Marantz UD 8004
5 svar till detta ämne
Marantz UD8004 (Blu-ray & DVD-spelare) 6 7.5 (1) Inga priser
1 relaterade trådar
Postad 05 January 2010 - 11:38
  • Audio Code 3
  • 12561 inlägg
Spelar Blu-ray, CD, SACD och DVD-Audio, Profil 2.0 spec, HDMI 1.3a och 1080p/24fps spec
Kostar £2300....
While Blu-ray playback is the focus, Marantz promises 'reference standard' CD playback and improved, upscaled DVD images thanks to the Anchor Bay ABT2015 processor.
The UD8004 boasts a newly developed, proprietary transport, that aims to deliver an ultra-rigid platform to remove all vibration.
Three separate audio circuit boards deal with the sound, with 192kHz/24-bit Burr-Brown DACs taking care of the all important conversion.
Elsewhere on the 'M1 chassis' you'll find a pure direct button and an SD card slot for playback of WMA, MP3, AVCHD and JPEG files.
Postad 03 April 2010 - 13:59
jln
  • jln
  • 465 inlägg
Hur du gör denna spelare regionfri på DVD:
How to set RF for 8004 and 9004 DVD part?
1. Press together “STOP” and “PAUSE” buttons of main unit.
2. During pressing these buttons, insert AC power plug to the rear panel.
(Check!)
The unit power will be “ON” automatically (“STAND-BY” will be skipped)
As well as normal mode, unit FL display shows
“BrandName”  “DISC MODE”  “Please wait…”,
after that the FL display shows “NO DISC”
3. Open the disc tray by “OPEN” key on the unit.
4. By 10 keys of remote hand set, press these numeric keys.
7  3  1  9  4  6  2  8
(check)
After the setting is done and around 5 second later, the disc tray will close automatically
Then it sooner becomes to “STAND BY” mode automatically
Finished!
How to confirm the setting?
1. Turn on the power of unit as well as normal usage
2. Press 3 buttons “STOP”, “SOUND MODE”, “OPEN” (of the unit) together few second
(“SOUND MODE” button is located inside of Hidden panel)
3. Confirm the FL display. It must be showed “ B A 2 “
Tip: if you try this confirmation mode as normal setting, the FL display shows just “B 2”.
Confirm the letter of “A” before “2”. It means “ALL”
How to cancel (release) this setting? (to back default setting)
There are two ways
1. Use “Initialize” of “SET UP” menu in the OSD (refer the user guide)
2. Use hidden key combination command.
3. Press 3 buttons on the unit together few second “PLAY”, “SOUND MODE”, “OPEN”
4. FL display shows “INITIALIZING” after few second, it will show “INITIALIZED
Postad 25 April 2010 - 07:10
jln
  • jln
  • 465 inlägg
Nu har det kommit ny mjukvara att tanka ner. Detta är vad som uppdaterats:
Improvements have been following the firmware update dated April 23, 2010.
* Improved behavior of certain Blu-ray Disc.
* BD Live Blu-ray in a particular operation was improved.
* CD GUI Enhanced CD GUI bug when playing distorted screen.
* Various other operating improvements.
Postad 28 July 2010 - 00:36
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Nu kommer ju även UD5005 och UD7005.
http://www.component...showtopic=12489
Postad 28 July 2010 - 09:59
DB9
  • DB9
  • 616 inlägg
Intressant!
Har funderat på en Oppo ett tag, men om dessa är lika kapabla (och går att regionbefria) så är det något att överväga då jag har en Marantz förstärkare. Rent estitiskt blir det snyggt ;-) Dessutom 3D förberedda.
Jag har fått för mej att Marantz nuvarande "UD" spelare INTE kör SACD i multikanal, bara två-kanal. Låter i och för sej konstigt, men i alla fall. Någon som kan bekräfta eller förneka?
Postad 28 July 2010 - 13:31
jln
  • jln
  • 465 inlägg
Jag har själv en UD8004 och den spelar SACD multikanals. Jag kör bara analogt ut för kör du via HDMI konverteras signalen till 16 bit/44.1 kHz.
  • More is Always Better
    2026-08-29 18:47:07
