Marantz UD9004
9 svar till detta ämne
Marantz UD9004 (Blu-ray & DVD-spelare) 5 7.5 (1) Inga priser
1 relaterade trådar
Postad 19 August 2009 - 00:19
Now when the new medium is fixed and functionality for Blu-ray is fully specified including BD-Live Profile 2.0 it is time for Marantz to bring the ultimate player for picture and sound.
Doesn’t matter what kind of disc will be insert, BD or DVD, CD or even SACD the performance will be outstanding and will bear even the most challenging tests of the most critical video- and audiophiles. UD9004 will give you state of the art quality of both audio and video.
Starting with the very heavy loading mechanism equipped with a rigid aluminium tray, developed by our top engineers, eliminating distortion caused by vibration of the mechanism. On the video side the UD9004 makes use of the Silicon Realta Optix HQV processing technology derived from professional broadcast technologies. With true 10-bit processing for Detail Enhancement, Noise Reduction, Pixel to Pixel Film Mode Detection, De-interlacing and scaling and other treatments, the picture from DVD and Blu-ray is simply astonishing.
The UD9004 has a copper plated chassis for best grounding at any point and is equipped with a strong power supply only feeding the analogue audio boards with clean current using a Toroidal transformer and customized capacitors. The circuitry uses the famous Marantz HDAM-SA2’s for all channels ensuring fast, precise and large bandwidth signal amplification.
A dual HDMI output makes it possible to output a dedicated video and a dedicated audio signal to their output source, minimize the deleterious effect on the audio and video and reducing the signal degradation by shorter route and less processing. Be prepared for an exceptional presentation – get the third dimension into your reproduction, get the depth for your image and sound stage – make it 3D, make it as real as possible.
UD9004 Users manual
Källa: Marantz.com
Redigerat av -Palle-, 19 August 2009 - 00:49.
Postad 19 August 2009 - 10:30
jonasprivate
  • jonasprivate
  • 11286 inlägg
wow vilken spelare men den lär kosta en slant,ska väl utmana Denon först och främst ?
Postad 19 August 2009 - 12:01
Vad jag har förstått så är den här och Denons värsting DVD-A1UD "syskon" modeller och delar en hel del teknik med varandra.
Postad 19 August 2009 - 14:22
jonasprivate
  • jonasprivate
  • 11286 inlägg
Okej det visste jag inte,men visst verkar det va en grym spelare.
Hade jag haft dom stålarna hade jag inte tvekat. ;)
Postad 23 August 2009 - 22:35
foggemannen
  • foggemannen
  • 47 inlägg
vilket ###### aaaaas!! grattis till den som köper en sån. jag skulle inte tvekat en sek om jag hade råd
Postad 11 December 2009 - 17:52
Omar Brännström
  • Omar Brännström
  • 141 inlägg
Test här http://www.stereopla...04_6107446.html
Omar Brännström
Postad 04 February 2010 - 17:30
Hays
  • Hays
  • 1192 inlägg
Snacka om best. Skulle man ha denna ses det väl nästan som obligatoriskt att låta den ta hand om ljudet och skicka det vidare analogt, finns väl knappast någon förstärkare eller försteg som kan ta hand om det lika bra.
Postad 04 February 2010 - 18:53
AckeOfSweden
  • AckeOfSweden
  • 105 inlägg
Ligger runt 75000:-
Postad 05 February 2010 - 00:40
tomano58
  • tomano58
  • 3281 inlägg
Ligger runt 75000:-
https://www.prisjakt...kt.php?p=469123
Postad 05 February 2010 - 09:44
Hays
  • Hays
  • 1192 inlägg
Jag fattar verkligen inte alls vad acke menar med sitt inlägg
