JVC DLA-RS45, 55, 65 ÅR 2011
42 svar i tråden
Skickat 19 oktober 2011 - 22:59
http://pro.jvc.com/p...roductId=PRO2.2
JVC Professional släpper 3 st nya 3D Full HD projjar med inbyggt linsminne för 2.35:1 filmer och industriledande nativ on/off kontrast från 24995kr!
[/center]
New JVC Home Theater Projectors Display Images With 4K Precision
Four new models upconvert images to four times the resolution of Full HD.
[/center]
INDIANAPOLIS, September 8, 2011 – JVC today introduced new home theater projectors that display 2D HD content with full 4K precision. They feature JVC’s new e-Shift technology capable of projecting images with 3840 x 2160 pixel resolution, four times that of full HD. The upconverting technology is available in four of seven new 3D-enabled projectors that boast a wide range of advancements, including higher native contrast than previous models for levels that remain unmatched by any other home theater projector.
The new projectors are the Procision Series DLA-X90R, DLA-X70R and DLA-X30, marketed by JVC’s Consumer Electronics Group, and the Reference Series DLA-RS65, DLA-RS55, DLA-RS4800 and DLA-RS45, available through JVC Professional Products Company. JVC’s 4K e-Shift technology is featured in the top four models, while all seven new projectors offer other advancements that boost picture quality, improve 3D performance and enhance functionality.
Earlier this year NHK Science & Technology Research Laboratories, NHK Engineering Service Inc. and JVC Kenwood Corporation collaborated in the development of a Super High Vision projection system that utilizes e-Shift technology. Now, that technology is available in the DLA-X90R, DLA-X70R, DLA-RS65 and DLA-RS55. Using e-Shift, 2D HD content is upconverted and scaled to a 4K signal (3840 x 2160) and the e-Shift technology displays it at full 4K precision. Compared to a Full HD (1920 x 1080) image, that’s twice the horizontal and vertical resolution and four times the number of pixels, or over 8 megapixels. The result is a stunningly detailed image with minimal aliasing artifacts found in standard HD displays.
All seven projectors are 3D-enabled and offer several 3D performance and feature enhancements:
  • 2D-to-3D Converter – Converts 2D program material to 3D using technology derived from JVC’s professional 2D-to-3D converter. Included are user adjustments for 3D depth and subtitle geometry correction;
  • JVC’s 3D anamorphic feature combined with an optional anamorphic lens make it possible to enjoy 3D movies in the popular 2:35 scope format;
  • Compatibility with a wider range of 3D broadcasts, including 1080p/24 and 720p side-by-side formats
  • Brighter 3D images than previous models are possible through the use of an improved driver that keeps the shutter on the active shutter 3D glasses open longer, thus allowing more light to enter, while at the same time minimizing cross talk;
  • A Cross Talk Canceller further reduces cross talk through analysis of the left eye and right eye signals and applying appropriate correction;
  • A parallax adjustment allows the user to tailor the 3D image effect;
  • Direct access to 3D formats and settings on the remote control.
In addition, the top four models -- DLA-X90R, DLA-X70R, DLA-RS65 and DLA-RS55 – have been designed to achieve THX® 3D certification and are scheduled for testing by THX. During the THX 3D certification process, more than 400 laboratory tests are conducted, evaluating color accuracy, cross-talk, viewing angles and video processing to ensure the superior out-of-the-box 3D and 2D display performance that home theater enthusiasts demand.
Other features shared by these four models include:
  • ISF certification;
  • Enhanced installation adjustment, including a new 1/16th pixel shift function to precisely tune convergence via 121 adjustment points (11 vertical x 11 horizontal) and an increased number of screen mode preset positions, up to a maximum of 255
  • An upgraded optical engine that further improves black level and native contrast
  • 7-Axis Color Management System;
  • ISF and THX Calibration via corresponding software to allow advanced adjustment by certified ISF calibrators;
  • Three Xenon lamp color modes that emulate the characteristics of high-end movie projectors.
Other enhancements new for all seven 2012 projectors are:
  • Lens memory function – Three memory settings store custom focus, zoom and horizontal/vertical lens shift position. This allows a constant height display of 4:3, 16:9 and 2:35 scope content without an additional anamorphic lens
  • A LAN connection that provides enhanced system control and easy firmware or screen mode updates.
To provide enthusiasts with a true measure of performance, JVC has long focused on native contrast and refused to artificially enhance contrast specifications through the use of a dynamic iris. For 2012, native contrast has been improved across the entire line, ensuring that every frame consistently and faithfully reproduces peak whites and deep blacks.
The new flagship projectors, the DLA-X90R and DLA-RS65, are built using hand-selected, hand-tested components and provide a 120,000:1 native contrast ratio. For 3D viewing, both models come with two pairs of 3D glasses and a PK-EM1 3D Signal Emitter. Both projectors also have a three-year warranty.
The DLA-X70R and DLA-RS55 offer 80,000:1 native contrast ratio, while the DLA-X30 and DLA-RS45 offer 50,000:1 native contrast ratio. All four projectors come with a two-year warranty. The DLA-RS4800 is ISF certified, offers a 55,000:1 native contrast ratio, comes with a three-year warranty, and includes a spare lamp. JVC Active Shutter 3D Glasses and the PK-EM1 3D Signal Emitter are sold separately.
All seven new projectors feature three 0.7” 1920 x 1080 D-ILA devices and are designed around JVC’s third generation D-ILA High Dynamic Range optical engine that is optimized to provide exceptional native contrast ratios without a dynamic iris to artificially enhance contrast specifications. A directed light integration system and wire grid polarizer ensures optimum light uniformity and minimal crosstalk in the light path. In the top four models (DLA-X90R, DLA-X70R, DLA-RS65 and DLA-RS55) a combined 16-step lens and lamp aperture adjustment allow the user to optimize the f-number (relative aperture) of the optics system in all steps. The DLA-X30, DLA-RS45 and DLA-RS4800 feature a 16-step lens aperture.
The new JVC D-ILA home theater projectors will be available in November at the following prices:
DLA-X90R/DLA-RS65 $11,999
DLA-X70R/DLA-RS55 $7,999
DLA-RS4800 $4,995
DLA-X30/DLA-RS45 $3,499
[/center]
In addition to the JVC PK-AG1 active shutter 3D glasses currently available, JVC announced new glasses – the PK-AG2, which are more compact, lighter and rechargeable. The PK-AG1 glasses remain available and are ideal for use over eyeglasses. Both models are compatible with the currently available PK-EM1 3D Signal Emitter.
About JVC Americas Corp.
Headquartered in Wayne, New Jersey, JVC Americas Corp. is a wholly-owned subsidiary of JVC Kenwood Corporation. JVC Americas distributes a complete line of video and audio equipment for the consumer and professional markets. For further product information, visit JVC’s website.
Inväntas sverige December 2011...
Det här inlägget har ändrats av jeppeman 28 november 2011 - 06:48
Skickat 19 oktober 2011 - 23:10
:wub:
http://www.prisjakt....ams=l=s77419884
Skickat 19 oktober 2011 - 23:23
http://translate.goo...&hl=sv&ie=UTF-8
Skickat 20 oktober 2011 - 07:27
Som ni säkert vet så är det endast kosmetiska skillnader mellan JVC's professionella och konsument projektorer,så här kommer en förklaring.
DLA-X90R=DLA-RS65 84995kr
DLA-X70R=DLA-RS55 58495kr
DLA-X30 =DLA-RS45 24995kr
Skickat 20 oktober 2011 - 08:04
Citat
Precis, så poängen med en ny tråd är?
Skickat 21 oktober 2011 - 19:03
Kanske göra folk uppmärksamma att de inte ska köpa X30 för 32 000:- när du kan få identisk prestanda för 25 000. De höjde priset med 4000 idag, men bör sjunka igen när det blir lite konkurrens (vilket det ju ej finns på X30)
Skickat 21 oktober 2011 - 22:51
Historiskt sett har jvc projarna aldrig gått ner i pris för ån de är EOL.
Prisbilden på RS och X i övriga världen ligger lika, så det känns konstigt att de har olika pris i Sverige.
Skickat 23 oktober 2011 - 18:48
Skickat 07 november 2011 - 22:17
http://dila.jvc.com/
Skickat 19 november 2011 - 19:56
Lens Memory Function The DLA-RS45 has 3 memories for lens offset, focus and zoom. This allows you to set a constant height and use the same projection screen for 1.78, 1.85 and 2.35 aspect ratios without an anamorphic lens. Your pre-assigned aspect settings are called up by pressing the "lens memory" button on the remote control. For example, assuming that you have a 2.35 screen and want to watch a 16:9 movie, you can resize it with the push of a button. If your movie is a 2.35 film, you can take full advantage of your Cinemascope screen.
Skickat 19 november 2011 - 21:45
DLA-RS4800 verkar vara exklusiv för professional segmentet.
Undrar vad den har att bjuda på?
Verkar prissätta sig mellan X30 o X70 så något extra bör den ha, men vad :o
Enda skillnaden jag hittar i texten är
Det här inlägget har ändrats av bigbadboogie 19 november 2011 - 21:46
Skickat 19 november 2011 - 22:00
Isf, borde innebära att den har cms.
Skickat 19 november 2011 - 22:19
Har för mig att det är CMS och ingen 4K funktion samt lite boostad kontrast. Optik vet jag ej.
Och vad jag förstår supportat inte jvc konsument garanti på RS.
Det här inlägget har ändrats av Jokkmokksjocke 19 november 2011 - 22:24
Skickat 19 november 2011 - 23:15
Angående garantin så är det rätt ointressant då alla större återförsäljare lämnar minst 1års garanti plus att du enligt lag har totalt 3 års reklamationsrätt. De som bokat den för 25kkr har gjort en riktigt fin affär.
Skickat 19 november 2011 - 23:28
Sant, det är det företag som säljer till konsumenten som måste lämna garanti enligt konsumentköps lagen. Och den känns ju trygg och glasklar ;) Mellan företag finns ingen lag om att lämna garanti.
Ja man får en guldring också och en engelsk manual.
Skickat 04 december 2011 - 20:30
Det här inlägget har ändrats av jeppeman 04 december 2011 - 23:21
Skickat 16 december 2011 - 16:39
http://www.creativev...t/jvc_dla-rs45e
Skickat 18 december 2011 - 14:42
25012 kr och dom levererar till sverige oxå :o
Skickat 18 december 2011 - 15:18
Skillnad på X30 och RS45?
Jämförde på prisjakt och det enda som skilde var 2kkr och nätverksanslutning, men är det verkligen det enda
Det här inlägget har ändrats av mikeman 18 december 2011 - 15:21
Skickat 18 december 2011 - 15:35
  • spuj
  • 352 inlägg
Ingen
Skickat 19 december 2011 - 16:50
kortare garanti och engelsk manual, Samt guld ring på RS.
Skickat 19 december 2011 - 17:21
det var jag som fyllde i fel här på prisjakt nätverksanslutning nu ändrat...
Skickat 19 december 2011 - 17:58
Har du fått svensk manual??
Det har inte jag...
Skickat 19 december 2011 - 22:26
Installationsmanualen har nu dykt upp hära: http://pro.jvc.com/p...tion_Manual.pdf
Skickat 20 december 2011 - 06:55
http://www.tnpbroadc...tor-p-8676.html
Skickat 12 januari 2012 - 18:52
Åå... Billiga ju... Så frestad... Bara skalet och garantierna men om man nu köper utomlands, är det ens idé att räkna med garantistöd?
Brukar det funka bra ändå? Verkar den vara lite halvt mellankvalité så risken är snäppet högre att behöva nyttja garantierna?
Iofs funderar jag på lacka om skalet isf och då försvinner väl allt vad garantier heter ändå, hehe.
Sistnämnda länk innebar ca 20180kr + post... Någon butik i sverige med detta priset?
Skickat 12 januari 2012 - 19:49
Det är väl pund & inte euro. Det blir mer än 20k.
Skickat 12 januari 2012 - 20:29
Mjahaja... okej... :(
=24270,46 + post
Det här inlägget har ändrats av yrrol2 12 januari 2012 - 20:30
Skickat 19 januari 2012 - 20:16
RS45 fanns inte med vitt skal anar jag? (farligt att läsa sig till svaret) hehe
Skickat 20 januari 2012 - 09:22
Nopp ingen vit
Skickat 20 januari 2012 - 16:33
Läste att ni firmware var ute till x30,70,90... dessa funkar till rs45 också då om maskinerna är likadana ?
Skickat 20 januari 2012 - 19:35
Vars läser man det då? Hört något om vad den firmwaren fixar?
Skickat 20 januari 2012 - 19:52
nämndes i x30 tråden.. länken avslöjar redan där rs45 ser jag nu
http://www3.jvckenwo...date/index.html
Skickat 24 januari 2012 - 15:54
Nu har art på Projector reviews spenderat 50 timmar med DLA-RS45 och synat den i sömmarna:
http://www.projector...-rs45/index.php
Skickat 14 april 2012 - 17:36
20345kr + frakt...
Värst vad de står sig i pris, de börjar ju bli gamla.. hade hoppats på lägre så man hade nånting tills 2012modellerna dykerupp..
- eller ja, de har ju iofs tappat 1000kr i månaden ifall man ser när jag sist skrev.. heh
Det här inlägget har ändrats av yrrol2 14 april 2012 - 17:37
Skickat 14 april 2012 - 20:01
24 611 + frakt va?
Tror där ligger en till salu på forumet för runt 22 000 inkl emitter o brillor , 200h på lampan. Det är bra pris+
Skickat 14 april 2012 - 22:53
Ah, jag tänkte euro istället för pund... igen... :unsure:
Skickat 09 maj 2012 - 21:52
http://www.projector...C_DLA-RS45.html
Skickat 26 augusti 2012 - 14:35
:mellow:
Nu har Scandinavianfoto sänkt ner priset till 24995kr för JVC DLA-RS45 igen!
http://www.prisjakt....kt.php?p=995891
Skickat 26 augusti 2012 - 19:36
Någon som har bra erfarenheter av att handla på ebay? Ser att det ligger några DLA-RS65 och x90 för ca 55tkr, det ju halva priset jämfört i Sverige.
Skickat 16 oktober 2012 - 18:17
Nu säljer Projectorpoint i london ut JVC DLA-RS45 (samma som DLA-X30).~18000kr inklusive emitter och 2 stycken 3d glasögon vill dom ha: http://www.projector...C_DLA-RS45.html
Skickat 16 oktober 2012 - 18:26
Riktigt bra pris!
Skickat 22 december 2012 - 19:30
Ops
Det här inlägget har ändrats av Sirmiax 22 december 2012 - 19:34
Detta forum sponsras av
  • Riktigt läckra blev dom på Memento stativen ;)
    Hifi_Perka
    2013-05-25 00:42:26
  • Bättre än så här blir det inte :P
    Hifi_Perka
    2013-05-25 00:36:08
  • Här har jag monterat de två duklagrena i fästskenan.
    Mistermister
    2013-05-24 22:15:30
  • Jag satte först fast ramen med ståltråd
    Mistermister
    2013-05-24 22:14:09
  • Nu är dukramen på plats
    Mistermister
    2013-05-24 22:12:29
