Mitsubishi HC7800, DLP för 3D-älskare
20 svar till detta ämne
Postad 19 October 2011 - 11:14
  • 10396 inlägg
Nu finns det en preview på denna på cine4home.de
http://translate.goo...0%20Preview.htm
Mitsubishi to Unveil HC7800D
Evan Powell, August 25, 2011
ProjectorCentral.com
Mitsubishi is planning to unveil a new mid-priced 3D 1080p home theater projector at CEDIA on Sept 8. This all new DLP-based projector will be rated at 1600 lumens, 30,000:1 full on/off, and 700:1 ANSI contrast. The MAP price will be $3,495.
We've had an advance look at the HC7800D, enough to pass along some initial impressions but not enough to do a full review. Two items stand out as particularly remarkable. First, the 3D image is as clean as we've yet seen. Cross talk is reduced to somewhere between negligible and completely invisible depending on how good your eyes are, and the bizarre motion artifacts that plagued many of the first generation 3D machines are gone entirely. The rapid rowing sequence in The Ultimate Wave: Tahiti looked even tighter than it did on the Panasonic AE7000, which itself is a major step in performance beyond earlier 3D projectors.
Second, the 2D to 3D conversion is remarkable. This is the first time we've seen 2D to 3D conversion that was worth the bother. Normally that conversion provides just enough increase in depth perspective to be noticeable but not enough to be impressive. As is true of all 2D to 3D conversions, the depth remains entirely behind the plane of the screen. But on the HC7800D, so much depth perspective is achieved that it begins to resemble authentic 3D rather than a conversion. We'd need to spend more time exercising it before making any final assessment, but from what we saw, this may be the first implementation of 2D to 3D conversion that I would actually use in my own theater.
If you are going to CEDIA and you are interested in 3D projection, we would suggest that you not miss the HC7800D in the Mitsubishi booth. We won't be able to get extended stick time with a review sample until after CEDIA, but we are anxious to set it up against the Panasonic AE7000 and the new units from Epson and Optoma. From what we have seen so far, the HC7800D could give the competition a serious run for the money. It is expected to ship in late November. We will have a full review of the HC7800D posted here in late SeptemberPostad bild
Postad 19 October 2011 - 17:27
30K-klassens dark horse det här...tror det kommer finns mkt att gilla runt denna, bra DLP kan ge en transparens och kontroll som jag ännu inte sett hos de andra teknikerna - oavsett pris.
Försäljningsmässigt tror jag det kommer bli mindre lyckat dock, ligger nog lite för nära en proj som t.ex JVC X30, tyvärr.
Postad 07 December 2011 - 00:16
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Om det som står i cine4homes review bara är i närheten av sanningen så är iallafall jag idel öga för att ta den i beaktning.
Så pass mycket att jag kanske tom kan göra avkall för linsminnesfunktionen.
De plus jag kunde utläsa:
- 3D brillor med ny teknik (Ferroelektriska flytande kristaller) som är upp till 100 ggr så reaktionssnabba som dagens brillteknik (= de kan dra ner tiden då du tappar ljusstyrka o ta bort fenomenet som gör att ghosting uppstår) Detta är tänkt att göra ghosting till ett minne blott samt ljusstyrkan kommer väldigt nära de teoretiska 25% man kan uppnå - det pratas om ca 20% som en uppskattning vilket sägs vara ca 100% bättre än alla andra 3D projar.
- Mitsubishis optik = skärpa (ED-lins)
- 1500 ANSI - bra tryck även fär lite större dukar även i 3D (i kombo med ny brillteknik speciellt)
- optisk lens shift
- Checker board contrast 700:1 pratas det om och referensnivå på plasticitet i bilden
- Full CMS
- Läste på annat ställe att 2D till 3D interpoleringen var fantastikst bra, nästan så att det såg ut som äkte 3D material....DET hade jag gärna sett :wub:
- Efter kalibrering upnås väldigt bra resultat sånär som blått som de inte lyckas träffa perfekt
- Saknas ca 8% rött i gråskalan i förvalt läge vilket lätt kalibrerades på plats
- Väldigt bra förinställd gammakurva (2.2) men även möjlighet för perfektion via kalibrering
- 3stegs bländare utan "bildpump", men visst en native contrast på 50000:1 som JVC x30 är ju ännu trevligare
- 3D är iaf det område där de höjer den till skyarna som mest....hela för-reviewen höjer den iofs nästan så man tror de har aktier i Mitsubishi :) men hur som helst så verkar den synnerligen intressant i mina 3-d fanatiska ögon
Som sagt - hade de lagt på ett bildminne för aspect ratio tror jag de andra hade fått riktigt tuff...nu får de nog bara det tufft ;)
Boogie - tror på allt han läser ^_^ -man
Redigerat av bigbadboogie, 07 December 2011 - 00:18.
Postad 07 December 2011 - 12:55
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Bugger.
Verkar inte som mitsun kommer in förrän januari nästa år.
http://www.projektor...bishi-hc7800dw/
Väldigt lite fakta om den på nätet bortsettt från cine4home reviewen.
http://www.mitsubish..._projector.html
http://www.mitsubish...ils/hc7800.html
http://www.xtremepla...?topic=103316.0
http://www.hifi-foru...d-94-11356.html
http://www.hjemmekin...nfo.aspx?ID=210
Verkar som de skjutit lansering från oktober-november-december-> januari så man börjar undra vad som händer eg.
Förstår dock inte det svala intreset - 3D is da shit ju :)
Postad 07 December 2011 - 12:59
B8
  • B8
  • 4536 inlägg
Ja precis, 3D is shit! :P
Postad 07 December 2011 - 16:08
Unregistered4f83064c
  • Unregistered4f83064c
  • 690 inlägg
Kan bara hålla med. 3D är hur coolt som helst :) :wub:
Postad 11 December 2011 - 22:12
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Nu verkar den svarta finnas i lager.
Borde inte dröja länge förrns man ser något mer om den :)
Postad 19 December 2011 - 12:18
bigbadboogie
  • bigbadboogie
  • 819 inlägg
Verkligen ingen som sett HC7800 i 3Dännu?
Boogie
ps
Kollade på LGs 3D mobil igår....coolt att se 3D utan brillor och med riktigt skapligt djup i bilden :)
3D var dock väldigt beroende av hur (lite) man tiltade telefonen.
ds
Redigerat av bigbadboogie, 19 December 2011 - 12:20.
Postad 10 February 2012 - 16:30
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Nu har Projector reviews recenserat HC7800: http://www.projector...7800D/index.php
Mitsubishi HC7800D Projector Highlights
  • 3D capable, includes supporting both 720 and 1080i/1080p 3D, including Blu-ray 3D and all DirecTV 3D content
  • Physically small for a home theater projector, sorta cute!
  • Really good color controls - calibrates well
  • Very good lamp life - up to 5000 hours
  • Excellent warranty!
  • Creative Frame Interpolation for smooth motion
  • Sold through authorized local dealers
  • A really good projector for smaller screens!
Postad 22 February 2012 - 05:53
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
http://www.mitsubish...d_features.html
Postad 01 March 2012 - 12:08
7.1
  • 7.1
  • 112 inlägg
http://www.trendhifi.de/491757.html ==> 2.500 € - Räkna med en kurs om 9,00 SEK, så blir det klart lönt att importera i dagens läge. Kanske uppgradera projektor istället för att byta lampa på den gamla projjen :P
Redigerat av 7.1, 01 March 2012 - 12:12.
Postad 13 June 2012 - 17:23
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Slutsatsen utav Cine4home's test utav HC7800D:
"5: e Slutsats:
Even in the two Cine4Home previews showed that it is an exciting and powerful 3D-capable projectors with reference potential. With completely new technology in conjunction with the glasses for 3D anyway currently superior DLP projection shows the Mitsubishi HC7800, the LCOS competition still is not unchallenged in all domains.Even this final test shows that confirm in 3D a lot of theoretical advantages, in practice: In bold colors allows the HC7800 a very high light output and combines them in 3D with an artifact free and eyes-friendliness without headache side effects. For budding 3D fans, this projector is therefore recommended that if you can get used to the glasses. In addition to the glasses also offer 3D presets for improvement for future generations, so that we can attract even without calibration, and contrast enhancement, the maximum potential in good light from the projector color tolerances. Of all the affordable 3D Studio Shutterbeamern in our test, we would currently choose the Mitsubishi when it comes to enjoying the relaxed third dimension.Our tests also show that the projector can be calibrated well in both 2D and 3D, as I heard it for the price range. Even without calibration provides an almost exact matching of the colors and gamma presets for accurate image reproduction, apart from a small blue weakness. Praiseworthy in this context, the fact that Mitsubishi's first integration of a full-fledged and well-working color management and gamma expands the equalizer is has. Also holds the perfectionist demands HC7800 Sun booth is not quite as perfectionist but you should be with the black level, because here we are dealing with a weakness of the projector. Even when the dynamic iris its dynamic range up to five digits extended, so goes the native share is not sufficient to scenes with a high proportion of black completely free of gray haze map (Black fetishists are after, we set aside prior to D-ILA best.) But scores of HC7800 with a very high and DLP Inbildkontrast typical in middle and light mixed scenes, they work even in 2D extremely deep and spatially reference the (LCOS) competition in their place, if the room permits. Because of the high spatial Inbildkontrast may produce little flare.Also upgraded is the big-screen enjoyment by the high (also typical for DLP) optical focus of the projector, which separates even the smallest details clearly. Although we had been promised by the lens with ED glass element even less color fringing, but the result is still at a significantly higher level than most competitors 3Chip. In optimized rooms and the high ANSI contrast makes for a better sense of focus, as high-contrast boundaries can be mapped steeper. "Last but not least," you have the motion blur is not ignored, because the 120Hz interframe calculation provides with moving elements and panning for an additional increase in sharpness achieved by the combination of the Trident processor, fine tuning options and DLP response time impressive results . In this regard, Mitsubishi has remained true to his line.Overall, the Mitsubishi HC7800 made a good living rounder with compact dimensions, living room-friendly paints and low volume. The remaining weaknesses (in the list) are all typical of DLP, so that the manufacturer no representations regarding the development can be made. But the strengths of the HC7800 DLP are exclusive, which is why many home theater enthusiasts still swear and not without good reason on this technology. The engineers have once again shown that they select the technology to reach the specifications of the projector, which in this model is clearly designed for a possible compromise 3D. So if you are looking for a powerful entry into the third dimension in combination with a good all-round performance in 2D, which should take a closer look at the Mitsubishi HC7800 a dealer nearby.
6th Assessment+ Very interframe calculation in 2D & 3D+ Good build quality, compact size+ Very quiet+ Good optical color matching+ A lot of image parameters+ Good factory settings+ Few DLP artifacts+ Eye friendly 3D+ Sharp picture- A little placement flexibility (despite lens shift)- Black- Illumination- Slight color fringing, depending on the zoom- DLP typical artefacts- Spectacle Lens size and weight- Weaknesses in the de-interlacing- Infrared remote control transmitter interferes
Postad 03 February 2013 - 21:12
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Nu har tyskarna fått tokfnatt och säljer ut denna Mitsubishi HC7800W:
http://www.beamer-di...=Preisvergleich
Postad 06 February 2013 - 18:52
Keiser
  • Keiser
  • 76 inlägg
Så, frågan är hur bra denna projektor är, jämfört med tex Epson TW6000/6100? Någon som sett den prestera? Börjar bli dags att köpa ny och inte riktigt hittat någon som uppfyller kriterierna ...i rätt prisklass. Använder lensshift idag så ser gärna att den nya också har det. Kört LCD förut och är lite nyfiken på DLP, ser inte regnbågarna heller så inget som stoppar (måste dock verifiera så sambon inte har problem). Osäker på 3D men generellt är det ju trevligt om den ger möjligheten. Denna kostar dryga 10 000kr nu så den hamnar definitivt bland de intressanta.
Varför är den inte populärare?
Postad 06 February 2013 - 19:21
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
För att den har kostat för mycket för att lira med de andra i 25000 kronorsklassen tidigare?
Postad 07 February 2013 - 20:03
Keiser
  • Keiser
  • 76 inlägg
Hehe, som man frågar får man svar. Ok, bör den sälja väsentligt bättre nu då med justerat pris? Är den ett kap jämfört med Epsons 6100 tex? Som jag förstått det är lenshiften ganska begränsad så den passar kanske inte ändå :(
Postad 07 February 2013 - 20:16
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Svårt att sägafaktiskt den skiljer sig nog en aning ifrån epsonmodellerna.Men det är inget snack om att den är ett kap för 11000 kronor.Den största begränsningen är väl att den kanske bara mäktar med att fylla moderata dukstorlekar med tillräckligt ljustryck.
Postad 10 February 2013 - 12:06
Keiser
  • Keiser
  • 76 inlägg
Ja det lät väldigt bra (för min del) till en början, en projektor som legat i prisklassen över nyligen och som hade både lensshift och bra 3D. Jag kör för närvarande 120" och använder en del lensshift så den passar kanske inte så bra in i setup:en som jag först trodde. Är medveten om att jag kan få kompromissa på lensshift och byta placering. Ligger och bevakar lite för att se om fler projektorer kommer ner i mitt spann eller att det släpps någon ny intressant.
Postad 10 February 2013 - 13:21
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Har du ordentlig mörkläggning där hemma så kan den nog funka kanske.Men inte till större än 120" dukar skulle jag tippa på!.
Postad 15 February 2013 - 19:03
UprightCitizen
  • UprightCitizen
  • 955 inlägg
Hur är svärtan? Om man jämför med modeller som ligger i nuvarande prisklass?
Postad 19 February 2013 - 12:09
dannep
  • dannep
  • 375 inlägg
Blivigt riktigt sugen nu när priset gått ner så pass mycket. Gäller nog att vara relativt snabb medans det finns kvar projektorer i lager.
Har varit nöjd med tidigare modeller ifrån samma tillverkare vad gäller bildkvalité så tvivlar inte på att jag kommer bli det även med denna. Självklart finns det bättre bilder, men frågan är om det finns någon som har mer "bang for the buck"
Redigerat av dannep, 19 February 2013 - 12:11.
