Denon, Marantz, Yamaha - Bug i chipset från Panasonic
16 svar till detta ämne
Postad 23 oktober 2020 - 20:57
Zerox_no1
  • Zerox_no1
  • 2 958 inlägg
Vafan, j*vla typiskt!  :angry: Gäller årets modeller.
https://translate.go...en-4935888.html
https://www.reddit.c...utm_term=jgjzsb
In essence it says that due to a BUG on the used panasonic chipset these functions are not working. The bug is not fixable by firmware update.
Update 2: I asked AudioHolics about the issue and they know of it too. Sound United (Denon, Marantz) will release info on this soon.
As stated in the article from heise there may be workarounds. How they look and how practical they are has to be elaborated.
Update 1: It seems the problem is specific to XBOX Series X and NVIDIA graphicscards. PS5 should work, but is not proven.
Guess we have to wait a bit till it clears up.
Redigerat av Zerox_no1, 23 oktober 2020 - 20:59.
Postad 23 oktober 2020 - 21:15
Fellow88
  • Fellow88
  • 1 128 inlägg
  • 4
Detta kommer inte accepteras av någon av årets kunder kan jag lova. Det är bara att reklamera om åtgärd inte ordnas pga felaktig specifikation.
Vad tror ni när hemsidan specar och flashar med funktioner som inte fungerar.
Svensk konsumentköplag är ganska tydliga här.
Redigerat av Fellow88, 23 oktober 2020 - 22:41.
Postad 24 oktober 2020 - 08:42
Bogge
  • Bogge
  • 790 inlägg
Oj vad illa om det stämmer. Årets receivers klarar alltså inte 4K 120Hz HDR med nya Xbox eller Nvidia 3000 korten pga en hårdvarubug i ett chip. Skärmen blir svart.
"..suspected breakdown of the chip manufacturer Panasonic Solutions (meanwhile taken over by Nuvoton Technology) ensures that, according to the current state of knowledge, all HDMI 2.1-compatible receivers from Denon, Marantz and Yamaha are not able to transfer videos in these ultra-high resolutions to the TV without errors with certain players. The TV screen then remains black due to the HDMI 2.1 glitch .
According to research by the c't, this problem also affects receiver models that are currently still in development - including the avantage models from Yamaha, which have been expected for a long time. Onkyo / Pioneer and Sony are also said to have bought the aforementioned HDMI chips from Panasonic Solutions; these companies have not yet announced any AV receivers with HDMI 2.1."
"With the PS5, the transmission should work according to c't information; c't has not been able to verify this so far."
Postad 24 oktober 2020 - 14:02
Zerox_no1
  • Zerox_no1
  • 2 958 inlägg
Update 3: Audioholics got a Response from Sound United in short: Sound United will offer a permanent solution at a later date. They are currently investigating the issue. (I think personally this will mean replacement of board or receiver) Workarounds are: set source to 4k60 or connect directly to the TV.
Postad 24 oktober 2020 - 14:33
Iceman666
  • Iceman666
  • 343 inlägg
Borde fungera med en HDFury emellan ”spelare” och förstärkare ?!?
Postad 24 oktober 2020 - 15:03
Fellow88
  • Fellow88
  • 1 128 inlägg
Det är inte en lösning på problemet. Vi som lagt 13 000 på en receiver med vissa specifikationer ska inte behöva köpa en låda för flera tusen för de gjort fel.
Visst, har man en av någon anledning liggandes är de säkert en temporär fix, men inte en lösning på problemet.
Jag antar att man kommer få skicka in som receiver för åtgärd som Onkyo gjorde mellan 2016-2018(?).
Redigerat av Fellow88, 24 oktober 2020 - 15:16.
Postad 24 oktober 2020 - 15:32
Zerox_no1
  • Zerox_no1
  • 2 958 inlägg
En på Avsforum verkar inte ha buggen.
https://www.youtube....h?v=zwKFS1HN6N8
Edit: Så fort han sätter på VRR så blir det igen bild på tv'n.
Redigerat av Zerox_no1, 24 oktober 2020 - 17:27.
Postad 24 oktober 2020 - 15:40
Hays
  • Hays
  • 1 098 inlägg
För mig blinkar hela videon grönt och bara massa svarta streck, både på datorn och mobilen blir det så.
Postad 24 oktober 2020 - 15:43
Zerox_no1
  • Zerox_no1
  • 2 958 inlägg
Ja, det verkar vara något problem med Youtube. Helt plötsligt har videos börjat se ut så där för en massa andra.
Redigerat av Zerox_no1, 24 oktober 2020 - 15:43.
Postad 24 oktober 2020 - 17:57
Iceman666
  • Iceman666
  • 343 inlägg
Fick precis detta svar från HDFury.
-“We do not have any products released with a new hdmi 2.1 chipset. Please check back with hdfury.com during December.”
Så var det med det!
Postad 24 oktober 2020 - 19:12
Zero
  • Zero
  • 1 169 inlägg
Så det är därför som Yamaha inte kan svara när de börjar skicka ut sina Aventage stärkare, väntar på en Yamaha RX-A8 men verkar som man får vänta lite längre då.
Postad 24 oktober 2020 - 19:17
Zero
  • Zero
  • 1 169 inlägg
Står i artikeln att påverkade modeller kommer få nya hela chip i mitten på nästa år, suck blir en jäkligt lång väntan på min RX-A8 med andra ord.
Postad 25 oktober 2020 - 14:51
Zerox_no1
  • Zerox_no1
  • 2 958 inlägg
Officiellt svar från Sound United.
https://www.audiohol...mi-2.1-chipsets
 Official Sound United Response Regarding the HDMI 2.1 Chipset Bug
Some new gaming source devices that support 4K/120Hz output may not work fully with Denon (or Marantz) 8K AVRs. You may discover this incompatibility issue due to a HDMI chipset mismatch between the devices. When the affected system is connected to the AVR via 8K HDMI input and set to output at 4K/120Hz, and the AVR’s 4K Signal Format option is set to “8K Enhanced,” you may not see the system’s source video on their display, and may not hear the system’s source audio processed through the AVR. This problem is only present when a display that supports 4K/120Hz is used.
We are currently investigating the issue further and will offer a permanent solution at a later date. Meanwhile, we would like to provide a couple workarounds to prevent the issue in its current state:
  •  You can connect the system to the display directly via HDMI and use the display’s ARC/eARC functionality to feed the native audio back to the AVR using the connected HDMI cable between the AVR and display. This will allow users to decode the native audio format sent from the source. With this method, the display’s CEC/ARC option must be enabled as well as the AVR’s HDMI Control and/or the AVR’s ARC option. In the AVR, this option is located within the GUI under “Video – HDMI Setup.”
  •  Another workaround is to leave or change the source’s video output to 4K/60Hz instead of 4K/120Hz until a permanent solution is available. This will ensure reliable communication between the source, the AVR and the display. The source’s default is set to output at 4K/60Hz, so if no change was initiated out of the box, then nothing further needs to be done.
We apologize for this inconvenience and we are currently working tirelessly to release a permanent solution so you can enjoy the 4K/120Hz experience using the latest sources with your AVR. We will have an update soon regarding the timeline of a permanent solution. We appreciate your patience.
Official Yamaha Response Regarding the HDMI 2.1 Chipset Bug
As we test and explore new gaming system capabilities and the latest HDMI specifications, we will provide guidance on our website to help new and future customers with the compatibility of our latest AV receivers. We will certainly provide you with an update in the near-term.
Redigerat av Zerox_no1, 25 oktober 2020 - 14:52.
Postad 25 oktober 2020 - 15:14
Zerox_no1
  • Zerox_no1
  • 2 958 inlägg
Ny uppladdning
https://www.youtube....eature=emb_logo
Postad 07 november 2020 - 16:00
Truckerhate
  • Truckerhate
  • 372 inlägg
Är det helt säkert detta inte kommer ställa till det på PS 5?
Postad 10 november 2020 - 00:20
Audio One
  • Audio One
  • 806 inlägg
Bättre och vänta på nästa generation, så slipper man oroa sig. Å andra sidan vad ska man till 8K med??
Postad 15 november 2020 - 23:14
Zerox_no1
  • Zerox_no1
  • 2 958 inlägg
Möjligt att det går att fixa med firmware/drivrutiner så att det går att köra PC med 2.1 grafikkort (3080) 4k120Hz+HDR+VRR stabilt via receivern. När det kommer till Series X verkar det behövas byte av chip.
https://translate.go...ar-4940324.html
