Läste på en tysk sida att priset där skulle ligga på 99.95€ för SRC-3200.
Lite bilder och fakta:
SRC-3200
Dimensions (W x H x L): 64 x 23 x 220 (mm)
Weight(without batteries): 8.5 oz (240 g)
Memory: 512KB Flash memory
Keys: 59 Keys/ 2 Pages/ 8 Devices
Learning Frequency: 20KHz - 455KHz & Pulse up to 256 bits long
Backlight: Multicolor LED
Interface: UART/ 115,200bps
IR Distance: 8 - 10 meters
Batteries: 4 X AAA Alkaline Batteries (SUM-4)
Power Consumption:
Operation current: 170 mA(max)
LCD on current: 160 µA
LCD off current: 40 µA
1. Enable to control up to 8 devices
2. Variety of LED backlight colors provide up to 7 different choices
3. Smart Macro automatically guides user through set-up procedure by learning directly
4. "Function lock" protects users from accidentally changing or deleting original set-up
5. Redesigned learning function provides solution for both existing tricky and upcoming new codes
at the same time
6. "Pick Up Sensor" not only turns on and off the remote automatically, but also saves power
when not using the remote
7. "Auto Set-up Saving" protects user¡¦s set-up from losing even taking batteries off
8. "Low Power Indicator" reminds user of power low condition by showing a warning sing on the
screen
9. Optional on-line support allows user to upgrade the latest version of software by internet
SRC-3060
Dimensions (H x W x D): 186 x 80 x 24 mm
Weight(without batteries): 7.4 oz( 210 g)
Keys: 56 Keys/ 2 Pages/ 8 Devices
Backlight: Orange LED
Batteries: 3 X AAA Alkaline Batteries (SUM-4)
Power Consumption
Operation current: 190 mA(max)
LCD on current: 180 µA
LCD off current: 30 µA
2. Orange LED backlight matches the housing color perfectly and stands out in the dark
3. Macro function is capable to store up to 60 series commends per macro key and also allows
time delay between commends
4. Redesigned learning function provides solution for both existing tricky and upcoming new codes
at the same time
5. "Pick Up Sensor" not only turns on and off the remote automatically, but also saves power when
6. "Auto Set-up Saving" protects user¡¦s set-up from losing even taking batteries off
7. "Low Power Indicator" reminds user of power low condition by showing a warning sign on the
screen
8. Optional on-line support allows user to upgrade the latest version of software by internet
/applehorn
1
16 bilder
369 filmer
