Canon PowerShot SX200 IS
46 svar till detta ämne
Postad 23 March 2009 - 23:01
smarts
  • smarts
  • 30 inlägg
Tänkte en mig en samlingstråd kring Canons nya kompakta långzoom. Om du äger en, dela gärna med dig av erfarenheter då vi är flera som väger mellan denna och ex. vis Panasonic Lumix DMC-TZ7.
Ett första test
http://www.dcresourc...iew/index.shtml
What I liked:
* Very good photo quality (in good light)
* 12X optical zoom with a nice 28 - 336 mm range
* Compact body for an ultra zoom; stylish and well-designed
* Optical image stabilization
* Sharp 3-inch LCD display with very good outdoor and light light visibility
* Full manual controls
* Auto mode will pick a scene mode for you; plenty of other scenes can be selected manually
* Can record HD movies at 1280 x 720 at 30 fps using H.264 codec
* Fast startup, menu operation, and playback speeds
* Face detection (with subject tracking), face self-timer, blink detection, and redeye removal features all work well
* i-Contrast feature brightens shadows effectively, in record and playback mode
* Elaborate playback mode
* HDMI output
What I didn't care for:
* Noise reduction causes detail loss above ISO 200 in low light, ISO 400 in good light
* Tends to clip highlights; some purple fringing, as well
* Anemic, slow-to-charge flash
* Optical zoom not usable in movie mode
* No multi-point autofocus or live histogram available
* Below average battery life
* Continuous shooting mode on the slow side
* No optical or electronic viewfinder
* No memory card or built-in memory included
Postad 04 April 2009 - 15:12
Unregistered89a7be48
  • Unregistered89a7be48
  • 2082 inlägg
Ingen som har köpt denna som kan ge en mini analys,står i valet mellan denna och Ixus 100is,just nu känns det som denna (allså sx200is) ligger närmast köp!
/Mats
Postad 04 April 2009 - 17:53
Har fått låna en på måndag i min jakt på ny kamera som skall komplettera min dSLR - återkommer med lite tycke
Postad 04 April 2009 - 18:30
  • 2082 inlägg
Kanon!
Då väntar jag med spänning,tror ganska mycket på denna.
/Mats
Postad 04 April 2009 - 19:03
Ja, jag tror också rätt hårt på den. Skall bli skönt att få testa runt lite under en dag.
Postad 06 April 2009 - 14:31
  • 2082 inlägg
Väntar med iver på hur den var?
/Mats
Postad 06 April 2009 - 18:27
No go idag, fick ingen kamera :)
Skall göra nytt försök imorgon.
Postad 07 April 2009 - 10:39
Så, nu har jag provat men kan tyuvärr inte rapportera några bilder tagna med kameran då min kontaktperson var riktigt stressad och jag fick muta honom med en lunch som han glupskt satte i sig medans jag lekte med kameran.
Intryck: Ligger skönt i handen och känns rätt välbyggd. Dock tyckte jag att det inbyggda linsskyddet kändes väl bräckligt och det sviktade misstänkt när jag tryckte lite på det. Skulle nog inte lägga kameran direkt i en väska utan ytterligare skydd. Batteriluckan verkade också lite ranglig. Verkar inte gå att skruva på andra konverteringslinser till den.
Kameran startar snabbare än någon annan kompaktkamera jag provat (eller kommer ihåg att jag har upplevt). Svårt att säga exakt hur lång tid, men uppskattningsvis någonstans runt sekunden att starta, ut med gluggen och upp med blixten.
Vidvinkel ger motsvarande 28/3.5 och tecknade rätt mjukt, likadant i max inzoomat där den också var mjuk, men inte på något sätt så det störde. Autofokus är okej, inte mer. Lite inomhusfoto visade lite svagheter, kanske inte i exakthet utan snarare i hastighet, och det är en punkt som gäller, eller mitt hatobjekt - ansiktsigenkänning - som gäller. Lite vinjettering och tunneldist men inget som störde.
Inget RAW-stöd som jag kunde hitta i menyerna och för mig kändes > ISO 200 som ohållbart för tryck.
Blir inget köp för mig pga iso prestanda och AFen som inte ville som jag alltid.
Korta anteckningar jag förde, fråga gärna om något som jag missat men kanske kommer ihåg.
Postad 07 April 2009 - 11:43
  • 2082 inlägg
Jag kan bara tacka så mycket för ditt omdöme tyvärr inte så bra som jag trodde,men den blir kanske köp för mig ändå eftersom min gamla kamera har somnat in för gått.
/Mats
Postad 07 April 2009 - 11:56
Alltså, kameran är inte på något sätt dålig. Jag hade bara förväntat mig mer av iso-prestandan.
Sen är jag rätt petig med tanke på vad jag är van vid för övrig utrustning - helt klart en orättvis referenspunkt, men jag har sett andra kameror med bättre iso-prestanda och snabbare AF men då med sämre vidvinkel vilket går bort för mig.
Prova den! Tror inte den gör dig missnöjd om du har "normala" krav :)
Postad 12 April 2009 - 09:59
Bibbas
  • Bibbas
  • 20 inlägg
Jag har ägt en Canon PowerShot SX200 IS i ungefär 4 veckor nu. Jag är ganska långt ifrån en expert inom området men är trots detta väldigt fotointresserad. Så det jag kan ge dig är ingen expert recension utan mest en åsikt från en glad amatör :P Man måste ju som sagt börja någonstans.
Så, det jag var ute efter var en kompakt men ändå riktigt kraftfull kamera som lämpar sig för "upplevelse bilder", jag är inte direkt någon som tar med sig en kamera till en förfest för att försöka blixtra ikapp med alla andra nötter. Jag ville ha en kamera som skulle kunna ta riktigt bra bilder när man är ute och reser och till andra lite mer speciella tillfällen då en billigare kamera inte håller måttet. Jag utgick ifrån teorin att, är kameran för stor så drar man sig för att ta med den överallt då man reser eller rör på sig i allmänhet.
Efter att ha letat kameror i ungefär 2 månader så fick jag syn på denna, jag har jämfört mot nästan alla andra Canon kameror och i princip alla andra kompaktkameror i samma klass. Jag har provat kameror och jämfört resultat vid fotobutiker och elektronikbutiker och kom tillslut fram till att det var denna kamera som var den absolut bästa för att täcka mina behov.
Den är enkel att använda, den tekniska utformningen av alla funktioner är också enkel och smart. Startar snabbt och känns rejäl och robust i handen. Men inte alls för tung. Inomhusbilder kan vara lite svårt om det är dåligt ljus eller konstigt ljus och rörelser, som i sporthallar osv. Men mycket handlar ju också om hur man fotar i de sammanhangen. De olika auto inställningarna som finns är också helt okej, då jag inte är någon expert så håller jag fortfarande på och lär mig att köra på manuellt läge. Men det finns även där riktigt mycket möjligheter till att ställa in och ta bra bilder. Något som jag gillar oerhört starkt är att man kan filma i HD, det blir riktigt bra filmer och med ett större minne så kan man filma riktigt långa och fina sekvenser.
Så, jag har inte hittat någon kompaktkamera som är bättre än denna. Det enda jag kan tänka på är om man vill ha en mindre och lättare kamera. Har man pengarna men inte vill ha en systemkamera så ser jag inget annat alternativ.
//Amatören.
Postad 12 April 2009 - 17:25
Bra sammanfattat! När man har kört dSLR ett tag märker jag att ens kravlista blir mycket längre av någon anledning :P
Postad 14 April 2009 - 09:30
smarts
  • smarts
  • 30 inlägg
Egentligen enda anledningen som gör att jag överväger Panasonicen (TZ7) är avsaknaden av zoom vid filmning på Canonen. Bibbas har du filmat något och har du isf saknat zoomen?
Postad 15 April 2009 - 07:51
Bibbas
  • Bibbas
  • 20 inlägg
Själv uteslöt jag Panasonic Lumix DMC-TZ7 ganska snabbt i jämförelsen mot Canon PowerShot SX200 IS.
Då saker som upplösning bild och bildsensor, objektiv, närgräns, exponering var vassare hos PowerShot'en. Sen var det även smådetaljer som avgjorde då jag tyckte Canon hade smartare lösningar på sådant som man inte lägger märke till speciellt mycket. Sen kändes priset på Lumixen överdrivet för sin kvalite, det verkade lite som "Det här är en TZ7, nu jä*lar ska vi ta betalt"
Men åter till filmningen, ja jag har filmat ganska mycket. Filmat mycket innebandy, inomhus och kvalitén är riktigt bra, undrar ibland varför jag inte köpte en filmkamera då jag nästan filmat mer än fotat än så länge :) Men visst saknar man zoomen, det går ju att zooma, men då endast digitalt. Det går dock att lura det hela om man zoomar först och spelar in sedan, fast då är ju förstås zoomen låst i det senaste läget. Men jag tycker inte att den detaljen ska spela in för mycket, hellre en allmänt lite bättre kamera än att kunna zooma optiskt under filmning. Om man nu kan zooma optiskt med Lumixen?.
Postad 27 April 2009 - 15:15
  • 2082 inlägg
Tack för all hjälp!
Blev köp i dag,står på laddning nu,så jag väntar med iver på att komma igång!
/Mats
Postad 04 May 2009 - 09:09
Lessfat
  • Lessfat
  • 51 inlägg
Men åter till filmningen, ja jag har filmat ganska mycket. Filmat mycket innebandy, inomhus och kvalitén är riktigt bra, undrar ibland varför jag inte köpte en filmkamera då jag nästan filmat mer än fotat än så länge ;) Men visst saknar man zoomen, det går ju att zooma, men då endast digitalt. Det går dock att lura det hela om man zoomar först och spelar in sedan, fast då är ju förstås zoomen låst i det senaste läget. Men jag tycker inte att den detaljen ska spela in för mycket, hellre en allmänt lite bättre kamera än att kunna zooma optiskt under filmning. Om man nu kan zooma optiskt med Lumixen?.
Filmat mycket innebandy skriver du. Har du möjligtvis något från den typen av filmning som du kan lägga upp som demo? Om det blir ett köp av en SX200 för mig så lär jag själv fota och filma rätt mycket innebandy och då är det kul om det iaf blir hyfsade klipp. Nu vet jag att innebandy är en ganska otacksam idrott att fota och framförallt filma med kompaktkameror eftersom det är en relativt snabb idrott.
Postad 07 May 2009 - 21:41
Lessfat
  • Lessfat
  • 51 inlägg
Tack för all hjälp!
/Mats
Får man fråga om du är nöjd med köpet?
Postad 08 May 2009 - 09:46
Bibbas
  • Bibbas
  • 20 inlägg
Just nu är jag på jobbet men bara jag kommer hem så ska jag se vad jag kan göra. Klippen blir ganska stora så jag vet inte riktigt hur jag ska göra för att de ska bibehålla kvalitén på bästa sätt när jag laddar upp det. Men som sagt, jag ska se vad jag kan göra :)
Som du säger, snabbheten i sporten och det ofta dåliga ljuset gör det knepigt att fota innebandy med en kompaktkamera. Men bara man klurat ut hur man ska fota på bästa sätt så går det få riktigt bra bilder.
Postad 08 May 2009 - 17:30
Varghjärta
  • Varghjärta
  • 58 inlägg
Jag har försökt hålla mig till Canon-kameror som äter R6-batterier, därför har jag flera i varierande styrkor som räcker mkt länge. Hur länge räcker en laddning _ungefärligt_ på en sån här kamera med medföljande batteri? Och är det möjligt att köpa kraftigare batteri som håller längre. Att få slut på ström mitt under ett äventyr vore helt tragiskt :)
Postad 09 May 2009 - 15:29
Lessfat
  • Lessfat
  • 51 inlägg
Kanon.
Jo det kan jag tänka mig, men det mesta brukar gå att lösa med rätt inställningar. Har du någon bild som du fotat med Powershoten som du kan delge också?
Postad 09 May 2009 - 19:49
Varghjärta
  • Varghjärta
  • 58 inlägg
Nej nu flippar jag snart, jag ska iväg till gröna lund på tu man hand på onsdag, och jag har ångest inför att dra med mig min Powershot S5:a pga dess storlek och hur jag ska göra om jag vill åka i någon attraktion, jag tänker mig iaf att man har det lite lättare om man ens kan få in en kamera i en liten ficka någonstans.
Så nu överväger jag starkt att köpa mig denna SX200 (och sälja av min knapert använda S5:a), jag har läst och läst och överallt verkar det ge mig samma uppfattning. Att den är mkt bra, men har nackdelar såsom t.ex att inte kunna zomma vid filming och att linsen tydligen ska vara sämre än den på "Panasonic Lumix DMC-TZ7", men jag som inte är någon super-expert kan inte urskilja några klara skillnader. Så det där lägger jag inte mycket vikt vid. Sen tycker jag rent estetiskt att powershoten har stark överhand. Lumix:en verkar samtidigt ha grova problem att fokusera vid zoomning+inspelning, vilket inte kändes så trevligt.
Jag hoppas även att zoom-problemet kan avhjälpas i framtiden: http://chdk.wikia.com/wiki/CHDK
Min tveksamhet ang batteri kanske kan avhjälpas genom att köpa en drös av dessa "piratbatteri": http://www.cyberphot...?article=980009
Jag ska iväg till jobbet inom kort men skall dra iväg till gallerian min eller stan imorgon för att försöka fingra på en SX200, jag vill få en bättre uppfattning om storleken.
#EDIT: Jag är nu stolt ägare till en svart SX200. Har inte hunnit provfota utomhus där jag avser göra det framöver, jag återkommer.
Redigerat av Varghjärta, 11 May 2009 - 22:15.
Postad 15 May 2009 - 13:50
Varghjärta
  • Varghjärta
  • 58 inlägg
Jag har haft min kamera nu sedan i måndags (11/5) och har haft chans att leka lite med den. Och dessutom varit med om en olycka. Jag drog med den på äventyr, och en tjejpolare lyckades slå ut sina armar så hon slog kameran ur händerna på mig varpå den flög ner 2 meter till plattformen där vi var. Detta medans den var på, jag hade fett ont i magen i den sekunden. Men trots att optiken var ute och allt så verkar den ha överlevt, har inte funnit några synliga defekter eller fel på bilder jag tar, men vem vet hur många år det tog av dess livslängd.
# Mina tidiga intryck:
+ Ovanligt bra vidvinkel, jag får stora bilder och stor del av synfältet
+ Jag har haft glädjande få ofokuserade bilder trots att jag ibland gått medans jag fotat
+ Macroläget är helt väldigt bra, den klarar likaså av att fokusera här mycket bra, och bilder blir ofta inte ofokuserade här trots att objektet kanske rör på sig (se exempelbilder av maskrosorna).
+ En glädje att ha med då den är tillräckligt liten för att faktiskt ha i bältet utan att störas!
+ Skärmen går att använda trots direkt solljus, den är stor och fin, men samtidigt kanske den känns lite oskyddad
+ Positivt överraskad av batteriet som jag ännu bara laddat en gång, och det är fortfarande 3 pluppar
+ Den är riktigt duktig på att fokusera vid snabba rörelser(springa djur/människor), och likaså i _mörker_
+ Att använda ratten för olika lämpade lägen ger överlag väldigt bra resultat, att sätta den på "djur/barn" verkar ge den snabbare slutartid och klarar av att fånga rörelser i farten.
- Jag gillar inte riktigt "landskaps"-läget eftersom den gör bilder mörka, men jag kanske använder den fel.
- Ratten är samtidigt jobbig att hela tiden snurra på om man inte vill ha den på "Auto" hela tiden
- Jag saknar en dedikerad film/inspelnings-knapp ifrån min förra Canon, jag vill ibland snabbt spela in men måste då snurra på ratten ett halvt varv
- Att inte kunna zomma under inspelning störde mig mer än jag trodde (tänk snabba sporter m.m), men jag kan lära mig leva med det.
Se bilagor för några av mina första test-bilder:
OBS. Högsta optiska zoom-nivå används på bilderna 014, 038 & 039.
Redigerat av Varghjärta, 15 May 2009 - 13:56.
Postad 15 May 2009 - 17:18
Bibbas
  • Bibbas
  • 20 inlägg
Så, nu har jag äntligen hittat några minuter till att ladda upp några exempelbilder och även ett videoklipp.
  • Bilderna är tagna med några av kamerans olika förinställningar, för att ge en så rättvis bild av kvalitén som möjligt.
  • Klippet är filmat i motljus och med en aning optisk zoom. Så klippet är inte det bästa, men det enda som var litet nog för att orka ladda upp :wub:
Postad 23 May 2009 - 08:11
L8W
  • L8W
  • 12 inlägg
Tack vare era omdömen så har jag äntligen, efter 1½ år, bestämt mig för att komma till skott och slå till på en kompakt långzoomare. Har hela tiden sneglat på Lumix, men hade fått låna en, i och för sig inte långzommare, men en Lumix, och jag var aldrig riktigt nöjd.
Nu måste jag ju naturligtvis "skynda mig" handla (innan anfallet går över ;) ), eftersom jag åker på semester om en vecka och väldigt gärna vill ha en sx200 som resekamrat. Nu återstår en fråga, men ack så viktigt tycker jag, vilket minne ska jag ha? Funderar på att köpa ett SanDisk SecureDigital Video HD SDHC 16GB, eller är jag helt ute och cycklar då?
##Edit: måste man ha speciell läsare för ett sdhc minne?
Redigerat av L8W, 23 May 2009 - 08:17.
Postad 25 May 2009 - 08:32
Bibbas
  • Bibbas
  • 20 inlägg
Jag kör med ett SanDisk Ultra II Secure Digital HC 16GB, funkar hur bra som helst. Ska till USA om några veckor och maxa kortet, kan återkomma med hur det gick :)
Redigerat av Bibbas, 25 May 2009 - 08:37.
Postad 18 June 2009 - 20:21
Sonnerphors
  • Sonnerphors
  • 380 inlägg
Hej! Tjejen fick en Powershot sx200 is och nu letar vi väska till den, nägra tips?
Postad 18 June 2009 - 23:30
Unregistered6e98fd36
  • Unregistered6e98fd36
  • 77 inlägg
Tja!
Har just beställt:
1 st Canon PowerShot SX200 IS
1 st SanDisk Secure Digital Card 8 GB Extreme III SDHC 30MB/s
1 st Canon NB-5L (Extra Batt måste man ju ha :-p finns ju inge tråkigare än när de tar slut när de minst ska de)
1 st Digi-Cover LCD skydd 3,0
1 st Canon DCC-1000
Tog med en org väska från som heter DCC-1000
http://digicom.nu/pr...t.asp?pid=15727
Beställde allt från www.digicom.nu de har alltid bra leverans o kunnig personal som ofta testar själva de produkter
som är poppulärast för o kunna ge bättre svar på kundernas frågor! rekomenderas skarpt!.
Kan ej ge svar om den väskan är bra än men återkommer när den kommit hem i början av nästa vecka.
Redigerat av Unregistered6e98fd36, 18 June 2009 - 23:37.
Postad 19 June 2009 - 16:33
Sonnerphors
  • Sonnerphors
  • 380 inlägg
Tja!
Har just beställt:
1 st Canon DCC-1000
kollade efter den väskan nyss på Dustin, Scandinavianphoto osv, där var den slut =/ Ska beställa en direkt från digicom
Tack=D
Postad 22 June 2009 - 10:24
Bibbas
  • Bibbas
  • 20 inlägg
Har haft den väskan ett par veckor nu och är riktigt nöjd.
Väskan är genuin i äkta läder(?) och riktigt stabil och fast vilket ger ett bra skydd till kameran.
Den är smart och snyggt utformad med bra funktioner som magnet i locket som gör väskan enkel
och snabb att öppna. Väskan kan även fästas på bältet om man nu är i åldern 40+ :)
Kan endast se en nackdel med den och det är att man inte kan förvara ett extra minneskort eller batteri i väskan.
I övrigt en "canon bra" väska!
Postad 24 June 2009 - 09:15
masse70
  • masse70
  • 8528 inlägg
Då har man sällat sig till den förhoppningsvis lyckliga skaran av ägare till en SX200 IS :(
Blev detta paket som skall hämtas på posten idag:
Canon Väska DCC-1000
Canon PowerShot SX200 IS Svart
SDHC Sandisk Ultra II 16GB
Den skall tas med till Gran Canaria resan nästa vecka så då får den bekänna färg.
Postad 26 June 2009 - 19:59
Babbly
  • Babbly
  • 19 inlägg
Har blivit lätt nyfiken på denna kamera, som alternativ till den kamera jag har nu och tänkte fråga; hur är den i miljöer som tex Aquaria, Skansen etc? Är det någon som vet det? *nyfiken*
Dock verkar den ta trevliga närbilder =)
Postad 27 June 2009 - 09:48
masse70
  • masse70
  • 8528 inlägg
Har nu hunnit fingra på denna kamera ett par dagar och kan bara säga att jag känner mig mer och mer nöjd med köpet! Den känns logisk i sina funktioner, lätt att förstå sig på och den har en fin byggkvalitet imo.
Sen har jag hunnit ta lite provbilder i Autoläge som jag tycker ser fina ut. Är dock ingen fotokille och är inte heller så insatt i alla funktioner än osv. Har dock visat lite bilder till mina väldigt fotointresserade kollegor på jobbet som alla verkar var imponerade av denna kompaktkamera, vilket känns ännu bättre ;)
Sen råkade jag plocka upp nya numret av Bild & Ljud till min förvåning hade dom ett kameratest där där den blev utsedd till "Bäst i Test"!
Här kommer några snabbilder:
Dock har jag numer stängt av den fula datumstämpeln som sabbar bilderna... :(
Bifogad fil  IMG_0009.JPG   2.5MB   0 Antal nerladdningar
Bifogad fil  IMG_0013.JPG   2.71MB   0 Antal nerladdningar
Postad 29 June 2009 - 09:09
maclaes
  • maclaes
  • 54 inlägg
:) Jag instämmer vad Masse70 har upptäckt att det är en skitbra kamera! I jämförelse med Nikon Coolpix S210 är den tung men det är det enda man kan jämföra. Ibland tar jag hellre den lilla Canonen istället för Canon500D då den tar så pass bra bilder! Ångrar inte en sekund den är helt klart värd sitt pris!
/maclaes ;)
Postad 30 June 2009 - 21:05
Unregistered13206d48
  • Unregistered13206d48
  • 46 inlägg
Har läst överallt och i massa forum, det är INGEN som nämner om den har autofocus vid filmningen eller ej.
Så hur är det?
Just nu testar jag min ixus 100 mot en lumix tz7
tz7 är grym på zoom vid inspelning samt att den har autofocus som funkar riktigt bra för att vara en kompakt.
Ixusen har dock betydligt lugnare bild och inget brus till skillnad från lumix, men jag saknar verkligen autofocus på ixusen.
Synd att dessa två kameror har rätt så starka för och nackdelar vilket gör det omöjligt att välja en av dem.
Postad 02 July 2009 - 13:35
Numero1
  • Numero1
  • 1920 inlägg
Bra tråd! Precis vad jag letade efter.
Jag har en Nikon D90 och min SONY T12:a dog för något år sedan.
Vill ha en bra liten kompaktkamera då jag itne orkar släpa på D90 (som förövrigt är grym!!!)
Väljer mellan denna och Panasonicen.
Ska nog gå och titta i butik på båda...
Postad 03 July 2009 - 07:31
Numero1
  • Numero1
  • 1920 inlägg
Jag är på gång att köpa en kompaktkamera och sneglar på Canon Powershor sx200 och Panasonic TZ7 som sagt.
Var i en butik och kollade lite i går och fick känslan av att de är rätt likvärdiga men att Panasonicen är ett
stråvassare när det gäller att kunna zooma undertiden du filmar och en bättre lins med bättre ljusinsläpp...
Vad säger ni?
Postad 03 July 2009 - 08:11
Unregistered421f5d40
  • Unregistered421f5d40
  • 1364 inlägg
Vad säger ni?
Kan bara säga att jag e jätte nöjd med min Canon & det som avgjorde var priset . TZ7 kostade nästan lika mkt som en system kamera när den kom . Hade jag köpt någon av dessa idag så hade jag nog tittat lite mer på TZ7 för den har möjlighet att zooma när man filmar
Postad 03 July 2009 - 12:33
Numero1
  • Numero1
  • 1920 inlägg
ja, precis och idag är prisskillnaden bara 500:-
Hur pass mycket värt är Leica linsen i TZ7an?
Postad 09 July 2009 - 15:45
masse70
  • masse70
  • 8528 inlägg
Sitter här och skriver från vår semester på Gran Canaria där min nya SX200 har fått följa med ;)
Kan säga att jag blir bara allt mer nöjd med den för varje gång den används!
Av de sista frågor som uppkommit här kan jag säga att isåfall är den enda "nackdelen" med Canonen att den har mer begränsade möjligheter att zooma vid filmning jämfört med TZ7an. Dock är det för mig nåt som inte gör mig det minsta samt att den även var tusenlappen dyrare när jag köpte min. Den har grym automatik och även fullgott med manuella val för de som vill, orkar och kan använda det.
Slänger upp en liten semesterbild från hotellets pool för de som vill se hur den gör sig. Jag tykcer iaf att det blir bra bilder med auto, fotoamatör som man är :)
Bifogad fil  IMG_0050.jpg   2.02MB   0 Antal nerladdningar
Postad 23 July 2009 - 18:19
Babbly
  • Babbly
  • 19 inlägg
Väcker liv i denna tråd då jag tänkte fråga ifall någon vet vilket stativ som lämpar sig att köpa till denna kamera? Räcker ett Gorilla stativ samt går det ens att sätta kameran på ett stativ?
Postad 23 July 2009 - 18:46
torvaldur
  • torvaldur
  • 907 inlägg
Ja, det är vanligt standardfäste till stativ 1/4" skruv.
Postad 23 July 2009 - 23:23
Babbly
  • Babbly
  • 19 inlägg
Man tackar för snabbt svar =)
Då vet jag vad det blir nästa månad ;)
Postad 01 August 2009 - 22:40
ndjr
  • ndjr
  • 256 inlägg
Kan någon svara på dessa frågor
Har SX200 vanlig HDMI eller Mini HDMI utgång?
Kan man använda anti shake läget med video inspelning också?
Är batteriet verkligen så bra att det räcker i ca 5 timmar i play läge?
Postad 04 August 2009 - 12:30
masse70
  • masse70
  • 8528 inlägg
Kameran har en mini-hdmi utgång samt mini-usb.
Postad 22 September 2009 - 20:35
jan44a
  • jan44a
  • 13 inlägg
Jag såg en video på youtube med denna kamera då det zoomades under filmning. Kolla
Postad 19 November 2009 - 02:35
aziraphele
  • aziraphele
  • 117 inlägg
Var kan man hitta en väska som passar denna kamera. Gärna en orginal. Beställde kameran idad och hoppas kunna hämpa den imorgon eller på fredag. (ska till barcelona på måndag och titta på Zlatan och då vore det ju kul att kunna ha med sig sin nya kamera.)
Redigerat av aziraphele, 19 November 2009 - 02:35.
Postad 19 November 2009 - 21:32
reflux
  • reflux
  • 162 inlägg
Gammalt inlägg men i fall nån ser detta och missförstår; vad ni ser i filmen är digital zoom. INTE optisk zoom.
