[ 09:00:20 ] [ Phoenix ] Opening device /dev/ttyUSB0
[ 09:00:20 ] [ Phoenix ] Setting Parity to: ODD
[ 09:00:20 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 09:00:20 ] [ Phoenix ] Setting Baud to standard 9600
[ 09:00:21 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
[ 09:00:22 ] [ Loader ] Reset failed ...
[ 09:00:22 ] [ Card queue /dev/ttyUSB0 ] Starting...
Och som man kan förvänta sig ######s det sen när Kaffeine försöker ansluta sig till newcs-servern:
[ 09:01:54 ] [ Newcamd ] new connection from 127.0.0.1 on socket 8
[ 09:01:54 ] [ Newcamd:15050 ] Connection from 127.0.0.1
[ 09:01:54 ] [ Newcamd:15050 ] User reinfallt logged in, client: Kaffeine CS
[ 09:01:54 ] [ Newcamd:15050 ] Connection from reinfallt to not-ready server!
Kör jag däremot "sudo /etc/init.d/newcs restart" fungerar allt som det ska:
[ 09:03:26 ] [ Phoenix ] Opening device /dev/ttyUSB0
[ 09:03:26 ] [ Phoenix ] Setting Parity to: ODD
[ 09:03:26 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 09:03:26 ] [ Phoenix ] Setting Baud to standard 9600
[ 09:03:27 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
[ 09:03:29 ] [ Serial ] Read on fd 5 (len=8 timeout=5300ms)
Så vad är det med autostarten som gör att newcs inte vill fungera? Just nu så får jag ju starta om newcs manuellt det första jag gör när jag startat datorn.
