Sony STR-DG910 ?
139 svar till detta ämne
Postad 03 April 2007 - 19:30
Matskarlsson
  • Matskarlsson
  • 23 inlägg
Har ni hört när Sony STR-DG910 ska släppas i Sverige?
Någon som vet något mer om den?
Posted Image
/Mats
Redigerat av Matskarlsson, 06 April 2007 - 20:54.
Postad 05 April 2007 - 22:45
scenic
  • scenic
  • 1066 inlägg
Du menar väl 910?
Jag tror före sommaren. 510 kommer nu o sen 710.
Info: 910
Audio
Channel Power Rating --- 770 Watts-100 Watts X 7 (8 Ohms, THD 1.0%)
Sound Fields --- Cinema - 3; Music - 4; Auto Format Decoding - 11; 2 Channel - 1
Tuner Type --- Auto Tuning, Direct Tuning, Station Name
Inputs and Outputs
S-Video Input(s) --- 4 (1 Front, 3 Rear)
S-Video Output(s) --- 1 (Rear)
Composite Video Input(s) --- 5 (1 Front, 4 Rear)
Composite Video Output(s) --- 3 (Rear-1 Monitor Output, 2 Video Outputs)
Optical Audio Input(s) --- 4 (1 Front, 3 Rear)
Optical Audio Output(s) --- 1 (Rear)
Coaxial Audio Digital Input(s) --- 2 (Rear)
RCA Audio Input(s) --- 8 (3 Dedicated, 5 Audio/Video)
RCA Audio Output(s) --- 3 (Rear- 2 Audio/Video Outputs, 1 Output)
Multi-Channel Input(s) --- 1 (Rear, 7.1 Channel)
Subwoofer Output(s) --- 1 (Rear)
Headphone Output(s) --- Yes (Front- Gold)
HD Component Video Input(s) --- 3 (Rear)
HD Component Video Output(s) --- 1 (Rear)
HDMI™ Connection Input(s) --- 3 (Rear)
HDMI™ Connection Output(s) --- 1 (Rear) Repeater
Digital Media Port (Input) --- 1
Audio Features
Dolby® Digital Decoding --- Yes
Dolby® Pro Logic® II Decoding --- Yes
dts® 96/24 Decoding --- Yes
dts® NEO:6 Decoding --- Yes
Dolby® Digital EX Decoding --- Yes
Dolby® Pro Logic® IIX Decoding --- Yes
Dolby® Pro Logic® Decoding --- Yes
dts®-ES Decoding --- Yes
Digital Cinema Sound™ Technology --- Yes
Convenience
AM/FM Memory Presets --- 30 FM - 30 AM
Convenience Features
A/B Speaker Switch --- A / B / A+B
Speaker
Speaker Terminal Type --- Screw Binding Posts (A & :D
Video Features
Up Conversion --- Yes (HDMI)
Weight and Measurements
Weight: Approx. 23 Lbs. 5 oz. (10.6Kg)
Dimensions: Approx. 16 15/16" x 6 3/16" x 13 3/16" (430x157.5x351.5mm)
The new STR-DG910 receiver offers HDMI "Active Intelligence," which automatically detects and receives optimal video and audio signals from connected devices. This all-digital path from source to display handles full 1080p HD resolution and up to eight channels of uncompressed audio.Sony's new Digital Media Port adds to the connectivity options with wireless Bluetooth enabled devices, WiFi and other ways to simply connect music sources. Once this accessory is connected, the device is powered and controlled by the receiver.The receivers also include BRAVIA Theater Sync, integrating their operation with a compatible BRAVIA television or video source like Sony's BDP-S300 Blu-ray Disc player over HDMI. With the touch of a button, you can turn on and switch inputs of connected devices automatically.Additionally, Digital Cinema Auto Calibration is included, simplifying multi-channel surround sound setup with the use of a microphone for a balanced home theater experience.Finally, the receivers offer a Portable Audio Enhancer. Plug any digital music player into the receiver and improve its clarity and depth by adding information to the audio signal that had been removed during compression.The STR-DG910 7.1 channel A/V receiver has 110 watts of power per channel, offers on-screen set-up and is XM Connect-and-Play ready.
Redigerat av scenic, 05 April 2007 - 22:59.
Postad 06 April 2007 - 20:57
Matskarlsson
  • Matskarlsson
  • 23 inlägg
Ja självklart menade jag 910 (Ändrade i ämnet så det blev rätt nu)
Tycker ni det är värt att vänta på denna stärkare?
Jag tycker att den ser jättebra ut.
Tror att den skulle passa perfekt till min Sony KDL-40W2000 och Canton Movie 151.
/Mats
Postad 11 April 2007 - 17:15
londonjohan
  • londonjohan
  • 48 inlägg
Denna verkar va riktigt het. Har funderat pa DA1200ES, da jag ar ute efter Bi-Amp pa frontarna. Sen sa sag jag att 1200ES va laskigt djup, sa maste tyvarr skippa den da den inte kommer fa plats i min nyinkopta tv-bank.
Nan som vet om denna kommer ha bi-amp?
Kommer DG910 ha det supersnygga GUI:et som finns pa 5200ES?
/johan
Postad 16 April 2007 - 17:15
Matskarlsson
  • Matskarlsson
  • 23 inlägg
Jag har fått information ifrån Hembiobutiken att förstärkaren ska komma i juni och ha ett utpris på ca 5500kr.
Så nu är det bara att vänta och se.
Brukar dom släppas tidigare i Tyskland?
Postad 19 May 2007 - 20:39
Unregisteredfe07d07a
  • Unregisteredfe07d07a
Tjena
Stärkaren har precis dykt upp på sony.se
Så det kan inte vara långt borta.
Postad 19 May 2007 - 21:54
Unregistered0e3a6535
  • Unregistered0e3a6535
  • 692 inlägg
Tjena
Undrar varför inte 810:an finns med där?
Postad 20 May 2007 - 09:35
simonerlandsson
  • simonerlandsson
  • 383 inlägg
Oerhörda likheter med str-db798. Skillnaden är väl den att denna har hdmi?
Edit: blind.
Redigerat av simonerlandsson, 20 May 2007 - 09:36.
Postad 20 May 2007 - 12:12
scenic
  • scenic
  • 1066 inlägg
Intressant nu har den även Sharc dsp och 6 band equlaiser....synd att den inte hade de nya formaten, lite konstigt när sony är påhejare av blueray
810 släpps inte i Sverige.....
Nu ser man fram emot de nya ES modellerna..
Postad 20 May 2007 - 20:13
  • 692 inlägg
Lite synd för jag hade siktat in mig på 810:an.
Vilka nya format menar du att den inte kan hantera? 8ch lpcm klarar den.
Postad 21 May 2007 - 11:50
scenic
  • scenic
  • 1066 inlägg
Jag menar att den inte har de decodrar inbyggda, Dolby True HD, Dolby Digital Plus and DTS HD decoding.
Annars får man köpa en spelare som har de inbyggda.
Postad 21 May 2007 - 15:57
  • 692 inlägg
Menar du på fullt allvar att pjäsen som vi pratar om 910 saknar allt som krävs för att ens sälja till en efterbliven. Detta är trots allt dess kronjuvel så rätta honom ni som vet,
Postad 21 May 2007 - 16:19
scenic
  • scenic
  • 1066 inlägg
:wub:
Du kan köra 8-kanalig linjär PCM för High Definition-ljud från Blu-ray Disc™-skivor. Njut av 7.1-ljud i CD-kvalitet i varje kanal.
Men det är nog inte "äkta" hd-ljud ror jag?
Den duger åt dig :wub:
Postad 21 May 2007 - 19:40
  • 692 inlägg
:wub:
Vad är dock äkta Hd-ljud? Om det inte är okomprimerad 8-kanaligt via hdmi
Redigerat av Unregistered0e3a6535, 22 May 2007 - 08:06.
Postad 21 May 2007 - 19:54
scenic
  • scenic
  • 1066 inlägg
Edit: fel post
Redigerat av scenic, 22 May 2007 - 19:16.
Postad 28 May 2007 - 13:06
Unregisteredeb2cc158
  • Unregisteredeb2cc158
  • 29 inlägg
Priser
STR-DG510: Ca 2 800 kronor (inkl moms)
STR-DG910: Ca 5 500 kronor (inkl moms)
Lansering på marknaden: STR-DG510 April 2007
STR-DG910 Juni 2007
pressrelease
PRESSMEDDELANDE FRÅN SONY 28 maj 2007
STR-DG510 och STR-DG910:
Vassa receivrar med helautomatisk kalibrering
Sony lanserar två nya receivermodeller med bland annat helautomatisk ljudinställning/kalibrering, en kontroll för alla funktioner samt anslutningar för alla typer av bärbara musikspelare och trådlösa nätverk.
De nya receivrarna STR-DG510 och STR-DG910 följer tätt i spåren på den kritikerrosade och framgångsrika ES-serien. Modellerna är enkla att hantera, har utökade anslutningsmöjligheter och mycket goda prestanda. Allt till ett överkomligt pris. Båda är avsedda att fungera som centralenhet i den allt vanligare kombinerade hemmabio/musikanläggningen.
Receivrarna passar lika bra för den som köper sin första platt-TV som för den passionerade TV-spelsentusiasten. Med Sonys DM Port-system kan man också ansluta mobiltelefon, en Network Walkman eller en dator för att spela upp ljudet från dem via de anslutna högtalarna.
Sony har lagt stor vikt vid att göra allt så enkelt som möjligt utan att kompromissa med kvaliteten. Både STR-DG510 och den mer avancerade modellen STR-DG910 ställer automatiskt in rätt ljudbild, som matchar såväl rummet som högtalarsystemet med hjälp av Sonys Digital Cinema Auto Calibration.
Det behövs bara en kabel för att koppla receiver och TV via HDMI. Med STR-DG910 kan man också styra alla enheter – DVD-spelare, receiver och TV – med en enda fjärrkontroll tack vare den inbyggda Bravia Theatre Sync-tekniken.
Bägge receivrarna är utrustade med digitala HDMI-in/utgångar. STR-DG910 har dessutom en HDMI repeater samt uppkonvertering av analoga videosignaler. Det betyder att det bara behövs en enda kabel för att ansluta allt från DVD-spelare till spelkonsoler och digital-TV-boxar.
Med DigitaI Media Port (DM Port) går det också att spela upp musik från exempelvis en MP3-spelare eller en dator via dessa receivrar. Det finns moduler för såväl Network WALKMAN-spelare som för Bluetooth och Sony Ericsson Walkman-mobiler och andra kompatibla modeller. Dessutom går det att låta musik lagrad på en dator strömma trådlöst via Wi-Fi till både STR-DG510 och STR-DG910.
STR-DG910 har dessutom en rad olika finesser som sällan eller aldrig finns ens på betydligt dyrare modeller, exempelvis uppgraderad videokonvertering till det högdefinierade ljud som finns på Blu-ray-skivorna.
STR-DG510: 5x100 W, HDMI-ingång, DCAC automatisk inställning.
STR-DG910: 7x100 W, HDMI-repeater/uppkonvertering, klar för Blu-ray, DMP,
Bravia Theatre Sync.
Postad 28 May 2007 - 16:23
Unregistered3b7f3b8e
  • Unregistered3b7f3b8e
  • 1169 inlägg
Ehh, what????!!!!
Avd. höra med ögonen?
Postad 28 May 2007 - 17:14
ers
  • ers
  • 492 inlägg
Ehh, what????!!!!
Hehehe...reagerade oxå på detta ;)
Postad 29 May 2007 - 11:50
Matskarlsson
  • Matskarlsson
  • 23 inlägg
http://www.dustinhom...odID=5010111039
Nu finns STR-DG910 att beställa.
Postad 01 June 2007 - 11:14
Unregistered99322caa
  • Unregistered99322caa
  • 470 inlägg
Manual här :
http://www.docs.sony...le=STRDG910.pdf
Svenska marknaden verkar få dem i mitten av Juni.
Jag har beställt en svart och hoppas får den då. Återkommer med testintryck.
Jag tänker bla se om jag kan driva DVI-ingången på en gammal LG RZ-PY10X via en HDMI->DVI-kabel. Och om komponentsignal från en Dreambox 7020 ger fint resultat på HDMI-utgången.
Redigerat av Unregistered99322caa, 04 June 2007 - 14:55.
Postad 06 June 2007 - 03:26
Ghorun
  • Ghorun
  • 686 inlägg
Hade ju bestämt mig för en 1200ES,
men för samma pris kan jag här få en reciever som är mer "framtidssäker" i sina funkationer.
Film, spel via dator och konsol, musik så klart och TV via digitalboxen är vad som kommer gå i anläggningen. Har tänkt ha den i ett antar år framöver, inte tänkt uppgradera så länge jag kan undvika det. Nuvarande stereo-uppsättning har varit oförändrad i 7 år tex.
Har varken HDTV eller nåt att spela HD-format i just nu förutom datorn, men PS3 kommer så snart spelen jag vill ha kommer ut, HDTV när FullHD är något jag känner att jag har råd med.
Har lättdrivna högtalare, Wharfedale Valdus (500or som frontar), så är rätt säker på att den orkar med. Är om jag tappar mycket i ljud, då den bör vara en bit klenare? Så, värt att vänta några veckor?
Känns då som att det är ett bra val på sikt, för att kunna köra Blu-ray/HD-DVD med "HD"-ljud utan att behöva köpa en ny reciever om ett år eller ha en spelare med inbyggd decoder.
Redigerat av Ghorun, 06 June 2007 - 03:29.
Postad 06 June 2007 - 17:09
dogsknob
  • dogsknob
  • 42 inlägg
Någon som har koll på Bravia theatre sync tekniken och vet om det går att kontrollera PS3 BD spelaren via denna?
Letar efter en lösning för att kunna använda min harmony 885 även till PS3 BD spelaren. Vill helst slippa bluetooth fjärren.
/d
Postad 18 June 2007 - 15:02
Matskarlsson
  • Matskarlsson
  • 23 inlägg
Nu ska tydligen den svarta finnas i lager hos Sony.
Silver räknar dom med att få hem första veckan i juli.
Källa: Loudness Hembio.
/Mats
Redigerat av Matskarlsson, 18 June 2007 - 15:06.
Postad 25 June 2007 - 19:27
Matskarlsson
  • Matskarlsson
  • 23 inlägg
Någon som fått hem sin STR-DG910 och kan ge en första recension?
/Mats
Postad 25 June 2007 - 23:22
  • 470 inlägg
Jag har haft en svart på order länge så dyker de upp borde jag märka det.
Postad 27 June 2007 - 11:46
Matskarlsson
  • Matskarlsson
  • 23 inlägg
Vart har du beställt ifrån?
Jag har beställt en silver ifrån Webhallen.
Mats
Postad 27 June 2007 - 14:57
Unregistered22960a33
  • Unregistered22960a33
  • 337 inlägg
Har försökt läsa mig till detta men får inte ihop det.
Hur är det med videokonverteringen. Kan den skicka ut ALLA signaler via HDMI eller är det någon typ som inte kan konverteras eller skickas ut via hdmi?
Postad 28 June 2007 - 17:17
Danne736
  • Danne736
  • 151 inlägg
Nej,det ska gå med alla signaler genom hdmi.
Postad 28 June 2007 - 20:04
  • 337 inlägg
Då är den mycket intressant. Vill ha en reciver som kan agera videoväxel åt alla typer av signaler så jag bara behöver köra HDMI till TVn. Ser onekligen prisvärd ut.
Postad 28 June 2007 - 22:28
Unregistered3c45c601
  • Unregistered3c45c601
Sant, någon som testat den ännu? Skulle vara skoj att läsa lite synpunkter innan man slår till.
Postad 29 June 2007 - 08:10
UA322
  • UA322
  • 98 inlägg
Jag fick hem min i mitten av veckan och har inte hunnit testa så mycket men inga problem att koppla digitalboxen via komponent för att sen köra upp via HDMI till plasman. Däremot har jag haft lite strul med datorn. Den är kopplad via DVI-D-HDMI och det fungerar bra när jag slår på datorn och har förstärkaren igång. Om jag däremot sätter datorn i viloläge och slår igång den igen så tappar den signalen. Tror iofs att det problemet ligger mer i datorn än i förstärkaren... :)
I stort är jag väldigt nöjd än så länge men som sagt har jag inte haft tid att leka med den så mycket!
Postad 29 June 2007 - 11:15
  • 337 inlägg
Du skulle inte kunna lägg upp en bild på fjärrkontrollen? Är väldigt nyfiken på hur den ser ut och om den kan styra min Sony 40W2000.
Postad 01 July 2007 - 11:14
Danne736
  • Danne736
  • 151 inlägg
Är det en svart du har UA322 eller har du en i silver?
Postad 01 July 2007 - 21:51
UA322
  • UA322
  • 98 inlägg
Har varit borta hela helgen men ska försöka fixa det i morogn, den jag har är den svarta, den i silver kommer inte för än i mitten av Juli
Postad 02 July 2007 - 15:10
Danne736
  • Danne736
  • 151 inlägg
Skulle inte den i silver komma i början av juli???
Postad 03 July 2007 - 10:19
  • 470 inlägg
Mats
Jag får min genom svenska Sony, Svart skall vara på g inom en vecka, silver ett par veckor senare verkar det som. Från början skulle svart komma i mitten av Juni så allt är väl försenat. Men det finns väl firmor som gråimporterar från andra länder så det kan väl finnas butiker som redan har dem. Jag kommer inte vara någon bra testpilot till att börja med, har knappt högtalare så det räcker till alla kanaler och definitivt inte för att säga vad 910:an går för ljudmässigt. Men är mest nyfiken nu hur det ser ut när den konverterat komponentsignal från Dreambox 7020 till HDMI :D och om min veteran LG PY10X-plasma kommer acceptera HDMI-signalnivåerna från denna Sony-burk på sin DVI-ingång.
Redigerat av Unregistered99322caa, 03 July 2007 - 10:22.
Postad 03 July 2007 - 17:10
Danne736
  • Danne736
  • 151 inlägg
Jag har också bestämt mig för den här men jag beställer den i slutet av juni.
Postad 04 July 2007 - 20:51
thompaa
  • thompaa
  • 98 inlägg
Den verkar ju inte ha analog 5.1 ingång, det gör att den faller bort för mig.
Analog 5.1 ingång är ju det smidigaste sättet att få 5.1 ljud från datorn (vanlig optisk/coax digital funkar bara vettigt för DVD, inte för spel). Och HDMI för ljud vill jag inte vara beroende av, för då måste jag köra bilden via receivern, det vill jag inte vara beroende av.
Postad 06 July 2007 - 14:50
  • 470 inlägg
Nu har min dykt upp så det blir en del intressanta prov i kväll.
16:41:
Ehmmm....ser nu de har skickat en Silver.
Bra för jag ville egentligen ha en sån men svart skulle komma 14 dar tidigare så då beställde jag en sån dvs jag trodde "S" betydde svart :D
Det betyder att silver finns i landet bland det som distribueras ut nu. Det här var inte via butikskanaler.
Däremot är fjärrkontrollen svart (se mitt foto). Knapparna är gjort av ett självlysande gummi som lyser i mörkret efter att ha "laddats" med dagsljus eller en lampa.
Men i praktiken är det väl mest siffertangenterna och volymkontroll /kanalval som är lätta att hitta i mörkret eftersom den beskrivande texten för de flesta knappar inte belyses, dvs en fattigmans belysnings-lösning. Bättre än inget alls men inte så mkt bättre.
Receivern ser ut som på produktbilden:
Posted Image
Redigerat av Unregistered99322caa, 12 July 2007 - 20:11.
Postad 06 July 2007 - 20:33
Matskarlsson
  • Matskarlsson
  • 23 inlägg
Vart beställde du din?
Vad fick de betala för den?
Kan du ge en första recension av den?
/Mats
Postad 06 July 2007 - 22:02
  • 470 inlägg
Jag jobbar på ett Sony-relaterat företag så det är intern personalshop. Men det går via ordinarie leveranskanaler så butikerna får väl prylar ungefär samtidigt.
Ups and downs, provade att mata en LG PY10X 42" plasma (DVI-ingång) via HDMI-DVI-kabel men den visar bara svart skärm, kanske klarar den inte kopieringsskyddet (HDCP) eller signalnivåerna är inkompatibla. Den TV:n fungerar bra med HDMI från en Panasonic S97 DVD-spelare men alltså inte från 910:an.
På en annan skärm (LG PX4R, 42" plasma) som har HDMI fungerar det bra.
Sensationell skärpa från Dreamboxens komponentsignaler omvandlade till HDMI så tydligare icke-HD-TV har aldrig setts från en sådan box.
Redigerat av Unregistered99322caa, 09 July 2007 - 14:38.
Postad 09 July 2007 - 16:20
boa16
  • boa16
  • 89 inlägg
Någon som vet vilken version det är på hdmi ingångarna.
Postad 10 July 2007 - 09:01
dogsknob
  • dogsknob
  • 42 inlägg
Läste på avsforum att det är 1.2a
/d
Postad 10 July 2007 - 09:46
boa16
  • boa16
  • 89 inlägg
Då vet ja, är riktigt sugen på en sådan undrar om det går att köra 4ohms högtalar på den läste lite i manualen som jag laddat ner men kunde inte hitta något om detta.
Redigerat av boa16, 10 July 2007 - 09:48.
Postad 10 July 2007 - 11:29
maep
  • maep
  • 25 inlägg
DG910 recenseras på senaste nr av Hemmabio. Där får den för det mesta bra kommentarer och rekommenderas varmt ;)
Postad 10 July 2007 - 11:51
boa16
  • boa16
  • 89 inlägg
Vilket nr är det? Är det numret som det står bla 5 Biobasar & Playstation 3- Lösningen på omslaget.
Redigerat av boa16, 10 July 2007 - 12:44.
Postad 10 July 2007 - 16:45
Dum-Dan
  • Dum-Dan
  • 269 inlägg
Vad är den största skillnaden på denna och DA-3200, någon som kan beskriva dessa för mig, blir nog någon av dessa två. Blir min första förstärkare så jag är noob! :)
Kan ju tillägga att jag har en Sharp 37GA9E och som dvd; Sonys NS76. Kommer även köpa nya högtalare när budget tillåter med, blir nog Qln Artech 8, så jag skippar att skaffa en baslåda. så den behöver jag inte bekymra mig över i förstärkar-valet.
Har inga spel-konsoler heller...
Vilken tror ni passar bäst, och varför?
Postad 11 July 2007 - 16:29
maep
  • maep
  • 25 inlägg
boa16 Postat Igår, 13:51
Nej, det numret som kommit igår på butiken, fast jag fick den i fredags (prenumerant).
Postad 11 July 2007 - 23:24
micao
  • micao
Hej! Är ny här på forumet och inte så insatt i dehär med förstärkare. Funderar även på denna alternativt STR-DG710. Det jag själv undrar över är om jag verkligen behöver uppskalning till 1080p som 910 har eftersom min nästa dvd samt digitalbox kommer att ha det... En annan sak som jag undrar över är att 710 har Högtalarväljare A/B medan 910 har Högtalarväljare A/B / A+B Min fråga tille er nu är att vad är den egentliga skillnaden mellan dessa? Har tänkt använda receivern både för film och musik....
Postad 15 July 2007 - 22:45
  • 337 inlägg
Tack för bilden på fjärren. Av vad jag kan tyda så ser den ut att kunna styra min TV också.
  • More is Always Better
    2026-08-29 18:47:07
