Cambridge Audio DVD89
92 svar till detta ämne
Postad 09 februari 2006 - 23:10
Unregistered94256dec
  • Unregistered94256dec
  • 337 inlägg
Cambridge Audio har nu släppt sin DVD89. Gamla DVD79 ska ju tydligen vara en klon av Oppo DV971H. Och ryktena säger att DVD89 ska vara en klon av Oppos kommande DV970H?
Länkar:
Cambridge Audio
Här finns bild på spelarens baksida
Ett test på franska. Testas mot några heta konkurrenter.
Vad jag kan förstå med hjälp av babelfish är att ljudmässigt sett sägs DVD89 vara riktigt bra, bäst i testet. Bildmässigt sägs den vara sämre än både Marantz 6600 och Denon 1920, dock ingen större skillnad. Det är tydligen deinterlacingen som haltar något. Kanske inte så oväntat då Faroudja har slopats...
Klistrar in lite babelfishat från testet:
I was also mistaken concerning Cambridge DVD89. I thought that it would be a hair better than Marantz, in audio, and quite higher than Denon, whereas it is in fact very far in front of Marantz in audio, and that it exceeds even its predecessor, Cambridge 540D, who was already unbeatable, at its price. With does such a result, new Cambridge reach the quality of a good reader CD (let us say up to 350/400?) and can replace it very well in your Hifi piece of furniture if its sound signature corresponds to the way in which you like to listen to the music. In video, I thought that it would be better than that. Admittedly I did not dream that it would be better than Denon, but I thought that it would pursue it. For a maniac of the image as I am it, it is a little in withdrawal on the DVD1920. A little more video noise per Ci, some effects of staircases by there, of the plane backs a little vaguer, it is sufficient for me to classify it below Denon. From there of saying that it is not appropriate for a video projector, I do not think it, because the image is far from being pushing back! Let us say that that which gives the priority to the image should choose Marantz DV6600, and which that which gives the priority to the sound should take Cambridge. For an image of small size (plasma of 107cm and less), there is not to hesitate, so much the sound quality of the DVD89 is beautiful, and its small video defects will be invisible there with this size.
Men OM DVD89 är en klon av Oppo DV970H, då borde Oppos firmwares funka även i DVD89. Och hur flitiga Oppo är på att producera firmwares har väl inte undgått någon. Jag tror att denna spelare kan bli nåt...
Godbitarna:
Både DVI och HDMI
480i via HDMI?
Uppskalning via HDMI, DVI och även komponent?
Finns i både silver och svart
Relativt billig, ca 330 euro
SACD + DVD-Audio
Redigerat av Unregistered94256dec, 31 maj 2006 - 10:19.
Postad 09 februari 2006 - 23:45
Unregistered42611
  • Unregistered42611
  • 4 120 inlägg
Kommer den finnas i svart? :D
EDIT.. skall lära mig läsa... ser att det står där nu :lol:.
//Loofy
Redigerat av Unregistered42611, 09 februari 2006 - 23:45.
Postad 12 februari 2006 - 17:59
wictor
  • wictor
  • 1 451 inlägg
när kan den här godbiten tänkas komma till sverige???
Postad 17 februari 2006 - 19:18
wictor
  • wictor
  • 1 451 inlägg
ngon som har luskat fram något?? :huh:
Postad 18 februari 2006 - 23:38
Mohawk
  • Mohawk
  • 80 inlägg
480i hmmm? Borde ju vara 1080i det klarar väl Oppo DV971H om jag inte är helt ute och cyklar.
Postad 18 februari 2006 - 23:53
  • 337 inlägg
Jovisst lär denna klara att skala upp till 1080i. Men det intressanta är om denna kan skicka 480i via HDMI. Detta "format" är, näst efter 480i via SDI, det "renaste" som man kan mata en extern scaler/videoprocessor med. Många rykten på diverse forum pekar på att Oppo kommer erbjuda den möjligheten i sin kommande modell, och DVD89 är med största sannolikhet en klon av Oppon.
Postad 19 februari 2006 - 00:10
  • 337 inlägg
Några länkar till ett par trådar på AVSforum angående kommande Oppo-spelare:
Tråd 1
Tråd 2
Tråd 3
Självaste Kris Deering (Secrets) bekräftar Oppos planer.
Ett annat mycket intressant men obekräftat rykte är att Oppo jobbar på en spelare med HQV från Silicon Optix. Precis som Denon har i sin värsting DVD-A1XVA...
EDIT: Lade till ytterligare en länk (den tredje) till en tråd där det påstås att Oppo även tänker erbjuda uppskalning via komponent. Frågan är om det är en, två eller tre nya Oppo-spelare på gång. Och vilken av dessa "är" Cambridge Audio DVD89?
Redigerat av Unregistered94256dec, 19 februari 2006 - 12:17.
Postad 05 mars 2006 - 21:02
wictor
  • wictor
  • 1 451 inlägg
någon som vet när denna kommer till sverige
Postad 05 mars 2006 - 22:01
thomas79
  • thomas79
  • 1 423 inlägg
Det där lät väldigt intressant. A1XVA:n har ju ganska hygglig bildkvalite om man säger så... Ska verkligen hålla utkik efter oppo...
Postad 08 mars 2006 - 21:17
Mohawk
  • Mohawk
  • 80 inlägg
I april skall de börja sälja den på Hi-fi klubben. 2498kr skall den kosta om någon undrar.
Postad 10 mars 2006 - 16:14
wictor
  • wictor
  • 1 451 inlägg
trevligt!!! ;)
Postad 10 mars 2006 - 18:23
NiklasK
  • NiklasK
  • 452 inlägg
Manual finnes här. Säger dock inte så mycket efter att ha skummat igenom den.
/Niklas
Redigerat av NiklasK, 10 mars 2006 - 18:23.
Postad 16 mars 2006 - 22:46
  • 337 inlägg
De senaste buden är att denna Cambridge Audio DVD89:
1. Inte kan mata ut 480i via HDMI. Detta kan vi vara ganska säkra på enligt rapporter från diverse forum.
2. Bara kan skala upp icke kopieringsskyddat material via component-utgången. Men det tros komma ett hack för detta snart då Mediatek-chippet tydligen ska vara lätt att knäcka.
Dessutom har det rapporterats att spelaren har vissa (grova) deinterlacing-problem med filmbaserat PAL-material. Se bilder i denna tråd på avforums.com.
Postad 16 mars 2006 - 23:03
Unregistered973
  • Unregistered973
  • 2 349 inlägg
det verkar ändå som att so mjag skall köpa ny Cambridge audio får mest om man köper en azur jämförrt med en oppo klon som jag har nu (dvd 57)
Även om azur kan ses äldre nu så har den fått barnsjukdomarna ur sig eller vad säger ni...
Postad 19 mars 2006 - 11:08
wictor
  • wictor
  • 1 451 inlägg
ja e grymmt sugen på den här! priset och designen e inte fy skam! ;)
Postad 19 mars 2006 - 21:17
MatsB
  • MatsB
  • 119 inlägg
Alltid lika jobbigt när dom inte specar MPEG4-chipsetet.
@Love Spy, du sa Mediatek, vilket chip är det?
Redigerat av MatsB, 19 mars 2006 - 21:19.
Postad 19 mars 2006 - 23:58
  • 337 inlägg
Att det är ett Mediatek snappade jag upp på AVSforum. En snabb googling gav: Mediatek 1389
I alla fall enligt denna site...
Postad 30 mars 2006 - 17:19
Spike
  • Spike
  • 56 inlägg
Mailade Hifiklubben och frågade när denna spelare kommer finnas till försäljning (CA DVD89), och fick till svar att dem inte kommer att ta in den. Verkar ju lite konstigt? Vart får man tag på den isåfall och vet någon när OPPO 970 kommer finnas ute i butikerna?
Postad 30 mars 2006 - 19:04
wictor
  • wictor
  • 1 451 inlägg
va i **** ! dom måste ju ta in den ! annars e de ju skumt
Postad 31 mars 2006 - 13:58
Spike
  • Spike
  • 56 inlägg
Ja det var vad jag tänkte också. Han skrev bara att dem inte kommer ta in den och att jag skulle titta på en Denon 1720 istället.
Då står det nog mellan Denon 1920 och Panasonic S-97 om dem nu inte kommer ta in DVD89.
Postad 03 april 2006 - 18:26
Unregistered973
  • Unregistered973
  • 2 349 inlägg
men va fan har snackat med flera på hifiklubben och de sa att de skulle få in den...
Postad 05 april 2006 - 15:36
NiklasK
  • NiklasK
  • 452 inlägg
Hur som helst så finns den nu på Hifi Klubbens hemsida. Här i Karlstad fanns den inte i butik än men den är väl på G så småningom.
Postad 05 april 2006 - 19:36
Spike
  • Spike
  • 56 inlägg
Fyy vad gött! Köper en så fort stockholmsbutikerna får hem den:) Skumt att man fär sådana svar när man mailar till dem ;)
Postad 07 april 2006 - 18:18
wictor
  • wictor
  • 1 451 inlägg
något test på g
Postad 10 april 2006 - 19:12
Spike
  • Spike
  • 56 inlägg
Enligt Hifiklubben på Fleminggatan i Stockholm kommer spelaren finnas i butikerna 1/5.
Postad 10 april 2006 - 19:26
Unregistered973
  • Unregistered973
  • 2 349 inlägg
de skrev (hifiklubben) att de skulle ta in dvd89 i väntan på azur som ev. skulle bli försenad
Postad 10 april 2006 - 20:04
joakim99
  • joakim99
  • 3 433 inlägg
dvd89 ser väldigt intressant ut på pappret tycker jag. Skall bli intressant att se hur den fungerar.
Postad 12 april 2006 - 16:31
Unregistered8f4a4b7a
  • Unregistered8f4a4b7a
  • 315 inlägg
Är det den enda Cambridge som kommer med hdmi eller kommer dom att släppa fler??
Postad 14 april 2006 - 09:30
Boye
  • Boye
Hej Alla
Jeg har bemärkt likheten på bakpanelet med denne dvd-spelaren fra Soken Thai. Även typnumret är likt Soken Thai DV-891
Soken Thai har dessutom en DV-971h-klon på programmet.
Postad 14 april 2006 - 09:43
Unregistered9bf3363c
  • Unregistered9bf3363c
  • 60 inlägg
Undrar bara vad det är för ¤#!"$£@!!1! att den inte stödjer mp3?! Har försökt få mer info om vad för sorts "modifikation" som skall krävas (se hemsidan) men nix. :)
Postad 17 april 2006 - 18:43
wictor
  • wictor
  • 1 451 inlägg
hmm ja det kan man undra !
men detta kommer nog bli bra
Postad 05 maj 2006 - 10:18
Unregistered9fcfa75b
  • Unregistered9fcfa75b
  • 94 inlägg
Den är släppt nu, åtminstone på Hi-Fi Klubben i Linköping! har dock inte köpt den ännu då jag inte bestämt mig för vilken Cambridge förstärkare jag ska ha till.
Postad 05 maj 2006 - 11:25
Audiovector
  • Audiovector
  • 4 884 inlägg
Tror ni att denna har sämre bild än Denon 1920 även om man kör via HDMI???
Redigerat av Audiovector, 05 maj 2006 - 11:36.
Postad 05 maj 2006 - 11:39
Audiovector
  • Audiovector
  • 4 884 inlägg
Finns det några konkurrenter som klarar MPEG4 förresten?
Postad 05 maj 2006 - 14:46
wictor
  • wictor
  • 1 451 inlägg
jag hoppas inte det iaf!!!!
Postad 05 maj 2006 - 15:33
Unregistered341d893c
  • Unregistered341d893c
  • 36 inlägg
Angående Cambridge Audio DVD89 är det någon som vet ifall den skickar signal på dvi och hdmi utgångarna samtidigt.
Redigerat av Unregistered341d893c, 05 maj 2006 - 15:34.
Postad 09 maj 2006 - 14:38
Unregistered40863e2a
  • Unregistered40863e2a
  • 137 inlägg
Halloj!
Är det ingen som testat denna ännu?
Den verkar ju vara ett hett alternativ till Sony NS92v & Denon 1920!!
Speciellt om man vill spela musik också, det skall den ju vara väldigt bra på enligt andra tester.
/Danne
Postad 14 maj 2006 - 09:05
  • 60 inlägg
Det finns f ö ett mp3-hack till DVD89. :wub: Tycker det är så tramsigt att "dölja" funktioner i servicemenyn, förr snarare än senare läcker den informationen ut på nätet och sen är det bara att googla..."Can´t stop the signal, Mal..."
Postad 31 maj 2006 - 10:21
  • 337 inlägg
Ändrade trådens rubrik pga att Oppo DV-970HD har fått en egen tråd :( .
Postad 14 juni 2006 - 19:08
Brinke
  • Brinke
  • 1 352 inlägg
Tog hem en DVD89 i första hand för att spela multikanal SACD & DVDA.
Mycket enkel design men känns ändå rätt gedigen med aluminium front och faktiskt, löstagbar nätkabel! Displayen är omöjlig att läsa om man står lite högre än DVD'n.
Fjärren inte mycke att imponeras av men vissa 7000.- spelare är inte bättre. Menyerna i setupen är klart fula. DVD'n laddar rätt fort, speciellt CD.
DVD89 skulle enligt vissa kommentarer på webben låta bättre än Denon 1920 och även Marantz 6600 som kostar 4000.- mot DVD89's 2500.-
Efter två dagars inspelning var det dax för en mer seriös lyssning. På CD är ljudet väldigt likt Marantz 7400 receiverns interna DAC'ar. Jag föredrar nog ändå DVD89 som låter lite fylligare, 7400 har också en tendens att gröta ihop ljudet lite vid röriga passager. DVD89 har också ett bra driv. Båda låter betydligt bättre än min gamla Sony 20ES CD från 1999. Den låter ljust och analytiskt och man drabbas snart av lyssningströtthet.
SACD låter kanon. Beror nog lika mycket på bättre mastring jämfört med gamla CD inspelningar. Lågbasen är tight och djup. Ljudbilden öppen och detaljerad men det låter aldrig hårt eller vasst.
Inte en tillstymmelse av elektronisk klang. Första DVDA'n är på väg med post så ingen åsikt där ännu.
Imponerande att en DVD spelare med HDMI (och DVI kontakt!) som spelar massor av format också kan låta så pass bra.
Min första DVD från 2002 kostade lika mycket och lät vidrigt på CD.....
Spelaren kan knappast mäta sig med en bra CD men frågan är hur stor skillnaden är så länge övriga komponenter håller medelklass. Man kanske ska låna hem en Cambridge.
Jag har inte utvärderar bilden mer än att den är OK via SVideo.
Postad 15 juni 2006 - 10:31
  • 137 inlägg
Tack för det "Brinke"!
Skönt att se en lite utförligare recention av CD-ljud på DVD spelare..
Är sugen på denna eller Pioneers nya 696:a..
/Danne
Postad 23 juni 2006 - 13:37
reggeman
  • reggeman
  • 67 inlägg
Vet någon om man kan mixa ner sacd och dvd audio ljudet till två kanals med dvd89´n, eller kan man bara köra med 5.1 utgången om man vill få med alla kanaler?
MVH reggeman
Postad 25 juni 2006 - 22:08
Brinke
  • Brinke
  • 1 352 inlägg
Vill man ha fem kanaler så är det väl bara 5.1 utgången som gäller. De flesta SACD & DVDA skivor har så vitt jag har sett både ett 5- och ett 2-kanals spår. Jag tror inte att DVD89 kan mixa in 5-kanalsspårets mitt och bakkanaler i front-kanalerna...
Missforstod jag dig?
När vi ändå berör detta. Mång HiFi traditionalister tycker att ljud i två kanaler är ett måste för seriös lyssing. Jag tycker oftast att femkanalsljudet ger en större musikupplevelse även om ljudet inte är bättre/mer korrekt.
Postad 18 juli 2006 - 16:37
Unregisteredd9379aaf
  • Unregisteredd9379aaf
  • 379 inlägg
Någon som har DVD89:an och kör projektor som har några åsikter runt denna spelare?
Främst då bildkvalitet via hdmi och komponent. Funderar på att köpa, men efter en testkörning
på hifiklubben mot någon samsung-lcd så är jag inte riktigt övertygad..
Postad 19 juli 2006 - 16:27
Brinke
  • Brinke
  • 1 352 inlägg
Inte någon input om detta men det finns ett gäng tester på www.cambridge-audio.co.uk där spelaren får mycker bra kritik både för bild och ljud. Tror inte att en HK 47 är värd dubbla pengen.
Postad 23 juli 2006 - 19:23
  • 379 inlägg
Har en DVD89:a hemlånad nu, och det är ett ordentligt lyft att köra HDMI
med den än att köra komponent med min Azur 540D.. Visserligen 2m HDMI-kabel
och 12m komponentkabel, vet inte hur stor inverkan det har?
Men, någon som har bra koll på specen på ljuddelen, måste ända säg att 540D:n slår
DVD89:an på fingrarna vid ren musiklyssning..
Postad 31 juli 2006 - 18:51
Brinke
  • Brinke
  • 1 352 inlägg
Köpte min DVD89 främst för DVDA och SACD lyssning men måste säga att den låter riktigt bra på CD också. Slår min Marantz 7400 receivers inbyggda DAC'ar och helt klart en Sony 20ES från 99.
På onsdag ska jag jämföra den med en Cambride 540Cv2 ren CD-spelare. Det blir spännande.
Jag har aldrig lyssnat på 540D DVD'n men tror att DVD89 är den ljudmässigt klart bästa DVD'n i sin prisklass (och lite till). Det tog några dar innan den presterade optimalt förståss.
Postad 31 juli 2006 - 19:43
Unregistered973
  • Unregistered973
  • 2 349 inlägg
a fasen det kanske blir att köpa en då...
Postad 09 augusti 2006 - 00:01
Depeche
  • Depeche
  • 571 inlägg
Har precis köpt en Cambridge DVD89 men nu när jag kopplar in den så får jag ingen bild med varken component-kabel eller HDMI-kabel.
Får endast bild med S-Video-kabel.
Någon som har en ide vad det kan bero på ?
Jag har den kopplad till min Panasonic PV600 plasma-tv.
Jag får bild direkt med Component-kabeln när jag kopplar den till min JVC DVD-recorder.
Köpte Cambridgen enbart för att den har HDMI-utgång och så får man inte ens bild. :)
Glöm mitt problem....jag löste det.
Redigerat av Depeche, 09 augusti 2006 - 00:51.
Postad 09 augusti 2006 - 00:14
Fluffy
  • Fluffy
  • 1 653 inlägg
Är det någon som vet om 89:an funkar med fjärren till 540R stärkaren? 89:an tillhör ju trots allt inte Azurserien men jag vill kunna använda stärkarens fjärr till båda.
Eller måste jag vänta på 540D v2 för att få min önskan uppfylld?
  • Nya Hifi-bänken
    joga
    2025-05-02 18:25:13
  • JBL M2 igen…..
    Anton
    2025-05-01 16:07:43
  • JBL M2!!!!!!!
    Anton
    2025-04-30 16:22:03
  • Front Atmos
    Globe
    2025-04-28 19:35:47
  • The12 Passive
    Globe
    2025-04-28 19:33:57
