på öppet köp.
Nu får man vänta till den 21 Okt. ( troligen lite till för SE ).
Men de här ser klart bra ut, pris runt 30.000:- SEK.
http://www.excite.co...p=JAEN&wb_dis=2
Edited by - ljudnisse on 2002/08/08 10:47:37
Postad 08 augusti 2002 - 11:40 på öppet köp. Nu får man vänta till den 21 Okt. ( troligen lite till för SE ). Men de här ser klart bra ut, pris runt 30.000:- SEK. http://www.excite.co...p=JAEN&wb_dis=2 Edited by - ljudnisse on 2002/08/08 10:47:37 Postad 08 augusti 2002 - 11:51 ************************************* - Main merit High picture quality, high brightness 1. Super high definition * new development 0.87 inch (wide XGA panel) < high vision correspondence panel > loading New development 0.87 inch wide XGA panel 3 loading. (The 1,386×788 dot ×3 * approximately 328 ten thousand dots) with the super high fine LCD pixel, without doing the high picture quality source which begins high vision sweetly reappearance. The high picture quality where expression power of black becomes deep more, the high brightness due to high numerical aperture compatibility. With new model lamp loading, high brightness high contrast ratio (700: 1) It acquires. The beautiful large picture is actualized even under bright environment. 2. High brightness of maximum optical output 1,000ANSI lumen Largest optical output at the time of cinema black off actualizes the high brightness of the 1,000ANSI lumen, you can enjoy the vivid large picture even at the bright room. (At the time of cinema black mode on 850ANSI lumen) 3. The I/P conversion circuit which reproduces the material faithfully (2-3 and 2-2 pull-down) loading The film source (2-3 pull-down), computer graphics or the animation source (2-2 pull-down) with the material which was recorded is converted, faithfully to the field picture, it is natural and the smooth picture is reproduced. 4. 3d gamma revision circuit, 3d COM filter adoption It detects men John three D of horizontal direction, vertical direction, and signal level of the liquid crystal panel, the SONY individual 3d gamma revision circuit and the cross color and dot disturbance and noise are little clearing which revise the gamma quality which differs to every dot precisely it loads the 3d COM filter which reproduces the picture. Being natural brightness unevenness and color unevenness are little, it reproduces rich image. 5. Raises the reappearance power of black the cinema black mode which From it equips the cinema black mode which raises the reproducibility of black. Entire brightness is held down by the fact that approximately 20% it lowers drive voltage, reproducibility of black is reproduced to a greater extent. 6. Re-displays natural beige, at the same time more increases the reappearance of black the cinema filter attachment which You re-display natural beige, the installation and removal system " cinema filter " which at the same time more raises the reappearance power of black you have belonged. Being one-touch on the lens front, it is installing possible. Various signal input expandability 7. Various input possibilities such as digital high vision television, progressive signal and personal computer signal Video and S video, RGB/ component /HDTV input each 1 systematic equipment. The progressive signal, the digital high vision TV, to the personal computer signal it is wide from the video signal correspondence. The 8.JPEG (the still picture), the MPEG1 (animated picture) corresponds the memory stick private slot equipment which The JPEG which equips the memory stick private slot on the substance front, records to the memory stick (the still picture) to in addition the MPEG1 (animated picture) the picture to direct reproducible. The photographing picture with the high picture quality digital camera only the wide XGA panel high reappears in definition * high picture quality. In addition with the remote control button, directly sliding show function is enabled. 9. It is due to PJ multiple input expandability PJ multiple input 1 systematic equipment. By the fact that various signal interface cables are used, video and S video, the RGB/ component /HDTV, no input of the personal computer signal open-ended. In addition signal interface unit (selling separately IFU-HS1) with the AV amplifier and the like it is jointly used by the fact that, furthermore input open-ended. Ease of installation variety 10 The new side shot which evolved 2 (vertical direction automatic trapezoid revision and length and breadth simultaneous revision) Keystone distortion of vertical direction automatic operation revision. Furthermore, new side shot 2 functional loading which can revise also lengthwise simultaneously not only former cross direction. 11. 1.3 time electromotive focusing * zoom lens adoption Focusing and zoom adjustment to adopt electromotive mechanism, installation * adjustment is possible simply with remote control. 12. Putting on the floor, heaven 吊 installation possibility (selling separately heaven 吊 metallic parts PSS-610 use) In addition to the putting on the floor, also heaven 吊 installation is possible. In order to reverse up and down left and right, modification of setting with the menu is needed. 13 It is short focus * long focus conversion lens installing possibility (selling separately VPLL-CW10/CT10 use) Conversion lens of installation and removal type installing possibility. From shortly projection with the focus or the long focus is possible. Projection distance standard lens 3.8 of 100 inch picture - 4.6m It is short focus party - at the time of John lens installing (VPLL-CW10) 3 - the 3.6m Long focus party - John lens (VPLL-CW10) 5.9m Other things 14. Matches to the environment with home the stylish color * design which The pearl white collar worker of the piano finish finish is employed. It matches to the room without impairing the atmosphere of the interior. 15. Fan noise approximately 30db of industry highest class actualization Fan noise of the industry highest class which does not become the interference of viewing (approximately 30db) it actualized. (At the time of cinema black mode on) ******************************** - Main specification ' VPL-HS10 ' Projection system 3 primary color optical shutter projection systems LCD panel 0.87 Type TFT wide XGA panel 328 ten thousand pixels (1,092,168×3) Optical output (Cinema black At the time of mode off) 1000ANSI lumen (Optical efficiency * 1200ANSI lumen) * Optical efficiency, it points to the optical output of optical unit itself. Lens 1.3 time electromotive zoom lens Lamp 180W UHP type Projection picture Wide 40 - 300 inches (diagonal) Color system NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N automatic / manual change Corresponding signal 15k video signal and DTV signal (525I / 525p / 1125i / 750p) Computer signal (fH:19 - 72kHz and fV:48 - 92 Hz), Input/output Video input PJ multiple input Memory stick DVI-D Composite video: Pin and S video: RGB/ component Progressive component / component /DTV (525i,525p,1125i,750 P) / Analog RGB/S video / composite video 1 system 1 system Power source AC100 - 240V and 50/60Hz Electric power consumption Maximum: 260 W (at the time of stand-by mode: 5w) External size 345 (width) ×148 (height) ×369 (depth) mm Mass Approximately 5.4kg Main accessory Remote commander (RM-PJHS10), signal interface cable SIC-HS41 (10m), air filter for exchange -, other things Optional fixture Signal interface unit ' IFU-HS1 ' open price Heaven 吊 metallic parts ' PSS-610 ' 50,000 Yen It is short focus conversion lens ' VPLL-CW10 ' 170,000 Yen Long focus conversion lens ' VPLL-CT10 ' 170,000 Yen Postad 08 augusti 2002 - 11:59 Priset på HS10:an i Sverige måste ju bli en bra bit över 30 papp annars kan dom ju strunta i att ta in 12:an! Den här verkar ju bättre! Postad 08 augusti 2002 - 12:33 Sony VW11 : 380000 yen Sony VW12 : 472000 yen Pana AE100 : 143000 yen Epson TW100 : 410000 yen Marantz VP12: 708000 yen Så där har ni lite att jämföra med. Pris i Sverige för HS10? Vågar man gissa på 40-50 tusen? Postad 08 augusti 2002 - 12:37 Cineza (VPL-HS10) 350,000 yen Cineza (VPL-HS1) 170,000 yen VPL-VW12HT 550,000 yen Det låter inte som priset hamnar under 40000:- i Sverige Postad 08 augusti 2002 - 14:06 Men Vpl-hs1 tror jag kostade runt 300000 yen som ny. Så kanske hs10 kommer att ligga runt 30000 skr ( man kan ju hoppas ) Postad 10 augusti 2002 - 13:10 The answer is technology! What was the question? Postad 12 augusti 2002 - 11:59 finns det någon som vet när denna projektor kommer till Sverige? Kommer den att visas på arken??? Postad 14 augusti 2002 - 10:44 Pris: Drygt 40,000:- Sverige lansering Nov-2002 Ingen mässa bokad, möjligen CeBit mars-2003 ( ??? ) Postad 14 augusti 2002 - 15:58 Uppgifter från Sony Sverige: Pris: Drygt 40,000:- Sverige lansering Nov-2002 Ingen mässa bokad, möjligen CeBit mars-2003 ( ??? ) ljudnisse, vem har du talat med? De uppgifter jag har är rekomenderar pris 43.500 kr. De uppgifterna fick jag efter en hel del lirkande direkt från Sony Sverige i Spånga Då var det bara att vänta till någon som Li On får tag på ett ex så vi får veta vad den går för... Enligt specifikation bör den i alla fall inte prestera sämre än en HT10 och kanske till och med en HT11! Man kan bara drömma om hur det kommer att se ut med HTPC via DVI!!! Om rekomenderat introduktionspris är 43.500 kr så lär det väl inte dröja länge innan de säljs för typ 35.000 kr! Det var vad en Monroe kostade för mindre än ett år sedan. Kul för dem som lade mycket pengar på en HT10 för något år sedan Ps. Jag fick just följande svar på vilket återförsäljarled som kommer ansvara för försäljningen av HS10: Det blir genom HS1-ledet. Även specialister/PROFFS kommer att kunna köpa in den. Inte så överaskande kanske men då förstår jag varför Sony ligger lågt och talar om att vilja bli av med HS1 och HS2 först. Kul för dem med HS1 i lager, det blir nog till att rea ut den snabbt som f**n om de skall bli av med dem innan HS10 finns i butikerna... The answer is technology! What was the question? Edited by - emumannen on 2002/08/14 15:14:25 Postad 14 augusti 2002 - 20:34 http://www.sony.jp/p...img/top_img.jpg http://www.sony.jp/p...0/img/img04.jpg http://www.sony.jp/p...0/img/front.gif http://www.sony.jp/p...10/img/side.gif The answer is technology! What was the question? Postad 15 augusti 2002 - 10:03 Uppgifterna kommer från Niclas Sandström Key Account Manager Display Sony Sverige, SPÅNGA Postad 15 augusti 2002 - 11:32 EmuMannen: Uppgifterna kommer från Niclas Sandström Key Account Manager Display Sony Sverige, SPÅNGA Suveränt, då har vi två oberoende källor från Sony som säger ungefär samma sak. Då kan man kanske börja tro på att denna projektor kommer att kunna inhandlas innan jul! The answer is technology! What was the question? Postad 15 augusti 2002 - 17:27 Översätt denna länk med BABELFISH http://www.sony.jp/p...-HS10/size.html Enl. detta måste man ha projen minst 6,98 m från duk för 100 tum vid tak montering !!! Och för att få ner avståndet krävs en optional lens för 170.000:- yen ( orkar inte räkna om ) MEN !!! Kolla avs. när den står på bord för 100 tum size där står bara 4,63 m. ??? Kan detta stämma att det ska skilja beroende på om man har den på bord eller i tak ??? Postad 15 augusti 2002 - 20:00 Specen der mycket fin ut och kontrasten verkar iallafall vara dubbelt så bra som mitt f.d. LCD-monster VW10HT som kom med gratis Arla reklam i form av en permanent mjölkhinna framför bilden. Självklart finns den för 30.000kr med en gång, det gäller bara att söka på de vanliga smultronställena som Hi-Fi Components, Hembiobutiken mm.. Sluta vara nervösa för priset varje gång en ny produkt är på väg, det är ändå bara "rek. åf pris" vilket innebär vida ramar. /Marcus [url="http://"../show.asp?user=marcus"]bio logi[/url] Postad 15 augusti 2002 - 20:06 Jag skall ha en 90" 16:9-duk och har 590 cm till bakväggen. I värsta fall gör jag hål i väggen till tvättstugan! Ärligt talat verkar tabellerna lite konstiga... Att tillbehören är dyra förvånar mig inte, det är ju Sony! Vore kul att veta vad en reservlampa kommer att kosta... The answer is technology! What was the question? Postad 15 augusti 2002 - 22:35 är den något att ha tro? 43 tusen Postad 15 augusti 2002 - 23:34 BAD NEWS !!! Översätt denna länk med BABELFISH http://www.sony.jp/p...-HS10/size.html Enl. detta måste man ha projen minst 6,98 m från duk för 100 tum vid tak montering !!! Något måste vara fel. Om vi tar uppgifterna för takmontage, 100" 16:9-duk och minsta möjliga avstånd (a shortest) så visat tabellerna följande värde för de olika linserna: preinstallment lens: 6987 mm long focal option lens: 5950 mm short focal option lens: 3031 mm Skulle preinstallment lens throw distance vara längre än long focal lens? Knappast! Om vi jämför samma värden med tabellerna för bordsplacering får vi: preinstallment lens: 4638 mm long focal option lens: 5950 mm short focal option lens: 3031 mm Här är preinstallment lens 78% av long focal option lens och 153% av short focal option lens. Om vi räknar om de takmonterade värdena efter de förhållandena så får vi: 5950 * 0.78 = 4641 3031 * 1.53 = 4637 Så min gissning är att det rätta värdet för preinstallment lens vid takmontering bör vara cirka 4639 det vill säga dryga 4.5 meter. The answer is technology! What was the question? Postad 09 september 2002 - 07:54 http://www.japaninc....ist=gw&issue=70 Name: Sony VPL-HS10 Category: AV Price: 350,000 yen Release date in Japan: October 21, 2002 The Gist: The new Cineza VPL-HS10 is described as an "LCD video projector for home use" and indeed it is a projector that would look very cool in your home. If you can afford it. The VPL-HS10 has three built-in 0.87-inch wide XGA LCD panels, each capable of 1,090,000 pixels, and a new 180W UHP lamp to produce a stunning contrast ratio of 700:1 and throw 1,000 ANSI lumens against the wall (when 'Cinema Black' mode is switched off) to produce a high-vision compatible image. In this Cinema Black mode, the supplied voltage is reduced by 20 percent, keeping the severe brightness down a bit and giving out only 850 ANSI lumens, which assists in the reproduction of blacker blacks, the bane of LCD projectors. With rear connections for every source from HDTV to RGB and down, the VPL-HS10 can handle inputs from digital televisions and progressive scan DVD players to your PC and, thanks to the inclusion of a Memory Stick slot ("It's a Sony!") will even display your holiday snaps taken in still JPEG or moving MPEG-1 format. The clever 'Side Shot' function is now in its second iteration in this Cineza. It only weighs 5.4kg and can be secured to the ceiling if you want (doesn't that kind of limit the cool side shot thing?) and are prepared to help such an installation along via the purchase of a few metal bracket accessories that Sony has thoughtfully knocked up for you for a paltry 50,000 yen extra. So, if any uber-kind and unfeasibly wealthy readers are reading, it's my birthday a few days after the VPL-HS10 is out. Hint, hint. More info: http://www.sony.jp/C.../200208/02-0807 Postad 14 oktober 2002 - 03:53 En sak som däremot gör mig förundrad är att många specar som jag läst nämner 1000 ansi lumens som högsta ljusstyrka och 850 i cinema black mode. Men de flesta i USA verkar ha läst att det ska vara 1200 ansi lumens, samma sak i specen hos go2camcorder.de. Vilket är rätt eg.? Postad 14 oktober 2002 - 12:55 Har precis pratat med dem... Postad 14 oktober 2002 - 12:58 Postad 15 oktober 2002 - 06:02 Priset va i skrivande stund 39990:- men kommer troligtvis att sänkas nåra lappar, allt enligt snubbe. boik skulle få sin för mellan 36 och 37k på ett av sveriges EG. Vi får väl se. Den är på gång iaf. För min del blir det Tysklandköp om de inte sänker priset rejält, mer än 30k så är det inte värt att köpa svenskt. Postad 15 oktober 2002 - 10:41 Pris kontra prestanda är fortfarande bra om man köper budgetutrustning men de känns helt enkelt för protektionistiska. Med det menar jag att man är mer och mer utelämnad till att spela efter Sonys regler för att få den prestanda man vill ha. Ta min DVD-spelare till exempel. En Sony NS300 som ger utmärkt ljud och bild i förhållande till det låga priset. Den klarar dock inte CDR och CDRW (men det går att köra CDRW även om det inte stöds officiellt). Den klarar inte SVCD, MP3 med mera och det går inte att stänga av Macrovisionskyddet. Till skillnad från många andra köper jag mina musikskivor och filmer men trots det kan jag vara intresserad av att bränna ett fotoalbum med digitala bilder eller en SVCD med DV-film från semestern. När nu informationen börjar sippra ut om HS10 så börjar jag känna viss skepsis. På pappret ser den ju helt otroligt bra ut för pengarna. Dessutom så verkar den kunna leverera mycket av det vi saknat hos projektorer i det lägre prissegmentet. Hög upplösning, acceptabel kontrast och svärta, bra färgåtergivning, tyst gång med mera. Det jag varit lite skeptisk till har varit hur Sony tänkt differentiera HS10 från VW12. På pappret ser de näst intill lika bra ut och till viss del så har HS10 ett övertag. Den har bland annat en DVI-port, något som VW12 fortfarande saknar! Det har spekulerats om att HS10 skall sakna vettig bildbehandling. VW12 har bra bildbehandling men inte är den värd dubbla priset. Speciellt inte om en iScan Pro eller HTPC kan göra samma jobb för en bråkdel av pengarna. Kanske kan jag anses paranoid men jag kan inte låta bli att ställa mig frågan, vad är haken med HS10? Detta är rena spekulationer men ni som tänker köpa en HS10 kan väl passa på att kontrollera om mina teorier stämmer. Om inte så är det ju bra, annars kan det också vara bra, inte minst för Sony! Här är några av mina konspirationsteorier kring HS10. DVI-ingången klarar bara DVI-D "640x350, 640x400, 640x480, 800x600, 832x624 och 1024x768 från en HTPC. Andra upplösningar kräver en DVI/HDCP (High-bandwidth Digital Content Protection) kompatibel bildkälla. Detta skulle innebära att man inte kan använda panelerna fullt ut med en HTPC och exempelvis PowerStrip. Om man hade tänkt att använda en HTPC för att kompensera för bristfällig intern bildbehandling så är i så fall det alternativet inte så kul längre. Vad har Sony att tjäna på det? Sony försöker få acceptans för HDCP som en standard. Då kan de både skydda sitt material från piratkopiering och låsa kunderna till egen utrustning som exempelvis Sonys SAT-HD200 HD/DIRECTV mottagare! HS10 saknar vanlig analog VGA-ingång (D-sub). I stället har de utrustat HS10 med en så kallad ”PJ Multi”-kontakt. För denna kontakt krävs en speciell och proprietär sladd från Sony (kostnad i Japan 11000 yen). Det innebär att du är utelämnat till kvaliteten hos Sonys kablage för att kunna ansluta en HTPC eller exempelvis iScan Pro analogt! Det kanske inte är hela värden men jag förstår inte varför jag skall vara beroende av en bit sladd från Sony om jag vill använda projektorn med en analog signal från en dator. Hur gör jag om jag vill använda en kabel från Supra i stället hela vägen? Sony försöker marknadsföra denna produkt som anpassad för HTPC. I mina ögon ser det mer ut som anpassad för HDCP! Jag vill inte vara negativ men detta är saker jag skulle kontrollera innan jag köpte en HS10. Kan man via någon port få en 1:1 pixelmappad bild över hela panelerna med exempelvis en HTPC och PowerStrip? Jag börjar få en krypande känsla av att Sony lockar med en produkt som på pappret är så bra och till ett pris som är så lågt att många kunder inte kan säga nej. Frågan är bara till vilket pris som sagt, är det till priset att tvingas underkasta sig Sonys villkor för att få bästa möjliga prestanda? [V] Ps. Den som är intresserad kan hitta mer information kring det jag nu bygger konspirationsteorier kring i Nightportiers tråd på AVSForum: http://www.avsforum....threadid=179491 Postad 15 oktober 2002 - 13:22 En sak bara: quote: Det innebär att du är utelämnat till kvaliteten hos Sonys kablage för att kunna ansluta en HTPC eller exempelvis iScan Pro analogt! Det går väl att välja om man ska få ut VGA eller komponent på IScan Pro? Och i så fall är det väl bara att ansluta den till HS10:ans komponentingångar? Rätta mig om jag har fel. Postad 15 oktober 2002 - 14:52 Det går väl att välja om man ska få ut VGA eller komponent på IScan Pro? Och i så fall är det väl bara att ansluta den till HS10:ans komponentingångar? Rätta mig om jag har fel. Du har nog rätt pacman men via componentporten är du helt utelämnad till projektorns interna scaler (det är du ju i och för sig med alla rena linjedubblare). Många som tänker köra sin projektor med HTPC använder ju grafikkortet som scaler och mjukvara för linjedubbling. De vill väl kunna ansluta grafikkortet i sin HTPC till projektorn på enklast möjliga sätt (antigen digitalt eller analogt via DVI-porten eller analogt via en normal VGA-port)? Dessutom vill de väl kunna använda hela panelerna och inte vara begränsade till vissa specifika upplösningar! Jag gissar ju bara men visst vore det olyckligt om HS10 begränsar en HTPC till vissa 4:3 upplösningar och användning av fulla paneler till ingångar som i sin tur är beroende av en bristfällig intern scaler (såvida man inte använder en DVI/HDCP kompatibel bildkälla)? Nu får vi väl hoppas på det bästa att det går att köra valfri upplösning både för DVI och RGBHV (via Sonys sladd). Dessutom kanske det visar sig att den interna bildbehandlingen i HS10 är riktigt bra. Personligen kommer jag dock att vara misstänksam tills motsatsen bevisats... [V] Postad 15 oktober 2002 - 15:36 Postad 15 oktober 2002 - 16:17 Jag tror nog att HS10 kommer att kunna tangera prestandan för TW100 under vissa förutsättningar. Däremot tror jag inte att den kommer att leverera bättre bild "out of the box" med en billig interlaced dvd-spelare eller vhs-bandare. Säg att den kommer att kosta 35 papp och att du får en IScan Pro för 12. Då är uppe i samma pengar som de som köpte TW100 i powerbuyet betalade. Visst går det att köpa HS10 billigare men då kanske man tvingas köpa den från utlandet. Sen skall vi inte glömma bort att pengar inte är allt. Kvalitet är en annan viktig faktor som omfattar bekvämlighet, driftsäkerhet, service, möjlighet till uppgraderingar med mera. Det är väl inget fel att belysa produkters starka och svaga sidor? Varför skulle jag inte kunna spekulera om svagheter och problem så att de som kanske funderar på att köpa denna maskin kan kontrollera detaljer INNAN de köper från exempelvis Japan eller Tyskland. Det är väl bättre än att få reda på det efteråt? Är det inte det detta forum är till för, att dela med oss av våra tankar erfarenheter och att vara till nytta för varandra? [ ![]() Personligen inser och accepterar jag att det kommer att finnas dubbelt så bra projektorer till halva priset om jag bara är villig att vänta tillräckligt länge. Jag var inte beredd att vänta längre så jag köpte helt enkelt den för tillfället befintliga projektorn som jag trodde att jag skulle vara nöjd med för lång tid framöver (och medan andra väntat på HS10 har jag hunnit se över 40 filmer på min TW100). [^] TW100 har inte gjort mig besviken och inte blir bilden sämre bara för att det kommer andra projektorer med bra bild till lågt pris. Personligen är jag lyckligt lottad och har ekonomiska resurser nog för att slippa svettas över den typen av världsliga frågor. Den som riskerar att börja svettas bör nog fundera både en och två gånger på om det är en projektor de skall lägga pengarna på! [} ![]() Som någon här på forumet så vist har formulerat sin signatur: -"fattigdom är inte att äga lite utan att sakna mycket". Med min TW100 så saknar jag mycket lite. Det är min sanna förhoppning att alla framtida HS10-ägare skall känna på samma sätt. [:X] Ps. Hinken74, det är inte fint att ha baktankar om andra. Du kanske skall tänka lite på ordspråk som "It takes one to know one" eller "man dömer andra efter sig själv", bara en tanke... [V] Postad 15 oktober 2002 - 16:36 Vadå då.. man får väl drömma! [ ![]() Mattias. Postad 15 oktober 2002 - 16:50 ![]() Postad 15 oktober 2002 - 17:10 ![]() ![]() ![]() Ps. Denna tråd skall handla om HS10 så låt oss sluta tjata om min TW100 nu (åtminstone tills någon kan jämföra HS10 med TW100 baserat på egna erfarenheter). Postad 15 oktober 2002 - 18:21 Sorry att jag gled OT... Postad 15 oktober 2002 - 21:58 ![]() Mattias. Postad 15 oktober 2002 - 22:25 Jag tror som du och förväntar mig faktiskt inget annat heller.[ ![]() Emumannen för din fina proj men jag tänker inte ruinera mig bara för att få en stor fin bild. Jag har lagt mig på en "nivå" som jag har råd med.[8)] Kommer att köra med komponentanslutning och därefter tweaka så gott det går. Min DVD har dessutom video eq och gamma correction så det ska nog gå och få till en skaplig bild. Det enda jag är orolig för är Screendoor, det fanns ju anmärkan om det i recensionen som var översatt från Japan. Det går nog inte och komma undan om man inte har PS på sin spelare eller kör med HTPC. quote:HS10 saknar vanlig analog VGA-ingång (D-sub). I stället har de utrustat HS10 med en så kallad ”PJ Multi”-kontakt. För denna kontakt krävs en speciell och proprietär sladd från Sony (kostnad i Japan 11000 yen). Det innebär att du är utelämnat till kvaliteten hos Sonys kablage för att kunna ansluta en HTPC eller exempelvis iScan Pro analogt! Håller med igen(lite väl Smörig[ ![]() och som du nämnde, det kommer (alltid) att finnas bättre för mindre pengar. Fast de kommer jag aldrig att ha råd med iaf så varför vänta. Om ca 2 veckor kommer jag att ha en hs10 för ungefär 30k. [ ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Postad 15 oktober 2002 - 22:58 HS10 kvalar in i min budget och verkar ha vad som krävs. Det stora frågetecknet är ännu hur det ser ut med s-video. Kommer först att köra med min 525:a men ett byte till en spelare med komponent och progressive scan kommer så fort det går, kanske en H/K 25:a, eller nya Philipsen som är på G. Jag har även fortfarande kvar Sanyo Z1 på min lista. Lägre upplösning än HS10 men kanske ändå mycket bild för pengarna. Panasonic AE300 har jag avskrivit p.g.a den sena releasen. Mattias. Postad 15 oktober 2002 - 23:12 soulmate?[ ![]() ![]() quote:Kommer först att köra med min 525:a men ett byte till en spelare med komponent och progressive scan kommer så fort det går, kanske en H/K 25:a, eller nya Philipsen som är på G. Kan säga att jag grinar blod vissa nätter när jag tänker på att det finns en DVP-NS900 med PS och jag har en utan. Orkar inte hålla på och sälja, köpa nytt igen från england. Hade jag köpt nya grejer idag hade PS stått högt på prioriteringslistan! Postad 16 oktober 2002 - 00:18 Screendoor borde inte vara något problem med den upplösningen. Jag ser ytters sällan någon på min TW100 som har lägre upplösning. Å andra sidan såg jag den hela tiden på VW11 som har samma höga upplösning som HS10 men det var svagt och inte störande. Det beror ju dessutom på hur stor bild ni vill ha och hur nära ni vill sitta... När det gäller kontakten till PJ-multi så går det säker att köpa löst om man är beredd att jaga runt lite. Jag hittade till exempel, efter mycket om och men, lösa kontakter till GameBoy-kartar! Jag tvingades dock att köpa ett helt gäng från USA och det blev inte billigt per kontakt (jag har flera kvar om någon är intresserad)... Om det kan glädja er så skall ni veta att TW100 inte är fri från brister. Den har sina styrkor och svagheter som _ALLA_ andra projektorer och så kommer det nog att förbli flera år framöver. Vi får hoppas att jag har fel och att HS10 är ett lika stort steg framåt för hemmabioprojektorer i det lägre prissegmentet som AE100 var för ett år sedan... Jag håller tummarna för er skull! [^] Postad 16 oktober 2002 - 01:44 Det glädjer mig absolut inte! Jag va avundsjuk inte svartsjuk.[ ![]() Men jag förstår vad du menar, den "perfekta" projen till rimligt pris kommer nog att lysa med sin frånvaro ett tag till. quote:Screendoor borde inte vara något problem med den upplösningen. Jag ser ytters sällan någon på min TW100 som har lägre upplösning. Fast då har ju du dcdi i din men det är ju lite lugnande att höra iaf.[^] quote:Jag håller tummarna för er skull! TACK!![ ![]() Postad 16 oktober 2002 - 13:35 ![]() Postad 17 oktober 2002 - 22:32 http://www.avsforum....threadid=180871 Kan det vara sant, vore ju suveränt iså fall, nån som hört nåt liknande? Mattias. Postad 18 oktober 2002 - 10:47
The Hem & Villa mässa will be held in Älvsjö next week. A part of this exhibition will focus on home cinema. I noticed from the exhibitor list that Sony, Panasonic and Sanyo is going to be there. Will be very interesting to see if any of them is showing the new machines presented at CEDIA. I will go there myself and have a look.
Postad 18 oktober 2002 - 19:58 Postad 19 oktober 2002 - 17:57 Läs här http://www.avsforum....433#post1453433 Det börjar som vattnas i munnen när man läser det... tyvärr måste man ju ändå hålla sig lugn i.o.m att man inte har nån aning om vem snubben är och vad han har för erfarenhet av projektorer... men lovande ltåer det! [ ![]() Mattias. Postad 23 oktober 2002 - 17:19 Cinema Concept http://www.hemmabio.se/ has put some rough prices on their website related to the Sony VLP-HS10, VLP-HS2 and Sanyo PLV-Z1. If these are the general prices here in Sweden than there is only one thing left to do and that is order it from abroad. Postad 23 oktober 2002 - 17:53 ![]() 1 användare läser detta ämne0 medlemmar, 1 gäster, 0 anonyma medlemmar |
Trendande produkter |
