JVC´s 2019 års 4K projektor modeller: DLA-N5, N7, NX9
592 svar till detta ämne
JVC DLA-N5 (Projektorer) 2 0 (0) 69 990:-
JVC DLA-N7 (Projektorer) 24 10 (3) 89 990:-
JVC DLA-NX9 (Projektorer) 0 0 (0) 199 900:-
1 relaterade trådar
#551
Postad 04 september 2020 - 22:07
Dr. Zaius
  • Dr. Zaius
  • 3 098 inlägg
Mer ingående info om vad den kommande firmware uppdateringen innehåller:
http://pro.jvc.com/p...er_Release.html
Firmware Upgrade Summary:
1. Theater Optimizer smart function, analyzes the usage environment for each user, and displays HDR content with optimum brightness.*
2. New Settings & Menu Structure (1) Brightness levels settings are increased to five steps for the Frame Adapt HDR function (was previously three steps).
(2) New Content Type menu, which displays usable Picture Mode based on each input signal. Only the Picture Mode matching the input signal can be selected, preventing image distortion due to gamma and color gamut mismatch.
(3) Function which automatically switches to the optimal Color Profile according to the color gamut information of the content.
(4) Added Auto Pic. Mode Select function transitions according to each input signal (SDR/3D/HDR10/HLG).
(5) Picture Mode for Panasonic's Ultra HD Blu-ray player DP-UB9000 Ultra HD Blu-ray player. Added Picture Mode, which allows easy and optimized connection without individual manual settings.
(6) Improved JVC Calibration Software
*Theater Optimizer function is valid only in "Frame Adapt HDR" picture mode.
Overview of Firmware Upgrade:
  • Firmware release date: Mid-November 2020
  • Supported products: DLA-NX5, DLA-NX7, DLA-NX9, DLA-RS1000, DLA-RS2000, DLA-RS3000
  • Content: Free of charge firmware Version 3.50
  • How to upgrade: Upgrade is possible with the file downloaded from the support website.
Redigerat av Dr. Zaius, 04 september 2020 - 22:14.
#552
Postad 07 september 2020 - 07:45
lirsa
  • lirsa
  • 767 inlägg
Tack så mycket för den uppdateringen Dr. Zaius.
Superspännande, undrar om den connection med Panasonics spelare också är applicerbart för UB-820 - som jag har. Idag kör jag med helt avstängd HDR omptimization på 820 och låter N5 få en orörd bild så att säga. Undrar hur det kommer vara framöver.
Som en liten side note: ska också bli superintressant att se Sonys ny projar och vad de kan erbjuda. De har några få fördelar över JVC med en lugnare lite mindre digital bild och betydligt mjukare rörelsehantering. Ska bli intressant att se om de ens kommer i närheten av JVCs DTM. Det var ju anledningen till mitt byte från Sony 520 till JVC N5.
Kul!
#553
Postad 07 september 2020 - 10:02
EkMg
  • EkMg
  • 19 inlägg
Off topic: Är det nya Sony 4k projektors i antågande eller? Inget jag sett något om.
#554
Postad 07 september 2020 - 12:19
lirsa
  • lirsa
  • 767 inlägg
Yes, precis en nystartad tråd om det också. VW590 t ex som jag förmodar blir en rak konkurrent till N5/N7.
#555
Postad 16 september 2020 - 20:37
  • 10 274 inlägg
Kris Deering kikat på den nya FW..
https://www.soundand...imizer-function
#556
Postad 17 september 2020 - 06:46
lirsa
  • lirsa
  • 767 inlägg
Läste också detta, verkat lovande men kanske ingen dealbreaker. Det som ställer till det rejält är att jag har låtit göra en kalibrering redan och måste då allstå göra om den om jag laddar in den nya mjukvaran. Kommer nog behöva avvakta lite...
#557
Postad 22 september 2020 - 11:49
Drem
  • Drem
  • 1 466 inlägg
Någon som testat göra kalibrering med SpyderX och JVC Autocal?
#558
Postad 22 september 2020 - 12:13
Saturnus
  • Saturnus
  • 1 637 inlägg
Såg att Youthman har ett klipp om detta på YT.
#559
Postad 22 september 2020 - 15:09
Drem
  • Drem
  • 1 466 inlägg
Ja precis, jag såg det också och blev sugen på att testa. Visst det blir inte några hundra procent som en riktig kalibrering, men kan man få 85-90% är jag nöjd. Sen kan man ju göra om den hur många gånger man vill. Bra när lampan börjar åldras senare eller något annat ändras i uppsättningen.
Jag tog och beställde en SpyderX Pro iaf.
Redigerat av Drem, 22 september 2020 - 15:10.
#560
Postad 22 september 2020 - 15:55
lirsa
  • lirsa
  • 767 inlägg
Intressant! Med tanke på nya mjukvaran snart så blåser den ju allt - dvs nu kalibrering måste ske. I och med att jag kör en held del HDR så är det int elika känsligt, men kan ma nå 90% med det du beställt och inbyggd programvara så why not. Kul om du skriver lite om detta sen!
#561
Postad 22 september 2020 - 19:10
haker
  • haker
De flesta på det amerikanska forumet menar att SpyderX 'bara' ger ett bra resultat för kalibrering av gamma.  För färg rekommenderas att man använder en eye1pro2 spectrocolorimeter. Jag har själv både en SpyderX och  eye1pro2 och min SpyderX mäter mycket fel gentemot spectrocolorimetern på en färg (tror det var röd) så mitt sample av SpyderX går i alla fall inte att använda till kalibrering av färgerna. Kan också rekommendera att du gör en extra kopia på backupfilen som du får när du kalibrerar första gången så att du kan återställa projektorn till ursprungsinställningar om det inte blir ett bra resultat.
#562
Postad 22 september 2020 - 19:17
Drem
  • Drem
  • 1 466 inlägg
Tack för infon. Det blir kul att testa. Kör du dessa alltså med JVC Autocal eller annan mjukvara? Är det som du säger så kanske man skulle införskaffa en eye1pro2 vid tillfälle. Eller låna kanske, var bor du? :D ;) Får du köra två vändor då eller klarar den att köra båda mätarna för färg och gamma, i samma omgång så att säga?
Lovar skriva något, även om jag ställer till det :)
Redigerat av Drem, 22 september 2020 - 19:19.
#563
Postad 22 september 2020 - 19:42
haker
  • haker
SpyderX har jag bara till JVC Autocal. En eye1Pro2 (eller EFI ES-2000) är ganska dyra men går att få tag på ebay begagnade. Föregångaren eye1Pro (eller EFI ES-1000) finns också begagnade på ebay och går även de att använda med JVC Autocal. När jag kalibrerar så kör jag först en vända med SpyderX och bara gamma kalibrering, sedan byter jag till eye1Pro2 och kör bara färg kalibrering. Det blir ett mycket bra kalibreringsresultat.
#564
Postad 22 september 2020 - 19:58
lirsa
  • lirsa
  • 767 inlägg
Vill inte på något sätt misstro - men vad är "mycket bra kalibreringsresultat"? Att det för ögat kan se bra ut är ju trevligt, men hur väl är det om man skulle mäta och kalibrera med riktiga ISF-verktyg? Har du fått det verifierat?
#565
Postad 22 september 2020 - 20:47
haker
  • haker
Nej det är ju inte så att jag har någon proffsutrustnig som de som kalibrerar projektorer yrkesmässigt men min eye1Pro2 har omkalibrerats det senaste året och med den har jag profilerat min C6 colorimeter samt mätt upp projektorn efter JVC calibreringen med Calman 5. När jag mätte upp projektorn med colorchecker så låg medelfelet deltaE på 0.7 och maxfelet deltaE 1.3 för rec 709 och det tycker i alla fall jag är ett bra kalibreringsresultat.
Redigerat av haker, 22 september 2020 - 20:48.
#566
Postad 23 september 2020 - 06:49
lirsa
  • lirsa
  • 767 inlägg
Kanon! Ville bara försäkra mig om hur du gjort - personligen kan jag tycka det är värt pengarna att få det gjort av ngn som verkligen kan kalibrera. Men finns det ett semiproffssätt som kan få det hyfsat och att man under lampans livslängd kan göra om det så kan det givet vara värt att titta in på det :)
Tack för svar!
#567
Postad 23 september 2020 - 23:33
Marquee
  • Marquee
  • 63 inlägg
Trots att själva projektorn är köpt via Tyskland så gör firman vinst med att sen importera från USA. Det är redan i annonsen tydligt att man får vänta en månad ibland som för mig för det är sån efterfrågan där. Men fått garantier att första veckan i oktober kommer det fyllas på och sen till tyskland och mig sen. Så för att få köpa en N7 för ca 71 tusen och ändå gå med vinst för dem är beundransvärt. Frågat 2 gånger längs vägen om det verkligen inte är fråga om påslag med importskatt och moms sen men de bedyrar att så är det inte. Den är till fullo betald! En RS2000.
#568
Postad 30 september 2020 - 16:46
Drem
  • Drem
  • 1 466 inlägg
Tog en evighet at få hem grejerna. Inte visste väl jag att butiken råkade ligga i Finland  :D
Får se om jag hinner göra detta innan veckan är slut, får återkomma med intryck.
Postad 30 september 2020 - 17:04
Garrett
  • Garrett
  • 6 317 inlägg
Kom hem till mig i Falkenberg sen och kalibrera min epson 9400, bjuder på kaffe och bullar...  :P  :lol:
#570
Postad 14 oktober 2020 - 21:33
edtjope
  • edtjope
  • 695 inlägg
Då var man en glad ägare till en N7:a. Otroligt imponerad över hur den hanterar HDR. Hade en X5000 tidigare med nedladdade custom gamma kurvor, men det är verkligen som natt och dag i skillnad
#571
Postad 14 oktober 2020 - 22:33
Marquee
  • Marquee
  • 63 inlägg
Firman i Tyskland som i sin tur kommer köpa min RS2000 har stött på hinder då JVC inte kunde leverera mellan 1:a och 5:e oktober som är mitt avtal med Tyskland. Men trygg med min investering ändå då JVC menar att det kommer ske veckan därpå. Där är vi nu!
Iaf, skulle allt vara bogus är mitt chatt med dem inom eBay väl dokumenterat att jag självfallet får igen pengarna om jag skulle tröttna på att vänta.
För er med N5/N7 berätta gärna mer om den s k "digitaliserigen" som JVC har över konkurrenten SONY som nu stuckit ut näsan! Jag såg en screenshot med en N7 och Prometheus där dem rundar vad som liknar Saturnus och såg riktigt kantig ut.. inte alls mjuk och fin som förväntat. Men SVART!
Redigerat av Marquee, 14 oktober 2020 - 22:34.
#572
Postad 15 oktober 2020 - 01:45
MKarlsson74
  • MKarlsson74
  • 6 010 inlägg
Screenshots ger tyvärr inte mycket.
#573
Postad 15 oktober 2020 - 07:09
lirsa
  • lirsa
  • 767 inlägg
Jag har både Sony och JVC i min bio och kan säga så mycket att med den senaste generationen av Sony så närmar soig Sony JVS lite med en lite mer digital bild, som säkerligen också härstammar lite från att de höjt ljusoutput en hel del.
Jag kom från fyåra år med Sony VW520 till JVC N5 och klart att Sony var uypplevt mindre "digital" och hade en mjukare bildhantering. Men också betydligt mer oskarp, sämre svärta och mycket mindre ljus. Sony har närmat sig rejält med skärpa och ljusoutput, men har en overall lugnare bild och bättre rörelsehantering men en betydligt sämre bottensvärta.
Så oavsett val, s¨å är det komrpomisser. den enda som kan avgöra vilka kompromisser du kan leva med är du själv och bara du kan avgöra genom att utvärdera på riktigt genom atyt titta själv. Sonys och JVCs projektorer finns på ett flertal ställen för direkt jämförelse.
#574
Postad 19 oktober 2020 - 21:21
Marquee
  • Marquee
  • 63 inlägg
Jag tycker man kan se mycket ur screenshots och det vackraste och behagligaste och på samma gång en så mustig färgåtergivning var från en Sony helt nyligen. Måste varit en 760.. man riktigt tänkte sig in hur det måste vara på plats. Mustiga färger som en CRT men skarp som en digital fast utan att vara kantig.
Iaf, nu har jag fått veta att JVC har en pall med RS2000 på väg till Europa så suget efter JVC måste vara stort. Har fått vänta mer än 1 månad. Jag var välkommen att ringa JVC själv ifall jag misstror tyskland men tror dem. De har sålt flera till Sverige också så inte ensam om detta och rankingen är hög på eBay. Köpt en 80 cm förlängare till takstativet men väntat med 3D-glasögonen. Dyra jäklar!
Sony VW60 är inte kattskit det heller. Fina färger eller en bra forotgraf! Men säkert grå borderlines som bara en (?) JVC kan producera svart. Det är iaf vad jag gått och väntat på alla år och säker vi är där nu.
https://www.avsforum....3137626/page-8
Redigerat av Marquee, 19 oktober 2020 - 22:10.
#575
Postad 19 oktober 2020 - 22:19
Marquee
  • Marquee
  • 63 inlägg
På gasen lite för ledig imorgon.
Men vill ändå påpeka att verkligheten kommit ikapp ficktion som i Prometheus t ex med genomskinliga OLEDs! Fränt av LG att ro hem nåt sånt när man var ett sånt skitmärke när det begav sig i början på 90-talet och VHS.
#576
Postad 27 oktober 2020 - 19:20
  • 10 274 inlägg
Någon som har lust att mäta hur långt det är mellan framfötterna till bakstycket?😊 n5 alt N7
Redigerat av mcmike, 27 oktober 2020 - 19:20.
#577
Postad 27 oktober 2020 - 23:09
Marquee
  • Marquee
  • 63 inlägg
Jag kan inte hjälpa att undra vad marginalen är för N7 för oss svenskar är. Jag får min från USA utan momstillägget till priset ca 70 tusen. Även jag höjer på ögonbrynen.. är påslaget så stort att jag kan köpa en RS2000 till futtiga 70 lax utan moms eller annat? Jag prutade från 75 till 70, btw.
Marcus.. törs du säga inpriset rent ut? Bara det kan förklara mitt pris öht.
Redigerat av Marquee, 27 oktober 2020 - 23:15.
#578
Postad 28 oktober 2020 - 07:10
jln
  • jln
  • 418 inlägg
Om jag tittar i USA kostar den mellan $8-9000x9x1,25x1,05= 95 - 106 000:- och med moms och tull i Sverige. Sverige kostar den 90 000:-.
#579
Postad 28 oktober 2020 - 07:18
Karamasha
  • Karamasha
  • 1 142 inlägg
  • 3
Tror du Marcus kan inköpspriserna i USA? Sen har du inte fått din projektor än, så avvakta vad tullen har att säga om ditt paket. Du kan fortfarande få en fet faktura direkt från dom i samband med leverans, som inte tyska butiken känner till. Att dom mellanlandat i tyskland är inga garantier skulle jag säga.
Kan inte tycka annat än att du är otrolig dryg och besserwissig i ditt inlägg att du hittat vad du tror är en bra deal och sen flasha om det här. Blir ännu mer tragiskt när du säger futtiga 70 lax när du måste ta ett banklån för det.
#580
Postad 28 oktober 2020 - 07:25
petsid
  • petsid
När du lägger på svensk moms om 25% så är ditt pris 87,5 kkr exkl. tullavgifter etc.
Jag skulle inte vara så säker på att du slipper undan allt sånt bara för att du går genom Tyskland.
För att svara på din fråga ligger denna typen av produkter normalt sett i spannet 15-30% marginal.
#581
Postad 28 oktober 2020 - 08:02
Filmsamlaren1
  • Filmsamlaren1
  • 2 617 inlägg
Rent juridiskt har man som privatperson alltid skyldighet att betala importmoms när man köper varor som skickas från regioner utanför EU:s skattesystem. Samma sak gäller även tullavgift i de fallen det är applicerbart och då utgår man ifrån EU:s tullsystem (då vissa områden ingår i det men inte skattesystemet).
I vilket fall... Det är alltså en ÅF i Tyskland du (Marquee) har köpt av? Vad säger de kvitton du har fått på betalning? Om momsen anges där, som i dagsläget ligger på 16% i Tyskland, kan man anta att de har skött klarering och deklaration från USA. Då har du ivf gjort din plikt så långt momsen går. Med det sagt innebär det inte att tullen är betald av dem; Det kan mycket väl hamna hos dig.
Helt riktigt. Räcker med att ändra nivåer i valfri bildbehandlare för att få svärtan att se kolsvart ut exempelvis.
Redigerat av Filmsamlaren1, 28 oktober 2020 - 08:18.
#582
Postad 28 oktober 2020 - 08:35
aperitif
  • aperitif
  • 215 inlägg
+1
#583
Postad 28 oktober 2020 - 08:53
perra1971
  • perra1971
  • 19 inlägg
Någon som har lust att mäta hur långt det är mellan framfötterna till bakstycket? n5 alt N7
Tjena !
På min N5 ser det ut att vara 373 mm.
Skall vara samma på N7.
Mvh Perra
#584
Postad 28 oktober 2020 - 12:36
  • 10 274 inlägg
Tjena !
Mvh Perra
Super, tack för återkoppling😊
// Micke
Redigerat av mcmike, 28 oktober 2020 - 12:36.
#585
Postad 28 oktober 2020 - 19:47
Audiostar
  • Audiostar
  • 1 264 inlägg
Om du tagit den av en svensk åf som du sade att du gjorde först hade du kunnat njuta av bilden från då tills nu istället för att prata om hur billigt du kom undan på något du fortfarande inte har fått.
#586
Postad 28 oktober 2020 - 21:48
Erik_N
  • Erik_N
  • 1 109 inlägg
Beträffade priser i olika länder så kan det även vara så att vissa tillverkare väljer olika prissättning på olika marknader. Projektorer från SONY har länge kostat betydligt mer i USA än i Sverige. Som exempel kan man se på nya VPL-VW790ES som kostar 140 kkr i Sverige och $20k i USA, fast där heter den VPL-VW915ES: https://www.soundand...rojector-review (priset i USA är dessutom utan "sales tax")
#587
Postad 28 oktober 2020 - 22:20
Marquee
  • Marquee
  • 63 inlägg
Jag måste säga att det jag menade med mitt inlägg var bara att få mer på fötterna om jag blivit lurad och absolut inte att "flasha" som en säger. 70 tusen är absolut mycket pengar där en del tar lån, en del samlar ihop, en liten promille tar den på lön. 70 är "futtigt" jämfört med 90 svenska men samtidigt äckligt mycket pengar varesig det är 70 eller 90.
Det jag hoppades på var mer på fötterna om jag blivit lurad eller vad det kan bero på att jag lyckades inte bara sänka priset i en budaktion som slutade med en kontring med + 1000 kr. Alltså 70 jämt kan vi säga. Trodde aldrig Marcus skulle berätta ett ord om marginalen på en N7 så det var mer en chansning men absolut inget hån mot honom. Han säljer säkert massor med N7 även iom jag köpt min på ebay för en mindre summa. Nu har jag mer på fötterna att jag s a s kan ställa fler frågor internt via ebay till säljaren som är en vanlig butik och ingen ÅF som en undrade över. Deras nya annonser (efter mitt köp) säger emellertid att VAT kan pålägga priset så frågat om detta men de bedyrar att 70 är mitt pris inga pålägg. Om det vore utanför handelsplatsen skulle jag bryta köpet men istället ska jag med nyfunna svar från er ställa några till så att repet snörs åt lite ifall det ändå är ett skämt.
Jag ville aldrig flasha, det var aldrig tanken, men tänkte vi kunde ha en trevlig stund inbördes med lite screenshots men tycker vi lägger det åt sidan och glömmer det helt. Påstruken gör vem som helst plump så det är jag skyldig till men annars är jag bara nyfiken vad som väntar mig. Kanske blir det hela en jävligt dyr läxa men kom då tillbaka och må gott åt det.
https://www.google.c...iw=1240&bih=571
Hittade detta så blir lite ängslig att jag måste öppna en dispyt för att få bollen i rullning.
Re: EBAY BUYER OPENED DISPUTE ON PAYPAL AFTER 45 DAYS! PLEASE HELP?
A buyer since June 17th can open a dispute up to 180 days post payment.
Lite mer till min fördel.
https://www.auctionn...rocess-a-guide/
I annonsen stod att leveransen skulle bli mellan 1:a och 5:e oktober. Dvs, ca 1 månads väntetid. Nu börjar vi tassa på snart 2 månaders väntetid.
Sen dess har jag frågat om detta och svaret är att JVC US inte kunnat leverera förren nu med en hel pall JVC. Det har dock gått över tiden även med detta så måste starta en ytterst vänlig dispyt så allt är dokumenterat och klart men misstror dem inte för det. Kommer berätta bakomliggande motiv också varför det måste till så tror de är helt ok med det. De säger ju att det är JVC som inte levererat. Kanske fast i tullen vad vet jag!
Redigerat av Marquee, 28 oktober 2020 - 23:42.
#588
Postad Igår, 08:07
  • 10 274 inlägg
@Marquee
Om du köpt genom ett EU land och i annonsen står att VAT inkl så behöver du inte vara orolig. Fick svar från JVC tidigare gällande garantin att den har man, dock i det landet man köpt ifrån vid näthandel över gränserna. Hoppas det går bra för dig iallafall😊
Redigerat av mcmike, Igår, 08:08.
#589
Postad Igår, 21:41
Marquee
  • Marquee
  • 63 inlägg
@Marquee
Jag letade efter min annons men nedtagen nu men har inget minne att VAT skulle läggas på priset. Deras nuvarande annons säger emellertid att tysk VAT om 16% är inkluderad i priset. Ser ut att vara en bra försäljare men man kan aldrig veta säkert så klart. Jag ger det någon vecka till innan jag frågar igen om hur det går.
https://www.ebay.com...xbwGve#shpCntId
#590
Postad Igår, 21:45
lirsa
  • lirsa
  • 767 inlägg
eller så drar du bort 20k och köper min kalibrerade N5 (du ser ingen skillnad mellan N5 och N7) med närmare 1,5 år garanti kvar ;)
#591
Postad Igår, 22:51
Marquee
  • Marquee
  • 63 inlägg
Tack för erbjudandet, ska ha det i minne! Vad tänkte du byta upp dig till då? Den nya sony för 75000?
Ahh, förlåt, det var ju du som redan har båda hemma. Men en sony vart det ju! Säkert en superprojektor som man bara måste få se en dag. Umeå är för litet för nichföretag som säljer projektorer av sorten man verkligen är intressserad av.
Om det till äventyrs finns någon som kan tyska och villig att läsa Terms and conditions of the sale för min projektor vore super. För stor text för Översättning på Google, tyvärr. Kanske finns något alarmerande dolt i mängden text där.
Redigerat av Marquee, Igår, 23:03.
#592
Postad Idag, 07:32
martiin82
  • martiin82
  • 501 inlägg
Jag missade just en 5a på blocket så jag är spekulant om någon vill byta upp sig
#593
Postad Idag, 08:04
lirsa
  • lirsa
  • 767 inlägg
Jag hade Sony VW790 på testbänken hemma under en helg, medn varit galet ambivalent om jag ska hoppa på lasertåget nu eller vänta. Det är som bekant kompromisser även på den prisnivån ska ni vet :)
