Efter att hört Cardas kabel till hd800 blev man en "cable beliver". En av dem bästa kablarna till hd800 kostar lika mycket som själva luren kostar. Och den är "hardwired" (inte bara byta ut, alltså måste lödas om) dem har jämfört med deras kabel och original kabeln och gjort ett sammanhang på ljudet.
Jag håller för det mesta med vad dem skriver om vad "stock" kabeln gör för "fel". Speciellt " midrange lacks warmth and richness" "Treble : "over emphasized and out of balance as it dominates most recordings".
Soundstage
Stock Cable: Very Good but can sound disoriented and out of focus with certain recordings.
Voice Cable: Excellent. Soundscape expands
separating voices and instrument with
improved richness. The music is now
presenting as if listened to in a well tuned
concert hall - emotionally engaging the
listener as does live music.
Bass
Stock: Good but a little weak and distant in relation to the soundstage.
Voice Cable: Excellent. Deeper, richer with clear
definition and punch. Integration with the
midrange is now seamless offering natural
clarity between the two. One of the most
important improvements the VOICE
offers.
Midrange
stock cable: Good but lacks warmth and richness. In
balance and suited for the rest of the
frequency characteristics of this cable
design But with the stock cable less than
optimal with a "hard" delivery which
contributes to the over emphasized treble.
Voice Cable: Excellent - warmer and fuller. Improves
and stays in balance with the bass and
treble improvements. This added
dimension adds a emotionally engaging
factor which really displays how wonderful
the HD800's will perform.
Treble
stock cable: Good but over emphasized and out of
balance as it dominates most recordings.
Voice Cable: Excellent integration with low and mid-
range delivering balanced life like detail
with a full realistic balance. A rich,
detailed but warm treble is now present
and this is a key improvement as it
eliminates a major problem introduced by
the stock cable.
http://stefanaudioar.....on Chart.html dem jämför mer också!
Redigerat av Unregistered9dec5957, 02 June 2011 - 17:30.
