Ser lite olika saker.
Först:
"2007-11-25 23:08:37.296875 [Info.][6]: DVBGraph:TuneChannel done signal strength:0 signal quality:0 locked:True"
Sen:
"2007-11-25 23:08:38.031250 [Info.][6]: DVBGraph:Send PMT#1 version:1 signal strength:98 signal quality:98 locked:True cam:Viaccess"
Vet inte om det betyder något.
Men framförallt så sprutar ju följande fel i loggen:
Kod
2007-11-25 23:08:50.468750 [Info.][13]: Planescene(768,576,768,576,122986336,False,8):Unhandled exception in Fel i tillämpningsprogrammet. Microsoft.DirectX.Direct3D vid Microsoft.DirectX.Direct3D.Device.PresentInternal(tagRECT* sourceRectangle, tagRECT* destRectangle, IntPtr overrideWindow)
vid Microsoft.DirectX.Direct3D.Device.PresentInternal(tagRECT* sourceRectangle, tagRECT* destRectangle, Control overrideWindow)
vid Microsoft.DirectX.Direct3D.Device.Present()
vid MediaPortal.Player.PlaneScene.InternalPresentSurface(Int32 width, Int32 height, Int32 arWidth, Int32 arHeight, Boolean InRepaint)
2007-11-25 23:08:50.500000 [Info.][13]: Planescene(768,576,768,576,122986336,False,8):Unhandled exception in Fel i tillämpningsprogrammet. Microsoft.DirectX.Direct3D vid Microsoft.DirectX.Direct3D.Device.PresentInternal(tagRECT* sourceRectangle, tagRECT* destRectangle, IntPtr overrideWindow)
2007-11-25 23:08:50.546875 [Info.][13]: Planescene(768,576,768,576,122986336,False,8):Unhandled exception in Fel i tillämpningsprogrammet. Microsoft.DirectX.Direct3D vid Microsoft.DirectX.Direct3D.Device.PresentInternal(tagRECT* sourceRectangle, tagRECT* destRectangle, IntPtr overrideWindow)
2007-11-25 23:08:50.578125 [Info.][13]: Planescene(768,576,768,576,122986336,False,8):Unhandled exception in Fel i tillämpningsprogrammet. Microsoft.DirectX.Direct3D vid Microsoft.DirectX.Direct3D.Device.PresentInternal(tagRECT* sourceRectangle, tagRECT* destRectangle, IntPtr overrideWindow)
2007-11-25 23:08:50.625000 [Info.][13]: Planescene(768,576,768,576,122986336,False,8):Unhandled exception in Fel i tillämpningsprogrammet. Microsoft.DirectX.Direct3D vid Microsoft.DirectX.Direct3D.Device.PresentInternal(tagRECT* sourceRectangle, tagRECT* destRectangle, IntPtr overrideWindow)
2007-11-25 23:08:50.656250 [Info.][13]: Planescene(768,576,768,576,122986336,False,8):Unhandled exception in Fel i tillämpningsprogrammet. Microsoft.DirectX.Direct3D vid Microsoft.DirectX.Direct3D.Device.PresentInternal(tagRECT* sourceRectangle, tagRECT* destRectangle, IntPtr overrideWindow)
2007-11-25 23:08:50.703125 [Info.][13]: Planescene(768,576,768,576,122986336,False,8):Unhandled exception in Fel i tillämpningsprogrammet. Microsoft.DirectX.Direct3D vid Microsoft.DirectX.Direct3D.Device.PresentInternal(tagRECT* sourceRectangle, tagRECT* destRectangle, IntPtr overrideWindow)
Jag skulle:
1) Kolla att du har alla förkrav installerade(Rätt versioner av .NET, DirectX 9 etc)
2) Om detta inte löser problemet lägga upp en buggrapport i MP forumet
