Cambridge Audio CXR120 och CXR200 - nya receivers 2015
11 svar till detta ämne
Postad 11 januari 2015 - 02:17
Bogge
  • Bogge
  • 770 inlägg
Cambridge släppte sin nya CX-serie i veckan på CES. Består av bla 2st receivers i premium segmentet. Nästan llte uppfriskande med ett släpp utan Atmos stöd :D. Vem vet, Atmos stöd kanske kommer senare.
The CXR-120 and CXR-200 will sell for $1,999 and $2,499, respectively.
The CXR AV Receivers are for audiophiles seeking a powerful, immersive home cinema experience. Blending unique network functionality and sublime visual 4k upscaling, the CXR AV Receivers give a very convincing performance.
CXR120
The CXR120 is a true, discrete 120 Watt per channel amplifier design for audiophiles seeking a powerful, immersive home cinema experience.
Not only that, but it features the same state-ofthe-art Cambridge Audio StreamMagic music streaming module found at the heart of the CXN network music player. This means that over Wi-Fi or an ethernet connection, the CXR120 will play the music that it sees on your network, including all popular formats such as FLAC, Apple Lossless and WAV. Playback from USB hard drives is also supported, as is streaming from Spotify.
A rich radio experience is also on board with internet radio as well as FM/AM. There’s even support for DSD, allowing you to playback SACDs from your Blu-ray player.
Complementing the sublime audio output, its visual performance is second to none. With HDMI 2.0 4K and 3D compatibility, upscaling of all 1080p signals to 4K ultra high definition and deep colour support, crisp and detailed images are guaranteed.
CXR200
The CXR200 incorporates the same functionality as the CXR120 but benefits from some unique flagship features.
Not only does it deliver 200 Watts of unrivalled power per channel but it also features 8 HDMI inputs and complete zone 2 control. This lets you use a second HDMI output to send a selectable high quality video source into another room with a matched audio signal. Watch or listen to a different source in a different room, all from one powerhouse; bring your world of entertainment to life.
Offering ultimate versatility, the CXR200 lets you bi-amp your front channels, have amplified height channels, or even assign a stereo channel to a second zone. Thanks to a dedicated zone 2 preout, you could also have a full 7.2 channel set up in your main room, and then send a pre out signal to be amplified by a second system. The CXR200 is your new digital hub with complete flexibility and unhindered power and poise.
CXR120
Power output: 120 watts RMS per channel, 6 ohms (two channels driven),100 watts RMS per channel, 8 ohms (two channels driven), 60 watts RMS per channel, 8 ohms (all 7 channels driven)
HDMI: HDMI 2.0, HDCP 2.2, ARC supported on HDMI 1 output
Audio Inputs: 3 x Analogue, Tuner (FM/AM), 7.1 multi-channel analogue direct, 2 x digital coaxial, 2 x optical
Video Inputs: 7 x HDMI 2.0 (6 x rear, 1 x front panel, 1 x MHL compatible)
Main Audio Outputs: 7 Amplified Speaker Outputs, 2 x subwoofer outputs
Video Output: 2 x HDMI 2.0, ARC through HDMI 1
Other connections: 1 x 1/4” / 6.35mm Headphone Output (32 To 600 ohms recommended), IR emitter input, IR receiver input, 2x IR outputs, 2 x 12V trigger outputs, 1 RS232C, 1 IEC type mains inlet, Wi-Fi module, RJ45 Ethernet, BT100 Bluetooth (BT100 not supplied), Spotify Connect
Audio formats (network streaming and USB HDD): ALAC, WAV, FLAC, AIFF, WMA, MP3, AAC, HE AAC, AAC+, OGG Vorbis (16-24 bit, 11.025-192kHz), DSD (via HDMI)
Max power consumption: 1000W
Standby power consumption: <0.5W
Dimensions (H x W x D)*: 165 x 430 x 420mm (6.5 x 16.9 x 16.5’’)
Weight: 13.2kg (29lbs)
CXR200
Power output: 200 watts RMS per channel, 6 ohms (two channels driven),170 watts RMS per channel, 8 ohms (two channels driven), 120 watts RMS per channel, 8 ohms (all 7 channels driven)
Audio Inputs: 4 x Analogue, Tuner (FM/AM), 7.1 multi-channel analogue direct, 2 x digital co-axial, 4 x optical
Video Inputs: 8 x HDMI 2.0 (7 x rear, 1 x front panel, 2 x MHL compatible)
Main Audio Outputs: 7 Amplified Speaker Outputs, L+R preamp outs, 2 x subwoofer outputs
Video Output: 2 x HDMI 2.0, ARC through HDMI 1, Zone 2 through HDMI 2
Zone 2 outputs: 1 x HDMI 2.0, 1 x Preamp, 1 x pair of amplified speaker outputs
Other connections: 1 x 1/4” / 6.35mm Headphone Output (32 To 600 ohms recommended), IR emitter input, IR receiver input, 3 x IR outputs, 3 x 12V trigger outputs, 1 RS232C, 1 IEC type mains inlet, Wi-Fi module, RJ45 Ethernet, BT100 Bluetooth (not supplied), Spotify Connect
Max power consumption: 1800W
Weight: 15.7kg (34.5lbs)
CXR200
CXR120
CXR200
Redigerat av Bogge, 11 januari 2015 - 19:38.
Postad 26 juni 2015 - 06:54
MikeVKR
  • MikeVKR
  • 4 019 inlägg
Inte så mycket aktivitet här inte. Dom ser ju onekligen välbyggda ut på utsidan. Kan vara ett intressant alternativ ifall man inte är intresserad utav Atmos och DTS-X. Någon som vet när dom beräknas dyka upp hos Hifiklubben?
Postad 26 juni 2015 - 07:14
MikeVKR
  • MikeVKR
  • 4 019 inlägg
Lite läsning: http://www.whathifi....trong-cx-series
http://www.cambridge...ure_swedish.pdf
Postad 17 augusti 2015 - 09:19
MikeVKR
  • MikeVKR
  • 4 019 inlägg
Nu finns dom hos Hifiklubben.
CXR-120: https://www.hifiklub...mmabioreceiver/
CXR-200: https://www.hifiklub...mmabioreceiver/
Postad 08 oktober 2015 - 08:28
MikeVKR
  • MikeVKR
  • 4 019 inlägg
Test: cxr-120
http://www.soundandv...z93H1fHR0wdh.97
Postad 09 januari 2018 - 22:07
Slater
  • Slater
  • 438 inlägg
Verkar som att dessa säljs ut nu och slutar säljas. Cambridge Audio fyller 50 år i år. Hoppas på ett härligt släpp snart med nya grymma maskiner. Vad tror ni?
Redigerat av Slater, 09 januari 2018 - 22:07.
Postad 10 januari 2018 - 19:04
mongo
  • mongo
  • 800 inlägg
Hifiklubben ska inte sälja Cambridge längre...
Jag köpte själv en CXR-200, men den åkte tillbaks igen. Faktiskt inte alls imponerad, tyvärr. Snyggare maskin får man leta efter.
Postad 14 januari 2018 - 01:00
Slater
  • Slater
  • 438 inlägg
Fan vad trist. Har en Cambridge Audio Azur 540r v3 som jag tycker ger sjukt bra ljud. Är dock sugen på att uppgradera den för att ha spotify connect i förstärkaren istället för chrome cast + bättre stöd för alla filmljud. Har bekymmer med PCM och måste köra en ljudswitch för att det ska fungera. Frågan är vad som annars skulle vara bra nu om Cambridge har tappat. Vill ha en som både presterar bra för film och för musik. Prisklass max 20k.
Postad 14 januari 2018 - 10:52
Blåtand
  • Blåtand
  • 2 822 inlägg
Är mycket en fråga om vilka högtalare du skall driva då förmågan att driva "låg Ohmiga" laster är något som många receivers har problem med.
Har man högt ställda krav på musik och lite mindre hårda krav på film är det ofta ett bra alternativ att satsa på en mellanpris receiver och komplettera med en tvåkanalare med HT-bypass. Då får man oftast mer kvalité både i förförstärkeriet och slutsteget i musikfallet.
Detta upplever i alla fall jag gör störst skillnad när det kommer till musik medan jag lätt kan leva med att jag bara vinner lite extra kraft i frontarna när det kommer till film.
Redigerat av Blåtand, 14 januari 2018 - 10:57.
Postad 19 januari 2018 - 22:41
Slater
  • Slater
  • 438 inlägg
Kör B&W 683 S1. Om de kommer med en ny kommer jag testa det. Tror annars att Yamaha kan passa mig i smaken. Får väl testa runt lite och höra mig för. Kanske en kombination som du säger kan vara en lösning.
Postad 19 mars 2019 - 21:40
Slater
  • Slater
  • 438 inlägg
Tydligen har Cambridge inte några planer på att göra en uppföljare till CXR200 och har inga planer att göra någon ny AV förstärkare. Såg det på ett annat forum och tog kontakt med dem för att få det verifierat. Så slog nu till på en CRX200 för jag tror att det är en förstärkare som räcker hela vägen i features för mig och ljudet är nog outstanding.
Intressanta var att någon på det andra forumet tyckte att Arcam AVR550 var i princip lika bra. Men den kostar ju runt 40k. CXR200 kostar ju faktiskt endast 16k nu. Ska bli spännande att koppla in den när jag väl får den och se om den levererar.
Postad 13 september 2019 - 21:32
Slater
  • Slater
  • 438 inlägg
Kan säga att den levererar sjukt bra. Tagit ett tag och ställa in allt. Måste dock köra med Dolby Volume, för utan det så blir det för mycket tryck i lägenhet. Kan tycka att det blir lite för brutalt utan, svårt att veta hur det skulle vara i ett mer dedikerat biorum. Sjukt grym för både musik och film.
