Enligt Tom's Hardware så får man ut 58-64fps på High i BF4 med detta kortet i denna maskin.
Postad 26 November 2013 - 15:14
Postad 27 November 2013 - 07:36
Om inte CPU:n flaskar då... Förmodligen en FX4300/Athlon II CPU i denna.Enligt Tom's Hardware så får man ut 58-64fps på High i BF4 med detta kortet i denna maskin.
FX6300 hade varit ett trevligare val.
Trots det bra pris, inte lätt att komma särskilt mkt under 5000 om man plockar ihop grejjerna själv. Tex:
steam.png 41.33K
0 Antal nerladdningarStörre HDD men fulare låda och man får plocka ihop grejjerna själv samt köpa till Stream-kontrollen.
Frågan är dock hur bra AMD funkar med Linux...
Redigerat av pacman, 27 November 2013 - 07:40.
Postad 27 November 2013 - 07:58
Spelar inte BF4 eller liknande skitspel som CoD =)
oavsett om man inte gillar genren eller speltypen så kan man knappast kalla det skitspel
Postad 06 December 2013 - 13:24
Phew, here’s another story revolving around Valve’s soon to be launched Steam OS and Steam Machines. Pocket Lint reports that a British PC manufacturer called Piixl will be launching a SteamOS optimised PC which will attach to the back of your flat screen TV. This PC will be able to accommodate some very pokey hardware in its slim chassis and it will be launched on New Year’s Day.
Overclocked i7 and an Nvidia Titan - no problem
The “superthin” chassis of the Piixl Jetpack will accommodate hardware specs up to and including overclocked Intel Core i7 processors, graphics cards such as the Nvidia Titan and GTX780 and SSD storage up to 1TB in capacity Pocket Lint reporters were told.
While the chassis definitely looks thin it doesn’t look so small, but fitting sleekly behind your big TV it shouldn’t be an eyesore. Piixl say the extendable chassis of the Jetpack will fit to the rear of any TV from 32 to 70-inches and up to 100Kg in weight. The chassis sits between the TV set and a VESA standard wall mount in a kind of pass-through configuration. If you have your TV on a stand then that’s even simpler as it just attaches directly.
Gamers who won’t compromise on performance or interior design
I’m sure the above headline describes lots of HEXUS readers. Francois-Xavier Gardes, London-based Piixl's managing director said “Jetpack is designed for gamers that do not want to compromise on performance nor interior design. Whether wall mounted or on a table, its presence stays smart and minimalistic while providing leading edge-performance and tweak potential virtually on par with a full-tower. If the future of gaming is open, so should be the hardware platform it is being played on.”
While the system is “optimised for SteamOS,” Piixl say this is an open platform and works well with Windows and other Linux OSes.
The Piixl Jetpack will be available to buy from 1st January 2014 with prices starting from around £600 (US$1000).
Källor:
http://www.sweclocke...d-steam-machine
http://hexus.net/tec...hine-announced/
Postad 07 December 2013 - 13:05
Påminner om en rackserver. De låter ngt fruktansvärt så det ska bli intressant att se hur de löser det.
Redigerat av Unregistereddc471864, 07 December 2013 - 13:09.
Postad 07 December 2013 - 13:40
Postad 11 December 2013 - 19:36
The time has come! We are ready to begin shipping Steam Machines and Steam Controllers to the 300 selected beta participants. The machines are due to leave the factory on Friday!
The 300 selected beta testers are being notified today (at about 2:00 p.m. Pacific Time) that they’ll soon receive Steam hardware and SteamOS for testing. Each selected user is also being awarded a special badge on their Steam Community profile, indicating that they’re a beta participant. In addition, a number of games that run natively on SteamOS are being added to each selected user’s library.
We’ve had to make the difficult decision to limit our beta to the U.S. only, because of regulatory hurdles. This was not our original plan, and it means we can’t collect beta feedback from Steam customers world-wide, which is pretty unfortunate. All things considered, we’re sure it was the right decision, because the alternative was to delay the whole beta beyond the point when we’d be able to incorporate any feedback into the 2014 products. This decision only affects Valve’s 300 prototype units; the commercial versions of Steam Machines that are for sale in 2014 won’t be affected by this. More information on those will be announced at CES on January 6.
SteamOS will be made available when the prototype hardware ships. It will be downloadable by individual users and commercial OEMs. (But unless you’re an intrepid Linux hacker already, we’re going to recommend that you wait until later in 2014 to try it out.) We’ll post info soon about that. Oh, and stay tuned for the in-home streaming beta to begin soon, too!
Happy holidays. And happy unboxing to our beta testers. See you on Steam.
http://steamcommunit...e#announcements
Postad 07 January 2014 - 10:03
Väldigt varierande priser måste jag säga.
Postad 07 January 2014 - 10:34
Postad 07 January 2014 - 10:52
Remember those Steam Machine partners we heard about? Gabe Newell just took the stage at Valve's CES 2014 event and made them official, doling out specs for gaming rigs from Alienware, CyberPower, Gigabyte, iBuyPower, Falcon Northwest, and more. There are thirteen machines in all, varying from $500 to $6000 a piece. Not all of them revealed their full hardware specifications, but skip past the break, and we'll give you a rundown of what we know.
Alienware -- Price TBD
Alternate -- $1339
CyberPowerPC -- $499 and up
Digital Storm "Bolt II" -- $2,584
Gigabyte "Brix Pro" -- Price TBD
iBuyPower -- $499 and up
Falcon Northwest "Tiki" -- $1,799 - $6,000
Materiel.net -- $1,098
Next "Spa" -- Price TBD
Origin PC "Chronos" -- Price TBD
Scan "NC10" -- $1,090
Webhallen -- $1,499
Zotac -- $599
Postad 07 January 2014 - 17:35
Postad 08 January 2014 - 21:42
Postad 13 January 2014 - 08:11
Postad 13 January 2014 - 08:14
Ju mer jag får veta om Steam Macines desto svalare blir mitt intresse. Tror det blir en flopp.
Jag är 100% säker på att det blir en flopp.
Postad 13 January 2014 - 08:23
Postad 13 January 2014 - 08:36
Jag är sugen på att se hur bra nya steam kontrollen kommer att vara. Undrar om den bara funkar med deras egna operativsystem?
Tyvärr ser den ut som skräp. De där touch-ytorna kan aldrig vara lika bra som analoga spakar (tror jag). De skulle haft stöd för DS4...
Postad 13 January 2014 - 10:26
Den är ute för betatestning och visar resultatet från dom testerna att det inte fungerar bra så blir det en annan design.
Postad 13 January 2014 - 13:34
Postad 13 January 2014 - 14:22
Postad 14 January 2014 - 08:09
Postad 14 January 2014 - 12:39
Utan att trassla till och fastna i termer så tror jag du har rätt så till vida att pc-fans och konsol-fans är dom "extrema" fantasterna.Problemet är att jag inte förstår vem som skall köpa den? PC-fansen har sina datorer och konsol-fans lär inte lägga ett par tusen till på en Steambox.
"Vanliga" människor som är öppna och "bara" bestämt sig för att köpa något nytt kan absolut vara intresserade av steambox.
Det största frågetecknet är väl antalet titlar som fungerar med steamOS/linux
Postad 14 January 2014 - 12:48
Tja, de är ju fler än till PS4 och Xbox One tillsammans och de båda konsollerna försvinner ju så fort de hamnar på hyllan.
Postad 14 January 2014 - 13:05
Postad 14 January 2014 - 14:26
Föredrar konsollerna för deras enkelhet samt jag måste ändå köpa konsollerna för att kunna spela Sonys/Microsofts/Nintendos spel. PC har jag redan och att lägga in ytterligare ett OS och att hålla på att dualboota så fort man ska göra ngt annat på sin PC är inget alternativ för mig.
Postad 22 January 2014 - 22:04
Alienware has announced its plans to launch Steam Machines every year, in order to mimic the lifecycles of consoles.
Alienware GM Frank Azor confirmed the plans to TrustedReviews, commenting that, like the consoles produced by Sony and Microsoft, the hardware of Alienware’s Steam Machines would be locked.
"Lifecycle wise, consoles update every five, six, seven years, we will be updating our Steam Machines every year," he explained. “There will be no customization options – you can’t really update it."
Postad 23 January 2014 - 07:58
Postad 03 February 2014 - 08:33
Fungerar fint, men man kan inte göra alla inställningar med kontrollern - ibland måste man ta till mus och tangentbord.
För att steamos och steambox ska ta andelar från PS4 och Xbox One krävs dock stora titlar.
Vad jag kan se finns det i dagsläget (förutom Valves egna bibliotek) endast en "stor" titel - Metro last light.
Om det nu ska ske någon stor lansering när man kan köpa steambox borde det vara tillsammans med en lanserings-titel som får folk att lyfta på ögonbrynen - annars blir det svårt.
Valve borde dra fram Halflife 3 som ett ess från rockärmen och att det endast finns tillgängligt exklusivt från Steam.
Postad 14 March 2014 - 23:06
Ska man skratta eller gråta? Den kan ju aldrig vara bra...
30 bilder
36 filmer
