Tack för era svar. Tyvärr är jag i behov utav boxen då Netflixappen fungerar så dåligt på vår gamla Panasonic 55VT50 Plasma.
Hittade att man kan stänga utav och begränsa HDCP 2.2 då min tv inte stöder det för för de olika ingångarna. Det fungerade bra för mig.
Detta följande jag:
Had the same issue and figured out how to fix this. Im guessing you have a 1080p tv only. If you have a denon x3400h, x3500h, x4400h, x4500h, etc. Go into the hdmi diagnostics mode on the denon receiver and change the limit mode to output 1080p then hdcp 2.2 to limit. To get into hdmi diagnostic mode turn on the receiver, then hold the back button and the up cursor on the receiver for around 3 seconds until it flashes hdmi diagnostics. It will run an auto check first and then display the diff modes. From there use ur remote to scroll down to limit mode and make the above changes. I just had my receiver over the weekend and it was driving me nutz trying to figure out how to get into hdmi diagnostics on the new denon receivers. Hope this helps everyone that has the same issue. :-)
