Postad 26 maj 2017 - 05:38
Drake001
Drake001
3 093 inlägg
http://www.nintendol...x_to_the_switchMONSTER HUNTER XX ANNOUNCED FOR NINTENDO SWITCH
Monster Hunter is a series that—in its early days—seemed to be something of a niche and relatively minor franchise in the bigger picture. But, starting with Monster Hunter Tri, the series transitioned to Nintendo hardware, and later found big success on the 3DS. It was a foregone conclusion that the series would be making its way to the Switch in time, and now Capcom has confirmed the first Monster Hunter game it will be bringing to the platform.
Monster Hunter X—known as Monster Hunter Generations in the West—received an expanded version called Monster Hunter XX in Japan earlier this year, featuring loads of new content that wasn’t present in the original release. Capcom has now revealed that it will be bringing this remix to the Switch in Japan, with more details to follow at Monster Hunter Championship 2017 this weekend. Though no Western release is confirmed yet, the region free Switch should make this easy enough to pick up if you don’t mind Japanese text. And who knows, with E3 around the corner, perhaps a Western announcement is imminent.
What do you think? Will you be picking this up? How long do you think it’ll be until the Switch gets an original Monster Hunter game? Drop us a comment in the section below.
Redigerat av Drake001, 26 maj 2017 - 06:14.
Postad 26 maj 2017 - 14:37
Postad 26 maj 2017 - 14:49
Transform
37 990 inlägg
Mm, jag hade hoppats på Monster Hunter 5 i så fall, detta är ju en port mer. Men kanske är läge att testa. Capcom är försiktiga med satsningen på Switch och Ultra Street Fighter, som de sa skulle vara avgörande för deras fortsatta satsning, har inte fått bra betyg och förmodligen inte sålt bra.
Men att det skulle komma ett MH var ju givet, det är perfekt för Switch.
Ryktet säger iofs att MH5 är för PS4 och inte kommer till Switch. Oh well.
Redigerat av Zoiler, 26 maj 2017 - 14:51.
Postad 27 maj 2017 - 04:57
Drake001
Drake001
3 093 inlägg
http://nintendoevery...undle-revealed/
– 1080p
– Control scheme is refined to fit well with Switch in both TV and portable mode
– Local and online 4-player multiplayer
– You also can play it together with 3DS if you use internet
– You can bring back Switch save data to 3DS too
– You can bring almost all save data from X to Switch’s XX
– And you can share save data of XX in between 3DS and Switch
– Switch hardware bundle
– Not only the dock, but the console itself has a unique design (to be shown later)
– Refined UI
https://youtu.be/CvzTD_RYDXs
Postad 27 maj 2017 - 08:11
Drake001
Drake001
3 093 inlägg
Docked 1080p, undocked 720p
https://twitter.com/...313327599931392
【MHXX】家では大画面で、外でも鮮明なグラフィックで。シーンにあわせた狩猟体験!TVモードは「1080p」対応、携帯モードは「720p」対応だ!狩りのプレイスタイルはさらに広がる!
Switch VS 3DS
https://twitter.com/aevanko
Redigerat av Drake001, 27 maj 2017 - 08:14.
Postad 27 maj 2017 - 09:11
Drake001
Drake001
3 093 inlägg
https://www.youtube.com/watch?v=d_OHuE8w1C8
Postad 27 maj 2017 - 14:23
Transform
37 990 inlägg
– You also can play it together with 3DS if you use internet – You can bring back Switch save data to 3DS too – You can bring almost all save data from X to Switch’s XX – And you can share save data of XX in between 3DS and Switch
Hmm... undrar om de kommer göra liknande med Pokemon Stars, interkompatibilitet samt den här typen av visuell uppgradering.
Postad 30 maj 2017 - 16:53
Drake001
Drake001
3 093 inlägg
http://gematsu.com/2...ver-screenshots
Monster Hunter XX Nintendo Switch Ver. screenshots
The Amazon Japan product page for Monster Hunter XX Nintendo Switch Ver. has provided a new set of screenshots from the upcoming high-definition port.
As previously announced, the Switch version runs in 1080p in TV mode and 720p in handheld mode, and features four-player local and Internet multiplayer, including local cross-play with 3DS users
Monster Hunter XX Nintendo Switch Ver. is due out for Switch in Japan on August 25.
View the screenshots at the gallery.
Postad 05 juni 2017 - 15:16
Drake001
Drake001
3 093 inlägg
http://nintendoevery...switch-footage/
During a live stream hosted today, Capcom showed off actual footage from Monster Hunter XX on Switch. We’ve posted the gameplay below.
https://youtu.be/GAP1g_b-5nw
https://youtu.be/dsQO63f1Dqg
https://youtu.be/FzMfVWFqjws
Postad 05 juni 2017 - 16:01
Transform
37 990 inlägg
Det här var spelet som fick Nintendos aktie att gå upp till högsta sedan december 2008. Folk är nog förväntansfulla att få spela det i bärbart.
Aldrig själv fastnat för serien dock, knappt testat.
Postad 26 juni 2017 - 10:43
Drake001
Drake001
3 093 inlägg
https://youtu.be/m88USg7Vn1s http://gematsu.com/2...bration-changesMonster Hunter XX Nintendo Switch Ver. details Target Camera, Hunter Arts, and vibration changes
by Sal Romano at 03:33 AM EDT, June 26, 2017.
4Gamer.net has gone up with a new preview of Monster Hunter XX Nintendo Switch Ver. While it doesn’t provide much new information, it does provide new screenshots and the following tidbits:
Target Camera – There is an icon in the upper right of the screen for the Target Camera. By pressing the ZL button, you can turn the Target Camera on or off. If you press the L button once while the Target Camera is on, the camera will turn to face towards the monster. You can also control the camera using the right analog stick.
Hunter Arts – There are gauges next to the item selection window at the bottom right of the screen that give you a better understanding of which Hunter Arts you are able to trigger. In the demo, three Hunter Arts were prepared and could be changed in the options. Hunter Art #1 was assigned to the Up button, Hunter Art #2 to the Right button, and Hunter Art #3 to the Down button. Because of this, it was necessary to release your fingers from the left analog stick in order to activate a Hunter Art while moving. While 4Gamer.net did not get to try it, there are other control types with key assignments that use multiple button combinations, which may be a better option for users who want to activate Hunter Arts while moving.
Vibration – The Switch version supports controller vibration, but not HD Rumble. Vibration can be turned on or off in the options. The controller will vibrate at times such as when a monster roars, when a Hunter Art hits, and when Barufaruku lands his big move, giving various situations a higher sense of presence.
Postad 01 augusti 2017 - 13:36
Drake001
Drake001
3 093 inlägg
http://nintendoevery...ut-august-10th/Japanese Monster Hunter XX demo out August 10th
Posted on August 1, 2017 by Nick in News, Switch
Postad 09 augusti 2017 - 21:37
Drake001
Drake001
3 093 inlägg
Postad 10 augusti 2017 - 12:05
6 423 inlägg
Körde igenom demo versionen.
Brutalt frustrerande kontroller, innan man får lite grepp om dom.
Karaktären man fick köra med (fick tyvärr inte den jag valde i menyn), var "smidig" som en pansarvagn
Känns som evigheter innan man lyckas svinga det gigantiska svärdet, och är man inne i en sådan animation, så kan man inte bara trycka på försvar, utan får istället rulla undan.
Kändes lite som i Dark Souls, när man packat på sig för tung utrustning
Var nära på att stänga av spelet, men fick till slut lite styr på det hela, och lyckades döda monstret.
Svårt att veta om det kan bli ett kul spel, eller bara frustrerande och enformigt i längden.
Men om det släpps här, och jag finner det till ett bra pris, så kan jag nog ändå tänka mig att ge det en värdig chans.
Spelade bärbart, men rullade på jämt och fint i 30fps, och såg skarpt och fint ut på skärmen.
Ska testa dockat sen.
Edit: kör dockat nu, och lyckades välja en snabb karaktär. Valde fel av misstag förut. Så nu är det mer respons i attackerna. Så det jag nämnde ovanför stämmer inte in på alla karaktärer, som tur är
Edit 2: tyvärr är kontrollerna fortfarande lite frustrerande i stridens hetta.
Problemet är även att allt är på japanska, och vette fan hur man använder potions m.m.
Försökte välja det i inventory, men lyckas bara kasta bort föremålen istället
Rullar på fint i dockat läge.
Redigerat av Svante Skoog, 10 augusti 2017 - 12:51.
Postad 10 augusti 2017 - 19:52
6 423 inlägg
https://youtu.be/GNJ2Og6zL4g
Postad 10 augusti 2017 - 20:03
Drake001
Drake001
3 093 inlägg
Postad 11 augusti 2017 - 14:10
Unregisterede32cf070
5 006 inlägg
Spelade ett Monster Hunter demo till WiiU, men blev aldrig kompis med spelkontrollen. Ironiskt är det ofta spel till Nintendo som jag har problem med spelkontrollen. Zelda, Mario, Metroid har också sepekontroller. 3D alltså, 2D brukar kännas bra.
Postad 11 augusti 2017 - 15:43
Transform
37 990 inlägg
Märkligt, de är ju typ perfekta (Mario, Zelda, Metroid) om man bortser från att knapparna sitter konstigt jämfört med på Xbox/PS.
Dvs, kontrollen är något som de spelen brukar hyllas för om något.
Redigerat av Zoiler, 11 augusti 2017 - 15:43.
Postad 11 augusti 2017 - 16:05
5 006 inlägg
Jag vet. Jag kan inte ens sätta fingret på vad det är som stör mig. Har spelat Wind Waker HD av och till i tre år (Wind Temple nu) och det känns avigt hela tiden. Mario World till Wii U samma sak. Metroid Prime var dock värst, hatade verkligen kontrollen där. Pikmin 3... huuu. Wonderful 101... usch
Mitt muskelminne kanske är knutet till XBOX, PSX. Nintendo funkade bra för mig fram t.o.m. SNES efter det har jag aldrig varit kompis med det.
Edit: Mario Kart 8 känns däremot bra.
Redigerat av Unregisterede32cf070, 11 augusti 2017 - 16:06.
Postad 13 augusti 2017 - 19:43
Transform
37 990 inlägg
Pikmin 3 som har såna underbara rörelsekontroller, tyckte nästan det var likvärdigt med en mus.
Postad 18 augusti 2017 - 16:12
Drake001
Drake001
3 093 inlägg
https://www.youtube.com/watch?v=FUy9lrTS28c
Även taggad med Capcom, Monster, Hunter, Switch
Media & Mediauppspelning →
Spelkonsoler & PC-spel →
Nintendo →
Startad av
Drake001
, 17 sep 2020
Ori, Microsoft, Switch
Nintendo →
Startad av
Drake001
, 17 sep 2020
Capcom, Switch
Nintendo →
Startad av
Drake001
, 17 sep 2020
Capcom, Switch
Nintendo →
Startad av
Drake001
, 13 feb 2019
Nintendo, Platinum, Switch
Hemma →
Tillbehör →
Kablar →
Bildkablar för digital överföring →
Startad av
HDWC
, 08 okt 2018
hdmi, splitter, switch, arc
Nintendo
Nya hyllor. 2670 DVD+Blu-Ray
UPDATE 2024
UPDATE 2024
UPDATE 2024
