* Officiell tråd - Denon AVR-4306 *
396 svar till detta ämne
Postad 12 October 2005 - 11:35
Horrabin
  • Horrabin
  • 402 inlägg
Denon AVR4306
Available in Black & Silver
Upconversion & Scaling to HDMI (High-Definition Multimedia Interface)
Built in Faroudja FLI-2310 De-interlacer & Scaler (480p / 576p / 720p / 1080i)
iPod Docking Port & USB dock port for connection to other MP3 players & memory sticks
Browse Your iPod music/photo collection through the on-screen display using the remote control
3rd and 4th Gen and Mini iPods compatible with docking port (older models through 3.5mm jack)
Charge your iPod through the docking port
Ethernet port allows WMA, MP3 & PCM files to be played from a remote server
Can be controlled across the internet using web browser
Dolby Digital and DTS decoding
Dolby Digital EX, Pro Logic IIx decoding with Cinema and Music Modes
DTS-ES Matrix & Discrete 6.1 decoding
DTS Neo:6 96/24 Cinema & Music Surround decoding • DTS 96/24 5.1 decoding
HDCD decoding
3D Y/C Separation & Time Base Corrector
32-Bit SHARC Floating point-DSP 3rd Generation SHARC ADSP-21367 2400 MFLOPs
Audyssey MultEQ XT Auto-Setup and Room EQ function with microphone supplied
Pure Direct mode, features 4 DACs per audio channel in dual-differential configuration (2 Channel Sources)
ALPHA 24 Processing Plus (AL24+) on all channels
3 Assignable Component Video inputs (100MHz Bandwidth), with On-Screen Display
Video Conversion of Composite to S-Video, Component to HDMI, with on-screen display
7.1 external wide bandwidth (100 kHz) inputs for multi-channel formats, such as DVD-Audio and Super Audio CD
5/7 Channel Stereo
Digitally regulated volume control with .5dB increment adjustments and step range of -80 to +15
Audio Delay adjustment to match audio signals with video signals (0-200ms)
DENON Link 3rd (Super Audio CD & DVD-Audio) compatible digital input
7 assignable digital inputs (5 Optical, 2 Coaxial)
Built-in RDS AM/FM tuner
3 Source, 3 Multizone functionality with Discrete Power, Source Select and Volume control for each zone
Power Amplifier Assign function, lets you assign 2 of the 7 amp channels to drive Zone 2 or 3 speakers directly & Bi-Amp the Front Channels.
New EL backlighting pre-programmed/learning remote
RS-232C Port for Third Party Control Systems
Remote I/O ports
Assignable +12v triggers (2)
Släpps i slutet av november.
Mycket intressant mellanalternativ. Jag har länge varit sugen på A11XV, och inte riktigt varit nöjd med 3806:s specar, men nu har information om denna dykt upp och ser verkligen lovande ut. 3 HDMI-ingångar, uppkonvertering till HDMI och scaling till 720p/1080i, Audyssey-inställningar, streaming från dator av musik, setup via webb-browser, iPod ingång m.m.
Läs mer (på tyska) hos Denon: Denon AVR-4306
Redigerat av Martin.M, 18 December 2005 - 21:34.
Postad 12 October 2005 - 12:21
clevername
  • clevername
  • 1088 inlägg
Interessant! Någon som vet vilken nivå Faroudja FLI-2310 ligger på kvalitetsmässigt?
Edit: Hm, ingen 1080p?
Redigerat av clevername, 12 October 2005 - 12:23.
Postad 12 October 2005 - 15:12
BioBerra
  • BioBerra
  • 5779 inlägg
Faroudja chipet verkar matcha denna DVD spelare i kvalité.
http://www.hifiklubb...55|5549|pdetail
I den analoga – och diskreta – bilddelen används två stycken 12-bitars 216 MHz-D/A-omvandlare av mycket hög kvalitet. DVD-3910 har även en inbyggd Faroudja FLI-2310-bildprocessor som ger bilder i Progressive Scan – både i PAL och NTSC. Samma processor utför skalning av bilden så att den kan anpassas till HD-kompatibla skärmar och projektorer.
Postad 12 October 2005 - 16:00
Unregistered1082
  • Unregistered1082
  • 211 inlägg
Hittade inget pris på den tyska sidan, men på den amerikanska sidan så hittade jag ett pris.
3,500.00 USD
United States Dollars = 27,201.65 SEK
Den lär ju inte vara aktuell för svenska marknaden... eller har vi tur ;)
ersätter denna A11XV eller??? den är mycket intressant i allafall.
Postad 12 October 2005 - 16:18
Horrabin
  • Horrabin
  • 402 inlägg
Nej, denna ska inte ersätta A11XV, utan vara en slags mellanvariant mellan A11XV och 3806. På AVLand i England är priset lite mer rimligt än i USA. Där kostar den £1499.95, ca 20 400 SEK. Jag har för mig att jag har sett någon som sett en planerad prisbild på runt 20 000 SEK, så det stämmer ju ganska bra. Som jämförelse kostar A11XV £2499.95 på AVLand, ca 34 000 SEK, men "bara" 27 000 SEK på Hifiklubben, så det verkar ju lovande. ;)
Den ska släppas i slutet på november.
Redigerat av Horrabin, 12 October 2005 - 16:22.
Postad 12 October 2005 - 18:12
Unregistered2811108e
  • Unregistered2811108e
  • 159 inlägg
Det står 1999,- EUR på Denons hemsida (om man kollar lite noga ;) )
Postad 13 October 2005 - 12:52
BioBerra
  • BioBerra
  • 5779 inlägg
Känns som denna kommer bli lite väl dyr trots allt, man får nöja sig med en 3806 känns det som.
Postad 13 October 2005 - 16:13
Blind Guardian
  • Blind Guardian
  • 335 inlägg
Ser ut som ett bra alternativ för en serils hemmabio. Typiskt Denon medoändligt många funktioner.
Postad 13 October 2005 - 16:29
Aztecface
  • Aztecface
  • 1194 inlägg
Denna modell är något jag ser fram emot.
Postad 13 October 2005 - 18:06
Cerwin vega Al-1000
  • Cerwin vega Al-1000
  • 1391 inlägg
Fråga är denna maskin klassat med
THX ULTRA 2??????
Fy för isåfall ;)
Postad 13 October 2005 - 18:11
lunkens
  • lunkens
  • 437 inlägg
Tråkiga med Donon är att HiFi-Klubben i stort sett har monopol på dess större maskiner. Visst kan andra återförsäljare köpa in dem. Men löjligt pris, vilket slår på deras avanser och intresset för att ta in produkten.
Enl. Svensk lagstiftning skall det råda fri konkurans inom detta. Men har ett företag hängsnaran hos en leverantör så blir det såhär tydligen :P
Verkar bli en verkligt godbit till maskin dock ;)
/K -_-
Postad 13 October 2005 - 22:41
Horrabin
  • Horrabin
  • 402 inlägg
Den verkar inte ha någon THX-certifiering över huvud taget. Ingen THX Ultra 2 i alla fall.
Postad 14 October 2005 - 06:30
Unregistered40880
  • Unregistered40880
  • 865 inlägg
Hmmm, den har fortfarande EI transformator medans modellen/erna över har Ringkärna....
Behöver ju inte betyda så mycket iof.....
Postad 14 October 2005 - 09:20
Unregisteredf2a7f9fd
  • Unregisteredf2a7f9fd
  • 3989 inlägg
THX ULTRA 2??????
Fy för isåfall :P
Nix det har den inte då måste man lägga till en del pengar och skaffa 4806..
Postad 14 October 2005 - 13:02
  • 12538 inlägg
Hm... en reciever för runt 20 lakan, utan ringkärna?
Postad 14 October 2005 - 15:19
Horrabin
  • Horrabin
  • 402 inlägg
Ageve eller The Count: Kan någon av er förklara vad en ringkärna innebär, varför det är bättre att ha det och hur det kan påverka ljudet. Själv har jag noll koll på detta.
Postad 14 October 2005 - 16:31
  • 12538 inlägg
Den största fördelen med ringkärnetrafo är mycket högre effektivitet i förhållande till storlek, men
det finns även många andra fördelar:
http://www.plitron.c...es/advantag.htm
Redigerat av Ageve, 14 October 2005 - 16:45.
Postad 14 October 2005 - 18:25
Cerwin vega Al-1000
  • 1391 inlägg
THX ULTRA 2??????
Fy för isåfall :P
Okej men tack för svaret.....men vad ligger en sån maskin på då i pris. Men den är inget för mig jag tänker nog satsa på A1SE eller A1SR för dom har thx ultra....
:lol: men tack för svaret
Postad 14 October 2005 - 18:34
Unregisterede68eb861
  • Unregisterede68eb861
  • 5548 inlägg
THX ULTRA 2??????
Fy för isåfall :P
Den klarar väl inte kraven för att nå upp till THX Ultra...? :lol:
Kanske inte lika kul att sälja en surroundreciver med en prislapp på nästan 20 papp med endast THX Select-märkning...! :(
Och ska man sälja en reciver för 50 papp...då MÅSTE den vara Ultra II-märkt=för trovärdighetens skull och för att motivera den höga prislappen & top-of-the-line.
THX-märkning kan både vara positivt, men oxå negativt för vissa recivrar...därför är en del utan märkning...även om de borde vara märkta... !
På billigare maskiner ger jag inte mkt för THX-märkningen...eftersom de lägsta THX-kraven är så låga....men dyrare recivrar bör vara THX-klassade så man vet vad man får när man lägger ut så mkt pengar...!
:P ...förklarar nog en hel del=enkel och billig strömförsörjning...!
Finessmässigt, för de som behöver allt och inte är ute efter bästa ljud & kraft för pengarna, verkar dock denna AVR-4306 vara en riktig höjdare...dvs ungefär som vanligt med Denons maskiner... :lol:
Mvh JB
Redigerat av Unregisterede68eb861, 14 October 2005 - 19:14.
Postad 03 November 2005 - 16:13
Horrabin
  • Horrabin
  • 402 inlägg
Nu finns det en manual att ladda ner från Denon:
AVR-4306 manual (eng)
Postad 03 November 2005 - 16:55
Andy1
  • Andy1
  • 159 inlägg
När kommer den till svedala???
Är sugen nu!!!!!!!!
/Andy
Postad 03 November 2005 - 17:03
BioBerra
  • BioBerra
  • 5779 inlägg
Blir nog så att man sparar pengar till denna istället för en Denon 3806, just att den har skalningsmöjligheter gör den mycket mer intressant,då slipper man ha en extern scaler och alla bildkällor blir av bra kvalité :D
Postad 04 November 2005 - 10:55
ingbrant7
  • ingbrant7
  • 27 inlägg
Vilka kommer skillnaderna att bli mellan AVR-3806, AVR-4306 och AVR-4806?
Postad 04 November 2005 - 21:26
Unregistered3992e2e8
  • Unregistered3992e2e8
  • 376 inlägg
Förstår inte vad man vinner på skalningen. Låt säga att man har en projektor med 1280x720 i upplösning. Att servera den med en 640x480-signal från exempelvis Digitalkameran kommer väl inte ge någon direkt förbättring? Projektorn kommer ju inte återge den i sitt ursprungsformat utan skala upp den till "sin" upplösning. Eller jämnar uppskalningen till bilden lite och räknar ut vilken färg det ska vara på bildpunkterna som ligger "imellan"?
Men det har ju projektorn redan gjort eftersom 640x480 inte är enkelt dubbleringsbart med 1280x720 (Eller 960x720 som blir den 4:3-upplösning som kommer användas)
Jag förstår som sagt inte det här med upskalning...men det kanske är så att jag behöver det... ;)
Postad 05 November 2005 - 01:52
  • 12538 inlägg
Jag förstår som sagt inte det här med upskalning...men det kanske är så att jag behöver det... :wub:
Om jag inte har helt fel för mig så:
Förstärkaren skalar upp bilden till HD-upplösning (om den inställningen är vald) och "deinterlacar"
bilden (skapar en progressiv bild).
Dvs projektorn får en 1280x720 signal. Om panelen har samma native-upplösning så kommer det
att resultera i en skarpare bild. Det stämmer som du säger, att den lägger till punkter, ungefär
som när man förstorar en stillbild på datorn i Photoshop eller Paint Shop Pro osv.
Däremot förstår jag inte heller riktigt meningen med att ha denna bildbehandlingen i förstärkaren.
Iaf inte för oss hemanvändare som inte har 32 olika signalkällor ;)
Bra DVD-spelare, t ex Denon 3910 med uppskalning, kopplad direkt till projektorn med DVI eller
HDMI = Det är stabilt :wub:
Redigerat av Ageve, 05 November 2005 - 01:58.
Postad 05 November 2005 - 17:20
  • 159 inlägg
Area DVD har en förhandstest mellan 3806 och 4306.
Förutom att det går att få uppskalad TV bild till projektorn , så låter tydligen 4306 mycket bättre än 3806. Så denna reciver står högst upp på önskelistan inför Jul :wub:
Postad 05 November 2005 - 20:02
Unregisteredc7194d09
  • Unregisteredc7194d09
  • 485 inlägg
Lite information om skillnaderna mellan AVR-3806 och AVR-4306:
* + 10 watt per channel
* Ethernet streaming via RJ45 port that will do:
Internet radio
MicroSoft web center support (stream any audio file from the PC’s hard dics)
Internet IP control (control any function on the amp from your PC’s internet browser – anywhere in the world with internet access)
* iPod connection (Same solution as in Denon S101)
* USB (for any other MP3 player)
Identical to AVR-3806
* Design – exactly the same
* Remote
* Video switching capabilities – like in AVR3806 and AVCA11XV it will do HDMI repeating, “passive” up conversion to HDMI from analogue video (composite, S-video and component)– but NO build in video up-scaling.
* Audyssey and other auto set-up features
/Mathias
Postad 05 November 2005 - 20:10
softman3
  • softman3
  • 1449 inlägg
Identical to AVR-3806... --->
det är väl skillnad på denna utgåva/version av audyssey? du har väl mer möjligheter på 4306an?
eller är det bara 4606an ( dvs 11an ) som är som värstingen???
Postad 05 November 2005 - 23:29
  • 159 inlägg
Samma version på 3806 och 4306, med 6 platser. 11:an har 8.
Postad 15 November 2005 - 16:55
Horrabin
  • Horrabin
  • 402 inlägg
Någon som vet mer exakt när denna ska släppas? Tidigare stod det "slutet av november" (fast på tyska) på Denons sajt, men nu står det att den ska komma i december. Någon från HifiKlubben här som har fått något mer exakt besked?
Postad 15 November 2005 - 18:31
  • 485 inlägg
Den ska enligt mina senaste uppgifter komma till vårt huvudlager "i början av december". Denon brukar vara rätt duktiga på att hålla sina leveransbesked på nya produkter så i mitten av december bör den finnas i butikerna. Hör efter med respektive butik när de får in den!
Mvh Mathias
Postad 15 November 2005 - 18:46
Unregistered1082
  • Unregistered1082
  • 211 inlägg
Mathias B>>>> den finns ju inte på eran hemsida, så till vilket pris kommer ni att sälja den för??
/Wecco
Postad 08 December 2005 - 18:16
Ratt
  • Ratt
  • 17 inlägg
Danska HIFI4ALL skriver lite om Denons 4306
http://www.hifi4all....d=1121&zoneid=1
/Ratt
Postad 14 December 2005 - 17:01
Fikonhjul
  • Fikonhjul
  • 27 inlägg
Home Cinema Choice har en färsk pressrelease.
Redigerat av Fikonhjul, 14 December 2005 - 17:03.
Postad 15 December 2005 - 02:34
Unregistered1103
  • Unregistered1103
  • 5967 inlägg
/Wecco
I Usa kostar 4306 "1999 dollar" vilket fritt omräknat blir 15.440 kr
3806 kostar i Usa 1299 vilket skulle bli 10.033 kr
Så lägg på två tusenlappar på 4306 som de har gjort på 3806
så har du det svenska priset Dvs ca 17.500 kr :)
Jag tror att jag kommer att slå till på denna, men har några frågor
som snurrar i huvudet fortfarande. Hoppas att få svar på dem på
HiFi klubbens forum.
Postad 15 December 2005 - 13:04
Horrabin
  • Horrabin
  • 402 inlägg
När jag frågade inne på Hifiklubben på Sveavägen i Stockholm för några veckor sedan så sa dom att den skulle komma runt den 16 dec och priset låg på 17900:-. Den har ju inte dykt upp ännu, men förhoppningsvis kommer den in innan jul i alla fall.
Postad 15 December 2005 - 20:40
  • 485 inlägg
Den har kommit in på vårt huvudlager nu, så det ska kunna bli en julklapp :D Priset är 17998 om jag inte missminner mig.
Lite mer info:
+ 10 watt per channel compared to AVR3806
HDMI video conversion like in 3806 – but with Faroudja video processing including de-interlacing (=progressive scan) and video upconversion to 1080i.
Ether net streaming via RJ45 port that will do:
Internet radio (mp3 based stations)
MicroSoft web center support (= stream any audio file from the PC’s hard dics)
Internet IP control (= control any function on the am from your PC’s internet browser – anywhere in the world with internet access)
iPod connection (=S101 solution)
3 HDMI input (3806 has 2)
Mvh Mathias
Postad 18 December 2005 - 14:41
Unregistered1103
  • Unregistered1103
  • 5967 inlägg
Eftersom att detta kommer att bli "Best choise" 2006 för mellan 15.000 - 25.000 pengar är det väl bara att göra denna tråden "officiell"
Jag har redan bestämt mig för ett köp, utan tvekan !!!
Postad 18 December 2005 - 15:47
Unregistered42611
  • Unregistered42611
  • 4120 inlägg
Priser tycker jag är skitsnack... :(
Allt beror ju på vad du har till, och priser finns det ju i överflöd. Tycker Inte heller det är en anledning att göra en officiell tråd. Men däremot! Så verkar ju det vara ett populärt diskutionsämne. Av DEN anledningen kan ju en Officiell tråd övervägas.
//Loofy
Postad 18 December 2005 - 17:51
Unregistered1103
  • Unregistered1103
  • 5967 inlägg
Tror inte att det var priset jag syftade på:(
Det var bara en angivelse i vilket skikt den ligger för inte kommer man väl ifrån att man måste betala för det man köper och liknande utrustning ligger väl i detta skiktet. Men helt okey för för mig om jag kan köpa en bättre sak för mindre pengar för märket spelar mig ingen roll.
Tror nog att det var produkten som jag anser vara intressant ... jag också :)
Postad 18 December 2005 - 17:59
Unregistered42611
  • Unregistered42611
  • 4120 inlägg
[quote name='MaVeRiC' date='Dec 18 2005, 14:41 ']
"Best choise"
[quote name='MaVeRiC' date='Dec 18 2005, 17:51 ']
[/quote]
Det jag syftade på var "Best Choise". Pris kanske är felformulering? utnämning, kanske bättre? Hursomhelst. Så var det detta jag menar. Det finns för många sådana här typer av utnämningar, så, jag tycker det är lite urvattnat begrepp, "Best Choise" tror jag inte ett ögonblick på, att den är till/för alla.
//Loofy
Postad 18 December 2005 - 18:49
Unregistered1103
  • Unregistered1103
  • 5967 inlägg
Är med dig !
Du vet, när man är övertygad om att något man valt är det bästa vill man gärna ge det ett fint namn .. Som tex tanten hemma :(
Postad 18 December 2005 - 19:39
Unregistered1103
  • Unregistered1103
  • 5967 inlägg
Så !
Nu till tekniken ..
Om man nu har alla omvandlare ( scaler ) som finns i 4306
då behöver man ju varken tänka på vad tvn eller DVD har om man
låter 4306 ta hand om alla bitar ??? ( hdmi kabel en förutsättning )
Vad gäller för ljudbiten. Där har det heller ingen betydelse vad som sitter
i DVD spelaren ( tänker på CD skivor ) för det är väl 4306 som fixar till
det också ???
Finns det något geni som kan reda ut begreppen för mig ?
Om vi börjar med detta.
Postad 18 December 2005 - 21:05
Horrabin
  • Horrabin
  • 402 inlägg
Tänkte bara meddela att jag knallade in på Hifiklubben på Sveavägen i Stockholm idag och fick höra att dom fått in ett exemplar av 4306, så jag blev ju tvungen att köpa den på en gång. Så nu sitter jag här hemma och ska koppla in allting. Jag får återkomma senare med lite kommentarer på hur den fungerar, om inte ikväll så förhoppningsvis i morgon.
Den är i alla fall snygg. :(
Postad 18 December 2005 - 21:50
Unregistered1103
  • Unregistered1103
  • 5967 inlägg
Låter bra !
Ser fram emot din resume ..
Du har nog en lång natt framför dig :(
Postad 19 December 2005 - 22:49
rsmg
  • rsmg
  • 24 inlägg
Ho ho, Horrabin !
...snart inga naglar kvar :-)
Mvh. rsmg
Postad 19 December 2005 - 22:50
skrotfot
  • skrotfot
  • 1201 inlägg
Den är i alla fall snygg. :angry:
Och naturligtvis, samma gamla tjat:
Vi vill se bilder! :( (avundsjuk)
Postad 19 December 2005 - 23:44
Unregistered1103
  • Unregistered1103
  • 5967 inlägg
Så bra var den !
Han kan inte slita sig ...
Vilket ego :angry:
Postad 20 December 2005 - 12:51
Unregistered1103
  • Unregistered1103
  • 5967 inlägg
Den svenska texten från HiFi Klubbens hemsida ! :(
Postad 20 December 2005 - 13:01
Horrabin
  • Horrabin
  • 402 inlägg
Har tyvärr inte så många kommentarer att komma med än så länge. Jag fick igång den rätt sent i söndags efter att ha försökt få bild & ljud på några olika sätt. Eftersom ingångarna är så flexibla så måste man peka ut vilken ingång som hör till vilken device, annars kan det bli lite knas. Sen har jag inte hunnit köra någon Audyssey-inställning (och lär inte hinna köra det innan jul eftersom jag åker bort i morgon) så jag kör bara rakt av. Ljudmässigt låter det ungefär som det gjorde med min tidigare receiver, en Yamaha 1400, men det är alltså utan större lyssningsprovningar och utan inställningar. Bildmässigt så fungerar det fint att koppla in allt möjligt och bara köra ut komponent eller HDMI, och även uppkonverteringen till 576p, 720p eller 1080i fungerar bra. Har inte tittat så noga på hur pass bra bilden blir, men den känns vassare än tidigare (när den gick genom 1400:an). Gillar displayen men är inte förtjust i fjärren. Som tur är har jag en multifjärr som jag ska programera, och då slipper jag använda Denons längre.
  • Switch 2 Zelda Edition
    2026-11-09 07:26:45
