Blu-ray Filmer
9284 svar till detta ämne
#8901
Postad 05 February 2013 - 12:36
Unregistered1aa3c9f9
  • Unregistered1aa3c9f9
  • 796 inlägg
De stirrar sig blinda på IMAX-scenerna. 35mm-delarna är mediokra.
Recensenten tycks inte anse det. I följande passage går han in på den saken ganska ordntligt:
"So how does the resolution of the 2.4:1 content compare to the 1.78:1 picture quality? Believe it or not, the detail remains nearly consistent in both aspect ratios--there's just more presence in the scenes shot using the IMAX cameras. Non-IMAX sequences give up surprisingly little in definition. Perhaps the most extraordinary scene to view the differences is when Batman raids the high rise building in Hong Kong to extract Lau (Chin Han). In the full IMAX resolution, with much of the screen enveloped in deep black, Batman is shown perched above the city. He then descends through the air, breaking through the window nearby the desk where Lau is working and quickly dispatches Lau's body guards. Finally, as he holds Lau near the broken windows, both men are whisked out of the building by a floating device and a passing aircraft. The complicated, busy action coupled with poor lighting would be problematic if not for the detail delivered both by the 1.78:1 and 2.4:1 shots that make up the scene. While the IMAX picture is preferable because of a greater sense of depth and resolution, the 2.4:1 content shares its small, gentle grain and otherwise clean, highly detailed presentation. Some element of the grain has a digital sheen to it, but I cannot justify deducting a point or half-point for that. "
#8902
Postad 06 February 2013 - 09:57
Drem
  • Drem
  • 1651 inlägg
Försöker hitta "Så som i himmelen" på bluray. Hittar endast en tysk utgåva. Är det den enda som finns på denna filmen? Någon som vet om den går att köpa i Sverige, eller någon annan stans ifrån billigt?
#8903
Postad 06 February 2013 - 10:49
  • 796 inlägg
Filmen kom ju tyvärr före blu-ray-eran, så jag skulle inte tro att den finns. Det ser extremt dåligt ut på remastringsfronten i Sverige. Redan under DVD-eran dröjde det alldeles för länge innan svenska klassiker började ges ut i nyutgåvor, och mycket har inte ens kommit i det formatet ännu. Eventuellt är marknaden för liten för att motivera kostnaden...
#8904
Postad 06 February 2013 - 12:08
The Hobbit på blu-ray den 19 mars. Nice med DTS-HD MA 7.1 :)
http://bluray.highde...it_journey.html
#8905
Postad 06 February 2013 - 12:24
Då ska han ignoreras. 35mm-scenerna saknar både detaljer och har en jäkla massa EE.
Redigerat av Tomanista, 06 February 2013 - 12:25.
#8906
Postad 06 February 2013 - 13:13
  • 796 inlägg
Du får gärna igonera vad han säger, men han har uppenbarligen inte stirrat sig blind på någonting, kanske retar han sig bara inte lika mycket på vissa saker som du gör. Jämför gärna med följande recension, som också är starkt positiv utan att vara reservationslös:
http://bluray.highde...darkknight.html
Det verkar råda en ganska stor konsensus om att den nuvarande blu-ray-utgåvan av TDK är minst sagt mycket bra, även om den har brister. Men jag har svårt att se att dessa brister skulle motivera en remastring. Inte än på ett tag i alla fall.
#8907
Postad 06 February 2013 - 14:47
thomas79
  • thomas79
  • 1423 inlägg
Det spelar ingen roll vad rescensenter sade om TDK för 5 år sedan. Den är otroligt mycket sämre än TDKR. På alla plan. Jag är övertygad om att det finns massor att hämta på en nymastring.
#8908
Postad 10 February 2013 - 23:55
http://www.avsforum....-comparison-pix
#8909
Postad 17 February 2013 - 21:16
Någon annan som fått att exemplar av Looper (Noble) med rosa streck längs vänstra kortsidan av bilden? Gäller under hela filmen...
#8910
Postad 19 February 2013 - 14:32
Unregistered242b20f0
  • Unregistered242b20f0
  • 686 inlägg
Nejdå..inte jag!
#8911
Postad 20 February 2013 - 17:10
Schindler`s List synad av Highdefdigest :) http://bluray.highde...ndlerslist.html
#8912
Postad 20 February 2013 - 17:47
  • 796 inlägg
Låter strålande! Och nu finns väl slutligen alla de stora Spielberg-klassikerna på blu-ray? Nu vill jag bara att James Cameron ska få tummen ur och ta tag i The Abyss också så är jag nöjd. :)
#8913
Postad 20 February 2013 - 17:52
Ja, The Abyss är högt upp på min lista också. Bara att hoppas på det bästa.
#8914
Postad 22 February 2013 - 23:56
Apo
  • Apo
  • 72 inlägg
Jag har samma problem med mitt exemplar. Jag har även ett litet neongrönt streck högst upp i högra hörnet i prometheus under scenen där skeppet landar på planeten. Minns inte vilket chapter det var men syns direkt när man hoppar fram till landningen. Någon annan som märkt detta?
#8915
Postad 28 February 2013 - 16:13
Noah06
  • Noah06
  • 1592 inlägg
Mad Max: Complete Trilogy släpps i usa i juni.
http://www.amazon.co...tag=hidefnin-20
Postad 28 February 2013 - 16:14
wesslan
  • wesslan
  • 1438 inlägg
Får se om jag kan hålla mig tills nya biofilmen har gått för då kommer garanterat en ny box. Vill inte hamna mitt i som med alla Die Hard boxar.
#8917
Postad 01 March 2013 - 08:35
Unregistered4e1812ee
  • Unregistered4e1812ee
  • 889 inlägg
Det var som ***, en ny MadMax film! Verkar vara första utan Mel i huvudrollen. 2014 först dock :huh:
Apropå äldre filmer, någon som känner till om "The Fabulos Baker Boys" finns utgiven på blu-ray?
#8918
Postad 05 March 2013 - 12:00
Hade också ett rosa streck till vänster som kom och gick, gick ju att se filmen dock ;) Nu ska den dock returneras och bytas mot nån annan ny film :)
Redigerat av henke007, 05 March 2013 - 12:01.
#8919
Postad 07 March 2013 - 22:40
Unregistered577c6879
  • Unregistered577c6879
  • 2986 inlägg
Kandidat till årets BD-släpp är helt klart Life of Pi, eller som det fult står på mitt fodral "The next Avatar" :rolleyes:
#8920
Postad 09 March 2013 - 10:37
(SiC)
  • (SiC)
  • 1025 inlägg
Varför finns inte Moonrise Kingdom på BD (sv text)? :(
#8921
Postad 09 March 2013 - 11:38
http://www.blu-ray.c...-Blu-ray/56520/
Finland har med svensk text (cdon.fi) men vet inte om de skickar till Sverige
#8922
Postad 09 March 2013 - 11:44
Dr. Zaius
  • Dr. Zaius
  • 3607 inlägg
Edit: Releas framflyttad till 12 Mars.
http://www.amazon.co..._rhf_ee_p_img_1
http://www.highdefdi..._Blu-ray_/10480
Bävern har recenserat Zulu Dawn. Verkar inte helt problemfri men kommer nog skaffa den ändå.
http://www.dvdbeaver...awn_blu-ray.htm
#8923
Postad 15 March 2013 - 02:14
Unregisteredbf63d3ba
  • Unregisteredbf63d3ba
  • 361 inlägg
Varför finns inte Oliver Stones JFK på blu-ray?
Världens bästa konspirationsfilm.
#8924
Postad 15 March 2013 - 07:34
downtown
  • downtown
  • 36 inlägg
Det gör den visst: http://www.amazon.co...-3&keywords=jfk
#8925
Postad 15 March 2013 - 11:59
Mrhoyt
  • Mrhoyt
  • 841 inlägg
Och den är Regionsfri om nu den frågan skulle komma.
Redigerat av Mrhoyt, 15 March 2013 - 11:59.
#8926
Postad 15 March 2013 - 13:32
  • 361 inlägg
Utan svensk text. Det är dåligt att inte en svensk version finns.
#8927
Postad 15 March 2013 - 15:49
Mrhoyt
  • Mrhoyt
  • 841 inlägg
Den är ENDAST utgiven i Nordamerika, så det är inte bara svensk version som saknas...
#8928
Postad 17 April 2013 - 22:24
Django Unchained synad av Highdefdigest, givet köp!
http://bluray.highde..._unchained.html
#8929
Postad 02 May 2013 - 10:23
DNR och 8 GB till xtras i SD på samma skiva för Great Escape, tråkigt..Hur fan kan man släppa sån smörja som om det vore 2007..
http://www.blu-ray.c...y/47102/#Review
#8930
Postad 02 May 2013 - 17:23
Avicii
  • Avicii
  • 1168 inlägg
Länken leder till US utgåvan.
Är det samma transfer på den engelska Steelbook-utgåvan?
Ser att det är många som postat inlägg på Blu-ray.com om att de har avbokat.
#8931
Postad 02 May 2013 - 17:44
bahama
  • bahama
  • 977 inlägg
Vet någon om det är någon skillnad alls på Life of Pi utgåvorna från Uk US och Sverige?
Letat men kan inte hitta någon skillnad. Kan dock inte hitta någon resention på svenska utgåvan som tittar på utgåvan.
HiFi klubben säljer svenska 3d utgåvan för 199kr inkl. frakt. I sin Kundklubb.
#8932
Postad 02 May 2013 - 18:04
wesslan
  • wesslan
  • 1438 inlägg
Också nyfiken på detta då svenska utgåvor ofta får nedgraderat ljud till 16-bit och ibland lägre bitrate på bilden men såg nu att vår version är ovanligt strippad med endast ett extra lossy svenskt ljudspår och svenska/engelska textningar. Verkar vara en vettig utgåva från Fox, hoppas recension snart eller ännu bättre, BDinfo information.
Svider att se svenskt titelnamn och alla jäkla recensioner på baksidan. Att det ska vara så svårt att hålla det clean.
Redigerat av wesslan, 02 May 2013 - 18:05.
#8933
Postad 15 May 2013 - 09:08
Varning för svenska boxen med Ett päron till farsa filmerna där endast 3 filmer ingår :lol: :ph34r:
http://cdon.se/film/...ordic)-22791769
Har bokat denna B) Sv text vet jag ej.
http://www.amazon.co...=A3P5ROKL5A1OLE
#8934
Postad 12 June 2013 - 16:07
Dr. Zaius
  • Dr. Zaius
  • 3607 inlägg
Fredagen den 13:e September släpps Friday the 13th: The Complete Collection på Blu-ray
Warner Bros. Home Entertainment has officially announced the Blu-ray release of Friday the 13th: The Complete Collection, which features all twelve franchise films in collectible tin packaging, more than eleven hours of bonus content, a 40-page book with behind-the-scenes photos, a Camp Crystal Lake counselor patch and more. With seven of the films making their Blu-ray debuts, the 10-disc collection arrives on Friday, September 13th.
This intense slasher series is one of the longest-running and most successful horror franchises in film history, surpassing the domestic theatrical box-office grosses of such legendary series as A Nightmare on Elm Street, Halloween and The Texas Chainsaw Massacre. The film that turned psycho killer Jason Voorhees and his infamous hockey mask into a pop culture icon has also bested the horror competition as the #1 home entertainment seller.
Friday the 13th focuses primarily on the character of Jason Voorhees, who drowned as a young child at Camp Crystal Lake due to the inattentiveness of camp counselors. Many years later, the camp becomes the scene of a number of murders – all of which are either committed or motivated by the avenging Jason, who forever lurks at Crystal Lake with his finely-honed machete. The box set has been assembled as a result of the strategic distribution alliance between Paramount and Warner announced last fall, granting Warner exclusive video distribution rights to over 600 Paramount titles.
The 10-disc collection includes twelve films spread across nine Blu-ray discs, as well as a "Killer Extras" Bonus DVD full of additional special features on the making of the famous franchise. The set will be presented in a collectible tin case with 11 hours of previously released special features and a 40-page soft cover book. The book is excerpted from "Crystal Lake Memories: The Complete History of Friday the 13th," a fan-favorite volume that's viewed as the ultimate memoir of the series, and highlights some of its 200 interviews, 600 photos, storyboards and concept art. Also included is a brand new, official Camp Crystal Lake embroidered counselor patch.
Finally, Friday the 13th: The Complete Collection includes digital versions of all twelve films with UltraViolet, allowing viewers to download and instantly stream the films to a wide range of devices from computers and compatible tablets to smartphones, game consoles, Internet-connected TVs and Blu-ray players.
While complete tech specs and extras have yet to be detailed, the 10-disc set breaks down as follows:
Disc 1: Friday the 13th
Disc 2: Friday the 13th Part 2
Disc 3: Friday the 13th Part 3 in 3D
Disc 4: Friday the 13th: The Final Chapter *
Disc 5: Friday the 13th Part V: A New Beginning * / Friday the 13th Part VI: Jason Lives *
Disc 6: Friday the 13th Part VII: The New Blood * / Friday the 13th Part VIII: Jason Takes Manhattan *
Disc 7: Jason Goes to Hell: The Final Friday * / Jason X *
Disc 8: Freddy vs. Jason
Disc 9: Friday the 13th (2009, Theatrical Version and "Killer Cut" Extended Version)
Disc 10: Killer Bonus DVD Disc
* Available for the first time on Blu-ray
http://www.blu-ray.com/news/?id=11398
Redigerat av Dr. Zaius, 12 June 2013 - 16:11.
#8935
Postad 13 June 2013 - 19:52
Dr. Zaius
  • Dr. Zaius
  • 3607 inlägg
Mycket trevlig nyhet. Franska Warner planerar att släppa The Fearless Vampire Killers (1967) någon gång under året.
http://www.blu-ray.com/news/?id=10397
Släpps 4 September enligt Franska Amazon.
http://www.amazon.fr...n/dp/B00BSVSSPO
Redigerat av Dr. Zaius, 13 June 2013 - 19:55.
#8936
Postad 13 June 2013 - 20:10
http://cdon.se/film/...ray%29-12217539
179 spänn för extended på CDON.
Ha ha..vilken underbar Avatar-bild! Är det möjligen du på bilden?
#8937
Postad 20 July 2013 - 07:44
thomas79
  • thomas79
  • 1423 inlägg
The right stuff kommer till blu-ray!
http://www.blu-ray.com/news/?id=11679
#8938
Postad 25 July 2013 - 21:04
sajbot
  • sajbot
  • 298 inlägg
Slapshot (1977) kommer 15:e Oktober :D
http://www.blu-ray.com/news/?id=11748
Bonusmaterial:
  • Feature Commentary with the Hanson Brothers
  • The Hanson Brothers' Classic Scenes
  • Puck Talk with the Hansons
  • Theatrical Trailer
#8939
Postad 29 July 2013 - 21:08
Anchor Bay släpper Halloween 35th Anniversary Edition den 24 sep
http://www.highdefdi...Detailed_/12207
#8940
Postad 30 July 2013 - 00:11
wesslan
  • wesslan
  • 1438 inlägg
Ännu en skiva, man blir lite less. Får hoppas de skippar hela divimax grejen de hade tidigare och satsar på hur den "ska" se ut och inte färgkorrigerar den åt fanderns. Känns som Anchor mjölkar Halloween rätt friskt.
#8941
Postad 30 July 2013 - 00:33
Dr. Zaius
  • Dr. Zaius
  • 3607 inlägg
Vad är det för fel på den äldre Ancor bay utgåvan egentligen, har aldrig förstått det riktigt? Tycker den känns rätt stabil även om jag inte emot om det släpps en utgåva som mycket bättre.
#8942
Postad 30 July 2013 - 01:40
Det är ju absolut inget fel på den tidigare utgåvan så det handlar nog mest om att mjölka Halloween fansen. Såg att nya kommer få Dolby TrueHD 7.1 vilket iofs är ganska häftigt (om man nu kan utnyttja alla kanalerna dvs.)
#8943
Postad 30 July 2013 - 02:53
  • 10392 inlägg
Äh, recievern kan lika gärna göra om till 7.1 som att det är lagt på skivan. Brukar inte märkas skillnad.
#8944
Postad 30 July 2013 - 14:10
Speciellt när källmaterialet är Mono...
#8945
Postad 08 August 2013 - 16:46
  • 361 inlägg
JFK verkar släppas senare i år. Äntligen!
http://cdon.se/film/...u-ray)-24693750
#8946
Postad 16 August 2013 - 08:04
  • 3166 inlägg
Är det nån som vet varför en del filmer på BD som kommer till europa inte finns med svensk text och säljs i sverige?
Discshop brukar ju importera men varför läggs inte textning på samtliga europeiska språk på skivorna och sen får vardera land bekosta ett eget omslag om dom vill, vart är flaskhalsen?
#8947
Postad 16 August 2013 - 11:15
sajbot
  • sajbot
  • 298 inlägg
Rättigheter och licenser som styr, vilket kostar pengar, men import innebär ju bara att t.ex discshop köper in filmen från utlandet och skickar till dig (snordyrt). Tidigare utgåvor av filmer från Warner Bros. hade nästan alla språk, men sen blev det en förändring. Jag skulle tro att de drog ner på kostnaderna, fast det är bara en spekulation från min sida.
#8948
Postad 16 August 2013 - 11:32
Zerox_no1
  • Zerox_no1
  • 3103 inlägg
Friday the 13th: The Complete Collection ser intressant ut men väntar nog på recensioner så man inte får några tråkiga överraskningar.
#8949
Postad 16 August 2013 - 12:22
  • 3166 inlägg
Vet att DS är dyra, ville bara poängtera att det säljs BD i sverige utan text.
Men ibland kommer det filmer med svensk text som tex amerikanska utgåvan av Conan Barbaren, Varulv i london etc och då finns det separata svenska utgåvor som inte är samma utgåva.
#8950
Postad 16 August 2013 - 16:08
  • 2899 inlägg
+1
