kanske skulle ta en titt på den svenska också :)
#3512
Postad 13 October 2011 - 14:08
LimpFish
  • LimpFish
  • 55 inlägg
Haha ja översättningen verkar ju vara gjord med Google Translate eller liknande... Kan man anmäla sånt här som bug-rapport på något sätt? Känns som att vi borde hålla Sveriges fana högt och fixa det :) Eller kör alla här engelska som språk kanske?
Jag har inte fått min än så jag har inte koll på vilket språk som är goast att köra... Ska hämta ut den om några timmar dock! :D
#3513
Postad 13 October 2011 - 15:20
XavierJH
  • XavierJH
  • 1185 inlägg
Airplay har blivit mycket mer stabilt nu i alla fall. Bild och filmvisning verkar funka flawless och ljudet lider inte av samma mängd dropouts utan spelar med hyfsad kvalitet. Kan fortfarande dyka upp lite dropouts dock. Boxeen startar om sig själv om man connectar med airplay via airfoil.
#3514
Postad 13 October 2011 - 16:14
lappen71
  • lappen71
  • 2053 inlägg
Jag upplever att det går snabbare att manövrera runt bland filmer och serier.
Men en irriterande sak som jag inte får bort och det är att jag får fel omslag på en serie.
Dum som jag var testade jag ett program för att lägga till den information jag skälv ville ha i en NFO-fil.
Programmet laddade hem rätt bild men det fungerade inte ändå utan jag tog bort Nfo-filen och bilderna.
Nu när BB letar själv så lägger den till en bild för en helt annan film och fast jag manuellt söker så kommer den felaktiga bilden fram.
Har ingen större lust att radera alla thumbnails men det ser ut som jag inte har nått val.
#3515
Postad 13 October 2011 - 18:07
PalmiNio
  • PalmiNio
  • 8074 inlägg
Allt är inte 100 så vill inte säga för mycket. Men tror det kommer uppskattas, om nu appen fungerar bra.
#3516
Postad 13 October 2011 - 18:24
Unregistered577c6879
  • Unregistered577c6879
  • 2986 inlägg
Eftersom svensk lag gäller både vid köp, nyttjande och eventuella reklamationer så är det inköpsstället man ingått ett avtal med och ingen annan, även om man måste "kryssa i en ruta" för att kunna starta mjukvaran.
Det avtal med Boxee du nämner "finns inte" i praktiken, eftersom hela rasket lyder under svensk lagstiftning och inget annat. Man ingår alltså inget avtal med vare sig D-Link eller Boxee vad gäller burk/mjukvara, även om man skulle kunna tro det.
Inser att vi har olika synsätt antagligen pga jobbbakgrund, men i praktiken är svensk lag ointressant i detta sammanhang då den inte styr produktutvecklingen. Konsumentköplagen värnar konsumentens intresse mot näringsidkare. Ingen svensk lag kommer tvinga D-Link att ha kontroll över mjukvaran eller släppa någon ny version om Boxee går i konkurs. Du har rätt att kräva skadestånd eller hävning. Produkten bryter inte mot produktsäkerhetslagen eller försäljningsförbud.
De tar det ansvar de kan och befintlig mjukvara finns ju, men vi båda vet att Boxee är fristående företag och inte kontrolleras av D-Link så länge de inte köper upp deras verksamhet. Alla servrar som kräver att du kan nyregistera och använda produkten kontrolleras av Boxee i dagsläget och deras avtal är fullt lagligt enligt svensk praxis...
Vet inte varifrån du fått uppfattningen att avtalet inte är bindande? Du använder en tjänst baserad i USA med en svensksåld produkt och vill man inte använda produkten så får man låta bli. Boxee bryter inte mot e-handelslagen.
#3517
Postad 13 October 2011 - 19:55
Unregistered4e1812ee
  • Unregistered4e1812ee
  • 889 inlägg
Tjosan!
Jo, såg det ikväll också. Avmätt o lätt skeptisk såg jag när den uppdaterade, o tänkte: så var det dags igen, svart bild efter uppdatering precis som i somras... :unsure: men, den hackade igång igen, menybild visades. Tur det, men annars har jag en MacBook Air o titta film på :rolleyes:
#3518
Postad 13 October 2011 - 20:35
SweElite
  • SweElite
  • 858 inlägg
DTS-HD drop-outs fortfarande inte fixat :(
#3519
Postad 13 October 2011 - 20:54
Benedict
  • Benedict
  • 257 inlägg
Finns det något enkelt sätt att komma åt webläsaren på förutom att söka i sökfältet?
Jag hittar inte någon genväg till webläsaren.
Eller är det något jag missat?
Annars är det lite jobbigt om man exempelvis vill gå till kanal9play.se som man sparat som bokmärke i webläsaren, om det enda sättet är att skriva in ett sökord för att webläsaren ska öppnas.
edit: finns det något sätt att få Boxee att välja högre upplösning på SVTplay än medium?
Testade att välja 720p men såg ingen större skillnad (gällande Landet Brunsås).
Redigerat av Benedict, 13 October 2011 - 20:56.
#3520
Postad 13 October 2011 - 20:56
lappen71
  • lappen71
  • 2053 inlägg
Du lägger till den som favorit App.
Gå till Appar och välj visa alla,sen letar du fram webbläsaren och när du klickar på den så i popup rutan går du upp till stjärnan och klickar på den.
Då läggs den till dina favorit appar
Redigerat av lappen71, 13 October 2011 - 20:57.
#3521
Postad 13 October 2011 - 21:34
Calzon
  • Calzon
  • 26 inlägg
Fick köpt mig en liten BB häromdagen. 100% impulsköp då jag egentligen åkte för att handla ett par högtalare till datorn. När jag går förbi en hylla står det ett gäng BB varav en märkt med FYND! Hmm tänkte jag varför är bara den märkt?
Tog lådan och gick till en kille som stog i närheten. På undersidan stog det retur ex, små repor finns. -Vi öppnar väl och kollar sa han. Sagt och gjort men var fanns reporna? Det syntes iaf inte några och jag frågade om han kunde kolla varför den returnerades och det var pga öppet köp, inget mer. Jag frågade därför varför det bara stog fynd på denna lådan och inte dom andra, var denna billigare då? Jodå, 1990:- var ord pris, denna kostade 899:-.
Tack sa jag och köpte den rakt av, jag menar under 30 dagar gammal och inga synliga reper eller spår av användning samt genomgången och fabriksåterställd, jag tycker det var ett fynd iaf. Och efter att ha stressat den lite nu med bla en ren BD skiva, streamad över trådlöst (dator-trådlöst till router-trådlöst till BB), kan jag konstatera att den 2(!?) gånger fått buffra om i 2 sekunder och den hörs absolut ingenting! Jag gillar den skarpt. Visst några filmer i biblioteket har den inte fattat riktigt vad det vart men tog inte lång tid att rätta till. Det jag skulle vilja se i framtida uppdateringar är:
Lite fler skins, alltid kul att alternera utseende och kanske själv kunna välja poster.
Lättare att få svensk sub utan att leta reda på den själv i förhand och lägga till i undertextmapen.
När man väl bundat filen och en film från imdb själv kunna ändra det synliga namnet i bibliotektet. Alla svenska filmer får t ex engelsk rubrik om det finns på imdb.
EDIT: Går det att ställa in undertextmapp precis som i XBMC? alltså att det räcker med att ställa in var alla mina undertexter ligger och sen hittar BB dom automatiskt med hjälp av filnamnet? eller måste jag lägga in varje undertext var för sig i filmmappen?
Redigerat av Calzon, 14 October 2011 - 01:12.
#3522
Postad 14 October 2011 - 07:09
danneber
  • danneber
Jag köpte en extern iomega disk igår. Har formaterat den till ntfs, men boxee:n hittar den inte. Någon som har varit med om samma sak och har förslag på lösning??
#3523
Postad 14 October 2011 - 07:19
lappen71
  • lappen71
  • 2053 inlägg
Nej...du måste ha undertexterna i mappen där filmen ligger och den måste ha samma namn
#3524
Postad 14 October 2011 - 09:22
  • 4773 inlägg
INGET lands lagar är särskilt intressanta när det gäller produktutveckling, och vi har nog egentligen inte särskilt olika synsätt heller.
Det verkar dock som att du ser en del kopplingar som inte riktigt finns, mycket eftersom du ganska envist pratar om att D-Link inte har något ansvar för mjukvaran i burken de säljer, vilket åtminstone enligt svensk lagstiftning är ganska uppåt väggarna.
Om burken sålts HELT UTAN MJUKVARA, dvs som en ren hårdvaruprodukt kunde det ligga något i dina synpunkter, men så är nu inte fallet.
Burken säljs som en fullt fungerande produkt, avsedd att användas som "mediaspelare", med en proprietär version av en i andra sammanhang ganska öppen mjukvara. Man betalar de facto för D-Links speciella version av mjukvaran och kan/får inte modifiera den.
Återförsäljaren har ansvar gentemot konsumenten att produkten fungerar och gör som den skall, men kan givetvis inte göra särskilt mycket åt om D-Link/Boxee bär sig dumt åt. Uppfyller produkten inte det som utlovats kan återförsäljaren tvingas till återköp, och får sen själv deala med grossist, tillverkare osv om det behövs.
Stämmer, och det finns ingen amerikansk lag som tvingar D-Link "att ha kontroll över mjukvaran" heller, så den infallsvinkeln är ganska ovidkommande.
Stämmer, men avtalet med Boxee har inget som helst med konsumentens rättighet att reklamera produkten (hård- och mjukvara) att göra.
Avtalet du hänvisar till handlar om inloggningen på Boxees servrar och har ingenting med själva produkten att göra eller konsumentens rättigheter.
De begränsningar i konsumentens rättigheter som D-Link och Boxee plitat ned i sina avtal gäller inte i de avseenden de avviker från svensk lag, helt enkelt eftersom produkten köpts i sverige från en svensk återförsäljare. Köper man burken från t ex Amazon.com är det inte riktigt samma sak.
#3525
Postad 14 October 2011 - 09:27
masse70
  • masse70
  • 8528 inlägg
Nog för att det förvisso kan vara intressant med vilka lagar etc som gäller. Men kan inte ghost och xyz fortsätta detta långrandiga sidospår via pm istället?
#3526
Postad 14 October 2011 - 09:35
  • 4773 inlägg
Det har du helt rätt i, men jag tror inte det finns så mycket mer att tillägga.
Allt borde vara klart som korvspad nu, eller? :P
#3527
Postad 14 October 2011 - 09:47
MrStarhouse
  • MrStarhouse
  • 128 inlägg
Om det är en liten 2.5" disk så kan det vara strömförsörjningsproblem. Dom små USB diskarna som tar sin strömförsörjning via USB kan vara lite kinkiga. Tex så kan man inte har för lång USB sladd, man bör använda den som följde med. Boxee Boxen är också känslig för att ha två 2.5" USB diskar samtidigt, då finns det risk att strömförsörjningen inte räcker.
Vill man ha två och fler ska man använda en USB hub med strömsförsörjning.
Det är väl det jag kan tänka mig.
för mig har USB diskar alldrig krånglat
/MrStarhouse
#3528
Postad 14 October 2011 - 10:56
ljudnisse
  • ljudnisse
  • 2129 inlägg
Noterade att svt play & tv4 play inte har något ljud efter gårdagens update, någon mer som kan testa och bekräfta ?
#3529
Postad 14 October 2011 - 11:48
  • 2986 inlägg
Förutom att många här verkar tro att de köpt en mediaspelare som funkar out of the box, vilket inte är fallet. Du har köpt hårdvara som kräver att du använder en extern tjänst precis som en mobiltelefon. Mjukvaran gör exakt det den ska, den tar dig till registreringen hos Boxee där du upprättar ett eget konto. Utan konto ingen mediaspelare vilket är hela affärsmodellen... oavsett om det står Iomega eller D-Link på boxen. Det står t.o.m. med på kartongen att internetuppkoppling är ett krav.
Men det är ju skitsamma så länge Boxee existerar... vill man klaga på buggar ska man vända sig till Boxee helt enkelt sen kan man ju intala sig vad man vill. För att återknyta till huvudfrågan, svaret är att exakt samma buggar inkl audio dropouts kommer Iomegan att ha och det hjälper i det fallet heller att klaga på Iomega.
Som kund håller jag med om att man bör bara behöva vända sig till säljaren för att få problem åtgärdade, men nu finns ju följande reservation i lagen om hindret ligger utanför säljarens kontroll. Vilket är fallet då det är Boxee och Intels fel att ljudet inte fungerar.
#3530
Postad 14 October 2011 - 13:30
lappen71
  • lappen71
  • 2053 inlägg
Du behöver inte läsa utan du kan scrolla förbi men det är ontopic så det bryter inte mot några regler.
Jag har ljud på på både play kanalerna.
En sak jag märkt efter uppdateringen att Airplay fungerar mycket bättre.
Det är fortfarande en liten fördröjning när man byter låt,stänger av men inte alls som förut.
Men det kan absolut bli bättre
#3531
Postad 14 October 2011 - 14:21
PalmiNio
  • PalmiNio
  • 8074 inlägg
Då var appen jag pratade om officiel.
Spotify.....
Hoppas den funkar bra
#3532
Postad 14 October 2011 - 14:30
Unregisteredb8e57d04
  • Unregisteredb8e57d04
  • 931 inlägg
*slänger sig mot BB.n och testar*....underbart!
edit: testar lite nu, känns helt klockrent och enkelt att använda.
Redigerat av Unregisteredb8e57d04, 14 October 2011 - 14:48.
#3533
Postad 14 October 2011 - 16:07
alienrebel
  • alienrebel
  • 1556 inlägg
Finns det nån bra app till android eller iphone/Ipad så man slipper sätta på tvn om man vill köra spotify genom boxee??
#3534
Postad 14 October 2011 - 16:39
dj_komodo
  • dj_komodo
  • 1194 inlägg
Spotify.....
min BB är nu helt komplett... fan va jag älskar den nu med spotify och airplay (funkar dock inte lika bra som min ATV2)... Allt funkar till 100%, play kanalerna, mina filmer och serier från NASen & min bärbara, Helt ljudlös...
#3535
Postad 14 October 2011 - 16:43
Gundeho
  • Gundeho
  • 287 inlägg
Tjohooo!! Spöttify i boxee ;-))
Hittar bara inte hur man söker låtar?!?!
Å hur lägger man till den som app??
#3536
Postad 14 October 2011 - 17:00
  • 931 inlägg
Du måste uppdatera BB.n för att hitta appen...funkar bara med premuim konto till spotify också.
#3537
Postad 14 October 2011 - 18:15
Benedict
  • Benedict
  • 257 inlägg
Tack för hjälpen Lappen71 angående browsern.
Skulle vara tacksam om det finns någon bra guide eller wiki till hur man ska ställa in sin boxee för bästa bild och ljud för TVn och Recievern. Finns för mycket valmöjligheter i inställningarna för att min hjärna ska kunna ta till det just nu.
Har en Sony Bravia 46EX503 och Onkyo 674.
Sedan vore jag också väldigt tacksam om någon kunde visa hur man ska göra för att koppla sin dator (Win 7 X64). Jag har inte fått det att fungera.
Har Boxeen kopplad med ethernet-kabel till väggen. Datorn samt alla andra datorer i huset (hyreshus, stadsnät) syns, men jag kommer inte åt den.
Funderar även om det går att koppla en eller två hårddiskar till min router D-Link Dir655, och ha de utdelade därifrån.
Funderar på att ev. köra Boxeen med trådlös uppkoppling men är osäker på om det blir problem då med att streama filmer över internet.
#3538
Postad 14 October 2011 - 19:06
Ludde76
  • Ludde76
  • 145 inlägg
Ja, ingen sökfunktion alltså??
Ganska värdelöst eller hur tänkte dom?
#3539
Postad 14 October 2011 - 19:25
apansson17
  • apansson17
  • 52 inlägg
Spotify fungerar bra och ser bra ut men jag saknar shuffle. Skittråkigt att höra playlisterna rakt igenom. Hoppas dom fixar det framöver.
#3540
Postad 14 October 2011 - 22:32
e3henri
  • e3henri
  • 3266 inlägg
Suck en av mina issues har blivit värre med 1.2.1.20451 :(
Tidigare hade jag audio-dropouts på DD5.1 på DVD filmer, nu börjar dessutom filmen gå i slowmoting för att sedan gå i 10ggr hastighet. Att ljudet faller bort går att leva med, men att bilden skenar iväg....dubbel suck.
P.S. Naturligtvis rapporterar jag detta i JIRA till boxee förrutom att gnälla här :)
#3541
Postad 14 October 2011 - 22:42
MalcomX
  • MalcomX
  • 1711 inlägg
Så irriterande
Inget nytt i nya firmwaren som jag har nytta av som bara ser på film
Nu har den börjat hänga sig, efter att det stått på en stund
Tvungen att stänga av med knappen på boxen
Har hänt 7 gånger på en och en halv dag
Hatar när man man skall stoppa in en massa skit i boxarna så det viktigaste inte fungerar
Nästa mediaspelare skall vara av kvalite och filmuppspelning skall ha prio ett
I denna boxen verkar det vara appar och annat skit som prioriteras
Redigerat av MalcomX, 14 October 2011 - 22:44.
#3542
Postad 14 October 2011 - 22:46
Schluug
  • Schluug
  • 164 inlägg
Äntligen Spotify i Boxeen, även om appen har mer att önska så är det en bra start. Det verkar som att tanken är att editera playlistorna på datorn och spela dem på Boxeen?
#3543
Postad 15 October 2011 - 06:44
ssstll
  • ssstll
Nu har min burk slutat att uppdatera filerna. Plötslig hade 600 filmer och 1000 serier försvunnit i samband med den nya fw releasen. När jag sätter den på scanning händer inget. Den har stått på hela natten utan reslutat.
Någon annan med samma problem?
#3544
Postad 15 October 2011 - 09:12
ssstll
  • ssstll
Factory reset. Back in business.
#3545
Postad 15 October 2011 - 10:22
DrBosa
  • DrBosa
  • 280 inlägg
Jaha, enligt IDG så behövs inte Premium?
http://www.idg.se/2....nt-med-varandra
#3546
Postad 15 October 2011 - 12:14
  • 931 inlägg
Och när jag provade utan premium så stod det att premium krävdes, fixade premium och vips! så var man igång.
#3547
Postad 15 October 2011 - 12:45
LimpFish
  • LimpFish
  • 55 inlägg
Jag fick min Boxee i förrgår... fixade VPN idag, Netflix och Vudu dyker upp som appar, men när jag trycker på dem händer inget alls... Någon som har några tips?
#3548
Postad 15 October 2011 - 14:36
  • 2986 inlägg
Antagligen för att de inte testat appen utan bara läst Boxees pressmeddelandet.
Spotify själva går ut med rätt info.
fakta: inga free eller unlimted. ;)
#3549
Postad 15 October 2011 - 19:46
e3henri
  • e3henri
  • 3266 inlägg
Har inte hunnit testa, men riktigt surt i så fall. Jag har bara upptäckt försämringar än så länge på uppdateringen.
Edit: Fast sambaanslutningen fungerar bättre nu. Känns som den kopplar upp snabbare.
Redigerat av e3henri, 15 October 2011 - 19:48.
#3550
Postad 15 October 2011 - 21:34
Unregistered2a850725
  • Unregistered2a850725
  • 291 inlägg
Senaste firmwaren har fukkat upp min BB fullständigt, både avi och mkv buffrar ofta och många gånger avslutas filmen helt... bittert...
Har ni några tips på vad jag kan göra? Factory Reset? Byta från NFS till SMB?
