PENTAX K-3
97 svar till detta ämne
Ricoh-Pentax K-3 (Systemkameror) 6 9.166666 (5) Inga priser
Ricoh-Pentax K-3 + 18-135/3,5-5,6 WR (Systemkameror) 7 (0) Inga priser
Ricoh-Pentax K-3 + 18-55/3,5-5,6 WR (Systemkameror) 7 (0) Inga priser
Ricoh-Pentax K-3 II (Systemkameror) 6 8.75 (3) Inga priser
Postad 07 October 2013 - 12:46
Pentax K
  • Pentax K
  • 284 inlägg
WR
PENTAX K-3
Type
Digital SLR
Sensor
Type: CMOS w primary color filter and integrated Shake/Dust Reduction sensor movement system
Size: 23.5 x 15.6mm
Color depth: 8 bits/channel JPG, 14 bits/channel RAW
Effective pixels: 23.35 MP
Total pixels: 24.71 MP
Recorded resolutions
Still: Jpeg –
L (24M:6016x4000),
M (14M: 4608x3072),
S (6M: 3072x2048),
XS (2M: 1920x1280)
RAW – L (24M:6016x4000)
Quality levels: ★★★ Best, ★★ Better, ★ Good, RAW (14-bit)
Movie (resolution/FPS):
Full HD (1920x1080, 60i/50i/30p/25p/24p)
HD (1280x720, 60p/50p/30p/25p/24p)
Dust Removal: DR II (ultrasonic vibration to low pass filter) with Dust Alert function
Lens
Type/construction: PENTAX KAF2 bayonet stainless steel mount
Usable lenses: PENTAX KAF3, KAF2, KAF, and KA (K mount, 35mm screwmount, 645/67 med format lenses useable w adapter and/or restrictions)
SDM function: Yes
Power zoom function: Yes (power zoom only)
Focus System
Type: SAFOX 11 TTL phase-matching - 27 point (25 cross type focus points in the center)
Focus modes: AF Single (w focus lock, focus/shutter priority selectable), AF Continuous (w focus/FPS priority selectable), Manual
Focus point adjustment: Spot, Select, Expanded Area (S, M, L), Zone select, Auto (27 AF points)
Viewfinder
Type: Pentaprism
Coverage (field of view): 100%
Magnification: 0.95X (w 50mm F1.4 at infinity)
Standard focusing screen: Natural-Bright-Matte III (interchangeable)
Diopter adjustment: -2.5m to 1.5m
Depth of field preview: Optical (diaphragm stop-down), Digital
LCD Monitor
Type: 3.2” TFT color LCD with brightness/saturation/color adjustment AR coating and air-gapless glass.
Resolution: 1037K dots
Wide angle viewable: Yes
Flash
Type: Retractable P-TTL popup flash
Guide number: 13m (ISO 100)
Coverage: 28mm wide angle (equiv 35mm)
Flash modes: Auto, On, Redeye, Slow Sync, Slow Sync + Redeye, Trailing Curtain Sync, High-speed sync, Wireless, Manual
Flash exposure compensation: -2 to 1 EV (1/2 steps)
External Flash
Type: Hotshoe (P-TTL), high speed sync and wireless w PENTAX dedicated flash, X-Sync Socket
Synchronization speed: 1/180 sec
Storage Media
Internal memory: n/a
Removable memory: SD, SDHC, SDXC, EyeFi, FLU
Interfaces
Ports: USB 3.0 hi-speed, AV out, HDMI out, DC in, cable switch, 3.5mm stereo microphone, X-sync socket
Video out: HD (via HDMI), NTSC, PAL
Printer interfaces: n/a
Power Supply
Power source: Rechargeable Li-Ion battery D-LI90, D-BG5 Battery Grip (optional) with trays for 2nd D-Li90 battery or 6x AA batteries
Recordable images: Approx 720 (approx 560 w 50% flash, CIPA)
Playback time: Approx 370 min
Movie recording time: Approx 25 min (automatic overheat shutdown protection)
AC adapter available: Yes - (optional) K-AC132
Physical Specs
Body dimensions (W x H x D): 5.17in x 3.94in x 3.05in
Body weight
Without battery or removable memory: 25.2 oz
Loaded and ready: 28.2 oz
Construction material(s): Magnesium alloy shell over metal chassis
Weather resistant: Yes (92 special sealing parts)
Operating temperature: 14-104°F (-10 to 40°C)
Language Support
English, French, German, Spanish, Portuguese, Italian, Dutch, Danish, Swedish, Finnish,
Polish, Czech, Hungarian, Turkish, Greek, Russian, Korean, Chinese
(Simplified/Traditional), Japanese
Image Stabilization
Type: Sensor-Shift Shake Reduction with rotational compensation (3.5EV TBD)
Electronic level function: Yes, verification via viewfinder and LCD panel
Metering System
Type: TTL open aperture metering using 86K pixel RGB sensor
Sensitivity range: EV -3 to 20 (ISO 100, 50mm F1.4)
Multi-Segment: Yes
Center weighted: Yes
Spot: Yes
Exposure compensation: +/- 5 EV (1/3 and 1/2 steps)
Exposure lock: Yes
Exposure bracketing: Yes (2, 3, or 5 frames, up to +/- 2 EV in 1/3 or 1/2 steps)
ISO Sensitivity
Auto: ISO 100-51200 (1, 1/2, 1/3 steps), Auto ISO range selectable,
Bulb mode: Auto ISO n/a
Manual: 100-51200 (1, 1/2, 1/3 steps),
White Balance
AUTO WB, Multi Auto WB,
Daylight, Shade, Cloudy, Fluorescent Light (D: Daylight Color, N:Daylight White, W:Cool White, L:Warm White), Tungsten Light, Flash, CTE,
Manual mode(s): Yes, Manual WB (up to 3 settings), Color Temperature Configuration (up to 3 settings), Copying the white balance setting of a captured image* WB fine adjustment available in all modes
Shutter
Type: Electronically controlled, vertical-run, focal plane shutter
Shutter speed: 1/8000 to 30 sec (1/3 or 1/2 EV steps), Bulb
Capture Modes
Mode selection: Green, Hyper Program (P), Sensitivity Priority (Sv), Shutter Priority (Tv), Aperture Priority (Av), Shutter & Aperture Priority (TAv), Metered Manual, Bulb, X-Speed, USER (3 presets).
Custom Image Modes: Bright, Natural, Portrait, Landscape, Vibrant, Radiant, Muted, Bleach Bypass, Reversal Film, Monochrome, Cross Processing,
HDR: Auto, HDR1, HDR2, HDR3, Exposure Bracket Value adjustable, Automatic composition correction function
- All include gamut radar and fine adjustment of saturation, hue, high/low key, contrast, and sharpness (regular and fine adjustment scales). Monochrome mode includes adjustments for filter effects (green, yellow, orange, red, magenta, blue, cyan, infrared), toning (sepia, warm/cool), high/low key, contrast, and sharpness (regular, fine, and extra sharp adjustment scales).
Green simplified mode available: Yes
P/A/S/M/B: P, A, S, M, B (extended modes Sv, TAv)
Date stamp: n/a
Digital filters (capture): Extract Color, Toy Camera, Retro, High Contrast, Shading, Invert Color, Unicolor Bold, Bold Monochrome
Data record: Folder name (standard, date), file name (standard, customizable), embed copyright.
Drive Modes
Mode selection: Single, Continuous (H,M,L), Self-Timer (12s, 2s), Remote (0s, 3s, continuous), Exp. Bracketing (standard, timer, remote), Mirror up (standard, remote), HDR Capture (3 shots at 1EV, 2EV, or 3EV, 3 blend settings plus Auto, pixel alignment)
Multi-exposure: Composite Mode (Additive/Average/Bright) Number of Shots (2 to 2000 images), Interval 2000 shots, 2 sec to 24 hrs, time delay available)
Continuous FPS (JPG ★★★)
- Continuous H: Approx 8.3 FPS (60 JPG, 23 RAW)
- Continuous M: Approx 4.5 FPS (100 JPG, 32 RAW)
- Continuous L: Approx 3.0 FPS (200 JPG, 52 RAW)
Self-timer: Yes (12s, 2s)
Remote control: Yes, infrared (0s, 3s, continuous), cable switch
Playback Modes
Mode selection: Single frame, multi-image display (6,12, 20, 35, 80 segmentation), display magnification (up to 16, 100% display and quick magnification available), rotating, histogram (Y histogram, RGB histogram), bright area warning, Auto Image Rotation, detailed info, Copyright Information (Photographer, Copyright holder), Folder Display, Calendar Filmstrip Display, Slide Show Mode pallet: Image Rotation, Digital Filter, Resize, Cropping, Slideshow, Save as Manual WB, RAW Development, Index Print, Protect, Movie Edit, Extract JPG from Movie, Magnification: up to 16X, scrollable, quick magnification.
Digital filters (playback): Base Parameter Adj, Extract Color, Toy Camera, Retro, High Contrast, Shading, Invert Color, Unicolor Bold, Bold Monochrome, Tone Expansion, Sketch, Water Color, Pastel, Posterization, Miniature, Soft, Starburst, Fish-eye, Slim
File Formats
Still: RAW (PEF, DNG), JPG (EXIF 2.30), DCF 2.0 compliant
Movie: MPEG-4 AVC/H.264(MOV) - JPEG(AVI) for internal movie record
Custom Functions
Functions available: 27
Computer Requirements
*For device connectivity. Bundled software requirements may vary.
Windows: Windows 8 (32 bit/64 bit) / Windows 7 (32 bit/64 bit) / Windows Vista (32 bit/64 bit), Windows XP SP3 (32 bit)
Mac: Mac OS X 10.8 / 10.7 / 10.6
Battery Life
Dimensions
Weight
Body weight
Operating Temperatures
Operating Humidity
Redigerat av Pentax K, 08 October 2013 - 04:48.
Postad 07 October 2013 - 18:27
Mikael_R
  • Mikael_R
  • 15622 inlägg
Bra jobbat Pentax! Kul att AF modulen får lite uppsving, blir helt klart det mest prisvärda i det övre asp-c segmentet!!!
Postad 07 October 2013 - 21:39
RedMarathon
  • RedMarathon
  • 1883 inlägg
Undrar vad priset kommer att ligga på, vad tror ni om runt 13 000 kr????
Postad 07 October 2013 - 23:49
Supernaut77
  • Supernaut77
  • 4148 inlägg
Wow, den har verkligen "extra av allt". Ska bli spännande att se de inledande rapporterna från de som haft förserieexemplar och nu får tala fritt :)
Pentax forums har en bra genomgång: http://www.pentaxfor...-announced.html
Postad 08 October 2013 - 10:21
topace
  • topace
Ser riktigt mäktig ut. Blir nog inköp. Tyvärr kommer nog $1300 att motsvara 13000kr, trots det låga dollarvärdet.
Postad 08 October 2013 - 11:02
Pentax K
  • Pentax K
  • 284 inlägg
Tror nog att risken finns för att det kan bli så illa men vi kan hoppas på ett pris runt 10 000 kr. Skall man samtidigt köpa några objektiv kan man säkert motivera en kortare tripp till USA och tjäna in biljettkostnaden på det lägre priserna "over there" (men tyvärr så missar man då förmodligen garantin).
Redigerat av Pentax K, 08 October 2013 - 11:04.
Postad 08 October 2013 - 11:11
Supernaut77
  • Supernaut77
  • 4148 inlägg
4 sidor med genomgång av finesserna: http://www.ricoh-ima...ts/k-3/feature/
Edit: Ang. pris så var officiella priset för K-5 $1400 och jag förbokade på cyberfoto för 11000 vilket var 1000 i rabatt vid det tillfället. Om man nu kan dra några paralleller... :)
Redigerat av Supernaut77, 08 October 2013 - 11:14.
Postad 08 October 2013 - 16:09
Mikael_R
  • Mikael_R
  • 15622 inlägg
Grymt!
Förlåt förlåt att jag är liiiiite neggo trots det gigantiska AF framsteget... men liiite synd att dom packat ihop dom så tätt...
Men å andra sidan 1: så lär kontinuerlig fokus med tracking bli riktigt bra nu! Förhoppningsvis i samma klass som Canikon (objektiv med inbyggd AF motor, då skruvdrivet varierar ganska mycket från objektiv till objektiv)
Men å andra sidan 2: så är nog storleken på af modulen avgörande för att få en så kompakt kamera som möjligt.
Redigerat av Mikael_R, 08 October 2013 - 16:10.
Postad 08 October 2013 - 16:39
Pentax K
  • Pentax K
  • 284 inlägg
Känns som en rätt ok kamera och kul att AF har uppgraderats ordentligt. Ska bli kul att läsa resultat av tidningars tester samt användaromdömen. Även bra med sådana små uppdateringar som
"Mode dial unlock lever:
This lever has two positions to prevent accidental operational errors: one position allows you to turn the mode dial only when the lock button is pressed; the other position frees the mode dial lock for speedier operation"
Men jag tror att många med K-5 kameror är så nöjda med den att de knappast har någon brådska med att uppgradera till en K-3:a. Finns här någon med en K-5:a som funderar på ett inköp av en K-3:a? Har man något äldre än en K-5:a kan det förstås vara dags för ett byte men som jag skrivit tidigare är det mest en K-5II eller K-5IIs som skulle vara aktuellt för mig
Postad 08 October 2013 - 17:42
Mikael_R
  • Mikael_R
  • 15622 inlägg
Jag hade bytt direkt :D först i kön, tälta utanför butiken typ
Postad 08 October 2013 - 18:49
RedMarathon
  • RedMarathon
  • 1883 inlägg
Ja du Micke, det är väl inte försent än att du packar ihop campingutrustningen och samtidigt avyttra din Nikon. :D
Håller med dig Pentax K att det känns inte alltför angeläget att uppdatera sin K 5:a.
Men blir priset det rätta så kan man ju alltid ändra sig.
Redigerat av RedMarathon, 08 October 2013 - 18:53.
Postad 08 October 2013 - 19:46
Mikael_R
  • Mikael_R
  • 15622 inlägg
Mjaaanäee :P ja man vet ju aldrig med mig....
Nä då, jag är nöjd med det lilla jag har, och jag är numer vaktmästare åt banken så det finns inte utrymme att byta foto prylar nu :D
Redigerat av Mikael_R, 08 October 2013 - 19:47.
Postad 08 October 2013 - 20:02
Supernaut77
  • Supernaut77
  • 4148 inlägg
Jag tar för få bilder och när jag väl gör det så är är det inte mer krävande situationer än att min K-5 duger gott. Mina pengar läggs på hög till denna skapelse kommer med en större sensor :)
Cyberphoto säljer den för 10990:- förresten.
Postad 08 October 2013 - 20:12
Unregistered590ad3db
  • Unregistered590ad3db
  • 200 inlägg
Det kan du skriva opp gosse! Har redan bokat en hos Foto Posé.
Postad 08 October 2013 - 20:19
Pentax K
  • Pentax K
  • 284 inlägg
Bra X-country :)
Här är Pentax K-3 reklam på YouTube
http://youtu.be/DPp7Xcq-NIw
Redigerat av Pentax K, 08 October 2013 - 20:23.
Postad 08 October 2013 - 20:36
RedMarathon
  • RedMarathon
  • 1883 inlägg
Jag är säker på att du får många slantar för dina Nikonprylar så du behöver inte bekymra dig om ditt vaktmästarjobb ;)
x-country vi vill att du kommer med en lite recension, se om du kan trigga oss andra till inköp.
10990 kr är ju inte blodigt.
Redigerat av RedMarathon, 08 October 2013 - 23:37.
Postad 08 October 2013 - 20:54
Mikael_R
  • Mikael_R
  • 15622 inlägg
njae... jag får ingen K-3 + 31/43/71 för mina Nikon leksaker
Postad 08 October 2013 - 21:15
Supernaut77
  • Supernaut77
  • 4148 inlägg
Vad jag har hört finns massor med pengar på just banken ;)
X-C: Har du fått något preliminärt leveransdatum?
Postad 11 October 2013 - 06:41
  • 200 inlägg
Nej, men min fotoaffär brukar få första sändningarna så jag hoppas på det även denna gång.
Postad 18 October 2013 - 20:13
Pentax K
  • Pentax K
  • 284 inlägg
I vänta på att K-3:an börjar levereras är här en liten jämförelse mellan K-5 och K-3
http://youtu.be/8UuUVX03FD0
Vid denna jämförelse mellan K-3 och Nikon D600 som är en 24 MP FF-kamera "krossade" K-3:an Nikons D600 (ska kanske tas med en nypa salt)
Pentax K-3 / Nikon D600
Redigerat av Pentax K, 29 October 2013 - 21:36.
Postad 30 October 2013 - 11:55
marmit
  • marmit
  • 18 inlägg
Någon som vet mer om säljstart i Sverige? Cyberphoto har nu ändrat från 'v 44' till 'början av november' till 'lev datum okänt'. :(
Postad 01 November 2013 - 07:00
  • 200 inlägg
Min kommer nästa vecka enligt Foto Posé i Östersund :)
Postad 03 November 2013 - 12:18
Supernaut77
  • Supernaut77
  • 4148 inlägg
Det ser vi alla fram emot. Kanske inte lika mkt som du gör själv dock :D
Som vanligt har Pentax en itusågad kamera i sina montrar på mässor. Som ingenjör är man svag för sånt :)
Fler bilder från montern på http://qicai.fengnia...077289_all.html
Användaren Winder på pentaxforums har provat den följande autofokusen på K-3 och den verkar fungera bra, speciellt med pentax-mått. Skönt eftersom AF-C har varit den kanske största anledningen att inte välja märket tidigare. Serierna är tagna på f/2.0 och f/2.8 för att utmana.
Se: http://www.pentaxfor...test-picts.html
Bifogad fil  Skärmklipp.PNG   600.04K   3 Antal nerladdningar
Redigerat av Supernaut77, 03 November 2013 - 12:20.
Postad 04 November 2013 - 20:21
  • 200 inlägg
Var in till min fotohandlare idag. K-3:orna finns i landet hos distrubitören. Kameran skickas i morgon och bör vara hos Foto Posé på torsdag.
Postad 07 November 2013 - 13:31
marmit
  • marmit
  • 18 inlägg
Min Pentax K-3 kom med posten idag :D . Tack Cyberphoto för som vanligt bra service! Bifogar bild med mitt Ebay-fynd, Sigmas monsterzoom 50-500/4.5-6.3.
Nu ska det fotograferas! Svårt att pensionera min trotjänare Pentax K-5. Den får nog bli andrakamera.
Bifogad fil  Pentax K-3 & Sigma 50-500.jpg   241.35K   14 Antal nerladdningar
Postad 07 November 2013 - 15:12
marmit
  • marmit
  • 18 inlägg
Hallelulja! Pentax K-3 Hands-On Field Test från TheCameraSToreTV
http://www.youtube.c...h?v=obRn__ZBq2A
Postad 07 November 2013 - 16:06
Pentax K
  • Pentax K
  • 284 inlägg
Härligt med din K-3:a förstår jag
Fick bra recension av The Camera Store men fortfarande är den svaga punkten AF. Han nämnde lustigt nog den lilla saken som jag noterade tidigare ang Mode dial unlock lever.
Postad 08 November 2013 - 06:30
  • 200 inlägg
Hämtade ut denna fantastiska apparat på lunchen igår. Eftersom det är kolsvart ute när jag slutar jobba så blev det ingen fotografering utomhus. Men jag har i alla fall hunnit pilla på manicken. Några första intryck hittills:
Hårdvara:
Sökaren är märkbart bättre.
Slutaren känns tystare och mjuk.
Ergonomin är om möjligt bättre en K-5/7 och så gäller även byggkvaliteten.
Mjukvara:
Liveview har "snabb" autofokus och flera lägen
Äntligen focus peaking.
Eye-Fi stöd i kamerans menysystem!
Postad 08 November 2013 - 12:11
Pentax K
  • Pentax K
  • 284 inlägg
Hårdvara:
Mjukvara:
Minns jag inte helt fel hade du även köpt en Sony A7. Hur är den i jämförelse med K-3:an jag har aldrig provat någon spegelfri systemkamera så det vore intressant att höra hur Sonys är.
Postad 09 November 2013 - 10:47
  • 200 inlägg
Nja. A7:an finns inte att köpa än. Men annars har du rätt. Jag har beställt en A7r. I väntan på att Ricoh släpper en Pentax med småbildssensor :-)
Postad 09 November 2013 - 17:03
Pentax K
  • Pentax K
  • 284 inlägg
Nu har Imaging Resource gjort en test där de jämfört K-3:an med K-5 II, Canon 70D, Nikon D7100, Olympus E-M1 och Sony A77.
Postad 13 November 2013 - 07:02
marmit
  • marmit
  • 18 inlägg
Och det finns ytterligare en test på Pentax forums : http://www.pentaxfor...troduction.html
Postad 24 November 2013 - 12:36
Supernaut77
  • Supernaut77
  • 4148 inlägg
En funktion som det inte talas om i tester (som jag sett) är att kameran justerar vitbalansen i olika delar av bilden om det är blandat ljus.
Ni som har kameran; fungerar det bra? Jag antar att det bara är i jpeg? Posta gärna exempel :)
Postad 24 November 2013 - 21:29
Mikael_R
  • Mikael_R
  • 15622 inlägg
Grymt bra ide i alla fall! Kan bli fullständigt galen av att se hur olika ljuskällor ger olika vitbalans när man fotar. Ett bra exempel är inomhus på kvällen med all belysning... släng in en blixt och pang... ett inferno av olika vitbalaser. Lösningen.. köp bara en typ av lampor till alla armaturer! Eller köp en Pentax K-3...
Postad 26 November 2013 - 18:57
marmit
  • marmit
  • 18 inlägg
Just hemkommen från en tvåveckors safariresa med min K-3 och ska sätta igång med Lightroom och 2 500 RAW bilder. Postar senare här om någon blev OK . . .
En sak som faktiskt är sämre än tidigare är att fyrvägsknappen på baksidan (den för vitbalans, blixt, seriebildstagning och färgeffekt) har blivit litet mindre distinkt - i alla fall jämfört med min K-5 (version 1). Resultatet blev att jag ett par ggr varje dag i en skumpig jeep ofrivilligt ändrat olika parametrar. K-3 an verkar också dra litet mer batteri än K-5.
En sak jag undrar över är hur man når 8,3 FPS med 24 M RAW filer? Vilken skrivhastighet krävs på SD-kortet?
Postad 02 December 2013 - 10:01
marmit
  • marmit
  • 18 inlägg
Bifogar två bilder (i full upplösning) från Safari i Ruaha/Tanzania. De är tagna i RAW med Pentax K-3 & Sigma 50-500/4,5-6,3, handhållet från jeepen och med OS på i objektivet (av i kamerahuset). Jag har justerat nivåer i Lightroom och lagt på lätt brusreducering & skärpa.
Lejonhannen är tagen med ISO400, f=500 mm, f/6,3, 1/200s
Vattenbuffeln med ISO400, f=330, f/14, 1/250s
Helnöjd med kameran - och Sigmazoomen. Tillsammans var de perfekta på denna resa och gav möjlighet att ta bilder både nära och på långt avstånd utan att behöva byta objektiv i dammet
Postad 02 December 2013 - 22:15
Zacabeb
  • Zacabeb
  • 2484 inlägg
Ju mer jag läser om den här kameran, desto mer imponerad blir jag. Vad är Pentax hemlighet?
Bara en sån sak som att vädertätningen illustreras med en dyngsur kamera samt att den hävdas klara spöregn och iskyla. Som ägare av en kamera i samma prisklass från ett annat märke har jag visserligen också vädertätning, men den lär bara fungera inomhus (min kamera tål regn så länge den inte kommer i kontakt med det).
Eller användandet av magnesium. Min kamera är av plast.
Och programvalen sen... tre egna lägen, snabbval för att styra exponering via ISO, ingen tramsautomatik som "springande barn i skymning med sammetseffekt"-läge... inget tjafs som är ivägen. Gröna knappen också.
Med andra ord är jag avundsjuk på er som har denna kamera. Det enda jag grubblar över om jag skulle gilla är ergonomin... men så har jag inte hållit i en K-3 heller.
Postad 03 December 2013 - 02:47
ida_ss
  • ida_ss
  • 459 inlägg
Ser trevligt ut, Marmit! Ser fram mot fler bilder, häftig resa!
Zacabeb, roligt att läsa dina reflektioner och tankar. Pentax är fantastiskt! ;) Är själv lite sugen att byta ut min K-5'a, men får nog dröja lite då jag fortfarande är väldigt nöjd med den. Pentaxergonomin är svår att inte gilla, testa! :)
Redigerat av ida_ss, 03 December 2013 - 02:48.
Postad 03 December 2013 - 13:43
Supernaut77
  • Supernaut77
  • 4148 inlägg
Trevligt! Imponerande också att du hunnit köpa kameran och åka på safari redan. :)
Zacabeb: Jag tycker du ska unna dig att klämma på en K-3. Tyvärr verkar en klassiker inom "klämma och prova", Mediamarkt, inte längre ha märket. Iaf inte i Bäckebol, Gbg :(
Postad 04 December 2013 - 09:03
marmit
  • marmit
  • 18 inlägg
Jo - safarin var kostsam och jag kunde ju inte åka med undermålig fotoutrustning och därigenom sabotera hela upplägget ;). Lyckades få leverans av en av Cyberphotos första K-3:or dagarna innan jag åkte. Det blev dessutom väldigt bra med K-3 + Sigma 50-500/4,5-6.3 och som andra-kamera min gamla K-5 + Pentax 18-135/3.5-5.6 för att kunna ta både landskap och djur på avstånd.
Pentaxobjektivet gick dessutom sönder (!) - redan andra dagen. Ett kontaktbleck (för AF) blev skadat och det var några skräckfyllda ögonblick innan jag insåg var felet var och lyckades få ihop det så det fungerade igen.
Postad 24 January 2014 - 08:57
Tava
  • Tava
  • 10 inlägg
Just nu 1200:- rabatt på Cyberphoto:
http://www.cyberphot...php?article=K-3
9569:- med postfrakt.
Postad 24 January 2014 - 12:17
Supernaut77
  • Supernaut77
  • 4148 inlägg
Just nu 1200:- rabatt på Cyberphoto: http://www.cyberphot...php?article=K-3 9569:- med postfrakt.
Riktigt bra pris! Börjar bli utrymme i prislistan för en prisvärd FF nu ;)
Postad 24 January 2014 - 15:15
Mikael_R
  • Mikael_R
  • 15622 inlägg
ha! och det har vi aldrig tänkt förut :D
Postad 24 January 2014 - 15:27
Supernaut77
  • Supernaut77
  • 4148 inlägg
Men teoretiskt har jag rätt!
Postad 24 January 2014 - 17:28
Mikael_R
  • Mikael_R
  • 15622 inlägg
Det sorgligaste med Pentax, är inte FF enligt mig, det är att dom i princip blir överkörda i aps-c segmentet, av såna som Fujifilm (men fuji började från scratch).
Det är som du sa Supernaut... för längesen... att Pentax borde gjort en ny fattning för längesen. En spegellös fattning som även skulle teckna ut FF i framtiden.
Postad 24 January 2014 - 19:11
Supernaut77
  • Supernaut77
  • 4148 inlägg
Nåja, Pentax kör imo över de andra spegelreflexerna i aps-c segmentet såsom Nikon och Canon så jag tycker du överdriver en smula. ;)
Däremot är små, nätta kameror deras hemmaplan så spegellöst vore perfekt. Se bara hur fin Ricoh gjort sin GR. Lovande :)
Postad 24 January 2014 - 20:15
Mikael_R
  • Mikael_R
  • 15622 inlägg
Sant!
Postad 25 January 2014 - 03:20
RedMarathon
  • RedMarathon
  • 1883 inlägg
10690 kr får då jag då jag lägger den i kundvagnen, var rabatten väldigt kortvarig?
Postad 25 January 2014 - 19:40
Tava
  • Tava
  • 10 inlägg
Japp.
Rabattkoden är borttagen fråb Cyberphoto nu.
Jag testade koden (K3JAN) nu och då sa den att koden hade utgått.
Tur att jag hann köpa den.
Har knappt hunnit testa kameran än, men det viktigaste för mig är testat: shutter lag.
Med spegeluppfällning är shuttern helt öppen efter 0,0145 sekunder.
Jag fotar blixtar med en lightningtrigger och då är det viktigt att kameran reagerar snabbt.
Min förra Pentax K7 reagerade på 0,025 sekunder med spegeluppfällning vilket var bra.
Med K3 kommer jag få bilder med mindre brus, bättre färgåtergivning och högre upplösning.
Med högre upplösning vågar man fota mer utzoomat då man kan beskära mer i efterhand.
Nu väntar jag bara på att DXO ska testa min Tamron 17-50/2,8 på K3:
http://www.dxomark.c...-the-Pentax-K-3
Redigerat av Tava, 25 January 2014 - 22:22.
Postad 13 February 2014 - 20:48
ComaBoB
  • ComaBoB
  • 114 inlägg
Jag köpte en K-3an med 18-135 mm objektivet förra veckan för 12000 kr jämnt, det tycker jag är ett bra pris
Redigerat av ComaBoB, 13 February 2014 - 22:48.
