Samyang objektiv
82 svar till detta ämne
Samyang MF 8/3,5 Fisheye CS for Canon
(Objektiv)
Rapporterad
5
(8)
Inga priser |
Samyang MF 8/3,5 Fisheye CS for Nikon
(Objektiv)
Rapporterad
1
(1)
Inga priser |
Samyang MF 8/3,5 Fisheye CS for Pentax
(Objektiv)
Rapporterad
3
(0)
3 888:- |
Samyang MF 8/3,5 Fisheye CS for Sony A
(Objektiv)
Rapporterad
3
(1)
Inga priser |
Samyang MF 85/1,4 AS IF UMC for Sony A
(Objektiv)
Rapporterad
1
(2)
3 042:- |
Samyang MF 85/1,4 AS IF UMC for Pentax
(Objektiv)
Rapporterad
1
(0)
Inga priser |
Samyang MF 14/2,8 ED AS IF UMC for Canon
(Objektiv)
Rapporterad
3
(6)
Inga priser |
Samyang MF 14/2,8 ED AS IF UMC for Pentax
(Objektiv)
Rapporterad
1
(0)
Inga priser |
Samyang MF 14/2,8 ED AS IF UMC for Sony A
(Objektiv)
Rapporterad
1
(0)
Inga priser |
Samyang MF 35/1,4 AS UMC for Canon
(Objektiv)
Rapporterad
3
(2)
Inga priser |
Samyang MF 35/1,4 AS UMC for Nikon
(Objektiv)
Rapporterad
1
(0)
Inga priser |
Samyang MF 35/1,4 AS UMC for Pentax
(Objektiv)
Rapporterad
1
(0)
Inga priser |
Samyang MF 35/1,4 AS UMC for Sony A
(Objektiv)
Rapporterad
1
(0)
5 164:- |
Samyang MF 14/2,8 ED AS IF UMC New for Nikon
(Objektiv)
Rapporterad
4
(5)
Inga priser |
Samyang MF 85/1,4 AS IF UMC AE New for Nikon
(Objektiv)
Rapporterad
2
(1)
Inga priser |
Samyang MF 800/8,0 DX MC for T2
(Objektiv)
Rapporterad
1
(0)
Inga priser |
Samyang MF 500/6,3 MC IF for T2
(Objektiv)
Rapporterad
1
(0)
Inga priser |
Postad 10 July 2011 - 23:50
Dennis_hembio
Dennis_hembio
986 inlägg
Ken Rockwell gillar Samyang 35/1,4Länk: http://www.kenrockwe...ng/35mm-f14.htmSLutsatsen i testet: "The Samyang 35mm f/1.4 is a manual-focus-only lens. It's amazingly sharper at f/1.4 than any other Nikon 35mm lens, including the Nikon 35mm f/1.4 G that costs over three times as much, but only if you know how to use it. For action photos, I need autofocus, and for that, I use a zoom or the 35/1.8 DX on my DX cameras. For where and when you can take the time to focus precisely manually, this Samyang lens is a total winner."
Postad 12 July 2011 - 22:15
perri
perri
799 inlägg
Var ute på Ken Rockwells hemsida och fann följande guldkorn från testet av Samyang 8 mm:
"A reader suggests that you may try to screw-up your focus yourself by rolling back the focus ring rubber grip. Note 3 set-screws. Set the lens to what is actually infinity focus. Unscrew these set-screws, rotate the focus ring to infinity mark, tighten the set-screws. The lens should now focus at infinity when set to infinity. GOod luck; I haven't tried this".
Testade det och jajamensan det funkade perfekt! Äntligen stämmer avståndsskalan och den stoppar perfekt vid oändligt. Men kom ihåg att det bara är de tre spårskruvarna det handlar om, inte den med kryssspår. Använd en mejsel med 1,4 mm klinga.
Fortsatte med min 14 mm men där var konstruktionen annorlunda. Tre spårskruvar även här men det är omöjligt att korrigera avståndet så att det visar rätt. Men man kan däremot få den att stoppa där oändligt egentligen är. I mitt fall 3 meter. Vilket är ju rätt värdefullt minst sagt.
Gör så här: Lirka av gummiringen. Lossa skruvarna. Vrid avståndsskalan förbi närmsta avståndet en liten bit. Vrid sakta tillbaka till där du har oändligt på ditt objektiv. Stoppa exakt där. Skruva fast och montera gummiringen.
Helt klart roligare att plåta med de här gluggarna nu!
Redigerat av perri, 12 July 2011 - 22:17.
Postad 21 July 2011 - 14:55
Ferniss
Ferniss
60 inlägg
HEJ!
Är väldigt intresserad av att köpa ett Samyang 8 eller 14 till min Nikon D90. Hur manuellt är objektivet till min kamera. Måste jag ställa in tid och bländare manuellt, eller går det att skjuta med bländar/tidsautomatik?
/Ferniss
#54
Postad 21 July 2011 - 16:50
Unregistered124686ac
Über-Guru
11229 inlägg
HEJ!
/Ferniss
Har för mig det har kommit en ny version i alla fall för 14mm som möjligör exponeringsautomatik på D90, det gamla ger inte denna möjlighet annat än för nivån D7000, D300 etc om jag inte är helt fel ute
#55
Postad 21 July 2011 - 23:53
Ferniss
Ferniss
60 inlägg
Okej, det var ju synd! Det är ju 1000 lappen dyrare än 8mm, så det lockar ju mer med 8:an när man har en lite stram budget plus att man får med ytterliggare lite mer
#56
Postad 22 July 2011 - 10:45
Über-Guru
11229 inlägg
Kolla för säkerhets skull på Cyberphoto de har skrivit ut för vilka begränsningar det blir för olika kameror
#57
Postad 22 July 2011 - 10:49
perri
perri
799 inlägg
Fast köper du en 8 mm till en D90 får du köra helt manuellt och stå ut med att sökaren blir mörk när du bländar ner. Ett bättre val är 14 mm rent allmänt då ett fish-eye trots allt är ett effektobjektiv som kan vara kul ibland men inte jämt. Från Foto-Tip får du den för 2870:- plus en hundring i frakt. http://www.foto-tip....kon-p-1936.html
#58
Postad 22 July 2011 - 13:39
Unregistered2d8d729c
879 inlägg
Jag är sugen på både deras 14mm och 35a, men inte orkat ta reda riktigt på hur väl dom funkar med min kamera, någon här som har bättre koll än mig på hur objektiven funkar på en Canon 5D? (ej mkII)
#59
Postad 27 July 2011 - 15:52
Ferniss
Ferniss
60 inlägg
Det kan inte bli så att jag måste betala moms på det? (För tull måste jag väl iaf slippa eftersom det är inom EU?) För annars var det ju en j*vla bra deal!
#60
Postad 27 July 2011 - 18:35
perri
perri
799 inlägg
Inte inom EU såvida det inte är en handlare som säljer till Sverige i större omfattning. Foto-Tip verkar inte omfattas av den regeln. Har hitintills köpt prylar från dem fyra gånger utan problem och med nada momspåslag.
#61
Postad 27 July 2011 - 20:18
Ferniss
Ferniss
60 inlägg
Okej, det lät ju bra! Då gäller det bara att bestämma sig
#62
Postad 05 August 2011 - 16:46
Ferniss
Ferniss
60 inlägg
Det blev ett 8 mm, och det gjorde mig riktigt glad! Har bara testat det lite grann, men det blev riktigt fina (och coola) bilder
Jag är supernöjd!
#63
Postad 10 August 2011 - 18:07
wictor
wictor
1453 inlägg
Ingen som har testat 85 mm varianten? Har funderingar på att byta ut mitt sigma 30mm f1.4 mot nått med mer "mm". :-D
#64
Postad 11 August 2011 - 15:33
Über-Guru
11229 inlägg
Tror du inte det är jobbigare med manuell AF på ett 85'a, mer känsligt för skärpedjupet. Jag skulle nog titta på Nikoor 85/1.8, som lär vara riktigt bra
#65
Postad 11 August 2011 - 15:53
wictor
wictor
1453 inlägg
Du menar den? Den låg ju faktiskt bra till i pris, speciellt om man hittar en begagnad  Nikkor vs samyang brukar ju oftast vara lite mer än några hundra i skillnad.
Redigerat av wictor, 11 August 2011 - 15:54.
#66
Postad 11 August 2011 - 16:14
Über-Guru
11229 inlägg
Ja den är billig och bra. Uppdaterad nu med rätt objektiv, dock så är Samyang på en Canon. Kanske svårt att jämföra det verkar stor skillnad om mna jämför testen med Nikkor 85 på en D200 jämfört med D7000 på DX http://www.photozone...d8518dx?start=1http://www.photozone...514apsc?start=1på FX http://www.photozone...nikkorafd8518ffhttp://www.photozone...amyang_85_14_5d
Redigerat av Unregistered124686ac, 11 August 2011 - 22:30.
#67
Postad 11 August 2011 - 22:02
perri
perri
799 inlägg
på DX http://www.photozone...ew--test-report
på FX http://www.photozone...605-sigma8514ff
Nå men nu är det ju inte Sigma utan Samyang 85/1.4 vs Nikon 85/1.8 som det handlar om. Ser man till testen med DX kameror hos Photozone ser det ut som följande:
Samyang_85.png 15.66K
1 Antal nerladdningar
Nikon_85_APS_C.gif 7.12K
1 Antal nerladdningarSom synes är det rätt stor skillnad i upplösningen med Samyang som en klar vinnare. Kör man båda gluggarna med FX blir däremot Nikon segraren. Fast plåtar man med fullformat har man nog råd med att köpa Nikons proffsgluggar istället... Stor dräggelfaktor på dem Men visst, att plåta manuellt med en 85:a med dagens undermåliga mattskivor är småstruligt. Så ett byte till Catzeyes mattskiva är nästan en förutsättning. Priset på Samyangs 85:a hos Foto-Tip är 2250:- plus en hundring i frakt. http://www.foto-tip....kon-p-1356.html
Redigerat av perri, 11 August 2011 - 22:27.
#68
Postad 11 August 2011 - 22:22
Über-Guru
11229 inlägg
perri. du har så rätt jag läste fel och plockade ett Sigma istället. Jag hittade inga Samyang som var testade på Nikon så det fick bli på Canon istället, har ändrat mitt inlägg. Verkar vara stor skillnad vilken kamera man testar på resultaten på D7000 är betydligt högre för Nikkor 85 än då D200
Redigerat av Unregistered124686ac, 11 August 2011 - 22:33.
#69
Postad 11 August 2011 - 23:25
perri
perri
799 inlägg
Dels beror det på CCD utvecklingen, dels på att D200 bara har 10 MP medan D7000 har 16 MP. Nikkor 85/1,8 har alltså i sig själv högre upplösning än vad D200 klarar av.
#70
Postad 16 August 2011 - 15:22
perri
perri
799 inlägg
Ny Samyang på G som fyller ut mellan 14 och 35 mm gluggarna. Den har fått det förklarande namnet Samyang 24 mm f/1.4 ED AS UMC och skvallret om den finns här: http://www.lenstip.c..._ED_AS_UMC.html
#71
Postad 30 October 2011 - 01:29
perri
perri
799 inlägg
Det börjar visst dra ihop sig för leverans av Samyang MF 24/1.4:
http://www.samyang.p..._available_soon
Den som väntar på något gott osv...
Redigerat av perri, 30 October 2011 - 01:45.
#72
Postad 02 December 2011 - 03:28
perri
perri
799 inlägg
Samyang har kommit ut med en ny 8 mm fisheye med CPU-koppling till Nikon.
Finns för omedelbar leverans hos Foto-Tip för 2964:- plus en hundring i frakt.
Kommer in hos Cyberphoto vecka 49 till en kostnad av 2990:- Just nu fraktfritt om man anger kod FF09
Intressant att Cyberphoto har börjat matcha Foto-Tips priser.
http://www.foto-tip....kon-p-2224.html
http://www.cyberphoto.se/
#73
Postad 22 January 2012 - 02:29
perri
perri
799 inlägg
Senaste nytt om Samyang 24/1.4 ED AS UMC är att den skall komma ut någon gång i mars-april.
Det ser vi fram emot.
#74
Postad 05 February 2012 - 16:15
perri
perri
799 inlägg
Samyang 24/1.4 ED AS UMC finns nu att köpa hos Foto-Tip för det facila priset av 698.10 € för Nikon och 662.74 € för alla andra.
Betydligt snabbare än vad det ryktades om för så sent som för två veckor sen. Men det gör ju ingenting...
För övrigt känns det rätt så ensamt här på tråden. Finns det verkligen inga andra här på forumet som vill prata Samyang?
http://www.foto-tip....lep/default.php
#75
Postad 05 February 2012 - 16:32
perri
perri
799 inlägg
Här några bilder från gluggen ifråga:
http://www.lenstip.c...ple_images.html
#76
Postad 11 February 2012 - 02:14
perri
perri
799 inlägg
Första recensionen om Samyang 24/1.4ED AS UMC finns här:
http://www.lenstip.c...troduction.html
Verkar som om Samyang för en gångs skull har klantat till det ordentligt. Den gluggen bör man nog dessvärre undvika.
Besviken alltså!
#77
Postad 12 February 2012 - 08:58
80-talet
80-talet
498 inlägg
Ja 24:an är en besvikelse. Jag har väntat på den, tycker att det finns dåligt med bra och prisvärda objektiv kring 20/24mm. Nu blev Samyangen dessutom mycket dyrare än vad jag hade väntat mig vilket bara gör mig mer besviken med tanke på resultatet i testet!
#78
Postad 12 February 2012 - 09:22
Unregistered0b884712
1690 inlägg
oj vad dyr den var... förlorar liksom charmen då de höjer priset med 100%
#79
Postad 21 June 2012 - 15:35
Anton
Anton
1044 inlägg
Kan bli en 8mm fisheye snart, beror lite på vad uppgraderingsjävulen gör hehe
#80
Postad 17 July 2012 - 09:41
Peken
Peken
675 inlägg
Inspirerad av tråden, skaffade en 8mm igår (bra pris hos FotoKungen - 2490:- ).
Ska bli kul o se hur den fungerar på min A57:a...
#81
Postad 25 October 2012 - 20:18
perri
perri
799 inlägg
Samyang kommer innan årets slut ut med ett tilt/shift objektiv med det förklarande namnet TS 24/3,5 ED AS UMC Tilt/Shift.
24mmts2.jpg 34.42K
0 Antal nerladdningar
Som synes är det inte samma 24 mm objektiv som tidigare i år inte blev så där väl mottagen. Så vi får väl hoppas på lite bättre skärpa och upplösning den här gången. Priset blir naturligtvis en väldigt intressant fråga då sådana här specialobjektiv brukar kosta som en bättre begagnad bil.
Personligen är jag mest intresserad av tilt/shift funktionen för att skapa riktigt hög skärpa längs hela motivplanet.
Ofta beskrivs effekten som om man utökar skärpedjupet vilket är en helt felaktig beskrivning då skärpa och skärpedjup är två olika saker. Skärpa är där man fokuserar. Skärpedjup är acceptabel skärpa runt detta område. Alltså inte den skärpa som objektivet presterar vid fokus.
Vad objektivet gör, utan att gå in på tekniska detaljer, är att skapa full skärpa istället för skärpedjup längs med det fotograferade objektet. M.a.o. riktigt skarpt! Så om objektivet bara är lite bättre än 24/1.4 kan det nog bli riktigt, riktigt intressant!
Sen finns det ju förstås en hel del annat objektivet kan göra. Bara att googla på tilt och shift...
Redigerat av perri, 26 October 2012 - 15:40.
#82
Postad 13 December 2012 - 19:39
Unregistered8947db47
278 inlägg
24mmts2.jpg 34.42K
cyberphoto har lagt in objetivet, men leverans okänt, 2013..10k kr.. http://www.cyberphot...rticle=24mmtsni
Redigerat av Unregistered8947db47, 13 December 2012 - 19:40.
#83
Postad 29 June 2013 - 19:18
3993 inlägg
Kom över ett 8mm för 1200:- på blocket och har testat det lite med min EOS550, riktigt trevligt objektiv och skarpare än jag trodde.
Några fler som använder detta obj. och vad tycker ni om det?
Hemma
Digitalkameror & Videokameror
Specialämne: Systemkameror & Optik
