Hur är Sennheiser HD 4.50 BTNC?
Inga svar i detta ämne
Postad 11 augusti 2020 - 21:44
Unregisterede1543a39
  • Unregisterede1543a39
When it comes to sound, they are good, well-balanced and clean. ANC is also good for the price. However, they are not very comfortable, and every single head movement tends to break the seal between the pillows and your head, which as you would imagine is quite worrying as it lets a lot of outside sound in. your footsteps as you walk, this has to do with the ANC, almost all ANC headphones have this ... the only pairs that do not have this issue are the beats Studio 3, Sony Ch700n and XM series. HD 4.50 does not go very high https://snaptube.cam/ 9apps.
I would definitely recommend the sony ch700n for that price. They walk around better. They go very high, ANC does not do so annoyingly stupid with every step you take, and they sound very clean with hollow bass. The pillows are not perfect but better than Hd 4.50, and they are also much more comfortable.
If you are willing to spend a little more, definitely get yourself the Sony 1000XM2. They are not regularly sold that XM3 is out, and are still the 2nd best ANC headphones I have owned, and I have owned almost all top-end headphones in the ANC at some point. And if you want the best possible ANC headphones that money can buy, the XM3 is a no brainer.
Hope it helps.
Redigerat av Unregisterede1543a39, 13 augusti 2020 - 10:13.
