Anthony Gallo Acoustics reference 3
36 svar till detta ämne
Anthony Gallo Acoustics Nucleus Reference 3.1 (Golvhögtalare) 1 9.166666 (5) Inga priser
1 relaterade trådar
Postad 18 April 2005 - 22:50
avancerar
  • avancerar
  • 1054 inlägg
.....högtalare.
vissa av er kommer att säga att det är det fulaste ni sett, medans vissa av er kommer nog tycka att denna skapelse är ganska intresant.
"It seems completely risk-free to predict that this speaker is destined to become a true classic in due time. While nothing in our material world is perfect safe for new love, the Anthony Gallo Acoustic Reference 3 is about as perfect as any under-$5,000 speaker has a bloody right to be. It also has the cheekiness to force many higher-priced entries into having a lot of fancy explaining to do."
6moons.com
The new Gallo Reference 3 was very much designed with the performance- and decor-conscious audiophile in mind.
This innovative new model builds on the design philosophies of our original, now legendary reference products - the Nucleus Solo and the Nucleus Reference. Martin DeWulf of Bound for Sound calls it "the loudspeaker surprise of 2004... a mechanical tour de force... a masterpiece of musical value... the loudspeaker savior of the middle class..."
A three-year development process was required to complete the design, with much of this time being invested in critical listening tests conducted by Anthony Gallo and his team of critical beta testers. It then garnered The Absolute Sound's "Product of the Year 2004" award.
This loudspeaker is uniquely equipped to demonstrate the advantages of the leading high resolution formats, DVD Audio and SACD. Very few high-end speakers, including the majority of $10K+ models, can approach, much less equal, the Reference 3's extended high frequency response - and none offer near omni-directional (300 degree) dispersion. For the ultimate in neutrality and transparency, the Reference 3 operates without a crossover across most of its bandwidth - from 125Hz to 50kHz.
Click to Enlarge
The Reference 3 features a revised version of our patented CDT™ tweeter, the CDT II™. A three-position transformer-coupled tweeter level control accommodates a range of room acoustic variables allowing -/+2dB cut and boost by selecting different transformer taps.
A pair of 4-inch hyperbolic carbon fiber drivers - each housed in its own ultra rigid, low diffraction 5-inch stainless steel sphere - handle the critical midrange frequencies without a crossover to the CDT II™ tweeter.
Low frequencies are reproduced by a long-throw, dual voice-coil 10-inch woofer. That magnificent driver is acoustically loaded into a sealed alignment that includes the Reference 3's hollow cast aluminium chassis which is filled with our S2 technology air density treatment.
The Reference 3 is equally comfortable being used in stereo or home theater set-ups. The Reference 3 SA (subwoofer amplifier) is our 2 x 240 watt amplifier/active crossover/bass EQ option to extend the Nucleus Reference 3's bass response to a room-shaking 22 Hz by driving the woofers' 2nd voice coil directly. The Reference 3/SA combo is the smartest way to obtain fullrange performance with true stereo subwoofer bass extension from a small, unobtrusive package that will give $10,000/pr behemoths a run for their money.
The Reference 3 also features our proprietary and patented "Roundsound S2" technology. S2 decouples the backwave of the driver from the air inside the enclosure. The benefits of S2 include superior low frequency extension, improved transient response and a substantial increase in efficiency.
Gold-plated all-metal binding posts ensure secure speaker wire connections and the full-height removable grille cage with welded steel support members lends a more traditional appearance. Each Reference 3 undergoes extensive computer quality control testing.
Specifications
Frequency Response 34Hz - 50kHz +/- 3dB
Frequency Response
(active bass): 22Hz - 50kHz +/- 3dB
Impedance top terminal 8 Ohms
Impedance lower terminal 4 Ohms
Sensitivity 88 dB/1 Watt/1 metre
Power Handling 350 Watts
Driver Dual 4" carbon fibre midrange drivers Custom 10" dual voice coil bass driver
CDT Tweeter 300 degree dispersion 3kHz - 50kHz
Midrange Driver Material Carbon fiber
Dimensions: 36.25" (H) x 8" (W) x 14" (D) with grill
35.5" (H) x 8" (W) x 14" (D) w.out grill Add 2 to 2.25" for spikes and spike protectors
Weight 47lbs each
Connections Gold plated all metal binding posts for secure wire connection
Finishes Black with black or stainless accents, black, Cherry or Maple base.
Warranty 5 Years Parts and Labor
Owner's manual click here for PDF file
  • Bifogad fil  4.jpg   92.06K   0 Antal nerladdningar
Redigerat av avancerar, 18 April 2005 - 22:58.
Postad 18 April 2005 - 23:00
avancerar
  • avancerar
  • 1054 inlägg
om man köper till detta steg å driver basarna aktivt, så spelar dom fina 10 tummarna rekt ner till 22hz :angry:
  • Bifogad fil  ref3_d.jpg   26.04K   0 Antal nerladdningar
Postad 18 April 2005 - 23:01
avancerar
  • avancerar
  • 1054 inlägg
lite mera fina bilder......
  • Bifogad fil  ref3_c.jpg   35.17K   3 Antal nerladdningar
avancerar
  • avancerar
  • 1054 inlägg
mera....
  • Bifogad fil  ref3_a.jpg   33.01K   0 Antal nerladdningar
Postad 18 April 2005 - 23:02
avancerar
  • avancerar
  • 1054 inlägg
å mera....
avancerar
  • avancerar
  • 1054 inlägg
å ännu mera....
Postad 18 April 2005 - 23:03
avancerar
  • avancerar
  • 1054 inlägg
åååå, inget mer.....
Postad 18 April 2005 - 23:32
alpha
  • alpha
  • Mega!
  • 1302 inlägg
Ja, det var nog det fulaste... :angry:
Postad 18 April 2005 - 23:38
avancerar
  • avancerar
  • 1054 inlägg
oväntat första svar..... :blink: ;) :angry:
Postad 19 April 2005 - 00:00
Unregistered8493ad0c
  • Unregistered8493ad0c
  • 228 inlägg
de var ju lätt mycket snyggare utan den där fula svarta kåpan! undrar hur de låter?
Postad 19 April 2005 - 01:14
avancerar
  • avancerar
  • 1054 inlägg
ja precis, kåpan är ju en valmöjlighet(eller skydd), jag själv hade nog spelat med den, ej på.
det skulle verkligen vara kul att få lyssna på ett par-då helst med det tillhörande bas steget.
kommer att åka å göra detta så fort det finns möjlighet, kanske redan finns?
är det ngn utav er som kanske redan har lyssnat på denna högtalare??
eller kanske sett den på ngn mässa??
mvh avancerar.
Postad 19 April 2005 - 02:43
JohnnyMann
  • JohnnyMann
  • 843 inlägg
Gamla nyheter.
Jag har lyssnat på denna högtalare för ett par månader sedan, den finns nu i affären vid bromma stormarknad(kommer aldrig ihåg vad affären heter).
Men hur den låter behåller jag för mig själv, eftersom trådskaparen inte anser mig vara hifikunnig *lol*
Redigerat av JohnnyMann, 19 April 2005 - 02:45.
Postad 19 April 2005 - 04:08
Lyssnade på den på High-end 05. Lät bra det lilla jag hörde.
Tycker den är riktigt läcker också. Annorlunda är kul.
Dom ligger ju inte så farligt i pris heller, jag trodde den skull kosta
mer pga den spektakulära designen.
edit: Fick med dom på kort också.
Redigerat av Martin.M, 19 April 2005 - 04:09.
Postad 19 April 2005 - 04:55
avancerar
  • avancerar
  • 1054 inlägg
Gamla nyheter.
har alldrig nämt ngt om att detta är en ny skapelse.
Postad 19 April 2005 - 05:01
avancerar
  • avancerar
  • 1054 inlägg
det ska iallafall finnas en tillhörande center snart/nu.
jag tippar på att denna högtalare spelar tight och med en fin diskantåtergivning, frågan är om mellanregistret å basen smälter ihop på ett bra sätt.
avancerar.
Postad 19 April 2005 - 08:24
Valhalla
  • Valhalla
  • 287 inlägg
Vad i..!
Hiskeliga saker! Undrar hur hög WAF de har.. :angry: :blink: ;)
Postad 19 April 2005 - 12:14
Unregistered37573cc1
  • Unregistered37573cc1
  • 8314 inlägg
ja, inte skulle då min fru vara vänligt sinnad till en sådan skapelse ... heller ... :angry:
Postad 19 April 2005 - 13:58
avancerar
  • avancerar
  • 1054 inlägg
det beror ju lite på vilken sorts inredning man "kör" med hemma oxå, dessa passar ju mkt fint en ligt mig i ett modernt hem, men kanske inte så bra i ett originelt hem.
ingen som har lyssnat på dessa?
avancerar.
Postad 19 April 2005 - 15:25
Schluug
  • Schluug
  • 164 inlägg
De hade helt klart jag kunnat köra med, utan kåporna såklart. Läckra och annorlunda tycker jag :angry:
Postad 19 April 2005 - 19:35
avancerar
  • avancerar
  • 1054 inlägg
De hade helt klart jag kunnat köra med, utan kåporna såklart. Läckra och annorlunda tycker jag :P
så känner jag oxå, hmmm, ska man skaffa sig ett par??????
Postad 19 April 2005 - 19:43
Gäst_sista_striden_*
  • Gäst_sista_striden_*
Se till att lyssna på dem, jag instämmer att de är läckra!
Hur är din möblering hemma, skulle högtalarna smälta in?
Postad 19 April 2005 - 20:35
skrotfot
  • skrotfot
  • 1201 inlägg
Såg/hörde dem på mässan i Sollentuna, tyckte basen var riktigt dålig, blöt och otajt. Blev rejält besviken faktiskt. Bäst på mässan var för övrigt Aurum Cantus, Volla - kan de ha hetat så..?
Postad 19 April 2005 - 21:23
Unregisteredf1616e6c
  • Unregisteredf1616e6c
  • 786 inlägg
Vad kostar de? Personligen tycker jag de är riktigt snygga...
Postad 19 April 2005 - 21:40
Har för mig dom ligger i trakten 20-25k ungefär.
Postad 19 April 2005 - 22:51
avancerar
  • avancerar
  • 1054 inlägg
dom kostar vad jag vet ca 29 995kr, men kanske går att få tag på billigare.
avancerar......
.....asså, dålig bas tyckte ngn, jaja, tur man själv kör med nht evolution då.... :P
Postad 20 April 2005 - 16:23
avancerar
  • avancerar
  • 1054 inlägg
vet du om dom drevs med det tillhörande bas steget när du lyssnade på dom???
avancerar.
Postad 20 April 2005 - 16:25
avancerar
  • avancerar
  • 1054 inlägg
hemma hos mig, så skulle dom enligt mig själv se riktigt läckra ut.
(tjejjen håller med mig, hon gillar dom)
avancerar.
Postad 08 June 2006 - 12:16
Rad
  • Rad
  • 23 inlägg
Död tråd men jag har köpt ett par Reference 3.05, dvs versionen utan switchen på baksidan
men ändå inte en 3.1 version. Skall spela in dem och sedan får jag försöka slänga upp lite bilder;)
Postad 08 June 2006 - 18:36
  • 786 inlägg
Gör det snabbt!! :)
Postad 26 June 2006 - 16:50
Rad
  • Rad
  • 23 inlägg
Nu ligger det bilder i galleriet ;)
Postad 27 June 2006 - 09:20
  • 786 inlägg
god damn vad coola de är!! :(
Postad 04 August 2006 - 18:52
Desertus
  • Desertus
  • 129 inlägg
Jag tycker att de är hur snygga som helst :blink:
Postad 05 August 2006 - 12:09
Unregistered8ca6fb75
  • Unregistered8ca6fb75
  • 516 inlägg
Instämmer med den övriga kören! Otroligt häftiga högtalare!
Mvh Andreas
Postad 04 September 2006 - 12:44
Rad
  • Rad
  • 23 inlägg
Lustigt att denna högtalare verkar dela folk i två läger...iaf när man kollar betygen som medlemmar ger på mitt galleri...Men en förkrossande majoritet tycker den är supercool! ;)
Postad 02 October 2007 - 13:19
blodapelsin
  • blodapelsin
  • 38 inlägg
Jag tänkte att jag skulle lägga in ett inlägg med mina intryck av denna lite annorlunda skapelse.
Jag har ägt dessa högtalare ett par månader och är än så länge väldigt nöjd.
Mina intryck är att de helt enkelt är väldigt bra, är transparanta. Bra drag i basen och har förmåga att spela härliga basgångar även på låg volym. Och det lite speciella diskantelementet som ser ut som en sån liten colaburk som man får på flyget, påminner i karaktären om elektroster och enligt min åsikt är det positivt.
Om man ska ta nåt om designen så at den nog lite antingen eller, antingen så tycker man om den eller så tycker man inte om den. Personligen faller den mig väl i smakenoch de flesta som har varit hemma hos miga har tyckt om den. Burkarna är dock avsevärt mindre än vad åtminstone jag trodde innan. De är tämligen små mycket beroende på att de inte har enstor låda som elementen sitter i utan en mer formsydd kostym där varje element sitter i ett eget kabinett som i sintur är monterad på en ställning. så innervolymen är rätt liten, detta leder till att det borde vara rätt tungdrivna, och de är det till viss del men en vanlig transistorförstärkare med en 80 watt klarar sig bra. Kanske inget för lite svagare rörföstärkare men jag har inte heller testat så ta det men en näve salt.
Ja är mycket nöjd och troratt flera skulle kunna bli det med dessa burkar.
Postad 02 October 2007 - 16:23
Unregistered32263a93
  • Unregistered32263a93
  • 649 inlägg
Jag har aldrig fått chansen att lyssna på dom, men är intresserad av dom då de har fått riktigt bra betyg i diverse tester. Kan du inte lägga upp lite bilder på dom?
Mvh Henrik
Postad 15 October 2007 - 11:24
blodapelsin
  • blodapelsin
  • 38 inlägg
jag ska försöka ta tag i det och lägga upp lite bilder så snart som jag har fått grepp på hur man gör.
Kan inte annat än att rekomendera dessa högtalare,är intresserad på hur mycket som förbättras om man fixar ett slutsteg som driver basen. de har ju ett eget slutsteg som är anpassat till högtalarens lite annorlunda lösning med dubbla talspolar på baselementet, blir lite som en inbyggd sub.
Dock är det lite dyrt tänkte man kanske skulle kunna lösa det med ett begagnat slutsteg eller nåt.
