* Officiell tråd - Samsung Galaxy S *
2004 svar till detta ämne
#801
Postad 20 juli 2010 - 11:21
Xet
Xet
269 inlägg
Till er som har problem med Kies har jag hittat lite tips som ska funka till Wave och som kan vara värt att prova: Ladda hem den senaste versionen av Samsung Kies v1.5.1.10071_32 kan laddas ner här: http://www.samsung.c...mp;menu2=detailWhat you do is this. - Go to the program where you install Samsung KIES. - Open te folder. - Search those files: _rapi.dll and _ceutil.dll - Copy both files and drop it on your dekstop. - Now make from _rapi.dll = rapi.dll - Now make from _ceutil.dll = ceutil.dll - So what you did is, you removed '' _ '' - Now take both files and drop it in the folder of KIES. - Replace them. - Now open Kies again and everything will work OK. This guide is tested on Widows XP, Windows Vista and Windows 7. Om inte det fungerar så kan ni testa detta: Just a thought.. I kept getting MTP USB Device Failed consistently on several PC's. I found that if I remove the external micro SD card and then let it install the drivers, it worked. This leads me to believe the MTP USB Device Failed issue is caused by an incompatibility with the external micro SD card that you have in the phone. You can still use the micro SD card normally, but if you want to use Kies, the external card seems to stop it from installing the drivers correctly to communicate with the phone. To Fix: Plug in the phone and when it fails, go into Device Manager and uninstall the following: Samsung Android USB modem (located in the Modems section) Samsung Android USB composite device (located in the Universal Serial Bus Controllers section) MTP USB device (located in the Portable Devices section) Don't rescan for new hardware. Shut down the phone, remove the external micro sd card and reboot the phone. Let the PC install the drivers. I'm betting the drivers are successful now, and Kies connects to the phone. Someone want to try it and advise the results? Edit: It looks like you don't even need to remove the sdcard. Just un-mount the external sd card, plug the usb cable in, and let it do it's thing with the drivers. You'll need to reboot the phone to re-mount the sd card. Hämtat ifrån Samsung-Firmware.webs.com
Redigerat av Xet, 20 juli 2010 - 11:22.
#802
Postad 20 juli 2010 - 11:26
Xet
Xet
269 inlägg
Kanon ju... Kan man hoppas på att de till Android 2.2 eller bara en så kallat "vanlig" uppdatering..
Nej det finns ingen uppdatering till 2.2 tillgänglig än, det du får med den här uppdateringen är bl.a. swype med svenskt tangentbord och ordlista.
#803
Postad 20 juli 2010 - 11:28
marotos
marotos
61 inlägg
Ska till och beställa från onoff, och vad tycker ni, ska man köpa till deras plusförsäkring eller inte ? den koster typ 1200 och den gäller i ett år.. min magkänsla säger att de är skit, men vad säger ni ?
#804
Postad 20 juli 2010 - 11:35
Xet
Xet
269 inlägg
Det är min magkänsla med, jag är extremt skeptisk till dom extraförsäkringar som olika teknikförsäljare säljer...
#805
Postad 20 juli 2010 - 11:49
Xet
Xet
269 inlägg
Jag ställde en fråga tidigare i detta forum om att E-shop hade i9000b som artikelnr och undrade vad b står för. Jag vet fortfarande egentligen inte det, men har nu telefonen i min hand och upptäckt att den är importerad från Tyskland. (tysk och engelsk manual medföljde) Ser inget "tyskt" i den utan svensk språk är inställt och svenskt tangentbord går ju att fixa (å ä och ö saknas nu). Men kan det vara andra saker som är till nackdel med denna? (som har en icke nordisk firmware och CSC) Framtida uppgraderingar osv. Vet inte om jag ska kontakta återförsäljaren och kräva en "svensk" eller om det är skitsamma egentligen. Jag frågade dem innan om den är importerad och fick något sorts nej på den frågan, så av den anledningen vill jag ringa tillbaka och ifrågasätta dem.
Kolla bara vad som gäller med garantin av importerade mobiler... jag har ingen kunskap om det. Det borde inte vara några problem att kunna uppdatera framtida firmware, men när jag uppdaterade senast(till den ryska uppdateringen) så uppdaterades alla filer utom xxe filen dvs. den svenska delen av programmet(vet dock inte vad den innehåller eller vad den gör). Den filen borde ju komma med nästa uppdatering via Kies så jag ser väl inte det som något problem igentligen.
#806
Postad 20 juli 2010 - 12:26
Xet
Xet
269 inlägg
En spännande video på samsungs kommande amoled-skärmar som är böjbara och tål betydligt mer yttre våld: http://www.youtube.c...layer_embedded#!
#807
Postad 20 juli 2010 - 13:06
marotos
marotos
61 inlägg
Sket i extraförsäkringarna, min hemförsäkring osv sköter de. Ska bli grymt roligt att få en samsung i handen om cirka två dagar !!
#808
Postad 20 juli 2010 - 13:30
arcspin
arcspin
653 inlägg
+1 Det är försäkringar som dom tjänar pengar på, så där ska man nog tänka efter lite och kontrollera vad sin nuvarande försäkring täcker eller t.o.m kanske utöka sin nuvarande försäkring med ett tillägg till den vanliga drulle försäkringen...
#809
Postad 20 juli 2010 - 13:52
arcspin
arcspin
653 inlägg
Ok, nu är jag lite less på Live wallpapers och tänkte kolla och se hur mycket ström och prestande man tjänar på att ha en statisk wallpaper.
Vilket format, storlek, upplösning på bilden ska man använda för bästa resultat om tänker skapa sig en egen bakgrund av ett fotografi eller från en vanlig pc-wallpaper man har.
Jag vill gärna ha effekten man får när man installerar en stock wallapper där bilden delvis flyttar med när man scrollar mellan de olika hemskärmarna ?
//arcspin
#810
Postad 20 juli 2010 - 13:59
Xet
Xet
269 inlägg
//arcspin
Jag vet inte vilken storlek som passar bäst, när det kommer till effekten där bilden flyter med när man scrollar mellan de olika skärmarna så sker detta automatiskt.
#811
Postad 20 juli 2010 - 14:11
mogeloga
mogeloga
7 inlägg
Numera lycklig? ägare till en Galaxy, trevlig tydlig och snygg. Men, har problem med wifi'n. Den hittar inte min router även om jag håller luren direkt mot routerantennen. Däremot fångar den upp grannens nätverk (som tyvärr är skyddat  ). Alla andra enheter anslutna till routern fungerar helt ok. Hittar inga inställningar för -b/-g/-n i luren men den ska efter vad jag förstår stödja alla. Har startat om både router o lur, även gjort en reset av luren. Ngn som har eller har haft samma problem eller vet vad f-n som är felet.
/T
#812
Postad 20 juli 2010 - 14:19
Megaman2
Megaman2
616 inlägg
telia hade en försäkring (som de inte har längre) som var ung3-4 hundra om året, där man i princip skulle få en ny telefon om den förra blev stulen et.c. Den värsta risken med Galaxy S är att den är väldigt vatten känslig. (tom iphone ersätter inte vattenskador, vilket lätt kan förstöra telefonen, och därmed göra den värdelös.) har inte sett någon försäkring som är generös men samtidigt billig. om man kunde få en försäkring för typ 500 kr om året, där man fick en ny telefon (no question asked) om telefonen skulle gå sönder/tappas bort et.c. så skulle jag ta den. men nu är försäkringarna ung 25% av värdet på telefonen och inte så mycket mer förmånligt än tillverkarens garanti. tror den mesta är värdeminskningen. (om samsung istället för att sälja dem för 4800 istället skulle ta 8-9000 för dem obundet så skulle värdet hålla i sig, för då skulle folk tro att det är en premiumprodukt som är dyrare än vad de egentligen är)
#813
Postad 20 juli 2010 - 14:38
wrekost
wrekost
72 inlägg
//arcspin
960*800pix kör jag
#814
Postad 20 juli 2010 - 14:41
Xet
Xet
269 inlägg
Numera lycklig? ägare till en Galaxy, trevlig tydlig och snygg. Men, har problem med wifi'n. Den hittar inte min router även om jag håller luren direkt mot routerantennen. Däremot fångar den upp grannens nätverk (som tyvärr är skyddat ). Alla andra enheter anslutna till routern fungerar helt ok. Hittar inga inställningar för -b/-g/-n i luren men den ska efter vad jag förstår stödja alla. Har startat om både router o lur, även gjort en reset av luren. Ngn som har eller har haft samma problem eller vet vad f-n som är felet. /T
Det är en bugg i mjukvaran tyvärr, jag har lyckats få till det men det krävdes många försök... Jag kan även tillägga att man ska vara observant på att den kan stänga av wifi:n medans man håller på att installerar den, ta då bort krysset för Wifi och låt den stänga av den korrekt och sätt sedan på det igen. När det gäller b/g/n anslutning så ställer telefonen in sig automatiskt... Jag använde mig av WPS...
#815
Postad 20 juli 2010 - 14:51
mogeloga
mogeloga
7 inlägg
Tack för snabb respons! Menar du att du gjorde upprepade ansluningsförsök till dess att det lyckades eller..? / T
#816
Postad 20 juli 2010 - 14:54
Pandi
Pandi
9 inlägg
Home Switcher använder du för att välja mellan redan installerade launchers. Eftersom du troligtvis inte har installerat någon annan än den som följer med ännu så är det inte så användbart.
Sök efter launcherpro i android market, installera och testa!
marotos: Det är möjligt att Telia inte säljer den själva, men hos tex. Katshing och Dustin Home kan man köpa den med Teliaabonnemang. Om du är student eller under 25, så har Telia ett rätt så fördelaktigt abonnemang. En fördel med Telia är att de har Edge på sitt 2G-nät, så även om man saknar 3G-täckning får man någorlunda acceptabla hastigheter.
Jag fick för övrigt hem mitt läderfodral från Zenuscase i fredags. Det passar telefonen perfekt, är rätt snyggt, och jag slipper vara rädd för att tappa den hela tiden. Men oj vad tungt det kändes när tullverket ville ha 102:- i avgifter för ett mobilfodral som kostade 250:-...
Har du länk till vilket Zenuscase du köpte?
#817
Postad 20 juli 2010 - 14:55
Xet
Xet
269 inlägg
/ T
Ja, har du möjlighet att göra det via WPS så är det enklast. Annars så får du gå igenom "Lägg till Wifi-nätverk"...
#818
Postad 20 juli 2010 - 15:06
mogeloga
mogeloga
7 inlägg
Är inte helt säker på vad WPS är men är det en funktion på routern så känner jag inte igen det från någon meny ( har gått igenom ett flertal gånger) blir att göra det den oenkla vägen  Ska nu sätta mig och nöta lite glas dvs försöka ansluta. Tack för hjälpen så länge. / T
#819
Postad 20 juli 2010 - 15:25
Xet
Xet
269 inlägg
/ T
Berätta gärna hur det går och om du hittar några andra knep att ansluta wifin på...
#820
Postad 20 juli 2010 - 15:41
mogeloga
mogeloga
7 inlägg
Will do, men så här långt har det inte lyckats, lagt till ap manuellt men får bara " Ej inom område, ihågkommen". ska åka till McD, MAX eller någonstans där det finns en telia hotspot och prova koppla upp mig. Hör av mig. / T
#821
Postad 20 juli 2010 - 16:24
mogeloga
mogeloga
7 inlägg
#822
Postad 20 juli 2010 - 16:47
Stefan S
Stefan S
684 inlägg
Kan det vara så att du har Hide SSID iklickad? För min galaxy hittar inte om jag har gömt SSID
#823
Postad 20 juli 2010 - 17:12
lacunaz
lacunaz
247 inlägg
Till folk som har problem med Kies och drivrutiner som jag hade.
Installera Kies.
Gå in i settings - about phone eller vad det nu heter i telefonen.
Gå in på usb instllningar där och byt till Mass storage istället för kies.
Koppla in till dator, den kommer då installera drivrutinerna.
Byt sedan tillbaka till kies igen i mobilen.
Koppla sedan in och det kommer fungera.
Funkade för mig iaf.
Samsung Store funkar dock ej, någon som vet varför?
#824
Postad 20 juli 2010 - 18:03
arcspin
arcspin
653 inlägg
//arcspin
OK, det var ju busenkelt, Långklicka på skärmen välj bakggrund sen gallery. Välj ut en bild som du har där. När "crop" verktyget kommer markerar du så mycket av bilden som bara går. Klicka på OK. Bandabing, Badabong, Klart !!! Hur enkelt som helst och bakgrunden blir riktigt bra, förutsatt att du har en bra bild. Jag tog en bild från Picassa web och till och med den blev bra som bakgrund... //arcspin
#825
Postad 20 juli 2010 - 20:12
Holly18
Holly18
33 inlägg
Är det i Keis man hämtar hem den uppdateringen? Eller går de att göra någon form av uppdatering med bara telefonen?
#826
Postad 20 juli 2010 - 20:43
Xet
Xet
269 inlägg
Nej, jag förklarade på sida 26 hur man gör och vad man bör tänka på. Det är som sagt en rysk uppdatering...
Redigerat av Xet, 20 juli 2010 - 20:54.
#827
Postad 20 juli 2010 - 20:58
mogeloga
mogeloga
7 inlägg
Nej då ssid är på. Har nu hållit på i stort sett hela kvällen varit runt lite här och där för att prova uppkopplingar, små eller inga problem att koppla upp sig men hemma, no luck. Gjorde en reset av routern samt uppdaterade Fw till densamma, bytte till en för området unik kanal och trodde då i min enfald att nu djäkl-r blir det åka av. Visst sa jag i min enfald? Just det, ingen skillnad grannarnas nätverk kommer upp men mitt är "ej inom område" gissa om man blir 1234. Får väl lov att investera i en ny router och se om det löser problemet. / T
#828
Postad 20 juli 2010 - 21:03
Xet
Xet
269 inlägg
/ T
Jag tror inte att det är något fel på din router, det är många som har samma problem...
#829
Postad 20 juli 2010 - 21:22
mogeloga
mogeloga
7 inlägg
Har mailat till shamesung på förmiddagen men dom har inte bemödat sig att ens verifiera att mailet kommit fram, än mindre kommit med något konstruktivt. Tur att det finns forum som detta  ) /T
#830
Postad 20 juli 2010 - 21:25
Xet
Xet
269 inlägg
/T
Jag ska leta efter en lösning i morgon...
#831
Postad 20 juli 2010 - 22:56
ruva
ruva
2 783 inlägg
/T
Du kommer endast få standardsvaret att göra en fabriksåterställning. Men först: byt till kanal 1 eller 10 i din router. Kanal 1 har jag fått fungera med min Samsung GS men har å andra sidan inte haft WiFi-problem sedan jag gjorde en fabriksåterställning av telefonen.
#832
Postad 21 juli 2010 - 02:04
Kniff
Kniff
309 inlägg
Fixa Wi-Fi Analyzer från appbrain och kika hur det ser ut, om du inte hittar din egen router men dina grannars är det ju knappast telefonens fel. Utan att låta nedlåtande så är det ju oftast användarfel när det gäller just routers och nätverk i allmänhet.
No offense som sagt, hoppas det löser sig och jag kan säkert ha fel i mitt påstående.
Ps, fabriksåterställning av både telefon och router är såklart steg 1, ds.
Redigerat av Kniff, 21 juli 2010 - 02:05.
#833
Postad 21 juli 2010 - 08:30
Xet
Xet
269 inlägg
Det som ändå verkar positivt med wifi problemet är ju att det "bara" är en bugg. Den amerikanska modellen av galaxy s, Vibrant har inga problem med wifin... http://www.alternati...on.info/?p=1016
#834
Postad 21 juli 2010 - 10:07
mackzen
mackzen
25 inlägg
Någon som vet hur man ändrar den defaulta kalendern till sin google kalender?
Och hur får man bort sina ringsignaler man själv har lagt dit ur musikspelaren?
#835
Postad 21 juli 2010 - 13:26
arcspin
arcspin
653 inlägg
Fransmännen får Froyo till Galaxy S i September. Läs mer här: http://androidcommun...ember-20100720/
#836
Postad 21 juli 2010 - 18:33
JagVetInte
JagVetInte
179 inlägg
För er som tycker att skärmen är fantastisk, läs denna artikel. http://arstechnica.c...-and-hacks.ars/Så dessa 800x600 är enligt artikeln egentligen 392x653. PenTile teknologin är även anledningen att kanterna ser taggiga ut. Jag tycker detta är irriterande, speciellt då man ser på kanter med hög kontrast som t.ex. text eller ikoner som är rektangulära. Skärmen är fortfarande bra men jag måste erkänna att jag tycker PenTile är rent fusk.
Redigerat av JagVetInte, 21 juli 2010 - 18:34.
#837
Postad 21 juli 2010 - 19:05
NisseGurra
NisseGurra
1 997 inlägg
Skärmen är fortfarande bra men jag måste erkänna att jag tycker PenTile är rent fusk. http://www.mobiletec...deo-comparison/
#838
Postad 21 juli 2010 - 19:33
Holly18
Holly18
33 inlägg
Nä, du missförstod mig... Den ryska uppdateringen vill jag inte ha  men undrar bara när det e dags för t.ex. uppdateringen av Android 2.2 kommer man då att behöva göra den via Kies eller går de att även göra med bara telefonen?
#839
Postad 21 juli 2010 - 19:58
Xet
Xet
269 inlägg
Det är genom Kies som man uppdaterar...
#840
Postad 21 juli 2010 - 22:13
marotos
marotos
61 inlägg
Vad gör jag för fel när inte kies hittar min mobil ? jag har försökt med flera usbportar, men ingen funkar :S Det funkade första gången, men sen när jag skulle göra de nån timme senare så hittar den inte.. skitmärkligt
Mvh Marotos
#841
Postad 21 juli 2010 - 23:36
junkan
junkan
5 283 inlägg
 Jag börjar misströsta, telefonen har potential att vara helt grymt bra men den är så låååångsssaaaam, sitta och titta på en svart skärm när den borde växla blixtsnabbt med den hårdvara den har. Wi-fi är instabilt. GPS startar inte alltid etc etc...
Alldeles för mycket programvarubuggar i en sådan här dyr telefon, och KIES skall vi ju bara inte prata om!
Nä funderar på en Desire istället.
#842
Postad 22 juli 2010 - 01:02
JagVetInte
JagVetInte
179 inlägg
Samsung ljuger när det gäller färgdjup. Samsing påstår att skärmen kan visa 16 miljoner färger (8 bpp) men i verkligheten är det bara 64k färger (5 bpp för rött och blått och 6 bpp för grönt). Detta kan snabbt verifieras med att titta på gradientbilder där bandeffekterna är mycket tydliga. Lite mer info om skärmen. Nexus one har ungefär samma skärm som Galaxy S och samma sjukdomar: http://www.displayma...ne_ShootOut.htmDock enligt detta test beror det dåliga färgdjupet på Android och inte skärmen. Vi får se om de fixar det.
Redigerat av JagVetInte, 22 juli 2010 - 01:23.
#843
Postad 22 juli 2010 - 03:49
Kniff
Kniff
309 inlägg
Beror det på Android och inte telefonen är det ju rätt ointressant då det isånafall gäller alla telefoner med Android. Det går att läsa och jämföra hur mycket siffror emellan telefoner som helst, enklast är väl att kika på videos på youtube där man enkelt kan se hur galaxyns skärm enkelt vinner över exempelvis Iphone4 i färg och speciellt svärta där svart verkligen är kolsvart, och då har ändå nya Iphone en LCD av IPS-typ. Sen att upplösningen inte är riktigt vad som står är litet synd, att texten kan bli suddig vid stora inzoomingar osv. Jag kan dock ärligt säga att skärmen på Galaxy har bättre svärta och i många andra sammanhang är bättre än min 7000krs P-MVA-monitor, riktigt imponerad är jag.
Redigerat av Kniff, 22 juli 2010 - 04:05.
#844
Postad 22 juli 2010 - 06:28
NisseGurra
NisseGurra
1 997 inlägg
Gammal test, testaren använde inbyggda bildvisaren som skalar ner färgdjupet. Ämmnet har redan kommit upp flera ggr och märkligt att testet inte har uppdaterats då slutsatserna är felaktiga. Finns mycket info på tex XDA. Froyo (2.2 fw) har uppdaterad bildvisare (cooliris) som inte har samma problem. Nexus och Desire har samma skärm, galaxy har det inte. Alla tester säger att galaxy s skärm är i klass med Iphone 4...
Redigerat av NisseGurra, 22 juli 2010 - 06:31.
#845
Postad 22 juli 2010 - 07:51
IDarkRoomI
IDarkRoomI
9 inlägg
Några tips. 1. Starta om telefonen varje morgon. 2. Kör TasKiller och döda allt du ser, ca 3ggr per dag. Brukar då får ca 200MB ledigt minne, RAM antar jag? Min telefon är aldrig slö eller har några svarta skärmar. Sedan kan jag hålla med om att KIES är rena skiten, hoppas på en välfungerande version för Win 7 x64 snart. Hoppas på ny mjukvara till telefonen snart (FroYo) , överlag så ÄR detta den bästa telefonen på marknaden förtillfället.
#846
Postad 22 juli 2010 - 08:47
Pandi
Pandi
9 inlägg
Mvh Marotos
Kies hittar aldrig min telefon, undra hur man ska uppdatera den då?
#847
Postad 22 juli 2010 - 08:55
wrekost
wrekost
72 inlägg
Det har jag funderat på också, fortsätter kies att strula som det gör får man väl lov att använda odin. Kanske inte känns helt bra, men jag vet inte om jag skulle lita mer på kies efter hur det betet sig.
#848
Postad 22 juli 2010 - 09:19
J3SPER
J3SPER
37 inlägg
Första timmarna funkade inte heller mitt wifi även fast jag la till mac-adressen i routern. Jag fixade detta problem genom att ta bort "accessen" på routern så att den var öppen för alla. Då fick mobilen äntligen kontakt med routern och jag kunde surfa. Därefter satte jag på accessen och det funkade fortfarande. Jag tror att det kan vara att mobilen och routern snackar två olika språk ifrån början och därför måste ni göra detta för att få det och funka. Hör av er om det funkar.
#849
Postad 22 juli 2010 - 09:27
arcspin
arcspin
653 inlägg
Jag har inte ens försökt mig på att installera KIES uta kommer att vänta så länge som möjligt med det i hopp om att det ska komma ut en uppgraderig på KIES. Annars får jag hoppas på att det kommer att gå att lägga ner uppdateringen på minneskortet och installera via minneskortet istället. Hoppas kan man alltid göra... ;o) //arcspin
#850
Postad 22 juli 2010 - 09:30
lacunaz
lacunaz
247 inlägg
Killar, när ni kör task killer ås ser man ju hur mycket ledigt minne man har.
Alltid när jag startar telefonen och kör task killer med en gång så ligger jag på 150 mb, sedan minskar det gradvis.
Ligger alla på 150 i början eller hur ligger det till?
Jag skrev ovan hur ni gör om datorn inte kan installera drivrutiner som den inte gjorde för mig.
Gör såhär!
Gå in i telefon inställningar - usb inställningar - ändra till Mass Storage.
Koppla in den i datorn då kommer drivrutinerna installeras.
Installera kies.
Byt tillbaka till Samsung kies istället för mass storage i telefon - usb inställningar.
Starta om telefonen.
Klart, redo att använda kies. Funkade för mig iaf.
Hemma
Mobiltelefoni & GPS
FW H, båda stegen på plats
DPC
2023-12-10 15:36:18
FW höger sida
DPC
2023-12-10 11:06:21
Baren 95% klar
erfah
2023-12-07 11:43:08
FW vänster sida klar med akustik
DPC
2023-12-06 10:47:00
Utsikt från bakre raden
Beffa
2023-12-03 23:11:21
