Korsun K-DM200
14 svar till detta ämne
Postad 13 oktober 2004 - 15:34
Matsen
  • Matsen
  • 2 792 inlägg
Halloj!
Kom över DENNA när jag satt å smygsurfade lite på jobbet.... <_<
Power output: 2×125W (8Ω), 2×250W (4Ω), 2×400W (2Ω)
THD: <0.1%
S/N: ≥106dB
Frequency Response: 5Hz - 100KHz
Net Weight: 27.5 Kg (shipping weight 37.5 kgs)
Pris: 599$ + frakt (Prisuppgift från timAudio)
Babelfishad text om stärkaren:
The K-DM200 power amplifier the performance, the acoustic fidelity, the structure which enlarges by extremely the grade power down to the needed materials for the design reference, uses the true double sound track (DUAL MONAURAL) the formula, two groups amplifiers are completely independent. This amplifier power source supply is extremely abundant, take two 600VA high grade annular power transformer separately as the about sound track power supply, the filter electric capacity total quantity reaches as high as 100000 微法, the output stage actuates with 16 150W/15A/50MHz high speed high efficiency transistor, this machine for the pure metal module type structure, massively uses the aluminum alloy material and the large-scale aluminum alloy radiator structural element, the input signal plug and specially is the K-DM200 design copper nature wiring column complete gold-plating, K-DM200 uses the expensive high-quality glass fiber two-sided engraving plate, moreover from massively uses 1% precision the metallized film resistor and high quality polypropylene electric capacity also sufficiently obviously K-DM200 is section extremely takes the acoustic fidelity the product. K-DM200 each sound track is equipped with the independent precise protection circuit, between each sound track protection circuit uses photoelectricity coupling way realization synchronization, the K-DM20O reality listens the effect regardless of the sound image localization accuracy, the entire frequency sound scope trim, the low frequency dynamics, the speed and so on achieved goes against a level machine kind of level, not only that, K-DM20O is good to the load controlling force, is extremely has the sound musical sense the after level amplifier. Through K-DM2OO, you was allowed to enjoy to before has missed the music detail.
Är det ngn som sett ngt om denna förut? Den finns inte med på Coems prislista så jag antar att den är ny....
Edit: La till prisuppgift och mumbojumbotext
Redigerat av Matsen, 14 oktober 2004 - 08:38.
Postad 13 oktober 2004 - 15:41
Unregistered3ecb30f4
  • Unregistered3ecb30f4
  • 675 inlägg
Det är en gammal stärkare.
finns på korsuns hemsida:
http://www.korsun.co...ucts_kdm200.htm
Postad 13 oktober 2004 - 15:48
Matsen
  • Matsen
  • 2 792 inlägg
Babefishad K-DM200 länk
Bindestrecket var på fel ställe hos Timaudio - därför gav inte google ngt först... <_<
Fast där ser man - jag som är lite okunnig i deras produkter då bara....
Fast likväl kvarstår frågan om någon vet ngt mer om den än det lilla som står på nätet?
Någon som sett ngn recension? Pris? (Har mejlat Tim ang. pris men inte fått svar...)
Postad 13 oktober 2004 - 16:02
  • 675 inlägg
Pris står på Korsuns hemsida: (inhemska priset i kina)
4380 Yuan vilket är ungefär 3800 SEK
Henrik
Postad 13 oktober 2004 - 17:39
Matsen
  • Matsen
  • 2 792 inlägg
Hmmm - försökte hitta ngt pris men lyckades inte! Hade hoppats på lite lägre pris dock!
Fast den verkar ha bra fin effektkub!
Lägger in ett par bilder till.... <_<
Postad 13 oktober 2004 - 18:16
Unregistered94f939c2
  • Unregistered94f939c2
  • 773 inlägg
Jobbigt att ingångarna sitter så långt ifrån varandra. Nu måste man ju reda upp den så fint ihopsatta lakritskabeln... Eller det kanske inte är några problem? <_< Jag väntar på en rca från marcuscables.
Är det någon som hört några förstahandsintryck av hur den låter? Kanske vore nåt att komplettera hembion med... När jag skaffar surroundförsteg förstås.
Postad 13 oktober 2004 - 18:21
nox
  • nox
  • 949 inlägg
0.1% THD är dock litet väl mycket tycker jag.
MvH /nox
Postad 13 oktober 2004 - 21:26
Unregistered80766140
  • Unregistered80766140
  • 478 inlägg
MvH /nox
THD: <0.1%
Mindre än 0,1%
Postad 13 oktober 2004 - 21:38
nox
  • nox
  • 949 inlägg
MvH /nox
THD: <0.1%
Mindre än 0,1%
Vilket betyder att det är 0.1% THD som minst <_<
Det är ungefär som när tidningar skriver 'över 70 000kr' när det handlar om 70 000kr och femtio öre.
Om dom lyckats mätt upp lägre så skulle dom utan tvekan skriva det.
MvH /nox
Redigerat av nox, 13 oktober 2004 - 21:39.
Postad 13 oktober 2004 - 21:56
Unregistered6dda665b
  • Unregistered6dda665b
  • 438 inlägg
Det är ingen stärkare utan ett slutsteg :D :lol: .
Det finns, som jag nämt i en annan tråd, ett matchande
försteg också till detta slutsteg. Verkar dock inte som
någon av "våra" kinaförsäljare saluför dessa <_< <_< .
Hade varit klart intresserad av recensioner av denna
kombo.
Liten länk till försteget: http://www.korsun.co...ucts_ksl260.htm
Postad 13 oktober 2004 - 23:51
  • 478 inlägg
MvH /nox
THD: <0.1%
Mindre än 0,1%
MvH /nox
De Kinesiska är inte så bra när det gäller specifikationer. Om <0.1% kan vära 0.003% eller 0.1% kan man ju aldrig veta när man har inga mätningar som referens.
Redigerat av Unregistered80766140, 13 oktober 2004 - 23:53.
Postad 14 oktober 2004 - 05:02
Matsen
  • Matsen
  • 2 792 inlägg
[quote name='Drengur' date='Oct 14 2004, 00:51 '] MvH /nox [/QUOTE]
De Kinesiska är inte så bra när det gäller specifikationer. Om <0.1% kan vära 0.003% eller 0.1% kan man ju aldrig veta när man har inga mätningar som referens. [/quote]
Tror det har sagt förr å det kommer säkerligen sägas igen...
Man ska inte stirra sig blind på specar. de låter ingenting - det är ens egna öron som avgör om det låter bra och det är först när man hör grejerna som man kan avgöra det. <_<
Jag fastnade för denna för att den ser så grymt maffig ut samt att den verka ha en bra effektkub.
Jag vill ju ha ett extra slutsteg till mina frontar och nu står det mellan denna, Jungson JA99C och Classic 8.0.
Postad 14 oktober 2004 - 10:12
Unregistered5cf1b4b0
  • Unregistered5cf1b4b0
  • 719 inlägg
Mycket inponerande pjäs det där,är det någon här som har detta eller åtminståne lyssnat på slutsteget.
Såg priset blev runt 4000 men är det inkl. frakt.Sen tillkommer väl moms och tull och sånt skit eller ?
Är väldigt intresserad av det,klar ståndvarning.........
Postad 14 oktober 2004 - 11:34
Matsen
  • Matsen
  • 2 792 inlägg
599$ är ju TimAudios pris - det kan ju skilja lganska mycket mellan de olika "butikerna". Jag har ställt en prisförfrågan hos Coem oxo men inte fått svar än.
Priset är exkl. frakt och moms men räknar man med 4$/kg (typiskt fraktpris i gruppköpen) + tull så borde man landa runt 6000 Svenska enkronor....
Som jämförelse så skulle man få 2 st Classic 8.0 för samma peng eller mindre!!! <_<
Edit: fick pris från Coem... citat Norman "the korsun 200 is not on the list in china" <_<
Redigerat av Matsen, 14 oktober 2004 - 11:46.
Postad 14 oktober 2004 - 13:07
Christopher
  • Christopher
  • 1 039 inlägg
Tro vad norman närmare bestämt coem tar för ett sådant :] Lär kanske bli den ehum 3:e saken man ska köpa då <_< <_<
