Comfortably Delivering Video with HD Quality to the Latest HDTVs and A/V Receivers
With most entry-level DVD players, you’re only able to watch video playback in standard definition. If you’ve already invested in an HDTV or planning to in the near future, the DV-SP404E will take standard DVDs to high-definition quality by converting to 720p or 1080i through the High Definition Multimedia Interface (HDMI) on the rear. Also, with a 108 MHz/12-bit video DAC supporting progressive scan, you’re assured of spectacular viewing time-after-time. The DV-SP404E will do what you expect from higher-priced players, and it will also serve as a capable playback device for all your audio sources from your own CD library or computer-based digital files. Easily matched with AV receivers up to the high-end range, the DV-SP404E is a worthy addition to any home entertainment system.
Features
Audio & Video Features
• DTS Digital Out & Dolby Digital
• Plays DVD video, Video CD, MP3 disc, WMA disc, CD-R/RW, DVD±R/DVD±RW, DivX-encoded disc, JPEG-encoded disc, and PCM audio CD*
• HDMI digital interface
• Component, SCART and composite video outputs
• 96 kHz/24-bit audio DAC
• 108 MHz/12-bit video DAC
• PAL/NTSC progressive scan video output
• Coaxial digital output
• Last play memory (DVD/CD) and resume function
• Program memory and playback
• Disc Navigator for browsing video contents and disc files
• DVD and audio CD fast forward and reverse (4 speeds)
• Slow motion DVD playback (1/2, 1/4, 1/8 or 1/16 speed)
• Repeat play (title, chapter)
• Random play for video and audio (title, chapter)
• Subtitle and language switching function
• Zoom function (2x, 4x)
• Multi-aspect ratio (16:9, 4:3)
• Multi-camera angle
• Screen saver
*Discs that have not been properly finalized may only be partially playable or not playable at all.
Other Performance Features
• High-resolution onscreen display (English, Spanish, French,German, Italian)
• Audio dynamic range control
• Virtual surround setting
• 7 equalizer settings
• Front panel control cursor
• Supplied A/V and coaxial cables
• Full-function remote control
