4 GByte MemoryStick Micro (M2)
28 svar till detta ämne
SanDisk Memory Stick Micro 4GB (Minneskort) 2 9.166666 (5) Inga priser
1 relaterade trådar
Postad 28 March 2007 - 11:39
what17ever
  • what17ever
  • 2416 inlägg
SanDisk Introduces 4GB Memory Card for Use in SonyEricsson Handsets
SanDisk has expanded its Memory Stick Micro (M2) line by introducing a 4GB card. With the capacity to hold up to 1,000 songs, 2,000 high-resolution photos or 20 hours of MPEG4 video2, the 4GB card is compatible with Sony Ericsson's latest generation of handsets such as the Cyber-shot and Walkman series.
"This is the threshold at which mobile phones provide enough capacity to become the user's all-in-one portable music player, camcorder, photo album and video player." said Norm Frentz, director of marketing for SanDisk's mobile consumer solutions division.
The SanDisk M2 card line is designed for use with mobile handsets that have an M2 slot. By using an optional Memory Stick PRO Duo adapter, M2 cards are fully backwards compatible with all digital cameras and hand-held game players that have a Memory Stick slot.
The 4GB M2 card will ship to OEMs in May, and will be available in retail stores later in the year.
Pricing is not yet determined
Postad 27 April 2007 - 04:27
memeddr
  • memeddr
Hej, någon som vet mer exakt än "later this year" när det släpps?
tack
Postad 06 May 2007 - 11:47
memeddr
  • memeddr
ingen? :)
Postad 07 May 2007 - 17:21
erran
  • erran
Hoppas det blir snart iallafall, är jättesugen på att utöka minnet på min W880i, räcker inte med 1 GB! Har förresten mailat Sony Ericsson om detta. Har nu också mailat SanDisk!
Redigerat av erran, 08 May 2007 - 19:11.
Postad 12 May 2007 - 04:33
memeddr
  • memeddr
Jepp, hade inte varit fel med ett 4GB minneskort. Har du fått något svar ännu? :)
Postad 12 May 2007 - 10:30
erran
  • erran
Båda tillverkarna sa att de inte hade någon information, tyvärr. :)
Postad 12 May 2007 - 17:33
memeddr
  • memeddr
Ok, men tack för att du tog dig tid och berättade iallafall :)
Postad 10 June 2007 - 18:04
Snailsmaskens
  • Snailsmaskens
  • 48 inlägg
Är det någon som provat 4gb minneskort till w880i ännu? Isf fungerar det?
Postad 10 June 2007 - 18:05
Snailsmaskens
  • Snailsmaskens
  • 48 inlägg
Vart har du hittat denna information?
Postad 10 June 2007 - 18:16
Unregistereda021f600
  • Unregistereda021f600
  • 587 inlägg
Verkar på G hos TBH:
http://www.tbh.se/in...k_Micro_M2_4GB_
Postad 10 June 2007 - 18:24
Snailsmaskens
  • Snailsmaskens
  • 48 inlägg
Ja på G verkar det vara men vore bra om man visste om det fungerade med w880i? :)
Postad 11 June 2007 - 09:09
Rille_lkp
  • Rille_lkp
  • 394 inlägg
Programvaran i telefonen ska kunna hantera upp till 32gb. Kan dock bli lite segt att navigera i mediaspelaren när du lägger in mycket musik.
Postad 29 June 2007 - 00:41
bobby555
  • bobby555
  • 130 inlägg
Jag har fått svar från Dustinhome att de kan leverera 4gb-kortet 070706. Men jag råkade se att det kanske inte funkar med min k800i, så jag måste nog avbeställa det..
AM
Postad 01 July 2007 - 11:33
triplea
  • triplea
Varför skulle det inte fungera med k800i?
Postad 10 July 2007 - 22:18
soda666
  • soda666
  • 98 inlägg
Hallo!
Jag har köpt ett M2 4GB minneskort och kan säga att det fungerar smärtfritt att använda till SonyEricssons K800i.
Bifogad fil  DSC00025.JPG   59.41K   0 Antal nerladdningar
Bifogad fil  DSC00024.JPG   65.86K   18 Antal nerladdningar
Bifogad fil  DSC00023.JPG   55.69K   14 Antal nerladdningar
Bifogad fil  DSC00022.JPG   57.23K   15 Antal nerladdningar
Bifogad fil  DSC00021.JPG   53.19K   81 Antal nerladdningar
Redigerat av soda666, 11 July 2007 - 07:10.
Postad 11 July 2007 - 17:41
Kabukiman
  • Kabukiman
  • 67 inlägg
Och det fungerar även utmärkt till en W880i...
Postad 11 July 2007 - 20:41
Fairfax
  • Fairfax
  • 82 inlägg
Var har ni inhandlat minneskortet och vad kostade det? Letar själv med ljus och lykta efter ett 4 gb kort!
Postad 11 July 2007 - 21:05
Majorglenn
  • Majorglenn
  • 3071 inlägg
Det räcker med att du tittar i början av tråden så finns en länk till lägsta pris å alla affärer som säljer det
Postad 11 July 2007 - 22:56
soda666
  • soda666
  • 98 inlägg
Inwarehouse
Postad 12 July 2007 - 06:15
Fairfax
  • Fairfax
  • 82 inlägg
Mmmm, jag blev så till mig att jag helt glömde det mest basala med den här sidan. :P Ledsen. Ett kort beställt. Suveränt. Härliga priser också.
Postad 12 August 2007 - 21:54
Unregistered26dd04a9
  • Unregistered26dd04a9
  • 236 inlägg
på sandisk hemsida kan man kolla specifikt vilket kort passar med vilken mobil. rätt bra känns bättre att beställa 4 gb micro minneskortet till w880i nu när man kan se. stog ingen annan stans på nätet direkt vad jag kunde se men här är länken
(http://www.sandisk.com)
http://www.sandisk.c...sson-W880i.aspx
Postad 09 October 2007 - 19:52
perperub
  • perperub
  • 186 inlägg
Här kan ni kolla om er mobil passar med sandisk-minnen.
http://www.sandisk.c...facturerID=1331
Mvh/Pär
Postad 16 December 2007 - 11:53
JohanOeberg
  • JohanOeberg
  • 97 inlägg
Ok, Jättebra att man kan använda 4 gb kort. Det stod 20 hrs video MPEG-4.... Säg att man lägger ner en vanlig film (2h) så är ju mobilens filmuppspelning kass då man endast kan starta och stoppa, inte pausa eller spola fram/bak....
Så är det nogån som vet ett bättre sätt att spela upp video (på en W880i)?
Kanske finns ett video-program som man kan ladda till mobilen?
Redigerat av JohanOeberg, 16 December 2007 - 12:09.
Postad 16 December 2007 - 17:30
Rille_lkp
  • Rille_lkp
  • 394 inlägg
Underhållning -> Videospelare så kan du spola i video <_<
Postad 16 December 2007 - 18:25
JohanOeberg
  • JohanOeberg
  • 97 inlägg
Hehe.. Då fick man "svansen mellan benen" känslan igen...=S
Det gick ju fint. Och pausa gick och allt.
WOOOW. Man kunde göra mycket där.
Tackar tackar!
Postad 21 January 2008 - 23:12
dealerovski
  • dealerovski
  • 883 inlägg
funderar på 8 gb varianten till min m600
Postad 22 January 2008 - 16:42
Unregistered862a88dc
  • Unregistered862a88dc
  • 185 inlägg
4GB för ynka 370 kr ...
Ebay.uk
Postad 22 January 2008 - 16:44
Unregistered0354d681
  • Unregistered0354d681
  • 2184 inlägg
Ebay.uk
Längsta pris i sverige är ju 335kr? Det för Sandisk och Sony finns för 300kr så varför köpa från ebay?
Redigerat av Unregistered0354d681, 22 January 2008 - 17:03.
Postad 22 January 2008 - 17:44
  • 185 inlägg
Ebay.uk
Shitt!! Dom hade hunnit sjunka en hundring på ett par veckor sen jag senast kollade :D
Underbart när det finns en marknad med konkurrens!
