LGs nya FullHD LCD-TVs Våren-07
914 svar till detta ämne
#551
Postad 31 May 2007 - 20:54
ktd
  • ktd
  • 1662 inlägg
Tror Moninfo är ett rätt ouppdaterat program så jag vet inte hur väl det stämmer.
Tex. så rapporterar det att jag kör Windows 2000 fast jag kör Vista Ultimate 32-bit...
Monitor
  Windows description......... Allmän PnP-bildskärm
  Manufacturer description.... 47LY95
  Manufacturer................ LGE
  Plug and Play ID............ GSM9CC2
  Serial number............... n/a
  EDID data source............ Registry (stored)
  Manufacture date............ 2007, ISO week 5
  EDID revision............... 1.3
  Display type and signal..... Digital
  Sync input support.......... n/a
  Screen size................. 700 x 390 mm (~33")
  Power management............ Standby, Suspend, Active off/sleep
Color characteristics
  Display gamma............... 2,20
  Red chromaticity............ Rx 0,640 - Ry 0,341
  Green chromaticity.......... Gx 0,287 - Gy 0,610
  Blue chromaticity........... Bx 0,146 - By 0,069
  White point (default)....... Wx 0,285 - Wy 0,293
Timing characteristics
  VESA GTF support............ Not supported
  Horizontal scan range....... 31-84kHz
  Vertical scan range......... 57-75Hz
  Video bandwidth............. 180MHz
  Extension blocks............ 1
  Timing recommendation #1.... 1920x1080 at 60Hz
      Modeline................ "1920x1080" 138,500 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync
  Timing recommendation #2.... 1360x768 at 60Hz
      Modeline................ "1360x768" 84,750 1360 1432 1568 1776 768 771 776 798 -hsync +vsync
Standard timings supported
   640 x  480 at  60Hz - IBM VGA
   640 x  480 at  60Hz - VESA
   640 x  480 at  75Hz - VESA
   720 x  400 at  70Hz - IBM VGA
   800 x  600 at  60Hz - VESA
   800 x  600 at  75Hz - VESA
   832 x  624 at  75Hz - Mac II
  1024 x  768 at  60Hz - VESA
  1024 x  768 at  70Hz - VESA
  1024 x  768 at  75Hz - VESA
  1280 x 1024 at  60Hz - VESA
  1360 x  768 at  60Hz - LGE
  1400 x 1050 at  60Hz - VESA
  1600 x 1200 at  60Hz - VESA
  1920 x 1080 at  60Hz - LGE
  1920 x 1080 at  60Hz - VESA
Raw EDID base
  00: 00 FF FF FF FF FF FF 00  1E 6D C2 9C 00 00 00 00
  10: 05 11 01 03 80 46 27 78  EA D9 B0 A3 57 49 9C 25
  20: 11 49 4B A5 6E 00 31 40  45 40 61 40 81 80 90 40
  30: A9 40 D1 C0 01 01 1A 36  80 A0 70 38 1F 40 30 20
  40: 35 00 E8 26 32 00 00 1A  1B 21 50 A0 51 00 1E 30
  50: 48 88 35 00 BC 86 21 00  00 1C 00 00 00 FD 00 39
  60: 4B 1F 54 12 00 0A 20 20  20 20 20 20 00 00 00 FC
  70: 00 34 37 4C 59 39 35 0A  20 20 20 20 20 20 01 D1
Raw EDID extension (reserved)
  00: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
  10: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
  20: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
  30: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
  40: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
  50: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
  60: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
  70: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
Display adapter
  Adapter description......... ATI Radeon Xpress 1200 Series
  Adapter device ID........... 0x79411002
  Display settings............ 1280x768, 32bpp
User/computer information
  Registered user name........ ktd
  Registered organization..... n/a
  Network user name........... ktd
  Network computer name....... HTPC
  Windows version ............ Windows 2000
  Windows build .............. 6.00.6000
  Installation date .......... n/a
#552
Postad 31 May 2007 - 21:28
ktd
  • ktd
  • 1662 inlägg
Märkligt... Om jag kör min HTPC via min Marantz 7001 så går bilden i kraftigt rosa. Samma sak gäller Blu-ray på Ps3 OM jag väljer automatiskt eller Y Pb/Cb Pr/Cr men väljer jag RGB går det bra.
Visst kan stärkaren och Tvn ha nått otalt med varandra MEN det funkade med samma utrustning och kablar med min Sharp LC-46XD1E så för mig är det Tvn som är "knäpp"...
Kan ju inte säga att jag är så där jättenöjd med den so far...
Får tex. till det så bilden fylls ut helt från HTPCn, det gick också att få på Sharpen. Men jag ska greja mer i helgen så får vi se.
Bilden är det dock inget fel på och kör jag flOw på Ps3an så har jag äntligen inget bandningsproblem som Sharparna lider av. ;)
#553
Postad 31 May 2007 - 21:44
niklaskb
  • niklaskb
  • 79 inlägg
Nääe, "Brightness justerar ljusstyrkan på skärmen" taget från manualen och bekräftat av mig.
Vad jag vet är det bara LY serien som har bakgrundsbelysning -> Katalog våren 07
Justering av ljusstyrkan kan ju ske på två sätt. Endera genom att manipulera själva pixlarna eller att manipulera bakgrundsbelysningen.
Om det inte går att justera bakgrundsbelysningen kan man ju inte påverka svärtan över huvud taget.
Till exempel om man sitter i ett helt mörklagt rum så skulle man ju vilja sänka bakgrundsbelysningen och på så sätt få bättre svärta på bekostnad av ljusstyrka.
Jag kan inte se nåt i katalogen om justering av bakgrundsbelysning.
Redigerat av niklaskb, 31 May 2007 - 21:45.
#554
Postad 31 May 2007 - 23:39
Unregistered87a6509e
  • Unregistered87a6509e
  • 116 inlägg
Tack för att du tog dig tid med moninfo! Märkligt, där ser det ju ut som att det bara är 60Hz som funkar i 1920x1080. Kan det vara så att man måste läsa av edid i videoläget (DTV) istället för i PC-läge. Blir det annorlunda då? I manualen står det nämligen att skärmen stödjer 24Hz, 50Hz och 60Hz i just videoläget, men bara 60Hz i PC-läget (båda lägena ska vara via HDMI).
Jag antar att Chuck och Havocsi har haft koll på läget att de verkligen matat med 24p (från PS3 och LG-spelaren), men jag kan inte läsa att någon verkligen har bekräftat det med OK-knappen. Det finns kanske en viss risk att LG-spelaren fungerar på samma sätt som PS3 att den har någon form av autoläge som läser av EDID och skickar (24p eller 60p) beroende av vad den hittar där. Visserligen såg rycken annorlunda ut än om det varit 60p....konstigt det här.
Samsung m86/87 tar ju tex emot 24Hz i 1080P från PC och visar det korrekt utan hack (enligt tråden på avforums), men har just problemet att EDID inte innehåller rätt info så det blir strul med PS3.
#555
Postad 31 May 2007 - 23:50
ktd
  • ktd
  • 1662 inlägg
Ha ha!
Sitter och svär över ATI när dom helt plötsligt slänger upp en ny drivis ikväll, ver 7.5 och då kan jag välja 24 i refresh rate och vips så har jag 1080p 24 när jag trycker OK på fjärren.
Och bild ända ut i kanten är det också! :unsure:
Nu ska jag bara få bukt den rosa bilden när jag kör HDMI genom min Marantz 7001. Men det får bli ett problem för Havocsi imorgon när jag svänger förbi dom på lunchen... ;)
#556
  • 116 inlägg
Jag stötte på ett test på 42LY95 från What Hi-Fi? Sound and Vision när jag läste på avforums.
Här finns det: http://www.avforums....42&d=1180625125
Inte speciellt snällt omdöme. Jag förstår faktiskt inte riktigt hur de har kommit fram till det. Ok jag har inte sett hur SDTV funkar, men i övrigt tyckte jag att 37:an gjorde riktigt bra ifrån sig jämfört med tex Sharp XD1E som stog brevid på hemmabiocenter.
#557
Postad 31 May 2007 - 23:58
  • 116 inlägg
Ha ha!
Och bild ända ut i kanten är det också!  ;)
Trevligt att det funkar bra från dator med ATI grafik också, NVIDIA funkar ju bra enligt urskog.
Märker du skillnad med 24p-material...är det bättre flyt jämfört med om du har 60Hz och 24p-material?
Har du någon aning om vad de menar med PC och DTV mode i manualen?
#558
Postad 01 June 2007 - 00:23
ktd
  • ktd
  • 1662 inlägg
Vet inte om jag har nått 24 material. Köpte en Xbox360 HD-DVD men har inte hunnit koppla in den idag. Ska kolla på det i helgen...
Men på Ps3an ser man stor skillnad. Tyvärr så hackar det lite även i 24 men inte alls så farligt som i 60...
Jag tror att det har med BTB och WTW att göra men är inte 100%. Jag har en liten LG 26" i sovrummet och har för mig att jag läste om det i den.
Dock har jag inte hittat den inställningen på min 47LY95. Ska den finnas?
Men annars står DTV för digital-tv på den här Tvn...
#559
Postad 01 June 2007 - 01:12
  • 116 inlägg
Jag tänkte mer på 24p-material som man kan ladda ner (lagligt alltså) och spela från datorn, med tanke på att du bekräftat 24Hz med ok-knappen när du kopplat in datorn. Alltså om det funkar utan hack då.
När det gällde DTV så tänkte jag inte på digitaltv...tror jag...det är det här från manualen som jag klurar på vad de menar angående upplösningar och timings:
Bifogad fil  manual.jpg   44.8K   118 Antal nerladdningar
Är det någon som har någon förklaring?
Sen till sist det du undrade om BTB och WTW ...det kanske är det du hittar under /picture/advaced/black level. Eller kan det vara justerbar backlight?
#560
Postad 01 June 2007 - 05:18
Mr Zäta
  • Mr Zäta
  • 172 inlägg
Har du provat en sök efter Backlight ??
#561
Postad 01 June 2007 - 06:52
urskog
  • urskog
  • 468 inlägg
Just ja, när jag testade att skicka 1080p24 från HTPCn så körde jag PC-mode på HDMI-in på TVn, får testa det även med DTV o se om det blir någon skillnad men funkade gjorde det iaf trots PC-mode.
Vart kan man få tag på bra lagligt 1080p24 material att testa med och kan lita på är riktigt välencodat så man inte kan skylla ev. problem på encoden i fråga?
#562
Postad 01 June 2007 - 08:50
niklaskb
  • niklaskb
  • 79 inlägg
Nu hittade jag det ;)
Är det alltså "Black level" under advanced-menyn som justerar bakgrundsbelysningen?
Redigerat av niklaskb, 01 June 2007 - 08:53.
#563
Postad 01 June 2007 - 10:03
badass
  • badass
  • 284 inlägg
Är det någon som har en hd box från canal digital ? Hur är bilden från dom vanliga kanalerna alltså inte hd kanalerna. Jag kollade en vanlig dvd film på expert igår(superman returns) och jag var inte så imponerad av bilden men det kanske var för att han visade en blueray film före. Jag kollade inte inställningarna på tv, det var så mycket folk. Dom hade ett bra pris 13995 för LF65
Redigerat av badass, 01 June 2007 - 10:04.
#564
Postad 01 June 2007 - 10:51
Unregisteredb7bdb1f7
  • Unregisteredb7bdb1f7
  • 1428 inlägg
Undrar om Expert här i stan också har för 14k, måste åka och kolla.
Redigerat av Unregisteredb7bdb1f7, 01 June 2007 - 10:51.
#565
Postad 01 June 2007 - 12:16
  • 116 inlägg
Här finns lite olika HD-klipp som man kan testa:
http://www.microsoft...ntshowcase.aspx
http://hdclips.net/index.php
http://www.drfoster....rs_hd-dvd.shtml
http://www.red.com/gallery-video.shtml
ftp://ftp.ldv.e-technik.tu-muenchen.de/dist/test_sequences/
En del av dem behöver man ganska snabb dator för. Men det är bara att prova sig fram. Det mesta är 24 fps, men inte allt.
#566
Postad 01 June 2007 - 12:32
urskog
  • urskog
  • 468 inlägg
Tack o bock!
Ska testa lite under helgen ;)
Datorn borde duga, kör en 4200+ med 2gig minne och den klarar iaf x264 i 1080p.
#567
Postad 01 June 2007 - 16:36
Buer
  • Buer
Är det någon som skulle kunna läsa av vad som står i EDID på TVn? Det skulle vara väldigt schysst.
EDID ger info till tex PS3 och datorer vilka upplösningar och timings som bör skickas till TVn.
Får man se den informationen kan man bättre förstå strulet med hackande 24p och tex PS3.
Man kan använda programmet moninfo som man kan ladda hem här:
http://www.entechtai...il/moninfo.shtm
Se till att datorn är kopplad med DVI eller HDMI bara...
Om inte 24Hz finns med i EDID skulle det förklara en del.
Om 24Hz finns med på 1080p så blir det svårare att förklara hacken via PS3.
Om det nu skulle vara så att det hackar från en HTPC som kringår EDID (via powerstrip eller avancerade inställningar i Nvidias drivrutiner) så är det något allvarligt fel med hur TVn hanterar bildsignalen. Man kan testa med ett program som heter judderttest som finns här:
http://www.avsforum....ad.php?t=318096
24Hz borde väl finnas med i tv'ns EDID, annars skulle ju inte PS3'an skicka ut i 1080/24 (då den ska känna av detta), och då skulle inte tv'n visa att den tar emot i 1080/24. Vilket TV'n enligt inläggen i detta forum gör.
Havoci (ursäkta om jag stavar fel ;) ) har även meddelat att det är inte alls samma slags hack som är vid panoreringar i 60Hz utan på ett annat sätt. (bra mycket mindre märkbara, om jag uppfattat rätt). Och dessa uppstår inte bara från PS3 utan med en av LG's egna HD/Blu-ray spelare (vilken det var kommer jag ej ihåg vid skrivande stund).
Obs, det här grundar sig enbart på inlägg i denna tråd. Hade jag sluppit vänta ytterligare 2v på min LF65'a (om jag inte får bra pris på LY95'an) så hade jag testat du hade fått ett 100% korrekt svar :unsure:.
Så här rapporterar Moninfo min tv...
Monitor
Windows description......... Plug and Play Monitor
Manufacturer description.... 42LF66
Plug and Play ID............ GSM9CC4
EDID data source............ I2C bus (real-time)
Display gamma............... 2.20
Red chromaticity............ Rx 0.640 - Ry 0.341
Green chromaticity.......... Gx 0.287 - Gy 0.610
Blue chromaticity........... Bx 0.146 - By 0.069
White point (default)....... Wx 0.285 - Wy 0.293
Modeline................ "1920x1080" 138.500 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync
Modeline................ "1360x768" 84.750 1360 1432 1568 1776 768 771 776 798 -hsync +vsync
Timing recommendation #3.... 1280x720 at 60Hz
Modeline................ "1280x720" 74.250 1280 1344 1472 1664 720 723 728 748 +hsync +vsync
Timing recommendation #4.... 720x480 at 60Hz
Modeline................ "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Timing recommendation #5.... 1920x1080 at 60Hz
Modeline................ "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Timing recommendation #6.... 1920x540 at 60Hz
Modeline................ "1920x540" 74.250 1920 2008 2052 2200 540 542 547 562 +hsync +vsync
Timing recommendation #7.... 1920x1080 at 30Hz
Modeline................ "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Timing recommendation #8.... 1280x768 at 60Hz
Modeline................ "1280x768" 80.140 1280 1344 1472 1664 768 771 778 798 -hsync -vsync
720 x 480 at 60Hz - LGE
1280 x 720 at 60Hz - LGE
1280 x 768 at 60Hz - LGE
1920 x 540 at 60Hz - LGE
1920 x 1080 at 30Hz - LGE
Raw EDID base
00: 00 FF FF FF FF FF FF 00 1E 6D C4 9C 00 00 00 00
70: 00 34 32 4C 46 36 36 0A 20 20 20 20 20 20 01 E9
Raw EDID extension (CEA-861)
00: 02 03 21 F1 4E 81 02 03 15 12 13 04 14 05 20 21
10: 22 1F 10 23 09 07 07 83 01 00 00 65 03 0C 00 10
20: 00 01 1D 00 80 51 D0 1C 20 40 80 35 00 BC 88 21
30: 00 00 1E 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00 13
40: 8E 21 00 00 18 02 3A 80 18 71 38 2D 40 58 2C 45
50: 00 06 44 21 00 00 1E 01 1D 80 18 71 1C 16 20 58
60: 2C 25 00 C4 8E 21 00 00 9E 4E 1F 00 80 51 00 1E
70: 30 40 80 37 00 BC 88 21 00 00 18 00 00 00 00 1D
EIA/CEA-861 Information
Revision number............. 3
DTV underscan............... Supported
Basic audio................. Supported
YCbCr 4:4:4................. Supported
YCbCr 4:2:2................. Supported
Native formats supported.... 1
DTV formats supported....... 14
CE standard timings supported
640 x 480p at 59.94/60Hz (4:3) - Default (Native)
720 x 480p at 59.94/60Hz (4:3) - EDTV
720 x 480p at 59.94/60Hz (16:9) - EDTV
720 x 576i at 50Hz (4:3) - Doublescan
720 x 576p at 50Hz (16:9) - EDTV
1280 x 720p at 50Hz (16:9) - HDTV
1280 x 720p at 59.94/60Hz (16:9) - HDTV
1920 x 1080i at 50Hz (16:9) - HDTV
1920 x 1080i at 59.94/60Hz (16:9) - HDTV
1920 x 1080p at 23.97/24Hz (16:9) - HDTV
1920 x 1080p at 25Hz (16:9) - HDTV
1920 x 1080p at 28.97/30Hz (16:9) - HDTV
1920 x 1080p at 50Hz (16:9) - HDTV
1920 x 1080p at 59.94/60Hz (16:9) - HDTV
Display adapter
Adapter description......... NVIDIA GeForce 6800 Series GPU
Adapter device ID........... 0x00F910DE
Display settings............ 1920x1080, 32bpp
#568
Postad 02 June 2007 - 01:39
  • 116 inlägg
Det var något i den stilen jag förväntat mig med LY95. Det kanske beror på det här med PC- eller DTV-mode (var väljer man det förresten?). Nåja, 1080p i 24,25,30,50 och 60Hz iaf. Dock står det 1920 x 1080p at 28.97/30Hz (16:9) - HDTV ...vilket förvånar mig. Det borde vara 29.97Hz, undrar vad som händer när tvn påstår att den ska ta emot 28.97Hz när den ska visa NTSC-video. Undrar om de har programerat in fel värde i EDID.
Hur som helst, det här EDID-spåret verkar vara en återvändsgränd. Några från Finland har rapporterat på avforums (inlägg #77 i den här tråden: http://www.avforums....&highlight=ly95 ) att det är samma problem med hack i 1920x1080@24hz från HTPC som det varit från PS3 och LG-spelaren. Det gäller både LF och LY.
#569
Postad 02 June 2007 - 09:12
badass
  • badass
  • 284 inlägg
Ingen som har en LF65 och och canal digitals hd box? Hur tycker ni bilden blir på en vanlig dvd?
#570
Postad 02 June 2007 - 13:11
Zerox_no1
  • Zerox_no1
  • 3103 inlägg
Kass bild med dvd får man vänja sig vid. Finns en tråd på AVS där de jämför dvd uppskalad till 1080 med HD DVD samt Blu-ray.
http://www.avsforum....02&page=1&pp=30
#571
Postad 04 June 2007 - 08:25
bjorkmarcus
  • bjorkmarcus
  • 19 inlägg
Kom att tänka på en grej igår. När man är i läget för att välja källa (LY95), blir bakgrunden riktigt svart, samtidigt som TVn visar menyn för källa. Borde inte detta innebära att TVn är kapabel att visa bättre svärta, eller kan den ha sänkt bakgrundsbelysningen till en nivå som inte skulle fungera för vanligt tittande i detta skede?
Jag har aldrig matat TVn med digital signal, och jag vet att svärtamenyn blir tillgänglig först när man gör det. Jag vet däremot inte hur mycket man kan påverka genom att ändra där.
Jag är bara nyfiken på om svärtan kan bli bättre än den är nu.
/M
#572
Postad 04 June 2007 - 09:28
Unregistered948c54a3
  • Unregistered948c54a3
  • 334 inlägg
Angående de finska forumen så har han som skrev inlägget som länkas till ovan skrivit ett nytt inlägg (Inlägg 85):
Citerat från avforums:
Ok, one LF series user at our finnish forums have confirmed that 1920x1080 @ 24hz works great on pc.
He tried the same sample clip that I previously linked here.
No judder!
It seems that the problem is with the LY series, or the LY series users source, which was also pc, not sure what player software he used.
But looking better now!"
Har tidigare bara läst om folk som testat detta på LY serien, om jag inte missar något. Hade varit intressant om någon med LF kunde verifiera detta. !!
#573
Postad 04 June 2007 - 10:41
Unregistereda7124cf7
  • Unregistereda7124cf7
  • 570 inlägg
Jag har LF å hoppas få tillbaks min PS3a från service i veckan, så man kan testa vad tvn går för
#574
Postad 05 June 2007 - 07:14
niklaskb
  • niklaskb
  • 79 inlägg
Är det nån som kan säga nåt om svärtan på LF eller LY-serien?
#575
Postad 05 June 2007 - 09:50
Unregistered8d64e932
  • Unregistered8d64e932
Får min 42lf66 idag (2007-06-05)....
Är på jobbet för tillfället, så vill bara härifrån, och sen dra och hämta den.
Jag kommer slänga upp en hel del bilder på tv:n, eftersom jag vet att det är en del som efterfrågat det. Blir väl idag eller imorron bilderna kommer upp i så fall.
// Engan
#576
Postad 05 June 2007 - 10:07
Hence Esko
  • Hence Esko
  • 128 inlägg
// Engan
Låter mycket trevligt Engan! Ska bli intressant och se hur "högtalargallret" ser ut!
Den långa väntan fortsätter för min del :)
#577
Postad 05 June 2007 - 10:20
BastaKox
  • BastaKox
Tjena!
Funderar starkt på en 42LF65/66 alternativt en 42LY95. Hur stor är skillnaden mellan dessa? Enligt spec ska det skilja i komponenter men hur stor skillnad gör det bildmässigt. Hur är svärtan på LF kontra LY?
Alternativ till dessa är väl Samsungs 40M86. Hur står sig LG gentemot Samsungen?
Tacksam för svar!
/BastaKox
#578
Postad 05 June 2007 - 11:43
urskog
  • urskog
  • 468 inlägg
Har inte gjort någon sida-vid-sida jämförelse med andra apparater men jag tycker att svärtan på LY är mkt bra iaf, absolut inget jag stör mig på att saker känns för grå.
#579
Postad 05 June 2007 - 13:08
Unregistered1226
  • Unregistered1226
Tjena!
Tacksam för svar!
/BastaKox
Fick min 42 LF 66 för ett par dagar sedan med inbyggd CA-modul boxer. Fungerar klockrent, likaså är bilden kanonbra för 16000 kr. Jämförde med Sonys W 2000 och märkte ingen större skillnad, i alla fall inte som motiverar 4000 kr mer. När det gäller vanlig TV så bör du dock se till att du har en bra mottagning Jag har på alla muxarna 85 % i styrka och 100% i kvalitét.
#580
Postad 06 June 2007 - 16:53
Har slängt upp lite bilder å 42lf66 nu. Om det är något speciellt ni vill ha bild på vad gällande tvn, skicka bara ett pm.
// Engan
#581
Postad 06 June 2007 - 23:55
Zerox_no1
  • Zerox_no1
  • 3103 inlägg
Hur långt ifrån sitter du?
#582
Postad 07 June 2007 - 14:22
evil_nike
  • evil_nike
  • 702 inlägg
Detta är jag oxå väldigt intresserad att veta. Det står mellan samsungen och lg:n just nu. Är det någon som har jämfört dessa? Samsungen verkar dock ha problem med pixelmappning.
/Niklas
#583
Postad 07 June 2007 - 14:47
urskog
  • urskog
  • 468 inlägg
Kunde inte Samsungen funka som extra spegel i hemmet oxå?
Det kan ju ses antingen positivt eller negativt :)
#584
Postad 07 June 2007 - 19:14
Hence Esko
  • Hence Esko
  • 128 inlägg
/Niklas
Jag var inne på Hifi-klubben här i Sundsvall och provade koppla in datorn i en Samsung M86a och det funkade klockrent! Ställde in 1366x720 på en gång. Detta via VGA-kabel och en Nvidia 7600 Go kort.
Däremot när jag slog på Tiberium Wars så ville den inte köra i högre än 1024xnånting, det spelet kör jag på 1680*1050 på vanliga skärmen så är inte spelet som sätter gränsen!
Vet inte vad det kan bero på...
Sharpen dom hade inne för 12000 klarade inte att pixelmappa alls.
Hoppas det hjälpt dig i ditt val!
#585
Postad 07 June 2007 - 20:11
badass
  • badass
  • 284 inlägg
Nu har jag äntligen köpt en tv. Det blev en LG 42LF65. Vet inte om det är jag som är gladast eller frugan för nu slipper hon höra mitt tjat om alla tv apparater som jag har velat mellan. Har inte packat upp den ännu men ska göra det ....NU.
#586
Postad 07 June 2007 - 20:16
Unregistered7c808eec
  • Unregistered7c808eec
  • 3866 inlägg
Är det nån som är ägare till en LY95 och har hunnit kolla på den ordentligt? Vad tycks om bilden, de omtalade hacken, funktionerna i största allmänhet? Att SD-TV ser muggigt ut har jag insett men nån sa att även vanlig DVD ser ut som skräp, kanske då främst på en riktigt stor skärm (47" eller 52") men håller ni med om det? Vad är ni riktigt nöjda respektive missnöjda med med er LY? Mycket tacksam för info! :)
#587
Postad 07 June 2007 - 21:18
Hast
  • Hast
  • 69 inlägg
Jag kollade på Samsungen inne på HiFi-klubben och den funkar fint som spegel iaf. Då jag ser matt skärm som en fördel med LCD (jmfr plasma och CRT) så blev den tyvärr helt ointressant efter det.
För min del ska TVn användas som TV (dvs i ljust rum), jag har redan en projektor jag kan slå på ifall jag mörklägger.
#588
Postad 08 June 2007 - 06:54
evil_nike
  • evil_nike
  • 702 inlägg
Ja ok men jag var mer intresserad av om den klarar av det lika bra i 1920x1080.
/Niklas
#589
Postad 08 June 2007 - 07:08
BulanS
  • BulanS
  • 227 inlägg
Ja ok men jag var mer intresserad av om den(Samsung M86a
) klarar av det lika bra i 1920x1080.
/Niklas
Den klarar pixelmappat, dock så skymmer listen som sitter på skärmen några pixlar i överkant.
Och ang "spegel"-effekten, så tror jag det är mindre/lika som en vanlig CRT (tjock-tv).
Men ta den diskussionen i tråden för samsung istället kanske.. :)
https://www.minhembi...view=getnewpost
#590
Postad 08 June 2007 - 08:26
evil_nike
  • evil_nike
  • 702 inlägg
Ok tack så mycket för infon.
Jag tror banne mig att jag klipper en lg endå. Den verkar göra sitt jobb.
Vad säger ni som har lg:n? För och nackdelar så här långt. Den här tråden är så inaktiv, kanske är det ett täcken på att det inte är några problem med lg-apparaterna...
/Niklas
#591
Postad 08 June 2007 - 08:41
  • 3866 inlägg
quote]
/Niklas
[/quote]
Instämmer med föregående talare! Vid det här laget måste det ju hänga några LY-skärmar ute i stugorna? Är ruggigt sugen på en sådan men undrar vad ni som har använt den tycker om den. Är ni besvikna eller imponerade, vad är svagheterna, hur går det med 1080p/24Hz, hur är det med ryckigheten etc. Snälla, dela med er!
#592
Postad 08 June 2007 - 08:48
ktd
  • ktd
  • 1662 inlägg
47LY95 och 1080p24 funkar bra men som sagts tidigare i tråden så finns det ryck.
Och som sagts tidigare så är det upp till var och en att avgöra om man stör sig på det eller inte...
#593
Postad 08 June 2007 - 12:19
Darwen
  • Darwen
Tänkte dra ut i helgen och titta lite på LY95 modellerna, någon som vet butiker centralt eller i närförort i Stockholm som har 42" eller 47" varianterna för beskådning?
Redigerat av Darwen, 08 June 2007 - 12:20.
#594
Postad 08 June 2007 - 12:22
Chuck
  • Chuck
  • 2498 inlägg
Yes, HBC på Lidingö har 47" vad jag vet.
/Chuck
#595
Postad 08 June 2007 - 12:26
ktd
  • ktd
  • 1662 inlägg
Jag tror inte HBC har nån längre. Jag köpte deras demo ex. och dom väntade ny leverans i juli.
Men ring och kolla...
#596
Postad 08 June 2007 - 17:59
Hybe
  • Hybe
  • 1429 inlägg
/Niklas
Samsungen klarar inte pixelmappat via HDMI.
testa www.pixelmappat.nu , å se.
Om man jämför med VGA ser man också att VGA är skarpare.
#597
Postad 08 June 2007 - 19:34
badass
  • badass
  • 284 inlägg
Finns det något sätt att se i tv menyn vilken upplösning man kör på? Jag har en LG 42LF65
#598
Postad 08 June 2007 - 20:25
didrik
  • didrik
  • 1740 inlägg
/Niklas
Inte för att vara den som är den och fortsätta på off topic, men m8:an kan visst pixelmappa över hdmi. jag har testat själv....
#599
Postad 08 June 2007 - 20:59
bjorkmarcus
  • bjorkmarcus
  • 19 inlägg
[quote name='Sir Duke' date='Jun 8 2007, 09:41 ']
quote]
/Niklas
[/quote]
[/quote]
Först minussidan:
* Hacken folk verkar prata om finns där och är inte så små att jag behöver leta efter dom. Det stör mig lite att dom är där. Det stör ännu mer att TVn inte verkar kunna visa upp korrekt flyt på 1080/24, som var en av anledningarna till att jag köpte den. Jag har tänkt köpa en ps3 framöver och den kombon verkar ju inte vara lika ultimat längre. På HD-material märks det inte alls lika mycket dock. Jag har testat wmv-filer i 720/1080p.
* Svärtan är helt ok även jag skulle vilja kunna få ner den lite till. Borde gått att justera även utan digital signal in. Hur blir det med svärta på "Låg" ni som provat?
* TVn blir vädigt varm och värmer upp hela rummet. Inte så skönt i sommarvärmen. Bagatell iofs.
* Jag har haft clouding i alla hörn utom övre högra hörnet. Jag tror det har försvunnit nu, eller i alla fall blivit mycket mindre.
* Jag har 1 död pixel. Den sitter längst upp och inget jag hetsade upp mig för ens första gången jag såg den. Den syns inte alls.
Och the goodies:
* Förutom hack, så är det riktigt fin bild. Skarpt, fina naturliga färger (pionrött kan sticka iväg lite) och inte mycket brus tycker jag.
* HD-material blir helt grymt. Har kört brända .wmv-filer på dual layer DVD genom xbox 360.
* Den är riktigt snygg. Får ta och fota den lite snart och lägga upp bilder här.
* Ljudet är helt ok. Inget tryck direkt, men det låter bra.
* Tittade på "Over the hedge" på dvd och det var klart snyggt.
* Att titta på foton via 360n är fantastiskt. Grymt bra.
* Jag blir mer och mer nöjd med den.
Kollade på några Full HD Sony LCD idag och dom hade inte en chans mot denna vid ett snabbt ögonkasst. Allt jag kom på att titta efter var sämre. Jag såg även nya Samsungen men det var för ljust i rummet för att gå att avgöra bildkvalitén på den.
Ingen komplett recension precis, men ändå :-)
#600
Postad 09 June 2007 - 10:53
evil_nike
  • evil_nike
  • 702 inlägg
Först minussidan:
Och the goodies:
Tack för den informationen. Mycket uppskattat. När man är så velig som jag har varit inför det här tv-köpet är all information välkommen.
Kan inte fatta att det ska va så himla svårt. Jag vet att jag kommer bli nöjd med vad jag än köper. Sitter och glor på en 28" Limited Label as we speak...
/Niklas
  • Triggerkabel
    2026-11-11 09:11:34
  • Denon DRS-810
    2026-11-10 15:11:51
  • Olika apparater
    2026-11-10 14:43:41
  • Music Filelity M6x 250.4/2
    2026-11-10 14:25:11
    2026-11-10 10:46:59
