CEC, en del av HDMI
2 svar till detta ämne
Postad 29 March 2007 - 10:31
Addex
  • Addex
  • 1902 inlägg
Från: en.wikipedia.org
The Consumer Electronics Control (CEC) channel is optional to implement, but wiring is mandatory. The channel:
* Uses the industry standard AV Link protocol
* Used for remote control functions.
* One-wire bidirectional serial bus.
* Defined in HDMI Specification 1.0, updated in HDMI 1.2a, and again in 1.3a (Added timer and audio commands).
This feature is used in two ways:
* To allow the user to command and control multiple CEC-enabled boxes with one remote control, and
* To allow individual CEC-enabled boxes to command and control each other, without user intervention.
An example of the latter is to allow the DVD player, when the drawer closes with a disk, to command the TV and the intervening A/V Receiver (all with CEC) to power-up, select the appropriate HDMI ports, and auto-negotiate the proper video mode and audio mode. No remote control command is needed. Similarly, this type of equipment can be programmed to return to sleep mode when the movie ends, perhaps by checking the real-time clock. If it is later than 11:00pm, and the user does not specifically command the systems with the remote control, then the systems all turn off at the command from the DVD player.
Någon som vet ifall det kommer funka mellan olika fabrikat?
Tex sonys version heter "BRAVIA Theatre" och Panasonics heter "Viera link".
Redigerat av Addex, 29 March 2007 - 17:54.
Postad 16 April 2007 - 07:45
MarJon1
  • MarJon1
  • 25 inlägg
Är oxå lite intresserad av om det funkar mellan olika tillverkare och om det fungerar på ett bra och tllfredställande sätt.
Någon som vet mer om det???
Postad 16 April 2007 - 09:39
Addex
  • Addex
  • 1902 inlägg
Det är en standard med hdmi så det borde funka mellan olika tillverkare.
  • Triggerkabel
    2026-11-11 09:11:34
  • Denon DRS-810
    2026-11-10 15:11:51
  • Olika apparater
    2026-11-10 14:43:41
  • Music Filelity M6x 250.4/2
    2026-11-10 14:25:11
    2026-11-10 10:46:59
