Fire Emblem: Awakening + Fates [3DS]
114 svar till detta ämne
#101
Postad 02 April 2015 - 16:57
Unregistered5deb0b1d
4329 inlägg
Dock vet vi väl inte om det blir samma i EU? Jag vill ha complete edition =/
Nej hoppet finns att de kommer en utgåva och inte blir en sådan variant.
Mer om den japanska versionen:
Fire Emblem If: White Kingdom will be the easier title, providing alternate ways to gain EXP and money, as well as more freedom - Fire Emblem If: Black Kingdom will limit these experiences and requires more strategy to maintain resources - White Kingdom and Black Kingdom's storylines are the same until chapter 6. From here, the storylines split. -If you buy only one physical copy, you'll be locked into whatever game you purchase. However, for 2,000 yen, you can download DLC with the other story path. -For digital users, players are given a choice of what path they would like to take. The other path (the one you don't choose) is available to download as DLC for 2,000 yen. -A third storyline will be available as DLC, though details aren't known about this DLC yet. -A special edition Fire Emblem If bundle, a two in one cartridge that has both versions of the game, as well the third storyline, limited edition artbook and trading card will be available for 9,250 yen.
#102
Postad 02 April 2015 - 17:21
Transform
38133 inlägg
Hmm, jag vill spela god men jag vill inte ha det lätt. I'm fucked?
#103
Postad 02 April 2015 - 18:25
4329 inlägg
Det jag har hört är att White kommer att vara gamla klassiska Fire Emblem medan Black kommer att vara ett annorlunda och mer utmanande sätt att spela. Tror inte man överger svårighetsgraden i spelet.
#104
Postad 19 May 2015 - 18:57
Transform
38133 inlägg
The Weapon Triangle, which has been a mainstay in the Fire Emblem series since 1996, will see a reform in the upcoming Fire Emblem If for 3DS, the latest issue of Famitsu reveals. Instead of the standard swords over axes over lances, it’s been changed to swords and magic, over axes and bows, over lances and concealed weapons.
In brief, swords and magic are stronger than axes and bows, while axes and bows are stronger than lances and concealed weapons, and lances and concealed weapons are stronger than swords and magic.
As previously reported, weapon durability is no longer present in Fire Emblem If. But the disadvantages of this are that the stronger the weapon, the larger the unit’s disadvantage in terms of abilities. For example, the Bronze Sword has no chance of landing a Critical hit, but has +10 Critical evasion, while the stronger Steel Sword has -5 evasion and makes it hard to use a Pursuit attack. Only staffs restrict the amount of times they can be used.
Maids, butlers, and shinobi use concealed weapons, which have weakening effects on enemy abilities when attacked.
#105
Postad 24 February 2016 - 17:05
Transform
38133 inlägg
Bästa launchen i seriens historia i USA.
Under tiden väntar vi i EU fortfarande =/
#106
Postad 18 May 2016 - 10:47
6891 inlägg
Det mest oväntade stället, har denna otroligt svåra limited utgåva på lager av Fates spelen
http://www.ellos.se/...065&pr=0C1B2S3T
Passa på innan den är borta, för dom börjar gå för betydligt högre summor nu på Amazon och Ebay.
Redigerat av Svante Skoog, 18 May 2016 - 11:01.
#107
Postad 18 May 2016 - 11:16
Transform
38133 inlägg
Lol, på Ellos... ja lite oväntat.
Jag började spela Fates igår, mycket mer strömlinjeformat än tidigare spel (snabbare strider/övergångar/få laddningstider). Men har inte kommit särskilt långt ännu.
Var jäkligt längesedan jag spelade på 3DS dock, kom inte ihåg att skärmen var sååå liten =P
#108
Postad 18 May 2016 - 11:53
6891 inlägg
Själv har jag kommit 2/3:e delar in i Awakening, brutalt bra spel, men ser fram emot att köra igenom Fates trilogin efteråt
#109
Postad 18 May 2016 - 12:59
Alex81
Alex81
200 inlägg
Det verkar som Media Markt har den lite billigare, 899:- stället för 1199:-.
http://www.mediamark...ds-1282746.html
#110
Postad 06 June 2016 - 18:40
Transform
38133 inlägg
#111
Postad 06 June 2017 - 20:42
Transform
38133 inlägg
MHB:s recension
(av Shadows of Valentia, det sista main på 3DS)
Kul att läsa vår diskussion från 2013 Mdag, bara vi som pratade i tråden flera sidor
Redigerat av Zoiler, 06 June 2017 - 20:42.
#112
Postad 01 July 2017 - 18:11
Transform
38133 inlägg
Varvade Valentia igår, 45 timmar. Slutstriden pågick över två dagar eftersom man dör direkt när Alm (huvudkaraktären) dör. När alla andra dör kan man spola tillbaka tiden, vilket jag också gjorde alla 11 gånger jag kunde pga att slutbossen anföll med en attack som skadade alla i laget och nådde över hela skärmen samt pumpade ut fiender en masse + underbossar.
I slutändan hade jag inga livlinor kvar och jag gjorde en sista desperat attack med Alm, både Alm och bossen var nere på 4 och 7 liv, och jag hade inga helare som kunde nå honom. Då inser jag att warp finns för första gången i spelet och warpar dit en helare med mina två sista drag som helar honom tillräckligt för att han ska vinna via en critical hit i nästa omgång med en hårsmån. Ja vad säger man, ingen här kan väl relatera till detta men måste ändå skriva av mig
Nu är det bara postgame kvar, vilket iofs verkar riktigt utmanande. Röstskådespeleriet höjer verkligen Fire Emblem-serien, att Celicas röstskådis är samma som Magilou från Tales of Berseria är chockerande, låter helt annorlunda. Fattar inte hur man kan föreställa sin röst så.
Alm som också hade en jättebra röst spelade tydligen 9S från Nier, en ny skådis. Alltid kul att gå in här och titta vilka spel olika karaktärer har varit med i innan. Flera skådisar som varit med i Nier, Persona, Tales etc som är med i Valentia.
Gimme FE till Switch nu tack
#113
Postad 04 July 2017 - 09:05
Walkir
Walkir
1812 inlägg
Skaffade FE:Echoes Limited Edition för ett par dagar sedan. Har inte spelat Fire Emblem sedan DS-tiden och älskar verkligen Echoes.
Ville köpa Fates när det begav sig, men det var helt hopplöst att få tag i Limited utgåvan då. Därför kändes Echoes för 777:- som ett fynd denna gången.
Känns skönt att hittat tillbaka till Fire Emblem igen efter alla år. Även kul att se att 3DS:en fortfarande har så pass bra spel. Tycker att de senaste 3 åren varit riktigt starka för konsolen.
Har även en Switch, men den ligger just nu och samlar damm. Hoppas också på ett Fire Emblem, men FE:Warriors kommer inte vara något för mig.
#114
Postad 04 July 2017 - 13:24
Transform
38133 inlägg
Nä inte mig heller, det är ju ett musouspel i grunden, sedan kan de inte göra mycket mer med det, bara ändra karaktärerna (Zelda/Fire Emblem), men det är fortfarande musou.
Förresten, du vet att ett riktigt FE redan är utannonserat till Switch va? Tänkte iom att du skrev "hoppas".
Redigerat av Zoiler, 04 July 2017 - 13:25.
#115
Postad 20 July 2017 - 09:19
Unregisterede32cf070
5006 inlägg
MHB:s recension
Kanske dags för ett nytt "strategi-rpg". Sist var då vi hade diskussionerna här för fyra år sedan.
Tactics Ogre till PSP lockar dock mer än Fire Emblem.
Redigerat av Unregisterede32cf070, 20 July 2017 - 09:30.
Media & Mediauppspelning
Spelkonsoler & PC-spel
Nintendo
