Får nu upp följande när jag ska titta på TV i MP, se bild och vid förhandgranskning i MP: TVServer får jag upp, se bild!
TV logg:
2010-11-13 11:24:21.866865 [(16)]: Controller: StopTimeShifting 2
2010-11-13 11:24:21.866865 [(16)]: card TerraTec Mantis DVBS BDA Receiver: StopTimeShifting user:setuptv sub:0
2010-11-13 11:24:21.866865 [(16)]: card: StopTimeShifting user:setuptv sub:0
2010-11-13 11:24:21.866865 [(16)]: card not IDLE - removing user: setuptv
2010-11-13 11:24:21.866865 [(16)]: user:setuptv remove
2010-11-13 11:24:21.866865 [(16)]: subch:0-0 tswriter StopTimeshifting...
2010-11-13 11:24:21.882465 [(16)]: mdplug: FreeChannel SVT1 HD
2010-11-13 11:24:21.882465 [(16)]: mdplug: usage counter for channel 'SVT1 HD' is zero
2010-11-13 11:24:21.882465 [(16)]: tvcard:FreeSubChannel: subchannels count 1 subch#0 keep graph=False
2010-11-13 11:24:21.882465 [(16)]: DVB subch:0 Decompose()
2010-11-13 11:24:21.882465 [(16)]: FreeSubChannel CA: freeing sub channel : 0
2010-11-13 11:24:21.882465 [(16)]: tvcard:FreeSubChannel : no subchannels present, stopping graph
2010-11-13 11:24:21.882465 [(16)]: dvb:StopGraph called
2010-11-13 11:24:21.882465 [(16)]: tvcard:FreeAllSubChannels
2010-11-13 11:24:21.882465 [(16)]: mdplug: FreeAllChannels
2010-11-13 11:24:21.898065 [TS_File_Cleanup(26)]: card: delete timeshift files C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live2-0.ts
2010-11-13 11:24:21.898065 [(16)]: dvb:StopGraph called
2010-11-13 11:24:21.898065 [(16)]: tvcard:FreeAllSubChannels
2010-11-13 11:24:21.898065 [(16)]: mdplug: FreeAllChannels
2010-11-13 11:24:21.898065 [(16)]: dvb:StopGraph filterstate already stopped, returning.
2010-11-13 11:24:21.898065 [(16)]: user:setuptv remove
2010-11-13 11:24:21.898065 [(16)]: Controller:Timeshifting stopped on card:2
2010-11-13 11:24:21.898065 [(16)]: RTSP: remove stream stream2.0
2010-11-13 11:24:21.944865 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:22.459666 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:22.709266 [Channel state thread(26)]: Controller: DoSetChannelStates for 93 channels
2010-11-13 11:24:22.709266 [Channel state thread(26)]: ChannelStates.DoSetChannelStates took 1 msec
2010-11-13 11:24:22.974467 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:23.489268 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:23.770068 [(16)]: card: Tune 2 to Unknown 51
2010-11-13 11:24:23.785668 [(16)]: card: user: epg:2:-1 tune DVBS:tv: Unknown 51 Freq:11434000 ONID:0 TSID:45 SID:81 PMT:0x106 FTA:True LCN:123 SymbolRate:24500 Modulation:ModNotSet Polarisation:LinearV InnerFecRate:Rate7_8 DisEqc:SimpleA band:Universal Pilot:NotSet RollOff:NotSet
2010-11-13 11:24:23.785668 [(16)]: dvbs: Tune:DVBS:tv: Unknown 51 Freq:11434000 ONID:0 TSID:45 SID:81 PMT:0x106 FTA:True LCN:123 SymbolRate:24500 Modulation:ModNotSet Polarisation:LinearV InnerFecRate:Rate7_8 DisEqc:SimpleA band:Universal Pilot:NotSet RollOff:NotSet
2010-11-13 11:24:23.785668 [(16)]: dvb:GetNewSubChannel:0 #0
2010-11-13 11:24:23.785668 [(16)]: TvDvbChannel ctor new subchIndex:0
2010-11-13 11:24:23.785668 [(16)]: LNB low:9750 hi:10600 switch:11700
2010-11-13 11:24:23.801268 [(16)]: Twinhan DVB-S2 modulation set to:ModNotSet
2010-11-13 11:24:23.801268 [(16)]: Twinhan DVB-S2 Pilot set to:NotSet
2010-11-13 11:24:23.801268 [(16)]: Twinhan DVB-S2 RollOff set to:NotSet
2010-11-13 11:24:23.801268 [(16)]: Twinhan DVB-S2 fec set to:Rate7_8
2010-11-13 11:24:23.801268 [(16)]: dvbs:channel modulation is set to ModNotSet
2010-11-13 11:24:23.801268 [(16)]: dvbs:channel FECRate is set to Rate7_8
2010-11-13 11:24:23.801268 [(16)]: Twinhan: SetLnb diseqc port:1 22khz:1 low:9750 hi:10600 switch:11700 power:True
2010-11-13 11:24:23.801268 [(16)]: Twinhan: SetLNB ok 0x0
2010-11-13 11:24:23.801268 [(16)]: 0000|04 00 00 00 E0 10 38 F0 00 00 00 00 00 00 00 00 |______8_________
2010-11-13 11:24:23.926068 [(16)]: dvb:Submiting tunerequest Channel:Unknown 51 subChannel:0
2010-11-13 11:24:23.926068 [(16)]: dvb:using existing subchannel:0
2010-11-13 11:24:23.926068 [(16)]: dvb:Submit tunerequest size:1 new:0
2010-11-13 11:24:23.926068 [(16)]: subch:0 OnBeforeTune
2010-11-13 11:24:23.926068 [(16)]: dvb:Submit tunerequest calling put_TuneRequest
2010-11-13 11:24:23.926068 [(16)]: dvb:Submit tunerequest done calling put_TuneRequest
2010-11-13 11:24:23.926068 [(16)]: subch:0 OnAfterTune
2010-11-13 11:24:23.926068 [(16)]: subch:0 OnGraphStart
2010-11-13 11:24:23.926068 [(16)]: dvb: RunGraph
2010-11-13 11:24:24.004068 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:24.378469 [(16)]: dvb: LockedInOnSignal ok
2010-11-13 11:24:24.378469 [(16)]: subch:0 OnGraphStarted
2010-11-13 11:24:24.394069 [(16)]: subch:0 SetupPmtGrabber:pid 106 sid:51
2010-11-13 11:24:24.394069 [(16)]: subch:0 set pmt grabber pmt:106 sid:51
2010-11-13 11:24:24.394069 [(16)]: subch:0 set ca grabber
2010-11-13 11:24:24.394069 [(16)]: WaitForPMT: Waiting for PMT 106
2010-11-13 11:24:24.456469 [(26)]: subch:0 OnPMTReceived() pmt:106 ran:True dynamic:False
2010-11-13 11:24:24.456469 [(16)]: WaitForPMT: Found PMT after 0,0624001 seconds.
2010-11-13 11:24:24.456469 [(16)]: subch:0 SendPmt:51 51 FFFFFFFF 7
2010-11-13 11:24:24.456469 [(16)]: Decode pmt
2010-11-13 11:24:24.456469 [(16)]: descr1 len:6 9 4 b 0 e0 45
2010-11-13 11:24:24.472069 [(16)]: Set descriptor data with length 6
2010-11-13 11:24:24.472069 [(16)]: PROBLEM : descriptor lengths dont match 3 9
2010-11-13 11:24:24.472069 [(16)]: Set descriptor data with length 10
2010-11-13 11:24:24.472069 [(16)]: Set descriptor data with length 7
2010-11-13 11:24:24.472069 [(16)]: Set descriptor data with length 3
2010-11-13 11:24:24.472069 [(16)]: subch:0 SendPMT: Channel FTA information changed to False according to CAIDs in PMT.
2010-11-13 11:24:24.472069 [(16)]: subch:0 SendPMT version:7 len:161 81
2010-11-13 11:24:24.472069 [(16)]: Decode pmt
2010-11-13 11:24:24.472069 [(16)]: descr1 len:6 9 4 b 0 e0 45
2010-11-13 11:24:24.472069 [(16)]: subch:0 cam flags:True
2010-11-13 11:24:24.472069 [(16)]: subch:0 SetMpegPidMapping
2010-11-13 11:24:24.472069 [(16)]: subch:0 pid:206 pcr
2010-11-13 11:24:24.472069 [(16)]: subch:0 pid:106 pmt
2010-11-13 11:24:24.487669 [(16)]: subch:0 pid:206 video type:MPEG-2
2010-11-13 11:24:24.487669 [(16)]: subch:0 map pid:206 video type:MPEG-2
2010-11-13 11:24:24.487669 [(16)]: subch:0 pid:2A0 audio lang: type:MPEG-1
2010-11-13 11:24:24.487669 [(16)]: subch:0 map pid:2A0 audio lang: type:MPEG-1
2010-11-13 11:24:24.487669 [(16)]: subch:0 pid:BD3 subtitle type:6
2010-11-13 11:24:24.487669 [(16)]: subch:0 map pid:BD3 subtitle type:6
2010-11-13 11:24:24.487669 [(16)]: subch:0 pid:BD4 subtitle type:6
2010-11-13 11:24:24.487669 [(16)]: subch:0 map pid:BD4 subtitle type:6
2010-11-13 11:24:24.487669 [(16)]: subch:0 pid:242 teletext type:6
2010-11-13 11:24:24.487669 [(16)]: subch:0 map pid:242 teletext type:6
2010-11-13 11:24:24.487669 [(16)]: subch:0 pid:350 type:C0
2010-11-13 11:24:24.487669 [(16)]: subch:0 pid:8FB type:B
2010-11-13 11:24:24.487669 [(16)]: ecm len:6 9 4 B 0 E0 45
2010-11-13 11:24:24.487669 [(16)]: Number of HWPIDS that needs to be sent to tuner :12
2010-11-13 11:24:24.487669 [(16)]: mdplug: SetChannel nr of currently decoding channels 0.
2010-11-13 11:24:24.503269 [(16)]: mdplug: SetChannel starting decryption on channel 'Unknown 51' using plugin slot 1 of 4 avail.
2010-11-13 11:24:24.503269 [(16)]: ecm len:6 9 4 B 0 E0 45
2010-11-13 11:24:24.503269 [(16)]: ECM #0 CA:0xB00 ECM:0x45 ID:0x0
2010-11-13 11:24:24.503269 [(26)]: subch:OnCaReceived()
2010-11-13 11:24:24.503269 [(16)]: mdplug: MDAPIProvID.xml Filling out MDAPIProvID False
2010-11-13 11:24:24.503269 [(16)]: mdplug: MDAPIProvID.xml mode used = Channel:False Provider:False Ca_typ:False
2010-11-13 11:24:24.503269 [(16)]: mdapi: Attempting to add entry to MDAPIProvID.xml
2010-11-13 11:24:24.503269 [(16)]: mdplug: tp_id:45(0x2D) sid:81(0x51) pmt_id:262(0x106)
2010-11-13 11:24:24.503269 [(16)]: mdplug: #0 CA_typ:2816(0xB00) ECM:69(0x45) EMM:0x0 provider:0(0x0)
2010-11-13 11:24:24.518869 [(16)]: mdplug: Send channel change to MDAPI filter Ca_Id:0 CA_Nr:1 ECM_PID:69(0x45)
2010-11-13 11:24:24.518869 [(16)]: subch:0 stop tif
2010-11-13 11:24:24.518869 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:24.518869 [(16)]: WaitForPmt: PMT handling took 0,0624001 seconds.
2010-11-13 11:24:24.518869 [(16)]: card: Tuner locked: True
2010-11-13 11:24:24.518869 [(16)]: **************************************************
2010-11-13 11:24:24.518869 [(16)]: ***** SIGNAL LEVEL: 0, SIGNAL QUALITY: 49 *****
2010-11-13 11:24:24.518869 [(16)]: card: tuned user: epg subchannel: 0
2010-11-13 11:24:24.518869 [(16)]: user:epg add
2010-11-13 11:24:24.518869 [DVB EPG timer(18)]: Controller: GrabEpg on card ID == 2
2010-11-13 11:24:24.518869 [DVB EPG timer(18)]: dvb:grab epg...
2010-11-13 11:24:24.643670 [SetupTv(1)]: TCP connect took : 13
2010-11-13 11:24:24.643670 [(16)]: Controller: epg start
2010-11-13 11:24:25.033670 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:25.548471 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:26.063272 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:26.578073 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:27.092874 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:54.892123 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:55.406924 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:55.921724 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:56.436525 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:24:56.951326 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:25:25.265376 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:25:25.780177 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:25:26.294978 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:25:26.809779 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:25:27.324580 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:25:55.054629 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:25:55.569430 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:25:56.084231 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:25:56.599032 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
2010-11-13 11:25:57.113833 [TwinHan CiMenuHandler(22)]: MMI State CI_STATUS_EMPTY_OLD
TsWriter logg:
13-11-2010 11:21:22.25 mhw grabber ended
13-11-2010 11:21:22.25 epg: epg received
13-11-2010 11:21:22.41 epg: do callback
13-11-2010 11:21:22.462 mhw grabber ended
13-11-2010 11:21:22.462 CMhwParser:GetTitleCount:0
13-11-2010 11:21:22.462 EpgScanner::GetMHWTitleCount:0
13-11-2010 11:21:22.493 epg: reset
13-11-2010 11:21:22.493 epg:ResetEPG()
13-11-2010 11:21:22.493 mhw reset
13-11-2010 11:21:24.771 del m_pVideoAnalyzer
13-11-2010 11:21:24.771 analyzer: reset
13-11-2010 11:21:24.771 del m_pPmtGrabber
13-11-2010 11:21:24.771 del m_pRecorder
13-11-2010 11:21:24.771 del m_pTimeShifting
13-11-2010 11:21:24.771 del m_pTeletextGrabber
13-11-2010 11:21:24.786 del m_pCaGrabber
13-11-2010 11:21:24.786 del done...
13-11-2010 11:21:24.786 CMpTsFilter::Pause()
13-11-2010 11:21:24.786 CMpTsFilter::Stop()
13-11-2010 11:21:33.741 analyzer: reset
13-11-2010 11:21:33.741 PatParser:Reset(0)
13-11-2010 11:21:33.741 NIT:Reset
13-11-2010 11:21:33.741 PatParser::Reset done
13-11-2010 11:21:33.741 cagrabber: reset
13-11-2010 11:21:33.881 epg: reset
13-11-2010 11:21:33.881 epg:ResetEPG()
13-11-2010 11:21:33.881 mhw reset
13-11-2010 11:21:33.881 CMpTsFilter::Pause()
13-11-2010 11:21:34.443 CMpTsFilter::Run()
13-11-2010 11:21:34.458 pmtgrabber: set callback:80fdf8
13-11-2010 11:21:34.458 pmtgrabber: grab pmt:384 sid:500f
13-11-2010 11:21:34.458 cagrabber: set callback:80fdc8
13-11-2010 11:21:34.458 cagrabber: reset
13-11-2010 11:21:34.474 pmtgrabber: got pmt 384 sid:500f
13-11-2010 11:21:34.474 pmtgrabber: PMT pids changed from:
13-11-2010 11:21:34.474 pcr pid: 0
13-11-2010 11:21:34.474 pmt pid: 0
13-11-2010 11:21:34.490 pmtgrabber: PMT pids changed to:
13-11-2010 11:21:34.490 pcr pid: 1fff
13-11-2010 11:21:34.490 pmt pid: 384
13-11-2010 11:21:34.490 pmtgrabber: got new pmt version:1 ffffffff, service_id:500f
13-11-2010 11:21:34.490 pmtgrabber: do callback pid 384
13-11-2010 11:21:34.536 cagrabber: got ca version:1 -1
13-11-2010 11:21:34.536 cagrabber: do calback
13-11-2010 11:21:34.552 epg: set callback
13-11-2010 11:21:34.552 EpgScanner::GrabEPG
13-11-2010 11:21:34.552 epg:GrabEPG
13-11-2010 11:21:34.552 epg:ResetEPG()
13-11-2010 11:21:34.552 epg:GrabEPG()
13-11-2010 11:21:34.552 EpgScanner::GrabMHW
13-11-2010 11:21:34.552 mhw grab
13-11-2010 11:21:34.552 mhw reset
13-11-2010 11:21:34.552 mhw grabber started decoders:2
13-11-2010 11:22:03.506 mhw-epg: added channel 'lDjäØG‘ÕÖ £ÿ6Ä' prog:34832 onid:0x8997 tsid:0x8fa6
13-11-2010 11:22:03.506 mhw-epg: added channel '–“z´Ý 貯³]Ë ' prog:42970 onid:0x977c tsid:0x2534
13-11-2010 11:22:03.506 mhw-epg: added channel '‡g…{«ºšö7IÏÔ¨' prog:23466 onid:0xba9b tsid:0xc507
13-11-2010 11:22:03.506 mhw-epg: added channel 'æC†ÕXH²1¦¢ªî' prog:44506 onid:0x11bc tsid:0x7391
13-11-2010 11:22:03.506 mhw-epg: added channel 'Fˆ/x±pp’BÐÄ@ èÉ' prog:13036 onid:0xf6cf tsid:0xee6
13-11-2010 11:22:03.506 mhw-epg: added channel '>–v
@-¾1=œNf' prog:9462 onid:0xcd9 tsid:0x205b
13-11-2010 11:22:03.506 mhw-epg: added channel 'äC¿²„.sžN‡_XÌ' prog:8159 onid:0x2086 tsid:0x1966
13-11-2010 11:22:03.506 mhw-epg: added channel 'ÒH—'FBjÛíþŽBÌ×' prog:10811 onid:0x761f tsid:0xfbd5
13-11-2010 11:22:03.506 mhw-epg: added channel '_“ðˆˆˆCOlæƒàµB' prog:7162 onid:0x3297 tsid:0xd2b6
13-11-2010 11:22:03.521 mhw-epg: added channel 'ER‰î*÷…ÿ×`§6žã(' prog:13516 onid:0x80f1 tsid:0xf628
13-11-2010 11:22:03.521 mhw-epg: added channel 'Ççà¯]+9Ø^ô§…«' prog:18935 onid:0xfd5 tsid:0xaa8f
13-11-2010 11:22:03.521 mhw-epg: added channel '°jîã0PØdDUƒðã?ã¦' prog:57977 onid:0x9658 tsid:0xbdc5
13-11-2010 11:22:03.521 mhw-epg: added channel 'V†Çtn,5Ò2Ð;hôøÐ' prog:57720 onid:0xb8c2 tsid:0x1ee
13-11-2010 11:22:03.521 mhw-epg: added channel 'bv^¾RªãKåñUjQ±7' prog:48507 onid:0xd570 tsid:0x1ccd
13-11-2010 11:22:03.521 mhw-epg: added channel '¬ìCŒ%Cpy}ŠÆÃ!Æ[' prog:42269 onid:0x32e8 tsid:0xe291
13-11-2010 11:22:03.521 mhw-epg: added channel 'îé¦9L§’ª¿À©««÷Á' prog:37463 onid:0xd1e2 tsid:0xa341
13-11-2010 11:22:03.521 mhw-epg: added channel 'r^uJ‹ú7>öxm' prog:43471 onid:0x5f77 tsid:0x794c
13-11-2010 11:22:03.521 mhw-epg: added channel 'Ù$u"œ÷ƒEESá‚~Hå' prog:5795 onid:0x5f6f tsid:0xc784
13-11-2010 11:22:03.521 mhw-epg: added channel 'ñûŒ™bL^#ÈÐŽR' prog:18682 onid:0xa444 tsid:0xb850
13-11-2010 11:22:03.521 mhw-epg: added channel 's¸“ÈŽ‡˜œçíP •À†' prog:63986 onid:0xd23a tsid:0x1b0
13-11-2010 11:22:03.521 mhw-epg: added channel 'ëÝwAѵ¡Ó›²¸ü' prog:35738 onid:0xf544 tsid:0x1f5f
13-11-2010 11:22:03.521 mhw-epg: added channel 'B‡
þé<³aâ—ª\Øó†' prog:39046 onid:0xac3a tsid:0x12bd
13-11-2010 11:22:03.521 mhw-epg: added channel 'W1PªF8P»ËJ¶j]6' prog:52263 onid:0x6b9d tsid:0x19b1
13-11-2010 11:22:03.521 mhw-epg: added channel ',ð¾ó©/º+7\ßv«D' prog:46094 onid:0xbf9c tsid:0xa8bb
13-11-2010 11:22:03.521 mhw-epg: added channel 'W¿0éPæÛŒÓãõ‚' prog:53246 onid:0x6449 tsid:0xdd94
13-11-2010 11:22:03.521 mhw-epg: added channel '7é@6ʹRtàïy™ª' prog:54316 onid:0xbf49 tsid:0x2d85
13-11-2010 11:22:03.521 mhw-epg: added channel '|P6ü,£w ç¢ ' prog:3847 onid:0xc9b2 tsid:0x9e49
13-11-2010 11:22:03.521 mhw-epg: added channel 'Öd>{–ÞϯLiÕk' prog:14832 onid:0x7614 tsid:0x86e8
13-11-2010 11:22:03.521 mhw-epg: added channel '(!þ·.ŠcT®¤`B20®Ö' prog:45898 onid:0xf5e5 tsid:0xb3a0
13-11-2010 11:22:03.521 mhw-epg: added channel 'û™tTK1ú,Ý8Ã=°ƒ–N' prog:50251 onid:0xaa80 tsid:0xbd72
13-11-2010 11:22:03.521 mhw-epg: added channel '`)Ũ·ÑŸëG„Å/P‘' prog:54690 onid:0x77f1 tsid:0x248d
13-11-2010 11:22:03.521 mhw-epg: added channel '¡`ùAkÒÌMC×{{nš™Ì' prog:39090 onid:0x6ba4 tsid:0x17d2
13-11-2010 11:22:03.521 mhw-epg: added channel 'j]~>~è’o—‰' prog:2201 onid:0x4b9 tsid:0xbee7
13-11-2010 11:22:03.521 mhw-epg: added channel 'jñè± À
8t:&—,qf' prog:58929 onid:0x3de tsid:0xe074
13-11-2010 11:22:03.521 mhw-epg: added channel '«4Øö
™C›t˜´…á^ËÉ' prog:55809 onid:0x883d tsid:0xdd0a
13-11-2010 11:22:03.537 mhw-epg: added channel 'ÉÐ-ob†ù ‘|+mpW' prog:16883 onid:0x4723 tsid:0xbc62
13-11-2010 11:22:03.537 mhw-epg: added channel 'ÐGÌ4`Ü(Ò2åÂÝmÀ' prog:13909 onid:0x3c1f tsid:0xb840
13-11-2010 11:22:03.537 mhw-epg: added channel 'ª¥H9)M¶Ñ¡WìÓ' prog:23822 onid:0x6801 tsid:0xb898
13-11-2010 11:22:03.537 mhw-epg: added channel '€ý‡>;'sþ¦ýš(‹&' prog:54001 onid:0xbd3e tsid:0x4370
13-11-2010 11:22:03.537 mhw-epg: added channel '"!ÏUMšQ™™r>' prog:57634 onid:0x3a82 tsid:0xa75e
13-11-2010 11:22:03.537 mhw-epg: added channel 'ù–É6Þªs¦×ò1C}óK\' prog:42516 onid:0xff87 tsid:0x2ce
13-11-2010 11:22:03.537 mhw-epg: added channel 'Ú[x`ÛA·¤nP÷|íª' prog:24285 onid:0x7a01 tsid:0x45fc
13-11-2010 11:22:03.537 mhw-epg: added channel 'fPN³†ñ“ªõ®‘Hi' prog:26068 onid:0x93f8 tsid:0xb071
13-11-2010 11:22:03.537 mhw-epg: added channel '؆5·h¢?„à2¼fü' prog:45982 onid:0xa298 tsid:0x8356
13-11-2010 11:22:03.537 mhw-epg: added channel '•!µwqïTá]}×ÿ ' prog:50967 onid:0x20b9 tsid:0x95
13-11-2010 11:22:03.537 mhw-epg: added channel 'º˜¨ÔÚ”*ð™á4Sä' prog:26731 onid:0xe759 tsid:0x8527
13-11-2010 11:22:03.537 mhw-epg: added channel ';YÅ:[œSX» ¥üet' prog:10374 onid:0x7c5b tsid:0xd88d
13-11-2010 11:22:03.537 mhw-epg: added channel 'O' prog:55043 onid:0x3490 tsid:0x85e
13-11-2010 11:22:03.537 mhw-epg: added channel '†«sµ›à§ÑvÐüp·‹ç' prog:47293 onid:0x88e8 tsid:0xff4b
13-11-2010 11:22:03.537 mhw-epg: added channel '“¯%’Fɯï¡c0¨' prog:18688 onid:0xb807 tsid:0xf6ea
13-11-2010 11:22:03.537 mhw-epg: added channel 'h’¿ö¶a[¹}³¸oäÏ' prog:63168 onid:0xf32 tsid:0xc162
13-11-2010 11:22:03.537 mhw-epg: added channel '’{ù3Ù¼ui92=b}‚7\' prog:31246 onid:0xef07 tsid:0x18e
13-11-2010 11:22:03.537 mhw-epg: added channel ':Ÿ|Üyt_oÖZ<mˆâ' prog:45854 onid:0x797e tsid:0x68cd
13-11-2010 11:22:03.537 mhw-epg: added channel 'o‹9w+j¤ ãëÆ×' prog:15073 onid:0x4ba2 tsid:0x123f
13-11-2010 11:22:03.537 mhw-epg: added channel '÷‹ã=ML<°Áãu !9HŒ' prog:36209 onid:0xe710 tsid:0x102
13-11-2010 11:22:03.537 mhw-epg: added channel ':¥2ç–ëþ7üºÈêv}b' prog:30104 onid:0x881f tsid:0xef61
‘›U•vž2Å;6¥6¿i' prog:25587 onid:0x9cc9 tsid:0x565e
13-11-2010 11:22:03.537 mhw-epg: added channel 'DÂî
¸*žuù¡A:*h' prog:37766 onid:0x4ed1 tsid:0x8900
13-11-2010 11:22:03.537 mhw-epg: added channel '2NÇ0ÖÝA¢úÏbV¦a' prog:16109 onid:0x7018 tsid:0xd8fa
13-11-2010 11:22:03.537 mhw-epg: added channel 'rØ×Ý¿
t¥)_œ“Fø‡' prog:61454 onid:0x64f tsid:0xb565
13-11-2010 11:22:03.537 mhw-epg: added channel '“óJ§_gzñL¼Òø‘' prog:61077 onid:0x992c tsid:0x7bb6
13-11-2010 11:22:03.537 mhw-epg: added channel 'R5ü/<&±¢ë†Hƒ' prog:25022 onid:0xbd00 tsid:0x200f
13-11-2010 11:22:03.552 mhw-epg: added channel 'ØWÀz€Ðöm–S¹' prog:29962 onid:0xd107 tsid:0x4dd
13-11-2010 11:22:03.552 mhw-epg: added channel 'xC
MÇÏïBy7•ð²' prog:53477 onid:0x28af tsid:0xa0d
13-11-2010 11:22:03.552 mhw-epg: added channel '¶Ÿ(0z>pf€ÜíX!αn' prog:55370 onid:0x852c tsid:0x84c6
13-11-2010 11:22:03.552 mhw-epg: added channel '±3#ðL"Yôå²GýVž' prog:19463 onid:0xe99f tsid:0x1b51
13-11-2010 11:22:03.552 mhw-epg: channels:66
13-11-2010 11:22:45.33 mhw grabber ended
13-11-2010 11:22:45.33 epg: epg received
13-11-2010 11:22:45.33 epg: do callback
13-11-2010 11:22:45.49 mhw grabber ended
13-11-2010 11:22:45.49 CMhwParser:GetTitleCount:0
13-11-2010 11:22:45.49 EpgScanner::GetMHWTitleCount:0
13-11-2010 11:22:45.782 epg: reset
13-11-2010 11:22:45.782 epg:ResetEPG()
13-11-2010 11:22:45.813 mhw reset
13-11-2010 11:22:46.889 del m_pVideoAnalyzer
13-11-2010 11:22:46.889 analyzer: reset
13-11-2010 11:22:46.889 del m_pPmtGrabber
13-11-2010 11:22:46.889 del m_pRecorder
13-11-2010 11:22:46.889 del m_pTimeShifting
13-11-2010 11:22:46.889 del m_pTeletextGrabber
13-11-2010 11:22:46.889 del m_pCaGrabber
13-11-2010 11:22:46.889 del done...
13-11-2010 11:22:46.889 CMpTsFilter::Pause()
13-11-2010 11:22:46.889 CMpTsFilter::Stop()
13-11-2010 11:23:03.799 analyzer: reset
13-11-2010 11:23:03.799 PatParser:Reset(0)
13-11-2010 11:23:03.799 NIT:Reset
13-11-2010 11:23:03.799 PatParser::Reset done
13-11-2010 11:23:03.799 cagrabber: reset
13-11-2010 11:23:03.939 epg: reset
13-11-2010 11:23:03.939 epg:ResetEPG()
13-11-2010 11:23:03.939 mhw reset
13-11-2010 11:23:03.939 CMpTsFilter::Pause()
13-11-2010 11:23:04.501 CMpTsFilter::Run()
13-11-2010 11:23:04.517 pmtgrabber: set callback:80fe78
13-11-2010 11:23:04.517 pmtgrabber: grab pmt:119 sid:fa5
13-11-2010 11:23:04.517 cagrabber: set callback:80fe48
13-11-2010 11:23:04.517 cagrabber: reset
13-11-2010 11:23:04.532 cagrabber: got ca version:4 -1
13-11-2010 11:23:04.532 cagrabber: do calback
13-11-2010 11:23:04.595 pmtgrabber: got pmt 119 sid:fa5
13-11-2010 11:23:04.595 pmtgrabber: PMT pids changed from:
13-11-2010 11:23:04.595 pcr pid: 0
13-11-2010 11:23:04.595 pmt pid: 0
13-11-2010 11:23:04.595 pmtgrabber: PMT pids changed to:
13-11-2010 11:23:04.595 pcr pid: 202
13-11-2010 11:23:04.595 pmt pid: 119
13-11-2010 11:23:04.595 video pid: 202 type: MPEG2
13-11-2010 11:23:04.595 audio pid: 2b0 language: UNK type: MPEG1 - audio
13-11-2010 11:23:04.595 pmtgrabber: got new pmt version:4 ffffffff, service_id:fa5
13-11-2010 11:23:04.595 pmtgrabber: do callback pid 119
13-11-2010 11:23:04.626 analyzer: set video pid:202
13-11-2010 11:23:04.626 analyzer: reset
13-11-2010 11:23:04.626 analyzer: set audio pid:2b0
13-11-2010 11:23:04.657 epg: set callback
13-11-2010 11:23:04.657 EpgScanner::GrabEPG
13-11-2010 11:23:04.657 epg:GrabEPG
13-11-2010 11:23:04.657 epg:ResetEPG()
13-11-2010 11:23:04.657 epg:GrabEPG()
13-11-2010 11:23:04.657 EpgScanner::GrabMHW
13-11-2010 11:23:04.657 mhw grab
13-11-2010 11:23:04.657 mhw reset
13-11-2010 11:23:04.657 mhw grabber started decoders:2
13-11-2010 11:23:25.209 del m_pVideoAnalyzer
13-11-2010 11:23:25.209 analyzer: reset
13-11-2010 11:23:25.209 del m_pPmtGrabber
13-11-2010 11:23:25.209 del m_pRecorder
13-11-2010 11:23:25.209 del m_pTimeShifting
13-11-2010 11:23:25.209 del m_pTeletextGrabber
13-11-2010 11:23:25.209 del m_pCaGrabber
13-11-2010 11:23:25.209 del done...
13-11-2010 11:23:25.209 CMpTsFilter::Pause()
13-11-2010 11:23:25.209 CMpTsFilter::Stop()
13-11-2010 11:23:46.97 analyzer: reset
13-11-2010 11:23:46.97 PatParser:Reset(0)
13-11-2010 11:23:46.97 NIT:Reset
13-11-2010 11:23:46.97 PatParser::Reset done
13-11-2010 11:23:46.97 cagrabber: reset
13-11-2010 11:23:46.222 epg: reset
13-11-2010 11:23:46.222 epg:ResetEPG()
13-11-2010 11:23:46.222 mhw reset
13-11-2010 11:23:46.222 CMpTsFilter::Pause()
13-11-2010 11:23:46.737 CMpTsFilter::Run()
13-11-2010 11:23:46.752 pmtgrabber: set callback:800018
13-11-2010 11:23:46.752 pmtgrabber: grab pmt:10e sid:57e
13-11-2010 11:23:46.752 cagrabber: set callback:800028
13-11-2010 11:23:46.752 cagrabber: reset
13-11-2010 11:23:46.815 cagrabber: got ca version:1 -1
13-11-2010 11:23:46.815 cagrabber: do calback
13-11-2010 11:23:46.908 pmtgrabber: got pmt 10e sid:57e
13-11-2010 11:23:46.908 pmtgrabber: PMT pids changed from:
13-11-2010 11:23:46.908 pcr pid: 0
13-11-2010 11:23:46.908 pmt pid: 0
13-11-2010 11:23:46.908 pmtgrabber: PMT pids changed to:
13-11-2010 11:23:46.908 pcr pid: 200
13-11-2010 11:23:46.908 pmt pid: 10e
13-11-2010 11:23:46.908 video pid: 200 type: H264
13-11-2010 11:23:46.908 audio pid: 280 language: swe type: MPEG2 - audio
13-11-2010 11:23:46.908 audio pid: 281 language: swe type: AC3
13-11-2010 11:23:46.908 Subtitle pid: 258 language: swe type: DVB subtitle 2
13-11-2010 11:23:46.908 Subtitle pid: 259 language: swe type: DVB subtitle 2
13-11-2010 11:23:46.908 pmtgrabber: got new pmt version:1 ffffffff, service_id:57e
13-11-2010 11:23:46.924 pmtgrabber: do callback pid 10e
13-11-2010 11:23:46.955 analyzer: set video pid:200
13-11-2010 11:23:46.955 analyzer: reset
13-11-2010 11:23:46.955 analyzer: set audio pid:280
13-11-2010 11:23:46.955 analyzer: set audio pid:281
13-11-2010 11:23:46.971 analyzer: reset
13-11-2010 11:23:47.02 Recorder: TIMESHIFT SetVideoAudioObserver observer ok
13-11-2010 11:23:47.02 Recorder: TIMESHIFT set filename:C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live2-0.ts
13-11-2010 11:23:47.02 Recorder: TIMESHIFT paused=yes
13-11-2010 11:23:47.02 Recorder: TIMESHIFT Received from TvService: pmt pid:0x10e serviceId: 0x57e pmtlength:79
13-11-2010 11:23:47.02 Recorder: TIMESHIFT Old pids cleared
13-11-2010 11:23:47.02 Recorder: TIMESHIFT got pmt - tableid: 0x2 section_length: 79 sid: 0x57e
13-11-2010 11:23:47.02 Recorder: TIMESHIFT PMT parsed - Pid 0x10e ServiceId 0x57e stream count: 5
13-11-2010 11:23:47.02 Recorder: TIMESHIFT pcr pid:0x200
13-11-2010 11:23:47.02 Recorder: TIMESHIFT SetPcrPid clear old PIDs
13-11-2010 11:23:47.02 Recorder: TIMESHIFT add video stream pid: 0x200 fake pid: 0x30 stream type: 0x1b logical type: 0x1b descriptor length: 0
13-11-2010 11:23:47.17 Recorder: TIMESHIFT add audio stream pid: 0x280 fake pid: 0x40 stream type: 0x4 logical type: 0x4 descriptor length: 6
13-11-2010 11:23:47.17 Recorder: TIMESHIFT add audio stream pid: 0x281 fake pid: 0x41 stream type: 0x6 logical type: 0x81 descriptor length: 9
13-11-2010 11:23:47.17 Recorder: TIMESHIFT add subtitle stream pid: 0x258 fake pid: 0x50 stream type: 0x6 logical type: 0x6 descriptor length: 10
13-11-2010 11:23:47.17 Recorder: TIMESHIFT add subtitle stream pid: 0x259 fake pid: 0x51 stream type: 0x6 logical type: 0x6 descriptor length: 10
13-11-2010 11:23:47.17 Recorder: TIMESHIFT paused=no
13-11-2010 11:23:47.17 Recorder: TIMESHIFT Start 'C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live2-0.ts.tsbuffer'
13-11-2010 11:23:47.33 Recorder: TIMESHIFT start of audio detected
13-11-2010 11:23:47.298 Recorder: TIMESHIFT start of video detected
13-11-2010 11:23:47.298 Recorder: TIMESHIFT clear TS packet queue
13-11-2010 11:23:47.298 Recorder: TIMESHIFT Info : Next broadcaster program clock reference rollover : 0 days 06:25:54 0
13-11-2010 11:23:55.536 Recorder: TIMESHIFT Stop 'C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live2-0.ts.tsbuffer'
13-11-2010 11:23:55.536 Recorder: TIMESHIFT Reset
13-11-2010 11:23:55.536 del m_pVideoAnalyzer
13-11-2010 11:23:55.536 analyzer: reset
13-11-2010 11:23:55.536 del m_pPmtGrabber
13-11-2010 11:23:55.536 del m_pRecorder
13-11-2010 11:23:55.536 del m_pTimeShifting
13-11-2010 11:23:55.536 del m_pTeletextGrabber
13-11-2010 11:23:55.552 del m_pCaGrabber
13-11-2010 11:23:55.552 del done...
13-11-2010 11:23:55.552 CMpTsFilter::Pause()
13-11-2010 11:23:55.552 CMpTsFilter::Stop()
13-11-2010 11:23:57.470 analyzer: reset
13-11-2010 11:23:57.470 PatParser:Reset(0)
13-11-2010 11:23:57.470 NIT:Reset
13-11-2010 11:23:57.470 PatParser::Reset done
13-11-2010 11:23:57.470 cagrabber: reset
13-11-2010 11:23:57.611 epg: reset
13-11-2010 11:23:57.611 epg:ResetEPG()
13-11-2010 11:23:57.611 mhw reset
13-11-2010 11:23:57.611 CMpTsFilter::Pause()
13-11-2010 11:23:58.48 CMpTsFilter::Run()
13-11-2010 11:23:58.63 pmtgrabber: set callback:80fdf8
13-11-2010 11:23:58.63 pmtgrabber: grab pmt:106 sid:51
13-11-2010 11:23:58.63 cagrabber: set callback:80fdc8
13-11-2010 11:23:58.63 cagrabber: reset
13-11-2010 11:23:58.157 pmtgrabber: got pmt 106 sid:51
13-11-2010 11:23:58.157 pmtgrabber: PMT pids changed from:
13-11-2010 11:23:58.157 pcr pid: 0
13-11-2010 11:23:58.157 pmt pid: 0
13-11-2010 11:23:58.157 pmtgrabber: PMT pids changed to:
13-11-2010 11:23:58.157 pcr pid: 206
13-11-2010 11:23:58.157 pmt pid: 106
13-11-2010 11:23:58.157 video pid: 206 type: MPEG2
13-11-2010 11:23:58.157 audio pid: 2a0 language: swe type: MPEG2 - audio
13-11-2010 11:23:58.157 Subtitle pid: bd3 language: fin type: DVB subtitle 2
13-11-2010 11:23:58.157 Subtitle pid: bd4 language: swe type: DVB subtitle 2
13-11-2010 11:23:58.157 pmtgrabber: got new pmt version:7 ffffffff, service_id:51
13-11-2010 11:23:58.157 pmtgrabber: do callback pid 106
13-11-2010 11:23:58.188 analyzer: set video pid:206
13-11-2010 11:23:58.188 analyzer: reset
13-11-2010 11:23:58.188 analyzer: set audio pid:2a0
13-11-2010 11:23:58.219 epg: set callback
13-11-2010 11:23:58.219 EpgScanner::GrabEPG
13-11-2010 11:23:58.219 epg:GrabEPG
13-11-2010 11:23:58.219 epg:ResetEPG()
13-11-2010 11:23:58.219 epg:GrabEPG()
13-11-2010 11:23:58.219 EpgScanner::GrabMHW
13-11-2010 11:23:58.219 mhw grab
13-11-2010 11:23:58.219 mhw reset
13-11-2010 11:23:58.219 mhw grabber started decoders:2
13-11-2010 11:23:58.266 cagrabber: got ca version:0 -1
13-11-2010 11:23:58.282 cagrabber: do calback
13-11-2010 11:24:06.518 del m_pVideoAnalyzer
13-11-2010 11:24:06.518 analyzer: reset
13-11-2010 11:24:06.518 del m_pPmtGrabber
13-11-2010 11:24:06.518 del m_pRecorder
13-11-2010 11:24:06.518 del m_pTimeShifting
13-11-2010 11:24:06.518 del m_pTeletextGrabber
13-11-2010 11:24:06.518 del m_pCaGrabber
13-11-2010 11:24:06.518 del done...
13-11-2010 11:24:06.534 CMpTsFilter::Pause()
13-11-2010 11:24:06.534 CMpTsFilter::Stop()
13-11-2010 11:24:06.565 analyzer: reset
13-11-2010 11:24:06.565 PatParser:Reset(0)
13-11-2010 11:24:06.565 NIT:Reset
13-11-2010 11:24:06.565 PatParser::Reset done
13-11-2010 11:24:06.565 cagrabber: reset
13-11-2010 11:24:06.690 epg: reset
13-11-2010 11:24:06.690 epg:ResetEPG()
13-11-2010 11:24:06.690 mhw reset
13-11-2010 11:24:06.706 CMpTsFilter::Pause()
13-11-2010 11:24:07.205 CMpTsFilter::Run()
13-11-2010 11:24:07.220 pmtgrabber: set callback:80ff38
13-11-2010 11:24:07.220 pmtgrabber: grab pmt:10e sid:57e
13-11-2010 11:24:07.220 cagrabber: set callback:80ffc8
13-11-2010 11:24:07.220 cagrabber: reset
13-11-2010 11:24:07.298 cagrabber: got ca version:1 -1
13-11-2010 11:24:07.298 cagrabber: do calback
13-11-2010 11:24:07.392 pmtgrabber: got pmt 10e sid:57e
13-11-2010 11:24:07.392 pmtgrabber: PMT pids changed from:
13-11-2010 11:24:07.392 pcr pid: 0
13-11-2010 11:24:07.392 pmt pid: 0
13-11-2010 11:24:07.392 pmtgrabber: PMT pids changed to:
13-11-2010 11:24:07.392 pcr pid: 200
13-11-2010 11:24:07.392 pmt pid: 10e
13-11-2010 11:24:07.392 video pid: 200 type: H264
13-11-2010 11:24:07.392 audio pid: 280 language: swe type: MPEG2 - audio
13-11-2010 11:24:07.392 audio pid: 281 language: swe type: AC3
13-11-2010 11:24:07.392 Subtitle pid: 258 language: swe type: DVB subtitle 2
13-11-2010 11:24:07.392 Subtitle pid: 259 language: swe type: DVB subtitle 2
13-11-2010 11:24:07.408 pmtgrabber: got new pmt version:1 ffffffff, service_id:57e
13-11-2010 11:24:07.408 pmtgrabber: do callback pid 10e
13-11-2010 11:24:07.454 analyzer: set video pid:200
13-11-2010 11:24:07.454 analyzer: reset
13-11-2010 11:24:07.454 analyzer: set audio pid:280
13-11-2010 11:24:07.454 analyzer: set audio pid:281
13-11-2010 11:24:07.501 Recorder: TIMESHIFT SetVideoAudioObserver observer ok
13-11-2010 11:24:07.501 Recorder: TIMESHIFT set filename:C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live2-0.ts
13-11-2010 11:24:07.501 Recorder: TIMESHIFT paused=yes
13-11-2010 11:24:07.501 Recorder: TIMESHIFT Received from TvService: pmt pid:0x10e serviceId: 0x57e pmtlength:79
13-11-2010 11:24:07.501 Recorder: TIMESHIFT Old pids cleared
13-11-2010 11:24:07.501 Recorder: TIMESHIFT got pmt - tableid: 0x2 section_length: 79 sid: 0x57e
13-11-2010 11:24:07.501 Recorder: TIMESHIFT PMT parsed - Pid 0x10e ServiceId 0x57e stream count: 5
13-11-2010 11:24:07.501 Recorder: TIMESHIFT pcr pid:0x200
13-11-2010 11:24:07.501 Recorder: TIMESHIFT SetPcrPid clear old PIDs
13-11-2010 11:24:07.501 Recorder: TIMESHIFT add video stream pid: 0x200 fake pid: 0x30 stream type: 0x1b logical type: 0x1b descriptor length: 0
13-11-2010 11:24:07.501 Recorder: TIMESHIFT add audio stream pid: 0x280 fake pid: 0x40 stream type: 0x4 logical type: 0x4 descriptor length: 6
13-11-2010 11:24:07.501 Recorder: TIMESHIFT add audio stream pid: 0x281 fake pid: 0x41 stream type: 0x6 logical type: 0x81 descriptor length: 9
13-11-2010 11:24:07.501 Recorder: TIMESHIFT add subtitle stream pid: 0x258 fake pid: 0x50 stream type: 0x6 logical type: 0x6 descriptor length: 10
13-11-2010 11:24:07.501 Recorder: TIMESHIFT add subtitle stream pid: 0x259 fake pid: 0x51 stream type: 0x6 logical type: 0x6 descriptor length: 10
13-11-2010 11:24:07.501 Recorder: TIMESHIFT paused=no
13-11-2010 11:24:07.501 Recorder: TIMESHIFT Start 'C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live2-0.ts.tsbuffer'
13-11-2010 11:24:07.564 Recorder: TIMESHIFT start of audio detected
13-11-2010 11:24:07.610 Recorder: TIMESHIFT start of audio detected
13-11-2010 11:24:07.876 Recorder: TIMESHIFT start of video detected
13-11-2010 11:24:07.876 Recorder: TIMESHIFT clear TS packet queue
13-11-2010 11:24:07.891 Recorder: TIMESHIFT Info : Next broadcaster program clock reference rollover : 0 days 06:25:34 0
13-11-2010 11:24:21.866 Recorder: TIMESHIFT Stop 'C:\ProgramData\Team MediaPortal\MediaPortal TV Server\timeshiftbuffer\live2-0.ts.tsbuffer'
13-11-2010 11:24:21.882 Recorder: TIMESHIFT Reset
13-11-2010 11:24:21.882 del m_pVideoAnalyzer
13-11-2010 11:24:21.882 analyzer: reset
13-11-2010 11:24:21.882 del m_pPmtGrabber
13-11-2010 11:24:21.882 del m_pRecorder
13-11-2010 11:24:21.882 del m_pTimeShifting
13-11-2010 11:24:21.882 del m_pTeletextGrabber
13-11-2010 11:24:21.882 del m_pCaGrabber
13-11-2010 11:24:21.882 del done...
13-11-2010 11:24:21.882 CMpTsFilter::Pause()
13-11-2010 11:24:21.882 CMpTsFilter::Stop()
13-11-2010 11:24:23.785 analyzer: reset
13-11-2010 11:24:23.785 PatParser:Reset(0)
13-11-2010 11:24:23.785 NIT:Reset
13-11-2010 11:24:23.785 PatParser::Reset done
13-11-2010 11:24:23.785 cagrabber: reset
13-11-2010 11:24:23.926 epg: reset
13-11-2010 11:24:23.926 epg:ResetEPG()
13-11-2010 11:24:23.926 mhw reset
13-11-2010 11:24:23.926 CMpTsFilter::Pause()
13-11-2010 11:24:24.378 CMpTsFilter::Run()
13-11-2010 11:24:24.394 pmtgrabber: set callback:80fdf8
13-11-2010 11:24:24.394 pmtgrabber: grab pmt:106 sid:51
13-11-2010 11:24:24.394 cagrabber: set callback:80fdc8
13-11-2010 11:24:24.394 cagrabber: reset
13-11-2010 11:24:24.440 pmtgrabber: got pmt 106 sid:51
13-11-2010 11:24:24.440 pmtgrabber: PMT pids changed from:
13-11-2010 11:24:24.440 pcr pid: 0
13-11-2010 11:24:24.440 pmt pid: 0
13-11-2010 11:24:24.440 pmtgrabber: PMT pids changed to:
13-11-2010 11:24:24.440 pcr pid: 206
13-11-2010 11:24:24.440 pmt pid: 106
13-11-2010 11:24:24.440 video pid: 206 type: MPEG2
13-11-2010 11:24:24.440 audio pid: 2a0 language: swe type: MPEG2 - audio
13-11-2010 11:24:24.440 Subtitle pid: bd3 language: fin type: DVB subtitle 2
13-11-2010 11:24:24.440 Subtitle pid: bd4 language: swe type: DVB subtitle 2
13-11-2010 11:24:24.440 pmtgrabber: got new pmt version:7 ffffffff, service_id:51
13-11-2010 11:24:24.440 pmtgrabber: do callback pid 106
13-11-2010 11:24:24.487 analyzer: set video pid:206
13-11-2010 11:24:24.487 analyzer: reset
13-11-2010 11:24:24.487 analyzer: set audio pid:2a0
13-11-2010 11:24:24.503 cagrabber: got ca version:0 -1
13-11-2010 11:24:24.503 cagrabber: do calback
13-11-2010 11:24:24.518 epg: set callback
13-11-2010 11:24:24.518 EpgScanner::GrabEPG
13-11-2010 11:24:24.518 epg:GrabEPG
13-11-2010 11:24:24.518 epg:ResetEPG()
13-11-2010 11:24:24.518 epg:GrabEPG()
13-11-2010 11:24:24.518 EpgScanner::GrabMHW
13-11-2010 11:24:24.518 mhw grab
13-11-2010 11:24:24.518 mhw reset
13-11-2010 11:24:24.534 mhw grabber started decoders:2
Jag sökte efter filen men jag hittar ingen sådan fil med det namnet den klagar på, kanske det inte är någon fil?
Tror det har att göra med filtret? Är ej säker och därför frågar jag er!
Notera att jag fick det att fungera igår kväll efter jag bytt codec men idag är det samma fel igen!
Kommer inte vidare innan jag löser detta fel. givetvis tittar jag efter en lösning själv!
Mvh Fredrik
Redigerat av freddehboy, 14 november 2010 - 10:46.
