Vaova DTV-400VGA
Inga svar i detta ämne
Postad 27 December 2006 - 23:27
frav
  • frav
  • 305 inlägg
Vaova DTV-400VGA
En DVB-T mottagare med bildskärmsutgång som ger upplösningen 1280x1024. Precis vad vi letat efter för att kunna mata 17", 18" 19" LCD-monitorer som är specificerade för denna upplösning.
http://www.umax.co.u.../DTV-400VGA.htm
Kostar 1099 Danska Kronor här;
http://kaps.dk/defau...r=9532&menu=dvd
Vaova DTV-400VGA
Set-top Box with additional VGA In & Out
Turns every Display and Projector into a DVB-T TV
The DVB-T receiver Vaova DTV-400VGA is universally applicable: no matter if you want to watch the program on your TV screen or on your PC display.
Do you want to watch TV in your study without great effort, without laborious building in a TV card and installing a driver? And all this totally independent from PC, Mac and operation systems? You can plug in the DTV-400VGA via VGA output to your display and literally instantly watch digital TV. Digital TV with a projector is just as easy.
The PC can be plugged into the VGA input. Annoying plugging out and in of the display from set-top box to PC is not necessary any more. The DTV-400VGA can of course be connected to the AV input of your TV. Next to receiving digital TV and radio it also features EPG, videotext and 1280 x 1024 pixels resolution.
Specifications
Compatible with DVB-T, MPEG II standards, PCM
Resolution: 1280 x 1024 pixels
Videotext, 8-Tage EPG
PAL / NTSC / SECAM
Composite, S-Video, 2.0 analogue audio
Antenna in/out, Upgrade Service Port (USB)
VGA out (to monitor, projector), VGA in (to PC)
Audio in (PC or monitor), audio out (PC or monitor)
VGA cable, audio/video cable, antenna cable, power adapter, manual, remote control, antenna optional
