Postad 11 February 2012 - 16:58
Då räkna du fel, us-pris * minst 10 brukar vara en bra hint om sverige-riktpris.Jag menade 65".
Fick det till cirka 28 000:-.
Redigerat av pacman, 11 February 2012 - 17:00.
Postad 12 February 2012 - 09:26
Tror jag läste på 2011 panasonic forum att man skulle ränka med 10 kr för dollarn.
Jag tog bara dollarn rätt av och då blev det cirka 28000:-
Postad 12 February 2012 - 11:13
Anade det.
Glöm inte peta på moms och andra roliga skatter. :-)
Postad 15 February 2012 - 18:37
Specifications
Features
Dimensions
Smart VIERA Engine Pro
VT50 Q&A/Comments
Added 1/26 and 1/27
- (PlasmaJunkie) Any news or enhancements on the 3D? (avjunkie) Yes even further reduction to crosstalk.
- (Ty819) 'cinema mode only' phrase really meant that the 25k steps wouldn't be available in vivid and similar modes? (avjunkie) All modes will benefit from additional steps in gradation. Not necessarily the full 25k though. Its dependent on the setting and the content used. All modes will show additional gradations at some level but like "600hz sub fields" less power drawn on the set is optimal.
- (speedraser) do we know the placement of the connections on the back of the TV yet? (avjunkie) Hdmi All on the side. The other inputs are the same as last year using break out cables for adapters.
- Will 2012 models be 10 lumen tech? (avjunkie) 10 lumen is not coming to 2012.
- (Heavyhitter) Is the 2012 VT implementing more of the Kuro technology in some way? (avjunkie) Ill say we use and tweak what we can and integrate. But this year was much a starting over period. Seeing what worked. What didn't and creating something I feel is very special. Our former pioneer engineers are very happy with this work.
- (ccip) Does the new driving method change the electronics only, or are the panels new also? (avjunkie) It's a new panel.
- Why was the 4 (VT40) skipped? (avjunkie) Pretty much deep ingrained superstition.
- (RichB) I think we just got a confirmation on a 70+ in the VT line. (avjunkie) It's not a no for the whole year but.. Maybe. absolutely not the final word. expect something mid year.
- (avjunkie) VT continues as the only model with 96hz playback
- (avjunkie) VT will have its own exclusive and sure to be highly controversial remote (web only; also comes with normal viera remote)
- Why do last years glasses not work with 2012? (avjunkie) This is Due to the change to the new universal Bluetooth standard all CE companies are using this year Previous glasses are not Bluetooth.
- (maygit) Do you have any estimations as to when the new glasses will be released? (avjunkie) First half 2012.
- (Icemanemp) Do 50-Series use the new unipher processors for Plasma? (avjunkie) its a brand new video processor. very state of the art from what it claims it can do with online services and video processing (dual core). Only gt and vt wt will carry it inside.
- (g12eyfox) Vjunkie, due this dual processor, will the high end model support the later version of Netflix (1080p and 5.1) and HD streaming for Youtube app? I know the older Viera Connect apps (2010 models) had older Netflix version and only SD youtube stream. (avjunkie) netflix i gotta get back to you on. hd youtube videos =absolutely! and the big thing is 3d conversion of all video services except skype.
- (*powerflower*) Will the VT come only with the the new RC or both of them. (avjunkie) It's only one remote for vt.
- (avjunkie) Clarifying something .. Numbers of subfields remains the same but the address time for each subfield has been dramatically reduced. To the 1/2500. Hence the number your seeing. (aka neo black 2500)
- (Darth Cardo) avjunkie is there any more info on Pure Mode 4:4:4 stuff? (avjunkie) I'm simply being told this explanation from engineering .. That the tv can accept full 4:4:4 without having to bring it down to 4:2:2. And this only applies to a source that can send this information so I was told higher end bluray disc players.they call it 1080p direct
- (fahrenheit) It hasn't been mentioned, so are we to assume that MgO hasn't been replaced by SgO? (avjunkie) Still mgo this year.
- (mnc) Any chance of a 60"VT50? (avjunkie) For USA.. No chance.
- (avjunkie) motion on the panels looked fantastic. the new drive system is genius in how it works. the factory is looking to keep this very confidential.its nothing like I've every heard before. it stems from some vx300 tech but more advanced. not the same.
- (RichB) I look forward to seeing them at MHT as well.When might that be? (avjunkie) May -june
- (avjunkie) I think this was asked before ces but yes the pdp still have fans in the larger sizes. im looking at a vt50 right now.
- (Jason Whiddon) Was it the ISF modes that did not work correctly last year early on. Will they be ready to go out of the gate this year? (avjunkie) Thats the plan. But it's too early to call right now. These panels technically are still waiting thx certification (Gotchaa) Joel Silver is suppose to get a panel in February for ISFccc control verification.
- (gmarceau) So if the ST, GT, and VT all have the same new pre-discharge tech, I'm assuming there are other factors toward deeper blacks that make the VT darker than the GT? (avjunkie) Only vt has the advanced pre discharge tech. technically all use some form of it but the lower black level is vt only.
- (3reach) When will thx be finalized then? (avjunkie) Already is. Just some legal technicality. We weren't even legally allowed to say it at CES
- (Jason Whiddon) Looking at its shape, and not being round, seems like its (stand) more stable of a design. Does the 65" swivel? (avjunkie) none do
- (avjunkie) word is 2012 products will not support network cameras this year as previous years always did.
Added 1/29 - Whats the MLL? No one knows yet.
Added 1/30 - (avjunkie)I think the addition of 2 thx mode for bright room and dark rooms is a step in the right direction for our thx mode. Last year we just missed the cut to have it added. I wasn't too happy that we only had a single thx mode and then a 3d thx mode. HERE
ASK YOUR QUESTION ABOUT PANASONIC'S 2012 TVS
Redigerat av Kirkman, 15 February 2012 - 18:52.
Postad 15 February 2012 - 21:41
Last, but certainly extremely cool, is the VT50 Series, which*we covered extensively*back in January. However, it's important to note that this flagship model includes everything mentioned above, including full HD 3D, the Infinite Black Ultra Panel, Deep Black hues, 24,576 steps of gradation technology, THX-certification, and ISFccc Calibration Mode with Advanced Calibration. Both will be coming in May, with the 55-inch*TC-P55VT50*hitting on the 7th for $2499 and the 65-inch*TC-P65VT50*coming on the 14th for $3999.
Redigerat av Foxxy, 15 February 2012 - 21:42.
Postad 16 February 2012 - 11:52
Redigerat av pacman, 16 February 2012 - 11:52.
Postad 16 February 2012 - 14:28
Anade det.
Amerikanska priser är alltid utan skatt. Detta för att man har olika sk sales tax beroende på var du bor i USA.
Postad 16 February 2012 - 17:44
Panna kommer presentera EU-modellerna på måndag (20/2), om nu nån inte visste det.
Och då kommer G50 finnas med?
Postad 16 February 2012 - 18:26
Postad 17 February 2012 - 03:25
Att den inte kommer förrän i sommar passar utmärkt.
Postad 17 February 2012 - 11:38
Redigerat av Unregistered1734, 17 February 2012 - 21:31.
Postad 17 February 2012 - 12:01
Sorry, tidsmaskinen är krasslig, åker bara till söndag. Ska försöka fixa den.
Postad 17 February 2012 - 20:48
Redigerat av Unregisteredbf63d3ba, 17 February 2012 - 20:50.
Postad 17 February 2012 - 21:36
Har du fixat din tidsmaskin än?
Postad 17 February 2012 - 21:45
Redigerat av stoffe69, 17 February 2012 - 21:46.
Postad 17 February 2012 - 21:55
Jag gissar på att endast vt och st serien kommer vara över 50". Vi får väl se måndag antar jag
Men det är vad som är under 50" som är det viktiga.
Postad 17 February 2012 - 22:20
Tur att vi alla tycker olika
Minst
Postad 18 February 2012 - 11:59
Postad 18 February 2012 - 12:04
"With EU-plasmas will have a huge problem. The new version of Energy Star 5.1 requires that consumption be limited to 50 "screen, a level not higher than 108Wt 50" FullHD display.
http://www.energysta....quirements.pdf
Also:
- VT50 now exists only in the form of ie engineering models. So-called "masters". Mass production began in late January."
Källa - http://www.avforums....-tv-2012-a.html
Redigerat av Unregistered1734, 18 February 2012 - 12:09.
Postad 19 February 2012 - 21:12
http://www.fullhd.gr...plasma-tvs.html
2500hz sub-field drive
Något att bita i för samsung och philips 800 resp 1200 hz tekniker , Panna krossar med 2500 Hz . Ha ha ha. Det roliga är att klisterlappen med 2500 hz kommer sälja Tvn.
Postad 19 February 2012 - 21:24
Den där länken var rena grekiskan... :-)
Postad 20 February 2012 - 13:14
Europe: Panasonic VT50 will be available in 50, 55 and 65 inches called TX-P50VT50, TX-P55VT50 and TX-P65VT50.
Press release: Panasonic launches the 2012 Smart VIERA Plasma HDTV line-up for Europe
Smart VIERA - Five Features (Summary) (for Europe) video
Det regnar tv-apparater från Panasonic (M3)
Inga specifika datum har angetts för säljstart, de kommer rullas ut i butik under våren med priser satta närmare lansering.
Redigerat av Kirkman, 20 February 2012 - 16:52.
Postad 20 February 2012 - 13:31
ST50: 2000 FFD (hz), saknar dual core och saknar thx. Har samma Infinite black pro 2 panel dock och fast phosphor.
I"n 2012, Panasonic introduces 2500 Hz FFD (focused field drive) - in the VT50 and GT50 – to improve motion reproduction and a 24,576 color gradation system for better color performance."
Fast 2000hz har ju också introducerats i ST50. Så skillnaden verkar bara vara +500hz, thx och dual core processor för teoretiskt bättre motion reproduction och multitasking med online-material?
Antagligen skiljs priset åt +2000 kr mellan ST50 och GT50 förmodar jag när priserna släpps! Min insikt är att det verkar ovärt! Vad tycker ni? Roligt att höra lite olika åsikter
Redigerat av Unregistered1734, 20 February 2012 - 13:37.
Postad 20 February 2012 - 14:16
jag är riktigt sugen på VT50! riktigt snygg är den också!
får man med den där touchpaden till den också så gör ju det bara en extra krydda på en redan grym tv!
ska bli kul att höra lite hands on nu!
Redigerat av Beagle five, 20 February 2012 - 14:22.
Postad 20 February 2012 - 14:27
GT50: 2500 FFD (hz), Dual Core processor, THX.
viktigt att påpeka, detta är fortfarande 600hz tv apparater (sub field drive).
800hz på samsung är inte bilduppdatering utan bara en siffra dom hittat någonstans i bildbehandlingens dator som slår ordet 600 på fingrarna.
Postad 20 February 2012 - 15:22
Pioneer kör väl med 960hz sub-field något? Vore kul o höra vad du säger om detta! Jag kan bara lite om sub-field! Är det teoretiskt möjligt att köra på 2500hz?
Postad 20 February 2012 - 15:57
Jo vi vet det Beagle, tack dock som uppmärksammar detta för okunniga! 600hz och 2500 hz etc är marknadsföring för sub-field driven är fortfarande 600hz som du säger. Men vågar man tro att i och med deras nya panelbyte då dem "radikalt ändrat alla parametrar och drivmetoder i panelen" som dem själva hävdar, så kan det faktiskt vara 2500 äkta hz?
hz är det mest onödiga som finns att diskutera eftersom det är helt oilka saker som jämförs hela tiden och sedan oavsett hz så kan man ju diskutera om mer verkligen betyder bättre!?
pioneer vet jag inte vad dom körde, på den tiden var sub field drive inget som pratades om. läst något om 840hz men faktiskt ingen aning, och som sagt... spelar ingen roll!
förstår att du och ni andra här nog vet om detta med hz men gemeneman vet inte ett skit och i butik idag så är det fortfarande 100hz som är en av dom mest frågade sakerna om en tv har eller inte, och till och med där är det ju inget som säger att 100 är bättre än 50! oavsett teknologi (lcd,crt,plasma)!
så därför jag var tvungen att bara säga detta med just denna nya härliga hz siffra.
dom påstås ju blinka mer per pixel men ändå köra 600hz.... vete sjutton hur det går ihop faktiskt! får studera det lite närmare hur det funkar mer exakt!
kort lathund för olika hz:
Ren bilduppdatering: bilder per sekund
LCD: ingen över 240hz (200hz på 50hz material ) vad jag vet, allt över det är bara olika processer som kör i 200hz x 2= 400hz = får man göra så ens?
Plasma: ingen över 120hz (100hz på 50hz ). och finns inget skäl att höja frekvensen över det, om det ens går utan att det går ut över bildkvalitén.
alla hz tal över dessa är påhitt och något helt annat än bilduppdatering.
viktigast av allting, glöm nu allt jag skrivit! har INGET med köpet av er nästa tv att göra! finns skräp LCDer med 50hz som har bättre bild än "400 hz" "led"!
varför man nu ska köpa en lcd...
nä tillbaka till VT50, om den infriar förhoppningarna live, så känner jag att jag vill verkligen köpa en 55VT50 i år! är redan smått kär i 55VT30, men tycker dom är lite för mörka så välkomnar med öppna armar den höjda ljusstyrkan.
Postad 20 February 2012 - 16:09
--> http://www.recordere...d=6378&zoneid=6 <-- nya blu-ray spelarna
--> http://www.recordere...d=6383&zoneid=5 <-- nya tv apparaterna med lite mer bilder
"The DMP- BBT01, DMP-BDT500, and DMP-BDT320 include a touch pad remote control by simply swiping a fingertip across it. " Coolt!
Finns även i sista länken en video som granskar noga VT-plasmans design. Riktigt cool!
Redigerat av Unregistered1734, 20 February 2012 - 16:34.
Postad 20 February 2012 - 16:25
Vad betyder ISFccc, förstår det handlar om kalibrering men innebär det att den är förkalibrerad eller att den är anpassad för att kunna kalibrera?
När dyker prisuppgifter upp?
Postad 20 February 2012 - 16:59
Shysst att du förklarade någorlunda ändå! Känns ovärt att gå in med HZ perspektiv för att motivera ett köp av GT framför ST då
Det är väl mest marknadsföring för 2D till 3D konvertion eller något...
Hängde inte med riktigt angående pekskärmen.Ska man kunna använda vilken Android tablet som helst eller funkar bara Panasonics ?
Postad 20 February 2012 - 17:09
Postad 20 February 2012 - 18:21
Man får vara glad att GT blir billigare iaf.
Och ingen G50 heller?
Postad 20 February 2012 - 20:01
Sedan ännu kåtare när jag läser mars-april. Kommer bli utan tv from nästa vecka, de som vet hur det är vet om att det kommer att bli ett **** ;-)
Postad 20 February 2012 - 20:15
Postad 20 February 2012 - 21:10
Blir så köpkåt när jag läser denna artikel http://www.flatpanel...l&id=1329738734
VT-50 var ju hur snygg som helst! Panasonic har äntligen hajat formgivning.
Postad 21 February 2012 - 16:35
Europe: Panasonic ST50 will be available in 42, 50, 55 and 65 inches called TX-P42ST50, TX-P50ST50, TX-P55ST50, and TX-P65ST50.
Så är det ju revolutionerande då det är första gången som >50" finns i annat än VT-serien i europa, dock en gåta varför inte GT gör det?
Postad 21 February 2012 - 17:40
Metal frame är så fult. Svart kant skall det vara.
Det hade varit snyggare. Ännu snyggare hade det varit om bilden hade gått ända ut till ramen. Men på filmer jag sett så täcker glaset ramen, vilket är lite synd, även om det ser mer helhetligt ut. Jag hade dock föredragit att bilden gått ända ut till ramen som på samsungs OLED.
Postad 23 February 2012 - 09:31
där har vi äntligen nåt att kika på.
Har inte hunnit kolla själv än, hoppas det är bra!
Postad 23 February 2012 - 10:11
Dessutom vill Panasonic bli nr.1 grönaste företaget. Målet är satt att bli detta till år 2018.
"Panasonic claims the dual-core processor also allows Flash content on websites to be displayed."
Processorn hjälper även till med att uppnå 24,576 steps of gradation technology i 3D FULLHD."
Det verkar alltså vara en grej för online-material och bättre flyt/bildkvalitetshantering i 3D såvitt jag uppfattat det rätt.
ST50 verkar onekligen som den prisvärdaste plasman i år med high contrast AR filter, Infinite black panel 2 pro, 2000hz Focused field-drive och fast switching phosphor. Om priserna som listats i UK överensstämmer med Sverige på 9,800 kr för denna teve. Can't wait <3
Postad 23 February 2012 - 11:27
Jag skiter fullständigt i 3D och vill ha bästa 2D bild under 10.000 kr. G30 har länge varit "TVn för mig" och nu när den ligger så bra i pris så har jag varit väldigt nära att slå till.
Frågor till er som vet,
- Panelen i ST50, är det samma panel som i G30?
- ST50 ser inte ut att ha THX stöd? Det har G30 och är väldigt uppskattat av många.
- När tror man att ST50 släpps? Brukar dom börja med de dyrare modellerna (VT50, GT50)?
Postad 23 February 2012 - 11:48
Tack för länken beagle 5! Dem pratar en del om att Panasonic inte ger upp support för kunder gällande "green tint/bolb" fenomenet och sådana fel i panelen många har upplevt på VT30 etc etc... Dem arbetar på en lösning och hoppas att alla forum ska höra av sig för få uppdateringar i panelen och invänta nyheter via 1on1 kontakt på mail etc...
Då borde inte 42GT50 vara långt efter i pris. Can´t wait either.
Postad 23 February 2012 - 11:50
Nej, ny panel (och ny drivning) i ST50.- Panelen i ST50, är det samma panel som i G30?
Verkar som om de inte slösat bort pengar på att ge dem helt i onödan till Mr Lucas ja...- ST50 ser inte ut att ha THX stöd? Det har G30 och är väldigt uppskattat av många.
Förhoppningsvis har den ett bildminne som presterar lika bra eller bättre...borde inte vara så svårt.
Dyrast brukar vara sist ut. Gissningsvis Mars för ST50.- När tror man att ST50 släpps? Brukar dom börja med de dyrare modellerna (VT50, GT50)?
Postad 23 February 2012 - 12:22
Tack pacman för bra svar!
Följdfrågor,
Ang THX läget - är det möjligt att idag med G30 uppnå samma bild genom att ratta fram det själv med kontrast-, ljus-, färg- inställningarna? I så fall så bara man vet vad man gör så behöver man inte THX läget?
Mars för ST50 låter inte alls dumt! Håller tummarna för det då
Någon som vet om det finns bilder på baksidan av ST50? Information om antal in och utgångar?
Hoppas verkligen inte att dom gjort samma tabbe som med G30 att sätta ingångarna rakt ut på baksidan..
7
Bildkalibrering
4 bilder
33 filmer
