Blu-Ray framflyttat igen
446 svar till detta ämne
#401
Postad 07 March 2006 - 00:36
Guppa
Guppa
Bredbildad
731 inlägg
Mkt intressant att se priserna på Blu-ray från DVDSoon.comThe Fifth Element - $25.98CAD = 180SEK 50 First Dates - $25.98CAD = 180SEK Hitch - $25.98CAD = 180SEK House of Flying Daggers - $25.98CAD = 180SEK Knight's Tale - $25.98CAD = 180SEK Kung Fu Hustle - $25.98CAD = 180SEK Legends of the Fall - $25.98CAD = 180SEK Resident Evil: Apocalypse - $25.98CAD = 180SEK Robocop - $25.98CAD = 180SEK Triple X - $25.98CAD = 180SEK The Last Walt - $25.98CAD = 180SEK Crash - $25.98CAD = 180SEK Lord of War - $25.98CAD = 180SEK The Punisher - $19.98CAD = 140SEK Saw - $19.98CAD = 140SEK Species - $25.98CAD = 180SEK S.W.A.T. - $25.98CAD = 180SEK Terminator 2 - $19.98CAD = 140SEK CAD = Canadian Dollars och 1 CAD kostar idag 6.90kr Att de strukit över dyrare priser kan ju betyda att priset faktiskt är lägre än man tidigare sagt. Kan för övrigt tillägga att jag har handlat därifrån flera gånger och det har fungerat utmärkt.
Redigerat av Guppa, 07 March 2006 - 00:40.
#402
Postad 09 March 2006 - 14:06
Über-Guru
12561 inlägg
Region-free HD DVD to debut in Europe 'next month' HD DVD may come to Europe earlier than expected, with an initial, low-level roll-out due in April, Reg Hardware has learned. Such a rapid launch after this month's US debut of the next- generation optical disc format is apparently possible because of a lack of region-coding in early pre-recorded media and players. The first HD DVD-equipped system to ship in Europe will be Toshiba's Qosmio G30 notebook, which the company launched today. So Toshiba claimed, at any rate. Officially, the company did not say when the machine will ship, though insiders put the release in the April timeframe, they also suggested media would be available at the same time. The debut of pre-recorded HD DVD media looks set to be a low-key affair, however. Toshiba confirmed the G30's built-in HD DVD drive will not check for region encoding, allowing it to play HD DVDs bought in the US and elsewhere, company officials said. How come? Early HD DVD releases are almost entirely back-catalogue movies which the studios are less concerned about co-ordinating local release dates than they are will films that have yet to make it onto home-oriented media. Then, maybe, region coding will kick in. That said, Toshiba insiders also suggested locally supplied HD DVD content would also be available in the April timeframe - one of the reasons, they implied, why the company has chosen to ship the new Qosmio at that point. Interestingly, Sony hinted last Autumn that Blu-ray Disc would abandon region coding, at least as far as games go, though there's been no indication that the policy put in place with the advent of DVD would not be extended to next- generation optical disc formats. Both the HD DVD and Blu-ray Disc camps are expected to make major announcements at the CeBIT show in Hannover, Germany this week. The G30, meanwhile, builds on previous models with the incorporation of an HDCP-compliant HDMI output port and a 17in 1920 x 1200 TruBrite LCD screen ready for 1080p HD content. The display is driven by an Nvidia GeForce Go 7600 graphics chip with 256MB of dedicated video RAM. The notebook has a 2GHz Core Duo T2500 processor on board, 1GB of DDR 2 SDRAM, an 802.11a/b/g Wi-Fi radio and Bluetooth 2.0. It has twin analogue and digital TV tuners, and a Dolby Home Theater-certified audio system based on Dolby virtual speaker technology, Dolby Pro Logic II decoding and Harman Kardon speakers. ® http://www.reghardwa...d-dvd_roll-out/
#403
Postad 10 March 2006 - 14:19
Unregistered7c5139ba
1310 inlägg
Lurade lite på det här med 1080i eller 1080P som utsignal från spelarna.
När det gäller filmat material borde det egentligen inte spela så stor roll, eller?
Det sägs ju att de första HD DVD-spelarna bara kommer kunna skicka ut en 1080i-signal, men filmerna ligger lagrade i 1080P@25 (PAL-länder). Med tanke på att det är filmat material med 25 fps, så borde uppspelning med 50 Hz bli i stort sett samma varken man väljer 1080i eller 1080P, om man har en 1080-bildvisare?
I och med att ursprungsmaterialet bara ligger med 25 fps, så förlorar man ju ingen information med en 1080i-signal i 50 Hz ut från spelaren. Den tar ju bara en helbild och delar upp i två halvbilder och skickar ut signalen i dubbelt så hög hastighet, vilket ju i praktiken blir samma!?! Projen tar ju dessa halvbilder och deinterlacear tillbaks igen. Det är enkelt att deinterlaca filmat material.
Det enda kravet är väl egentligen att det sitter en bra deinterlacer i projen om man ska mata med 1080i i så fall? Annars tycker jag slutresultatet på duken borde bli exakt samma, men jag kanske har fel???
En helt annan femma blir det förståss med video-material, ör att inte tala om HD-material som filmas med 50 fps naturligtvis!
#404
Postad 10 March 2006 - 15:17
Über-Guru
22892 inlägg
Filmbaerat 1080i kan deinterlaces till "perfekt" 1080p ja. Men det ställer som du säger duktiga krav på deinterlaceingen i projjen...och så enkelt är det väl inte, iaf inte i praktiken, finns ju många som inte ens gör rätt med SDTV.
Sen vet jag inte hur det har blivit med med vertikal filtrering. Iprincip ALLT material idag som kan skickas ut som interlace filtreras verikalt innan det lagras/komprimeras (gäller såväl 1080i HDTV-sändningar som D-VHS som 480/576i DVD!). Detta för att minimera sk "line twitter", vad man gör är att man minskar extrema kontraster i vertikalled. Detta reducerar naturligtivs detaljrikedommen.
Det har pratats om (eller snarare bildgurras ala Joe Kane mfl har kommit med önskemål) att det vore önskvärt att de som sitter med progressiv display (vi är några stycken nu) ska slippa denna eftergift för interlace-ägarna så att maximal bildkvalité kan uppnås. Tanken var att man lagrar materialet o-filtrerat och att man endast applicerade filtrering vid interlace-output (dvs spelaren filtrerar).
Om man även i fortsättningn utför denna filtrering innan lagring så borde rimligtvis 1080i bli iprincip identiskt med 1080p men om man går efter denna "nya" metod finns det iaf ett plus till för 1080p.
#405
Postad 10 March 2006 - 17:19
1310 inlägg
OK! Det här med filtreringen var nytt för mig! Vore ju ett plus i kanten då om de låter spelarna filtrera om de skickar ut en interlaced signal då. Utöver själva upplösningen skulle man även få denna fördel med HD-formaten då alltså! Fast då gäl+ler det att skaffa en 1080-bildvisare först... Men kör de på med samma princip spelar det alltså ingen roll om man kör ut 1080i eller 10180p. En del verkar väldigt besvikna över att de första HD DVD spelarna inte kan skicka en 1080P-signal, vilket alltså egentligen kvittar för filmat material (vilket väl kommer vara 95% av allt man tittar på genom sin HD- spelare!?!). Bra deinterlacer är som sagt viktigt i så fall, men denna form av deinterlacing är ju den absolut simplaste, så det borde (?) inte vara något problem egentligen. Det är ju bara att baka ihop två fields till en frame, varannan rad från varje. Ingen motion compensation eller annat jox behövs ju i deinterlacingen. Fast något värre blir det för R1 (NTSC-länderna, 60 Hz-versionen, vad kommer det heta egentligen?) där ju spelaren själv måste fixa 3:2 pulldown av 24 fps filmen för att skicka ut en 1080i@60 Hz. Troligt är väl att detta kan ge upphov till en liten kvalitetsförlust?
#406
Postad 12 March 2006 - 13:42
Unregistered92fb460e
64 inlägg
Ingen som vet någon annan svensk återförsäljare som ska sälja TOSHIBA HD-A1 när det väl beger sig än Dvdirekt?
#407
Postad 12 March 2006 - 15:00
Guppa
Guppa
Bredbildad
731 inlägg
Nya rykten Site drops HD DVD titlesMove could signal delay as Wal-Mart halts online pre-orders By Susanne Ault and Paul Sweeting 3/10/2006 MARCH 10 | Now you see ’em, now you don’t. The first batch of Warner HD DVD titles have abruptly disappeared from Wal-Mart’s Web site, three weeks after the retailer started taking online pre-orders for the high-definition discs. Consumers who had place pre-orders received e-mails from Walmart.com beginning March 8 telling them their orders had been canceled. The items “may become available some point in the future,” the e-mails said. At least through March 4, Wal-Mart was accepting pre-orders for Batman Begins, The Phantom of the Opera, Million Dollar Baby and others, scheduled to street on March 28. Walmart.com had been offering early dibs on titles for the last couple of weeks. Many were retail-priced at $25.48 a piece, marked down from a list price of $29.98. At the time, Wal-Mart was the only retailer taking pre-orders for the titles. Amazon.com continues to have people sign up to receive e-mails the instant HD DVD products become available for pre-order but is not currently taking orders. Several electronics retailers are taking pre-orders for the first two Toshiba HD DVD players, also slated to hit stores March 28, but none were soliciting orders for the software titles (VB, 3-6). Warner and Toshiba officials said earlier that the plan for the initial rollout of the format called for restricting sale of the titles to retailers that also are selling the hardware, due to the limited quantity of discs available. Wal-Mart has not participated in Toshiba’s initial retail demo tour, and it was unclear last week whether the mass merchant would be selling the hardware at launch. Wal-Mart officials declined to comment on the chain’s plans for the hardware or on the disappearance of the titles from its Web site. However, the unusual move by the retailer sparked speculation last week that Warner might be having problems getting the first wave of titles prepared and replicated in time to meet the March 28 street date and might have to delay their introduction. At least one software supplier in Japan has already indicated that the long delay in reaching an interim licensing agreement for the AACS copy-protection system for HD DVD had caused the label’s launch plans to slip. The label, Shochiku, announced last week that its planned March 28 release, Shinobi, would be pushed back to April 28. “We judged that we can not meet the scheduling, considering the contractual procedures,” a spokesman said, according to an English translation of a Japanese news report. Warner executives declined to comment. Toshiba Consumer Products America marketing VP Jodi Sally said she was not aware of any announcements from Warner departing from earlier HD DVD title street dates. She also insisted the Toshiba players “are still on schedule” and will be shipped to retailers throughout March. As a member of the eight-company AACS consortium, Warner would have had access to information about the likely contours of the interim licensing agreement before those details became available to other software suppliers such as Shochiku. That inside knowledge might have helped Warner begin preparing its launch titles far enough in advance to meet the March 28 street date even if some other suppliers can’t. Warner also has worked closely with Microsoft, another AACS member, to develop some of the encoding procedures for HD DVD titles, which could give the studio a leg up over other distributors in preparing its titles for the launch. http://www.videobusi.../CA6315184.html
#408
Postad 12 March 2006 - 21:13
kalvbräss
kalvbräss
454 inlägg
www. dvdstockholm.com har den upplagd till priset 5695:-
#409
Postad 13 March 2006 - 09:52
Über-Guru
22892 inlägg
Man kanske kan tycka att det inte borde vara något problem men uppenbarligen är det det. Många av dagens produkter har problem med inverse telecine på SDTV, ser ingen anledning att tro att de skulle vara bättre på HDTV. Men ja, med bra chip och algoritmer, t.ex. HQV så borde det inte vara några problems. Faktum är att vad jag har "hört" så är det enklare att köra inverse telecine på 3:2 än på 2:2 (t.ex. PAL) eftersom den senare är likformigt och det är så att säga lättare att "gå bort sig" under tidens gång. Men ja, korrekt deinterlaceat 1080i kommer se vrålbra ut, det gjorde det iaf på Ruby.
#410
Postad 13 March 2006 - 17:26
1310 inlägg
Jo, nog är det väl så att deinterlacer i bildvisare inte håller någon vidare hög klass, generellt sett. Om jag bara ser till mig själv så sköter min BBK- spelare för 1800 pix deinterlacingen bättre än min panna AE500. Sedan är det bättre att deinterlacea i spelaren och inte i bildvisaren också eftersom spelaren får tillgång till MPEG-flaggningarna, vilket ju inte bildvisaren har. Lättare med 3:2 än 2:2? Kanske det! Speciellt om deinterlacingen inte har tillgång till MPEG-flaggorna. Det finns MPEG-flaggor specifika för just 3:2 pulldown, vilket skulle kunna göra det "lättare" med deinterlacing av just sådant material. Och med 3:2-material är vissa fields exakt identiska så det är lätt för deinterlacern att "känna igen" en 3:2-signal. Med 2:2-material är ingen field den andra lik så det är inte lika lätt att "känna av" att det är 2:2 material det handlar om. Och flaggningarna kan dessutom vara felaktiga! Så bra deinterlacers kör materialet genom en MPEG-dekoder först så den får en digital interlaced signal som den sedan bearbetar utan att deinterlacea med hjälp av MPEG-flaggor. Men det är nog så också att man märker inte lika tydligt om deinterlacingen "går bort sig" på 3:2 material jämfört med 2:2 material. Med 60 Hz bildvisning av 24 fps-material skapas per definition "judder", oavsett om det är interlaced eller progressiv signal så fort något rör sig i bilden, så lite extra judder sticker ut mindre. 2:2 däremot visar varje frame lika länge och det flyter mjukt, så där märks felaktigheter mycket tydligare!
#411
Postad 14 March 2006 - 10:47
Über-Guru
12561 inlägg
CEBIT: NEC demonstrates HD- DVD R burning NEC Corp. is demonstrating at the Cebit trade show in Germany this week a recently developed optical disc drive that can write to HD- DVD discs. HD- DVD is a new disc format that uses blue lasers to achieve a storage capacity of about three times that of DVD. A single-sided HD- DVD disc can accommodate 15GB of data compared to 4.7GB on a DVD. It’s one of two soon-to-be-launched formats that uses blue lasers. The second, Blu-ray Disc, can store 25GB on a single-sided disc but requires a more complex drive mechanism because the disc’s physical structure is different than that of DVD and CD. NEC is demonstrating the drive with media from Mitsubishi Kagaku Media Co. Ltd., which is best known by its Verbatim brand name. The company is shooting high-definition video each morning at the show and burning it onto a disc for playback during the day, said Ryoichi Hayatsu, an NEC storage product division manager, in an interview. The blank media, which only became available days before Cebit began, is single-sided so can store up to 15GB of data. The drive is also compatible with dual-layer discs, which can store 30GB. In addition, the drive, called HD-1100, also writes to DVD and CD discs. NEC is also working on support for rewritable HD- DVD media although the standardization for HD- DVD Rewritable has yet to be completed. That’s expected to be finalized in May or June this year, said Hayatsu. Toshiba Corp. is also showing off its first HD- DVD products at Cebit. One of the products, the Qosmio G30 laptop, was launched at the show and will be the first laptop to include an HD- DVD drive. Qosmio is Toshiba’s multimedia PC range and the computer includes a TV tuner and Dolby Home Theater support. Users will be able to watch HD- DVD content on the laptop’s screen or on a compatible high-definition monitor or television. The machine will be available in April in major markets and will cost around €2,000 (US$2,410). http://www.macworld.....php?lsrc=mwrss
#412
Postad 15 March 2006 - 20:31
Über-Guru
12561 inlägg
Man kan helt enkelt inte ge upp hoppet.... LG to deliver dual-format HD DVD/Blu-ray LOS ANGELES (Reuters) - Korea's LG Electronics Inc. (066570.K) said on Tuesday it planned to launch a next- generation DVD player that will bridge the yawning gap between two competing formats by playing both HD DVD and Blu-ray. "LG is a supporter of Blu-ray and is now considering a dual format player for later this year," said John Taylor, a U.S. spokesman for the Korean company. Both Blu-ray, developed by a Sony Corp (6758.T)-led consortium, and HD DVD, championed by Toshiba Corp (6502.T), offer more capacity than current DVDs, but the groups' failure to reach a unified front has paved the way for a costly battle in the $24 billion home video market, like the VHS/Betamax war of 25 years ago that caused widespread customer confusion. Korean LG Electronics last week became the second high-profile Blu-ray supporter after Hewlett-Packard (NYSE:HPQ - news) to announce it would also support HD DVD. In addition to throwing its support behind HD DVD, the Korean-based electronics maker also notified dealers in a memo that it was developing a dual-format HD DVD/Blu-ray Disc player, Taylor said. Richard Doherty, analyst with Envisioneering, said LG planned the launch for fall. A dual player would be a win for both retailers and consumers who will likely face months or years of frustration and confusion in a standards war, he added. "While LG is the first to announce a dual player, we're sure it will not be the last system that gives consumers what they expect -- high definition discs that play with no questions asked," he said. HD DVD players are expected to be out of the gate first, hitting stores later this month, while Blu-ray has said it expects its first players and titles to hit the market in May. Both sides were the subject of rumored delays on Tuesday. The Nihon Keizai business daily said on Tuesday that Sony will push back the release of its much anticipated PlayStation 3 video game console, which will include a Blu-ray drive, to November, although a U.S. Sony spokesman said plans to launch the PS3 in the spring remained on track. A Blu-ray spokesman also said the spring launch of the format and players remained on track. The Hollywood Reporter also on Tuesday said HD DVD films from Time Warner Inc's(NYSE:TWX - news) Warner Bros. may not be ready in time for the launch of Toshiba's player on March 28, contrary to expectations. Retailers are already frustrated by the format battle. "A lot of people are asking if this is Betamax revisited. I think it's frustrating to a lot of people in the market," said Tom Drake, president and chief executive officer of North American Retail Dealers Association. http://news.yahoo.co..._lg_bluray_dc_1
#413
Postad 23 March 2006 - 22:43
Guppa
Guppa
Bredbildad
731 inlägg
HD DVD-spelarna och de första filmerna kommer att försenas till tidigast 18e April
#414
Postad 24 March 2006 - 14:44
Über-Guru
12561 inlägg
Anledningen till uppskjutet datum för HD DVD enligt nedan... NEW YORK (Reuters) - Toshiba Corp.'s (6502.T: Quote, Profile, Research) U.S. unit may delay the launch of its next- generation DVD player for several weeks to coincide with the April debut of movies that play in the new HD DVD format, the company said on Thursday. Championed by Toshiba, HD DVD is one of two competing formats hoping to breath new life into the slowing $24 billion home video market. The rival format is Blu-ray, created by a group led by Sony Corp. (6758.T: Quote, Profile, Research) In January, Toshiba America Consumer Products said it would in March ship its first players, the HD-XA1 and HD-A1, for $799 and $499, respectively. "Toshiba is currently working with the studios as well as our retailers, to finalize the sale date of our players," the company said in a statement. In order to maximize the launch of HD DVD, we intend to synchronize the launch of our players with HD DVD title releases." Last week, Time Warner Inc.'s (TWX.N: Quote, Profile, Research) Warner Home Video said it would release its first titles, including "Million Dollar Baby," and "The Phantom of the Opera," on April 18. By contrast, Sony Pictures has said it aims to deliver its first movies in the Blu-ray DVD format to U.S. stores in late May to coincide with the entry of compatible disc players, from makers like Samsung Electronics Co. (005930.KS: Quote, Profile, Research) However, Sony has delayed the release of its PlayStation 3 console until early November, a launch that is expected to give a huge boost to the installed base of the Blu-ray technology. Both Blu-ray and HD DVD offer far more capacity than current DVDs, but the competing groups' failure to agree on a unified format has paved the way for a costly battle like the VHS/Betamax war of 25 years ago that caused widespread customer confusion. Several retail chains have already voice annoyance with the fact that there are two new formats, which will force them to carve out space in their stores for sundry devices related to both formats, including the players, the movies, other programing and accessories. Still, the payoff could be very lucrative. Warner Home Video said it expects motion picture industry sales of next- generation DVDs to reach as much as $750 million in the last quarter of this year. http://today.reuters...TOSHIBA-DVD.xmlSamt en artikel om ökade merkostnader i och med införskaffningen av nästa gen- dvd spelare som många säkert inte riktigt räknat med om man verkligen vill utnyttja den fulla potentialen som dessa kommer att återge. Extra costs a worry for next-gen DVD adoption LOS ANGELES (Reuters) - Consumers about to face a confusing and expensive choice between two conflicting standards for high-definition DVDs will face further costs to upgrade their entertainment systems if they want to enjoy all the benefits of the new movie players. Hollywood and electronics makers have aligned themselves behind two warring formats called Blu-ray, led by Sony Corp. (6758.T: Quote, Profile, Research), and HD DVD, championed by Toshiba Corp. <6502.T, which on Thursday said it may delay its launch from late March to mid-April. "I don't think all the challenges and costs of next- generation DVDs have been realized by consumers yet," analyst Paul-Jon McNealy of American Technology Research said. By offering discs with far more capacity than current DVDs, the groups hope to breath new life into the $24 billion home video market. But their failure to use a unified format has paved the way for a costly battle similar to the VHS/Betamax video war 25 years ago that caused widespread customer confusion. "Our findings are not encouraging about the consumer adoption of HD DVD and Blu-ray early on," McNealy added in a note. He said some high-definition TV sets may be incompatible with copy protection on the HD DVD and Blu-ray players. Analyst Richard Doherty of Envisioneering said most stereo systems are not up to the full home-theater sound capabilities of HD DVD and Blu-ray. Both analysts said both new players will likely require consumers to buy new cables, which are not inexpensive. Several retail chains have already voiced annoyance with the prospect of a format war that is likely to aggravate consumers forced to choose among products and accessories that may ultimately be rendered obsolete the way Betamax video cassette recorders were. Both formats have faced delays recently. In addition to Toshiba's delay announced on Thursday, Sony has delayed the release of its Blu-ray capable PlayStation 3 console until early November, a launch that was expected to give a huge boost to the installed base of the Blu-ray technology. Blu-ray continues to target late May for the launch of new disc players by Samsung Electronics Co. (005930.KS: Quote, Profile, Research) and early summer for a player from Sony. Additionally, Microsoft Corp. (MSFT.O: Quote, Profile, Research) this week delayed the release of its much-anticipated Vista operating system for consumers until after this year's holiday shopping season. Vista is slated to support HD DVD, which is expected to give a huge boost to the installed base of HD DVD technology in PCs. "Toshiba's announcement was a disappointment, coming in a week with Microsoft pushing back Vista a few months. The whole idea of PCs supporting HD DVD is now skewed and delayed," Doherty said, noting that when DVDs were introduced eight years ago, about 70 percent of the DVD systems sold in the first year were in personal computers, and only 30 percent sold were stand-alone DVD players for TVs. All these factors add up to the fact that the vast majority of homes are not adequately set up to fully appreciate the new generation of high-definition DVD viewing. "Only one in 10 homes is set up to appreciate the sound quality of these new discs and players, while one in eight homes have an HDTV set with good enough picture quality to properly appreciate Blu-ray or HD DVD," Doherty said. "The players, costing from $500 to $1,000, are still much lower priced than the television or the kind of sound systems that would do justice to them," he said. http://today.reuters...umber=1&summit=
#415
Postad 24 March 2006 - 20:39
Unregistered9a177c31
1716 inlägg
Vilken storlek kommer fodralen att vara till Blueray och HD- DVD? Vore ju underbart om man kan återanvända sina hemmagjorda DVD-fodral.
#416
Postad 24 March 2006 - 20:43
thetias
thetias
2965 inlägg
Vilken storlek kommer fodralen att vara till Blueray och HD-DVD? Vore ju underbart om man kan återanvända sina hemmagjorda DVD-fodral.
Återanvända? Varför skulle du använda egentillverkade fodral?
Redigerat av thetias, 24 March 2006 - 20:44.
#417
Postad 05 April 2006 - 10:08
B8
B8
4536 inlägg
Dagarna är förbi när formaten som släppte mest porrfilmer vann Det var enklare förr
Inte för att vara den som är den, men det där är dock en myt. VHS marginaliserade Betamax på helt andra grunder  Man blir i alla fall mer och mer sugen för var dag som går. Att läsa speccar motverkade ju inte det heller direkt
Redigerat av B8, 05 April 2006 - 10:15.
#418
Postad 05 April 2006 - 13:07
Unregistered59dcaef6
5025 inlägg
Förstår inte den där grafen riktigt...
Det är ju inga som helst problem med att läsa en MPEG2 HD-ström på dryga 15 Mbps från en vanlig DVD-R.
Uppåt 25 Mbps börjar det bli allvarliga problem dock...
Åtminstone i min IO-Data AvelLink- spelare med Sigmachip så är det så.
Det borde väl betyda att de maxgränser som de har satt är väldigt konservativa..?
#419
Postad 05 April 2006 - 13:13
Unregisteredf2a7f9fd
3989 inlägg
Förstår inte den där grafen riktigt... Det är ju inga som helst problem med att läsa en MPEG2 HD-ström på dryga 15 Mbps från en vanlig DVD-R. Uppåt 25 Mbps börjar det bli allvarliga problem dock... Åtminstone i min IO-Data AvelLink-spelare med Sigmachip så är det så. Det borde väl betyda att de maxgränser som de har satt är väldigt konservativa..?
Gränserna i den där grafen är alla för 1x hastighet (dvs vanlig uppspelningshastighet i en standalone DVD spelare) och inte max på ngt sätt. DVDX2 är alltså 20 och 10x ca 100... Så visst kan du läsa en 15mbps ström från en DVD. Som ett exempel så är tex xbox360´ns DVD ungefär lika snabb som PS3ans BD.
Redigerat av Unregisteredf2a7f9fd, 05 April 2006 - 13:16.
#420
Postad 05 April 2006 - 14:31
1310 inlägg
Vill inte verka tjatig om detta, men egentligen spelar det ingen större roll med 1080i eller 1080p för filmat material så länge man har en hyffsad deinterlacer i bildvisaren (eller i scalern om man använder en sådan.)
Teoretiskt får du exakt samma bild med en 1080i-signal som en 1080p-signal om deinterlacern sköter sig som den ska...
Sedan kan faktiskt filmen ändå vara lagrad som 1080i@ 24 eller 25 men man får ut en felfri 1080P-signal i alla fall, beroende på codec osv.
#421
Postad 05 April 2006 - 17:30
Guppa
Guppa
Bredbildad
731 inlägg
<{POST_SNAPBACK}> I have spent all of my life working on conversion from interlace to progressive. Now that I have sold my successful company, I can tell you the truth: interlace to progressive does not work!”.-Yves Faroudja
#422
Postad 05 April 2006 - 18:55
1310 inlägg
I have spent all of my life working on conversion from interlace to progressive. Now that I have sold my successful company, I can tell you the truth: interlace to progressive does not work!”. -Yves Faroudja
<{POST_SNAPBACK}> Bäst att sälja sina Faroudja och HQV aktier innan "the shit hits the fan" då...  Allvarligt, för video-material är jag beredd att helt hålla med eftersom två interlaced fields då inte direkt bildar en komplett frame, vilket filmbaserat material ju gör, i teorin, men för film-material går det rätt hyffsat att få till en P bild tycker jag, men vad vet väl jag... Ska sluta tjata om det här nu, sorry...
#423
Postad 05 April 2006 - 19:47
mikee
mikee
1638 inlägg
Redigerat av mikee, 05 April 2006 - 19:50.
#424
Postad 06 April 2006 - 07:03
Stefan T
Stefan T
28 inlägg
Minns ni tiden då VHS var det absolut bästa man kunde ha? Man, i alla fall jag, samlade på sig en uppsjö med filmer på VHS. Sedan kom DVD som var ännu bättre, ja, man gick och köpte sig en DVD men dessvärre var man ju tvingad till att köpa filmer också och att köpa alla filmer man tidigare hade på VHS till DVD blev ju en dyr historia. Nu, ett antal år senare har man en gedigen DVD samling på ca 500 filmer.
Det jag gick och funderade på var nu när BlueRay och HD- DVD är på ingång, kommer man att bli tvingad att göra om hela processen igen? Alla dagens DVD filmer blir väl oanvändbara i dessa spelare eller har jag helt fel där kanske?
Bara en tanke...
Stefan
Redigerat av Guppa, 08 April 2006 - 14:15.
#425
Postad 06 April 2006 - 07:26
phil neal
phil neal
2633 inlägg
Det jag gick och funderade på var nu när BlueRay och HD-DVD är på ingång, kommer man att bli tvingad att göra om hela processen igen? Alla dagens DVD filmer blir väl oanvändbara i dessa spelare eller har jag helt fel där kanske?
Bara en tanke...
Stefan
Svar nej, bägge systemen är bakåtkompatibla.
#426
Postad 08 April 2006 - 18:56
RightOn
RightOn
17 inlägg
Hmmm... när jag läser en del inlägg så blir jag fundersam på om man tänker på hela kedjan?
Att en projektor eller en TV har en upplösning på ex 1280 x 768 är ju bara en del. Om man matar den med DVD så har man aldrig mer än 720 x 576 (PAL-standard) eller ev 720x480 (NTSC) då det inte existerar skivor på marknaden (såvitt jag vet) med HD-film. Därför vet man ju inte hur en sådan ser ut i projektor eller TV än så länge. Enda chansen är om man har en "fullvärdig" HD-film i en dator med DVI eller HDMI.
Att man snackar om DV- spelare med HD-ut är också bara en del i kedjan. Eftersom film på DVD-skivor redan är duktigt packade (utnyttjar mesta lagringskapaciteten på skivan) oftast skulle en uppskalning av HD-film på DVD-skiva kräva brutal komprimering som sänker kvalitén och därför är det en tveksam lösning i längden (även om jag absolut skulle fördra en HDMI utgång på DV- spelaren till HD-ready TV). Alltså tvivlar jag på någon större satsning på HD-film på DVD-skiva.
Här kommer HD- DVD och BluRay in.
Jag har inte födjupat mig i "upplösningsfrågan" på spelarna eftersom min gissning är att den inte behöver vara så styrd. Där handlar det om lagringskapacitet och vad man kan få plats med i vilken upplösning och kvalité.
Personligen hoppas jag mer på Blu-Ray. Varför? Vi kommer behöva byta ut spelarna hemma och i datorn och idag är lagringskapaciteten på DVD 4,7. Att då bara 3 dubbla (tror HD- DVD lagrar cirka 14 GB) ett format som vi kanske behöver leva med i minst 5-8 år och med den utveckling som finns där vi behöver lagra allt större filer och så vidare känns som ett alltför klent steg. BluRay blir åtminstonde 5 dubblat (cirka 25 GB) och då finns det lite mer för framtiden.
Är man lite fixare så kanske en variant att fixa en snygg kompaktdator med TV-kort och HDMI-stöd med en DVD spelare, så kanske man om ett år kan rycka ut den och sätta i en Blu-Ray.
MVH Lars
#427
Postad 08 April 2006 - 19:12
Guppa
Guppa
Bredbildad
731 inlägg
Om man skulle lagra HD-filmer på DVD-skivor så skulle man använda MPEG4 som komprimeringsteknik vilket skulle göra att man kunde använda samma videobitrate som dagens dvd-filmer (6-10Mbps) för att få en bild med kvalite som motsvarar amerikansk HDTV(15-20Mbps). Men för detta skulle du ändå behöva en helt ny spelare.
När det gäller utrymme på DVD, HD DVD och Blu-ray så är alla de utrymmessiffror du nämner för single-layer skivor. 95% av dagens DVD-filmer ligger på dual-layer skivor med 9 GB utrymme. Både HD DVD och Blu-ray kommer även dom troligen att använda främst dual-layer skivor där HD DVD då får utrymmet 30 GB och Blu-ray 50 GB. Detta gör att man kan få en videobitrate som är betydligt bättre än amerikansk HDTV. Sen för övrigt så har HD DVD en protoypskiva på 3 lager och Blu-ray har prototypskivor på både 4 lager och 8 lager.
Redigerat av Guppa, 08 April 2006 - 19:14.
#428
Postad 08 April 2006 - 19:47
RightOn
RightOn
17 inlägg
Ja, du har rätt. Min HD-videokamera lagrar 1 timma HD-film på DV-band och jag vill minnas det är MPEG4.
Men sedan är väl all komprimering av film bestående av flera tänkbara parametrar (även om kameran har en standard). Vad jag tänker på är när man drar ut DV-projekt till skiva själv så kan man få plats med olika mycket på en skiva beroende på hur hårt man pressar komprimeringen. Ungefär som JPEG-komprimering kan ställas olika hårt. Vad jag menar är att kanske man vill välja att inte komprimera hårdare än nödvändigt? Fast det är klart, MPEG4 brukar vara en förhållandevis snygg komprimering.
Och det där med Dual-Layer är också sant, och självklart intressant. Jag är förståss lite sugen på att kunna komma åt "bränning/lagring" och tänker delvis på det. Det är kanske inte sannolikt att brännarna kommer stödja mer än singel-layer när de först kommer? Eller vad tror du?
Men dual-kapaciteten blir ju naturligtvis ett duktigt steg upp.
De hemma-stationära kommer väl dröja med bränningstöd, men jag läste någonstans att någon datortillverkare gick ut med en kommande Lap-top med Blu-Ray brännare. Och det är väl där man först kommer stöta på det.
MVH Lars
#429
Postad 08 April 2006 - 20:19
Guppa
Guppa
Bredbildad
731 inlägg
Stationära Blu-ray brännare lär komma under nästa år och de har troligtvis stöd för dual-layer skivor medan vissa Blu-ray brännare för PC/Mac som visats upp och som kommer att släppas under 2006 nog kan komma att sakna stöd för dual-layer.
Sony har sagt att de ska släppa en stationär och en laptop med Blu-ray men även en brännare att köpa separat. Apple, Dell och HP lär följa efter med att inkludera Blu-ray i deras bästa datorer. HP lär även ha någon dator med HD DVD i sig också eftersom de står bakom båda formaten. Sen har Pioneer, Philips, LG, Benq, Panasonic och Samsung alla visat upp varsin spelare för separat försäljning.
Redigerat av Guppa, 09 April 2006 - 16:20.
#430
Postad 09 April 2006 - 16:15
Über-Guru
12561 inlägg
Härliga underbara nyheter staffanw!
Det blir ett mycket spännande år att se fram emot, speciellt HC3an som man absolut tänker skaffa
#431
Postad 12 April 2006 - 16:23
Über-Guru
12561 inlägg
Uni delivers Serenity to HD DVD Sci-fi adventure first from studio on high-def format on April 18 By Jennifer Netherby 4/10/2006 APRIL 10 Universal Studios Home Entertainment appears poised to become the second studio to release films on HD DVD. The studio will debut Serenity on April 18 as its first HD DVD release, followed a week later by Apollo 13 and Doom, according to retailer Web sites. Universal hasn’t made any announcements and a spokeswoman was unable to confirm anything Monday morning. However, all three films are available for preorder at Amazon.com for $23.99 and for the same price on Target.com’s video store, which is run by Amazon.com. Amazon shows the list price of the disc at $34.98. CircuitCity.com also has the discs listed for preorder, priced at $33.95, but the site has no release date for the film. At least one rental retailer also confirmed it has placed orders with Universal for its initial April HD DVD releases, though as of last week, the retailer hadn’t been given a release date for the titles. Warner Home Video announced last month that it would debut its first three HD DVD titles on April 18, after delaying its planned March 28 release. Warner will debut Million Dollar Baby, The Phantom of the Opera and The Last Samurai April 18, followed by a dozen other releases into May. Paramount Home Entertainment, the only other studio to commit to HD DVD releases, has not yet announced any release plans. http://www.videobusi.../CA6323662.html
#432
Postad 17 April 2006 - 17:29
Über-Guru
12561 inlägg
HD DVD set to launch quietly APRIL 13 | If all goes as planned, HD DVD is set for a low-key launch Tuesday with five movies out from Warner Home Video and Universal Studios Home Entertainment and players from Toshiba coming the same day or shortly after. With small initial shipments, stores are likely to have four or five players in stock and about 10 units of HD DVD discs at launch, according to distribution and retail sources. The studios are expected to ship between 7,000 and 10,000 copies of each of the five initial titles set for the April 18 release, according to distributors. Toshiba is expected to ship between 10,000 and 15,000 players, several thousand of which are for retail displays. Toshiba representatives didn’t return calls for comment. Wal-Mart also has an RCA brand player listed on its Web site, although no availability date is given. The player appears to be a re-branded version of the basic Toshiba player. HD DVD movies mostly will be available at the select mass merchants and electronics retailers that also are selling players, including Wal-Mart, Best Buy, Tweeter, Ultimate Electronics and other regional chains. But smaller retailers won’t be completely left out. “It’s tough to really get a bead on how this will come down, even at this late date,” Ultimate Electronics senior VP of merchandise Jim Pearse said. “We are going with the flow and can change our execution quickly.” Toshiba reportedly kicked off a TV ad campaign on HDTV channels this week themed “So Real You Can Feel It,” according to BrandWeek. Ultimate Electronics will promote the first software titles in its April 16 circular; other retailers were tight-lipped about their promotional plans. Universal has yet to announce or confirm it, but the studio is expected to release sci-fi cult favorite Serenity on April 18, the same day Warner debuts its first three HD DVD titles—Million Dollar Baby, The Last Samurai and The Phantom of the Opera. On April 25, Universal will release Apollo 13 and Doom. Amazon.com is currently taking pre-orders on the titles. Amazon is offering the Universal HD DVD movies for $23.99 each, the same price as Target.com’s video store, which is run by Amazon. Amazon lists the manufacturer’s suggested price of the discs at $34.98. Warner has priced its titles similar to standard DVDs, at $28.99, though its HD DVD movies are selling for around $20 at Amazon.com and other online retailers. While Warner has mostly restricted sales of its initial releases to retailers selling HD DVD players, thereby cutting out distribution and smaller retailers from the launch, Universal has a more relaxed policy. Distributors and smaller retailers have been allowed to place orders on the studio’s first three releases. New England’s 26-store Newbury Comics will be selling Universal’s HD DVD trio throughout its chain. Since early last week, F.Y.E. has been accepting pre-orders on its Web site for the titles. Rental specialists, including Seattle’s Scarecrow Video and about two dozen members of the National Entertainment Buying Group, also are set to offer the Universal releases. Independent retailers are cheering Universal’s broad distribution. “I definitely think they are being smarter,” said Newbury buyer Ian Leshin. “If you limit your market right away, you are conditioning customers to think they won’t be able to find stuff in other stores.” Leshin expects to be able to sell Warner HD DVD titles about 90 days after their April 18 bow. With HD DVD an untested format, many smaller retailers are conservatively ordering a few copies of each Universal title per store. Yet Newbury, Scarecrow and others hope to avoid having to steer customers to rival retailers for their HD DVD titles. Scarecrow is prepared to buy Warner titles elsewhere, in order to have some in stock for customers. “We’re the largest indie retailer on the West Coast, with 72,000 titles to rent, so people come to the store and expect us to have everything,” Scarecrow buyer Mark Steiner said. Warner’s distribution strategy is “a bummer,” he adds. “I don’t get Warner’s decision. It seems unfriendly to retailers. I don’t think they’ll sell any less at Best Buy because they sell five copies of a title to me.” Indies recognize people will need to shop at electronics chains first, as they’ll need a player for their HD DVDs. At the same time, indie retailers want to be early bird participants in a format that has been hyped as the key to growing the home entertainment business. “To a degree, it makes sense to get the software next to where the hardware will be,” NEBG president Todd Zaganiacz said. “But at some point, to get the most exposure, you really need to get it out to all venues. That will help increase awareness and education.” Warner hasn’t cut all rentailers out at the start. Netflix began allowing its users to add Warner HD DVD releases to their queue for shipping at launch. Netflix sent a survey out Monday to users that had added the HD DVD rental option to their queue to assess subscriber interest in the new format. The survey quizzed users on their home entertainment setup and whether they could play HD DVDs at launch and what type of movies they expect to be available as well as what types of movies they’d like to watch on HD DVD. Blockbuster Online also will have HD DVD movies available for rent at launch. The company said a customer survey showed action is the genre most early high-definition disc adopters want to see in the new format, with Warner films The Matrix and Harry Potter and the Goblet of Fire the top movies they want to see. Science fiction and scenic movies were the second and third most requested genres, the rentailer found. About 55% of Blockbuster Online users have a high-definition TV but only one-third of users said they plan to purchase a high-definition player at this time. “It’s the old beta versus VHS dilemma,” Blockbuster Online senior VP and general manager Shane Evangelist said. “There’s no way to know how long it’s going to take for the general market to decide which formats will ultimately prevail. So while this shakes out, we’re just going to listen to our customers and make sure we give them the movies they want in the format they prefer—whatever the technology.” http://www.videobusi...dustry=New Tech
#433
Postad 17 April 2006 - 18:34
1310 inlägg
Undrar varför de går för en sån liten lansering i början?
Förväntar de sig väldigt begränsad efterfrågan eller har de inte hunnit få fram spelare/filmer i tillräckligt antal till launch?
Vad är det egentligen sagt om regioner när det gäller HD DVD och BD? Kommer det bli samma indelning som för DVD?
#434
Postad 24 April 2006 - 19:33
Yves
Yves
75 inlägg
Pioneer har tydligen haft en DVD som sände 96k/24 via S/PDIF så självklart går det men frågan är om spelarna kommer att stödja konvertering av "lossless" Dolby TrueHD eller DTS HD till PCM. Men det lär vi få veta när alla spelarna är här, kan Toshiborna det? Enligt en tråd på AVS forum kommer både Pioneer och Sony att vara HDMI 1.2a kompatibla. De hoppas också på konvertering till LPCM eller DSD (HDMI 1.2). http://www.avsforum....27&page=1&pp=30
#435
Postad 28 April 2006 - 19:30
Unregistered6332cbbb
882 inlägg
ähh, ja får krupp snart, måste köpa!
#436
Postad 04 May 2006 - 22:35
Unregistered8147b14e
2473 inlägg
Experter: Porrbranschen avgör DVD-striden Har valt Blu-ray som format
Striden om vem som kommer att dominera framtidens DVD-format står mellan Blu-ray och HD-DVD. Kampen kan komma att avgöras av – porrbranschen. Det anser flera experter på området.
Liksom på 1980-talet, när videoformaten Betamax och VHS kämpade om världsherraväldet, kommer porrbranschen att ha en avgörande betydelse i striden mellan de två alternativen för framtidens högupplösta DVD-format. Och, till skillnad från på 80-talet, ska nu den amerikanska porrbranschen ha valt Sonys Blu-ray Disc, enligt amerikanska medier.
Fast Aftonbladet är ju inte direkt tillförlitliga. *** La till tydligare källangivelse. /Tomas_D700
Redigerat av Unregistered8147b14e, 04 May 2006 - 23:25.
#437
Postad 04 May 2006 - 22:56
Guppa
Guppa
Bredbildad
731 inlägg
Om nu Blu-ray skulle vinna formatkriget vilket jag själv tror så tror jag då inte på att porren kommer ha någon större betydelse. Visst kan jag tänka mig att det finns ett litet antal personer som väljer att köpa en Blu-ray spelare för att de vill se in-ut i 1080p men det lär inte vara många... Jag tror internet och DVD räcker för de flesta p-konsumenter.
Redigerat av Guppa, 04 May 2006 - 23:02.
#438
Postad 04 May 2006 - 23:16
B8
B8
4536 inlägg
Om Aftonbladet för en enda gångs skull haft lite källkritik så hade de ju tex kunnat upptäcka att porrens betydelse för utgången av 80-talets videokrig bara är en modern myt.
TRor inte det kommer ha någon betydelse den här gången heller...
#439
Postad 04 May 2006 - 23:32
Tomas_D700
Tomas_D700
Rådgivare
5023 inlägg
En sådan kommentar fungerar bättre om du anger din egen källa
#440
Postad 05 May 2006 - 18:11
Unregistered81406615
887 inlägg
Precis, någon som sett porr nyligen? De flesta filmer är inte ens bredbild ännu. En annan myt är att VHS vann över en egentligen överlägsen produkt. I själva verket hade Betamax aningen bättre bild men var urdåliga på allt annat. Bandlängd, timerinspelning etc. Det är ungefär som att säga att jumbojet vann över en bättre produkt. Må vara att Concorde var snabbare men den var kass på allt vad komfort hette. Följaktligen var inte den bättre farten nog för att ta marknadsandelar.
#441
Postad 07 May 2006 - 00:09
kimpa888
kimpa888
446 inlägg
En dum fråga bara,, fins det blu-rey dvder? kan man använda en z3a till en blu rey spelare och få äkta blu-rey? Fins det dvdspelare med både blu-rey och HD?
(nybörhare)
#442
Postad 07 May 2006 - 08:36
Unregistered1022
Unregistered1022
5433 inlägg
det bästa är att vänta och se vilket format som kommer att slå
så man inte sitter med en maskin som är värdelös efter ett tag
//www.aftonbladet.se/vss/it/story/0,2789,820115,00.html
#443
Postad 07 May 2006 - 16:49
Unregistered572600b4
43 inlägg
fan vad jag gillar porrbranschen. det dom nappar på blir det =)) läste presis artikeln om att det e uppskuttet med lanseringen surt =(
helt klart att jag väntar med att inhandla en sådan innan man vet vilket det blir.
#444
Postad 07 May 2006 - 21:43
Über-Guru
12561 inlägg
Tidigare har det sagts att de första Blu-Ray filmerna skulle släppas den 23:e maj. Nu är datumet framflyttat till den 20:e juni eftersom hårdvaruleverantörerna av Blu-Ray spelarna vill ha mer tid på sig. Enligt Sony är deras första filmer klara till det ursprunliga releasedatumet, men kommer inte att släppas förrän 20:e juni. De första titlarna som släpps ärUnderworld Evolution, XXX: State of the Union, The Fifth Element, A Knight's Tale, 50 First Dates, The Last Waltz, Hitch, House of Flying Daggers och Resident Evil: Apocalypse. Den första spelaren från Samsung förväntas börja säljas 25:e juni. Formatkriget mellan Blu-Ray och HD-DVD fortsätter, och vissa spekulationer finns att porrbranschen kommer att göra Blu-Ray till segrare ur striden.
Källa: <a href="http://pryl.feber.se...">Prylfeber</a>
Vem har ändrat mitt allra första inlägg och med vilken rätt är den helt utraderad?
#445
Postad 08 May 2006 - 11:39
thetias
thetias
2965 inlägg
Verkar som om någon Moderator leker runt lite väl mycket i trådarna nu.
#446
Postad 09 May 2006 - 11:38
ROK
ROK
163 inlägg
Här en översättning på mitt förra inlägg, dock med reservation att översättaren tar ord för ord och därmed inte hänsyn till grammatik o.dyl.
vad är HD DVD? Varför den er intäkter verklig, worldwide stöd HD DVD, eller hög- definitionen DVD, är den nästa- generation DVD formaten så pass tillåt inspelningen av mer än åtta timmen av hög- beslutsamhet bion på en enkel ROM avkasta ( i tillfället av 30-gigabyte (GB), dubbel- lager ROM avkasta), användande en blå- lasern diode och avancerat video sammantryckningen teknologien. Idag DVD ROM avkasta innehålla 8.5GB på en sjunga- ta parti mot någon, dubbel- lager avkasta.
HD DVD har gjord stadig framsteg över den sist sex månaden så den bara officiell formaten bemyndiga och gillat vid den DVD Forum, den internationell förening så pass komma med tillsammans något 220 konsumenten elektronik, underhållning, mjukvaran och annan berättat sällskap i omkrets det värld. I November, 2003, den DVD Forum gillat version 0.9 om fysisk specifikationen för den HD DVD ROM formaten, följde efter vid den frige om specifikationen Bok version 1.0 i Juni, 2004. Den här Februari, den Forum gillat version 0.9 om HD DVD rewritable, med final gillande väntat den här höst. Teknisk studier har blitt också fullständig för HD DVD-R, en en- tid recordable version om formaten, och bricka bedömningen proverna er dirigerat vid den DVD Forum med förberedelse på möjlig adoptionen av version 0.9 den här September.
MPEG4 AVC (H.264) och VC-9 var valde så den mandat video sammantryckningen planerna vid den DVD Forum i Juni 2004. Båda åstadkomma tre tiden sammantryckningen effektivitet av MPEG-2, den video sammantryckningen teknologien använd i ström DVDs.
Inne om areal av kopia säkringen, en nyckel bekymra av hinna studion, en större steg var tog den här Juli, när den Avancerat Tillträde Belåtenhet System Licens Administratören, inbegripa åtta större OSS och Japansk firman inne om underhållning, DEN och CE industri, var format till definiera och befordra en högt avancerat kopia säkringen system för nästa- generation optisk avkasta.
samma avkasta strukturen så idag DVD Med 0.6- millimetern tjock avkasta förbindelse rygg till rygg, HD DVD avkasta införa absolut den samma avkasta strukturen så ström DVD avkasta. På grund av så pass, avkasta fabrikanterna vilja kunde utnyttja deras ström avkasta fabrikationen linjen med bara minimum stigningen. Till täcke den förutse global begära för nästa- generation, hög- utrymme optisk avkasta, byggningen ny plantera till produkter avkasta med en absolut olik avkasta strukturen så pass införa en 0.1 millimetern- tjock täcke lager, för exempel, är beräknat till behöva en grov ny investeringen ut över 400 milliarden yen worldwide. Möten den samma utrymme med HD DVD vilja behöva långt mindre investeringen, så just nu funktionsduglig DVD plantera i omkrets det värld kanna bli fullt ut utnyttja med omyndig person modifikationerna, fördriva tiden i tillägg utrymme kanna bli fyllt med brändjärn- ny konvertibel linjen bygget från klösa.
För längre bort upplysning på sällskapen omtalat i denne press frigivning, behaga tillträde den officiell spindelväv tomten antyd nedan.
http:/www.toshiba.co.jp/index.htm / http:/www.nec.com/ / http:/www.memory-tech.co.jp/index_e.html / http:/www.ponycanyon.co.jp/
haha, fin grammatik mannen
#447
Postad 18 May 2006 - 14:16
Guppa
Guppa
Bredbildad
731 inlägg
Vi fortsätter diskussionen i Stora Blu-ray/HD DVD tråden
Minhembio & Prisjakt
Kommentera & Felrapportera
Nyhetskommentarer
Ny projektor!
